See <https://build.geoserver.org/job/geoserver-master/6002/display/redirect?page=changes>
Changes:
[github] [GEOS-8769] Add integration tests and documentation about the usage of
[...truncated 11.11 MB...]
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:207)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
Caused by: java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(File.java:1012)
at org.geoserver.importer.ImportContext.lockUploadFolder(ImportContext.java:324)
at org.geoserver.importer.ImportContext.updateState(ImportContext.java:258)
at org.geoserver.importer.ImportContext.updated(ImportContext.java:381)
at org.geoserver.importer.Importer.changed(Importer.java:942)
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:230)
... 60 more
Jul 02, 2018 10:34:08 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.743 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Jul 02, 2018 10:34:09 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
Jul 02, 2018 10:34:09 PM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.156 sec
Results :
Tests run: 75, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[INFO] Processed 30 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.963 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.132 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.383 s]
[INFO] Main Module ........................................ SUCCESS [01:07 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.058 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:12 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 34.383 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 21.117 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.161 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.375 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.588 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 38.196 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:37 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:55 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 28.585 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.133 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [02:16 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:24 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 19.650 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 18.034 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 13.406 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.061 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.154 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 10.366 s]
[INFO] Demos Module ....................................... SUCCESS [ 17.369 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.914 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.068 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:33 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 59.490 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.237 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.466 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.038 s]
[INFO] Printing Module .................................... SUCCESS [ 15.236 s]
[INFO] Community Space .................................... SUCCESS [ 0.052 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.021 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:34 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.837 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.527 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.768 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.939 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.390 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.208 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.220 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.079 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.482 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.308 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.037 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.463 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.915 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.035 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:07 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.649 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.005 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.530 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.373 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.460 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 18.232 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 12.807 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 25.942 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.572 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.450 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.047 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.039 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.036 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.255 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.092 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 19.596 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.077 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.355 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.776 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 37.778 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.756 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.044 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.584 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.467 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.038 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 17.192 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.878 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.006 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.055 s]
[INFO] Importer Core Module ............................... SUCCESS [ 51.260 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 43.156 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 14.598 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.606 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.586 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.957 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 53.397 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 13.600 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.795 s]
[INFO] BUILD FAILURE
[INFO] Total time: 16:57 min (Wall Clock)
[INFO] Finished at: 2018-07-02T22:34:10+00:00
[INFO] Final Memory: 141M/1417M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
Not sending mail to unregistered user noreply@anonymised.com
