[Geoserver-devel] Build failed in Jenkins: geoserver-master #5506
See <https://build.geoserver.org/job/geoserver-master/5506/display/redirect&gt;
[...truncated 11.91 MB...]
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geoserver/gs-wfs/2.13-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geoserver/gs-wfs/2.13-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/gs-wfs/2.13-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geoserver/gs-wfs/2.13-SNAPSHOT/maven-metadata.xml (2 KB at 151.8 KB/sec)
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-kml ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-kml ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-kml ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-kml ---
[INFO] Copying 28 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-kml ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-kml ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-kml ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-kml ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-kml ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-kml ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-kml ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/kml/target/gs-kml-2.13-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/kml/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/kml/target/gs-kml-2.13-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/kml/target/gs-kml-2.13-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/kml/target/gs-kml-2.13-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-kml ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/maven-metadata.xml (2 KB at 227.7 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-20180128.123429-541.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-20180128.123429-541.jar (182 KB at 6061.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-20180128.123429-541.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-20180128.123429-541.pom (3 KB at 142.3 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/maven-metadata.xml
[WARNING] Checksum validation failed, expected 1cb0593f88494e8b809bf30ac99f28882c96c648 but is 6a2779e3b2c2cd27b62f3c2001c5a285ecebee8d for https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/maven-metadata.xml (591 B at 44.4 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/maven-metadata.xml (2 KB at 173.3 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/maven-metadata.xml (544 B at 53.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-20180128.123429-541-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-20180128.123429-541-tests.jar (107 KB at 2481.5 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/maven-metadata.xml (2 KB at 154.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-20180128.123429-541-sources.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-20180128.123429-541-sources.jar (108 KB at 4688.5 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/maven-metadata.xml (2 KB at 198.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/gs-kml/2.13-SNAPSHOT/gs-kml-2.13-20180128.123429-541-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.076 s]
[INFO] Core Platform Module ............................... SUCCESS [ 0.720 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 2.265 s]
[INFO] Main Module ........................................ SUCCESS [ 8.730 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.726 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 0.300 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 0.478 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 0.259 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.226 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 0.697 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 0.509 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 0.458 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 0.564 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 1.873 s]
[INFO] KML support for GeoServer .......................... FAILURE [15:39 min]
[INFO] gs-rest ............................................ SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] gs-restconfig-wcs .................................. SKIPPED
[INFO] gs-restconfig-wfs .................................. SKIPPED
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] SpatiaLite Extension ............................... SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] Aggregating Data Store ............................. SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer Scripting Extensions ..................... SKIPPED
[INFO] Core Scripting Extension ........................... SKIPPED
[INFO] Web UI Scripting Extension ......................... SKIPPED
[INFO] BeanShell Scripting Extension ...................... SKIPPED
[INFO] Groovy Scripting Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] Python Scripting Extension ......................... SKIPPED
[INFO] JavaScript Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension ........................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] gs-notification-common ............................. SKIPPED
[INFO] GeoServer notification event system extension for GeoNode SKIPPED
[INFO] OWS Dispatcher Simulate Plugin ..................... SKIPPED
[INFO] JDBC Metrics Plugin ................................ SKIPPED
[INFO] OpenSearch EO parent ............................... SKIPPED
[INFO] OpenSearch for EO .................................. SKIPPED
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] OpenSearch for EO REST configuration API ........... SKIPPED
[INFO] GeoServer Mapbox Styling ........................... SKIPPED
[INFO] GeoServer Status Monitoring Module ................. SKIPPED
[INFO] NSG WMTS 1.0 Profile ............................... SKIPPED
[INFO] NSG WFS 2.0 Profile ................................ SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] S3 Geotiff Support ................................. SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 16:06 min
[INFO] Finished at: 2018-01-28T12:50:08+00:00
[INFO] Final Memory: 166M/897M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project gs-kml: Failed to deploy artifacts: Could not transfer artifact org.geoserver:gs-kml:jar:test-sources:2.13-20180128.123429-541 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Connection timed out (Read failed) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-kml
See <https://build.geoserver.org/job/geoserver-master/5507/display/redirect?page=changes&gt;
