[Geoserver-devel] Build failed in Jenkins: geoserver-master #6125
See <https://build.geoserver.org/job/geoserver-master/6125/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Adding some more logging about oauth2 logins
[...truncated 9.53 MB...]
T E S T S
[INFO] Processed 5 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 0 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.14-SNAPSHOT/gs-web-sec-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.14-SNAPSHOT/gs-web-sec-2.14-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
Running org.geoserver.security.cas.CasAuthenticationTest
Aug 14, 2018 10:01:25 AM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.598 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.206 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-sec-cas ---
[INFO] Processed 14 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.14-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.939 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.148 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.375 s]
[INFO] Main Module ........................................ SUCCESS [01:02 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.097 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:18 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 41.185 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.648 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.209 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.291 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.234 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 42.850 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:36 min]
[INFO] Web Map Service Module ............................. FAILURE [01:57 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 16.608 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:25 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 19.195 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 18.137 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.065 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 10.395 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.090 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:36 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:06 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 19.334 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.501 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.042 s]
[INFO] Printing Module .................................... SUCCESS [ 14.057 s]
[INFO] Community Space .................................... SUCCESS [ 0.080 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.029 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.878 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.993 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.932 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.925 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.375 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.214 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.205 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.098 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.250 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.040 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.083 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.949 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.037 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:10 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.771 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.058 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.422 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.865 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.505 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 18.115 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 16.926 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.746 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.228 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.105 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.034 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.818 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.035 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.600 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.785 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.049 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.841 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.744 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 31.669 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.711 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.032 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.764 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.406 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.042 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 17.439 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.794 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.339 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.871 s]
[INFO] BUILD FAILURE
[INFO] Total time: 11:35 min (Wall Clock)
[INFO] Finished at: 2018-08-14T10:01:27+00:00
[INFO] Final Memory: 133M/1504M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <https://build.geoserver.org/job/geoserver-master/6126/display/redirect&gt;
