[Geoserver-devel] Build failed in Jenkins: geoserver-master #5932
See <https://build.geoserver.org/job/geoserver-master/5932/display/redirect&gt;
[...truncated 11.14 MB...]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[debug] Using AOSP style
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.14-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Jun 18, 2018 3:19:29 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.529 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Jun 18, 2018 3:19:30 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
Jun 18, 2018 3:19:30 PM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.245 sec
Results :
Tests run: 73, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[INFO] Processed 30 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.772 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.418 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.490 s]
[INFO] Main Module ........................................ SUCCESS [01:02 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.067 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:11 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.750 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.204 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.132 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.199 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.389 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 38.425 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:35 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:53 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 26.321 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.903 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [02:21 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:24 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 18.300 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.563 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 14.103 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.077 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.303 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 10.537 s]
[INFO] Demos Module ....................................... SUCCESS [ 16.604 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.550 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.104 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:34 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:00 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.786 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.539 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.062 s]
[INFO] Printing Module .................................... SUCCESS [ 14.857 s]
[INFO] Community Space .................................... SUCCESS [ 0.072 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:28 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.679 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.270 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.677 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.909 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.385 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.202 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.193 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.475 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.939 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.256 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.027 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.278 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.950 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.026 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:05 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.298 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.935 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.446 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.582 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.496 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.563 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.085 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 23.348 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.496 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.089 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.037 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.023 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.838 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.243 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.175 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 16.932 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.043 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.851 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.882 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 36.951 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.565 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.048 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.494 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.624 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.037 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.623 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.882 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.591 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.051 s]
[INFO] Importer Core Module ............................... SUCCESS [ 48.482 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 42.737 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 14.205 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.738 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.455 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 16.103 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 52.588 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 13.926 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.870 s]
[INFO] BUILD FAILURE
[INFO] Total time: 16:45 min (Wall Clock)
[INFO] Finished at: 2018-06-18T15:19:31+00:00
[INFO] Final Memory: 138M/1355M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <https://build.geoserver.org/job/geoserver-master/5933/display/redirect?page=changes&gt;
