[Geoserver-devel] Build failed in Jenkins: geoserver-master #5996
See <https://build.geoserver.org/job/geoserver-master/5996/display/redirect&gt;
[...truncated 11.26 MB...]
  at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
  at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:133)
  at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:97)
  at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:827)
  at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:738)
  at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:872)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
  at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
  at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:160)
  at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:127)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
  at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:207)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
Caused by: java.io.IOException: No such file or directory
  at java.io.UnixFileSystem.createFileExclusively(Native Method)
  at java.io.File.createNewFile(File.java:1012)
  at org.geoserver.importer.ImportContext.lockUploadFolder(ImportContext.java:324)
  at org.geoserver.importer.ImportContext.updateState(ImportContext.java:258)
  at org.geoserver.importer.ImportContext.updated(ImportContext.java:381)
  at org.geoserver.importer.Importer.changed(Importer.java:942)
  at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:230)
  ... 60 more
Jul 02, 2018 12:05:41 AM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Tests run: 16, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 15.61 sec <<< FAILURE!
testDirectWrongFile(org.geoserver.importer.rest.ImporterIntegrationTest) Time elapsed: 120 sec <<< FAILURE!
org.junit.ComparisonFailure: expected:<INIT[_ERROR]> but was:<INIT>
  at org.junit.Assert.assertEquals(Assert.java:115)
  at org.junit.Assert.assertEquals(Assert.java:144)
  at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongFile(ImporterIntegrationTest.java:151)
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Jul 02, 2018 12:05:41 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Jul 02, 2018 12:05:42 AM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.869 sec
Results :
Failed tests: testDirectWrongFile(org.geoserver.importer.rest.ImporterIntegrationTest): expected:<INIT[_ERROR]> but was:<INIT>
Tests run: 75, Failures: 1, Errors: 0, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.328 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.221 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.726 s]
[INFO] Main Module ........................................ SUCCESS [01:05 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.066 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:17 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.496 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.071 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.907 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 15.654 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.930 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 40.218 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:34 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:56 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 28.611 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.366 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:18 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:23 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 20.040 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 18.508 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.491 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.063 s]
[INFO] Core UI Module ..................................... SUCCESS [01:08 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.839 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 53.598 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.215 s]
[INFO] Demos Module ....................................... SUCCESS [ 17.359 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 11.719 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.086 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:37 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:09 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.227 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.434 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.056 s]
[INFO] Printing Module .................................... SUCCESS [ 12.195 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.444 s]
[INFO] Community Space .................................... SUCCESS [ 0.058 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:29 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.218 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.520 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.983 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.909 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.379 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.225 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.200 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.603 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.386 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.246 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.036 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.211 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.063 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.048 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:11 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.263 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.062 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.469 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.521 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.543 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 18.056 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 12.628 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 26.312 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.894 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.177 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.064 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.766 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.026 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.086 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.073 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.981 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.943 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 36.112 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.622 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.045 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.048 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.486 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 31.421 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.987 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.070 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.614 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.895 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.038 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 15.753 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.754 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.692 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.048 s]
[INFO] Importer Core Module ............................... SUCCESS [ 50.399 s]
[INFO] Importer REST Api Module-ng ........................ FAILURE [ 43.080 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.554 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.245 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.698 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.636 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 52.140 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 14.267 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 13.664 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.860 s]
[INFO] BUILD FAILURE
[INFO] Total time: 18:01 min (Wall Clock)
[INFO] Finished at: 2018-07-02T00:05:42+00:00
[INFO] Final Memory: 148M/1377M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-importer-rest: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-rest
Another failure of ImporterIntegrationTest.testDirectWrongFile. Build kicked.
On 02/07/18 12:05, monitor@anonymised.com wrote:
See<https://build.geoserver.org/job/geoserver-master/5996/display/redirect&gt;
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/&gt;
New Zealand
See <https://build.geoserver.org/job/geoserver-master/5997/display/redirect&gt;
