[Geoserver-devel] Build failed in Jenkins: geoserver-master #6248
See <https://build.geoserver.org/job/geoserver-master/6248/display/redirect&gt;
[...truncated 9.55 MB...]
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Removing Member [127.0.0.1]:5009
Oct 02, 2018 4:41:53 PM com.hazelcast.cluster.ClusterService
Members [1] {
  Member [127.0.0.1]:5010 this
Oct 02, 2018 4:41:53 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Destroying node initializer.
Oct 02, 2018 4:41:53 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Hazelcast Shutdown is completed in 14 ms.
Oct 02, 2018 4:41:53 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Address[127.0.0.1]:5009 is SHUTDOWN
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTTING_DOWN
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Hazelcast Shutdown is completed in 9 ms.
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTDOWN
Oct 02, 2018 4:41:53 PM com.hazelcast.spi.impl.BasicOperationScheduler
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Starting with 8 generic operation threads and 8 partition operation threads.
Oct 02, 2018 4:41:53 PM com.hazelcast.system
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5011
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTING
Oct 02, 2018 4:41:53 PM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
  Member [127.0.0.1]:5011 this
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTED
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Starting with 8 generic operation threads and 8 partition operation threads.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5012
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTING
Members [2] {
  Member [127.0.0.1]:5012
Members [2] {
  Member [127.0.0.1]:5012 this
Oct 02, 2018 4:41:54 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTED
Oct 02, 2018 4:41:54 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Oct 02, 2018 4:41:54 PM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement...
Oct 02, 2018 4:41:59 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Oct 02, 2018 4:41:59 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Oct 02, 2018 4:42:00 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Oct 02, 2018 4:42:00 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 13 ms.
Oct 02, 2018 4:42:00 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 9 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.712 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-wps-cluster-hazelcast ---
[debug] Using AOSP style
[INFO] Processed 5 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.336 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.093 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.564 s]
[INFO] Main Module ........................................ SUCCESS [01:03 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.077 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:15 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 38.498 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.496 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.047 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.316 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.741 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.242 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:35 min]
[INFO] Web Map Service Module ............................. FAILURE [01:56 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 16.919 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:26 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.602 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.992 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.063 s]
[INFO] Core UI Module ..................................... SUCCESS [01:10 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 11.083 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.068 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:34 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:05 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 19.339 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.598 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.052 s]
[INFO] Printing Module .................................... SUCCESS [ 14.258 s]
[INFO] Community Space .................................... SUCCESS [ 0.078 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.032 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.012 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.746 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.042 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.909 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.382 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.199 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.198 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.149 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.252 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.031 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.278 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.998 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.048 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:12 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.894 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.202 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.456 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.883 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.519 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.571 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 27.440 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.654 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.122 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.051 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.532 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.039 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.684 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.278 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.057 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.961 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.510 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 31.285 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.978 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.050 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.639 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.490 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.042 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.469 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.702 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.697 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.881 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 11:44 min (Wall Clock)
[INFO] Finished at: 2018-10-02T16:42:00+00:00
[INFO] Final Memory: 138M/1586M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <https://build.geoserver.org/job/geoserver-master/6249/display/redirect?page=changes&gt;
