See <http://ares.opengeo.org/jenkins/job/geoserver-master/633/>
[...truncated 25217 lines...]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.052 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.732 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 33.729 sec
Running org.geoserver.security.web.jdbc.group.JDBCConfirmRemovalGroupPanelTest
Query:
feature type: MappedFeatureType
filter: [ shape intersects POLYGON ((-1.3650000000000033 52.475133749539246, -1.235000000000003 52.475133749539246, -1.235000000000003 52.52485219413131, -1.3650000000000033 52.52485219413131, -1.3650000000000033 52.475133749539246)) ]
[properties: ALL ]
Query:
[properties: ALL ]
Query:
filter: [ shape intersects POLYGON ((-1.365 52.475, -1.235 52.475, -1.235 52.525, -1.365 52.525, -1.365 52.475)) ]
[properties: ALL ]
Query:
[properties: ALL ]
Query:
filter: [[ shape intersects POLYGON ((-1.365 53.475, -1.235 53.475, -1.235 53.525, -1.365 53.525, -1.365 53.475)) ] AND [[ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = http://urn.opengis.net ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = a ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = b ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = c ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = d ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = e ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = f ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = g ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = h ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = i ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = j ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = k ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = l ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = m ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = n ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = o ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = p ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = q ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = r ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = S ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = t ]]]
[properties: ALL ]
Query:
[properties: ALL ]
Query:
[properties: ALL ]
Query:
[properties: ALL ]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.287 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.935 sec
Running org.geoserver.security.web.jdbc.group.JDBCEditGroupPageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.456 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.561 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.644 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 1.348 sec <<< FAILURE!
testGeometry(org.geoserver.test.XlinkGeometryTest) Time elapsed: 1325 sec <<< FAILURE!
java.lang.AssertionError: expected:<0> but was:<1>
at org.junit.Assert.fail(Assert.java:88)
at org.junit.Assert.failNotEquals(Assert.java:743)
at org.junit.Assert.assertEquals(Assert.java:118)
at org.junit.Assert.assertEquals(Assert.java:555)
at org.junit.Assert.assertEquals(Assert.java:542)
at org.geoserver.test.AbstractAppSchemaTestSupport.assertXpathCount(AbstractAppSchemaTestSupport.java:358)
at org.geoserver.test.XlinkGeometryTest.testGeometry(XlinkGeometryTest.java:132)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.172 sec
Results :
Failed tests: testGeometry(org.geoserver.test.XlinkGeometryTest): expected:<0> but was:<1>
Tests run: 151, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.742 sec
Running org.geoserver.security.web.jdbc.group.JDBCGroupListPageTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.493s]
[INFO] Core Platform Module .............................. SUCCESS [14.791s]
[INFO] Open Web Service Module ........................... SUCCESS [16.907s]
[INFO] Main Module ....................................... SUCCESS [3:18.902s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.761s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:20.871s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [51.818s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.701s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.377s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:16.596s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:04.672s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:42.981s]
[INFO] Web Map Service Module ............................ SUCCESS [6:30.679s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:32.999s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:34.599s]
[INFO] REST Support Module ............................... SUCCESS [45.502s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:16.140s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.532s]
[INFO] Core UI Module .................................... SUCCESS [2:34.090s]
[INFO] WMS UI Module ..................................... SUCCESS [1:08.993s]
[INFO] GWC UI Module ..................................... SUCCESS [1:42.248s]
[INFO] WFS UI Module ..................................... SUCCESS [41.756s]
[INFO] Demoes Module ..................................... SUCCESS [1:03.490s]
[INFO] WCS UI Module ..................................... SUCCESS [57.654s]
[INFO] Security UI Modules ............................... SUCCESS [0.306s]
[INFO] Security UI Core Module ........................... SUCCESS [3:38.452s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [43.913s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.227s]
[INFO] Printing Module ................................... SUCCESS [40.941s]
[INFO] Community Space ................................... SUCCESS [0.276s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.062s]
[INFO] Application Schema Support ........................ SUCCESS [0.192s]
[INFO] Application Schema Integration Test ............... FAILURE [4:32.650s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.688s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.804s]
[INFO] GeoSearch Index Module ............................ SUCCESS [49.355s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.621s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.231s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.595s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.505s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.612s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.515s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.121s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.492s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [34.952s]
[INFO] Excel Output Format ............................... SUCCESS [40.506s]
[INFO] Validation Module ................................. SUCCESS [6.233s]
[INFO] Chart external graphics support ................... SUCCESS [1.686s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.899s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.971s]
[INFO] OWS request flow controller ....................... SUCCESS [28.957s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.367s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:21.573s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:03.536s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.167s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.658s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.368s]
[INFO] Core Monitor Extension ............................ SUCCESS [27.059s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [58.411s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [55.529s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [49.084s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.312s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [19.714s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.047s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:53.957s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.362s]
[INFO] DXF WFS output format ............................. SUCCESS [41.821s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [38.560s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.189s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [46.028s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [31.689s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [34.948s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.202s]
[INFO] Importer Core Module .............................. SUCCESS [1:53.536s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 37:44.166s (Wall Clock)
[INFO] Finished at: Tue Jul 15 10:50:15 UTC 2014
[INFO] Final Memory: 74M/288M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
