See <https://build.geoserver.org/job/geoserver-master/6364/display/redirect?page=changes>
Changes:
[Andrea Aime] Make the module build on Windows (sort of, one tests related to postgis
[...truncated 1.10 MB...]
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
Nov 06, 2018 10:52:19 AM org.geoserver.importer.Importer init
SEVERE: Failed to init the context
java.lang.NullPointerException
at org.geoserver.importer.SpatialFile.prepare(SpatialFile.java:103)
at org.geoserver.importer.Importer.addTasks(Importer.java:472)
at org.geoserver.importer.Importer.init(Importer.java:440)
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:227)
at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:75)
at sun.reflect.GeneratedMethodAccessor293.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:207)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:800)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1038)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:901)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:166)
at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:133)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:206)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 22.34 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.76 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.291 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.119 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.500 s]
[INFO] Main Module ........................................ SUCCESS [01:00 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.104 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:10 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 36.594 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 6.928 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.023 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.082 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.034 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.391 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:30 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:58 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 28.086 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.870 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [02:04 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:17 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 17.278 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 16.490 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.238 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.057 s]
[INFO] Core UI Module ..................................... SUCCESS [01:06 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.537 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 11.144 s]
[INFO] Demos Module ....................................... SUCCESS [ 18.065 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.398 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.057 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:31 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:54 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.318 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.196 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.054 s]
[INFO] Printing Module .................................... SUCCESS [ 11.319 s]
[INFO] Community Space .................................... SUCCESS [ 0.064 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.036 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:52 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.950 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.866 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.218 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.736 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.539 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.199 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.209 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.660 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.670 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.299 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.029 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.639 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.111 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.051 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:04 min]
[INFO] OGR WPS ............................................ SUCCESS [ 18.555 s]
[INFO] Excel Output Format ................................ SUCCESS [ 12.581 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.481 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.017 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.462 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.082 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 21.740 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 43.960 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.418 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.905 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.043 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.047 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 13.428 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.052 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.802 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.926 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 19.089 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.110 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.200 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.313 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 56.567 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 15.609 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.061 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.531 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 17.104 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.051 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 26.161 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 24.013 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.929 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.067 s]
[INFO] Importer Core Module ............................... SUCCESS [01:21 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [01:09 min]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 23.676 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 26.199 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.296 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 18.112 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:17 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 26.086 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.252 s]
[INFO] REST SLD service ................................... SUCCESS [ 29.589 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:08 min (Wall Clock)
[INFO] Finished at: 2018-11-06T10:52:20+00:00
[INFO] Final Memory: 152M/1416M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
