[Geoserver-devel] Build failed in Jenkins: geoserver-master #6605
See <https://build.geoserver.org/job/geoserver-master/6605/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-9127] Insecure Storage of credentials
[...truncated 1.15 MB...]
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 20.394 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.753 sec
Running org.geoserver.importer.web.ImportTaskTableTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.782 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.16-SNAPSHOT/gs-importer-rest-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [89/99]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.917 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.843 s]
[INFO] Core Platform Module ............................... SUCCESS [ 17.732 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.054 s]
[INFO] Main Module ........................................ SUCCESS [01:27 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.164 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:37 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 42.706 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 4.711 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.294 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.043 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 22.783 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 52.246 s]
[INFO] Web Feature Service Module ......................... SUCCESS [02:08 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:57 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.296 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.637 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:28 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:54 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 22.414 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 25.156 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 16.645 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.238 s]
[INFO] Core UI Module ..................................... SUCCESS [01:42 min]
[INFO] WMS UI Module ...................................... SUCCESS [01:01 min]
[INFO] GWC UI Module ...................................... SUCCESS [01:35 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.695 s]
[INFO] Demos Module ....................................... SUCCESS [ 24.248 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 29.591 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.095 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:09 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:41 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.219 s]
[INFO] REST UI Module ..................................... SUCCESS [ 13.684 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.104 s]
[INFO] Printing Module .................................... SUCCESS [ 14.417 s]
[INFO] Community Space .................................... SUCCESS [ 0.097 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.083 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:53 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 15.461 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.112 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 13.060 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.029 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.700 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.240 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.360 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.926 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.895 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.554 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.087 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.571 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.761 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.139 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 16.563 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.581 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.254 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.610 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 13.623 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.919 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.932 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.175 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 33.223 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.128 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 3.033 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.055 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.537 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.111 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 22.170 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.108 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.796 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.422 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 44.001 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.817 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.093 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.274 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.060 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 13.384 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.236 s]
[INFO] Importer Core Module ............................... SUCCESS [ 57.441 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 52.696 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 14.591 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.256 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 21.986 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 30.521 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 22.388 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 21.813 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.563 s]
[INFO] REST SLD service ................................... SUCCESS [ 32.499 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 27.009 s]
[INFO] GeoFence Server .................................... SUCCESS [ 44.789 s]
[INFO] BUILD FAILURE
[INFO] Total time: 22:13 min (Wall Clock)
[INFO] Finished at: 2019-03-16T13:22:43Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <https://build.geoserver.org/job/geoserver-master/6606/display/redirect&gt;
