[Geoserver-devel] Build failed in Jenkins: geoserver-master #726
See <http://ares.opengeo.org/jenkins/job/geoserver-master/726/&gt;
[...truncated 4898 lines...]
Running org.geoserver.security.decorators.ReadSecuredCatalogDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Running org.geoserver.security.decorators.SecuredFeatureCollectionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.geoserver.security.decorators.SecuredGetMapRequestTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Running org.geoserver.security.file.FileTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.202 sec
Running org.geoserver.security.filter.GeoServerBasicAuthenticationFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.043 sec
Running org.geoserver.security.impl.AdvertisedCatalogTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.impl.DataAccessRuleTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.029 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.823 sec
Running org.geoserver.security.impl.GeoServerRoleConverterImplTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.security.impl.MemoryRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.902 sec
Running org.geoserver.security.impl.MemoryUserDetailsServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.863 sec
Running org.geoserver.security.impl.MemoryUserGroupServiceTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.52 sec
Running org.geoserver.security.impl.RoleHierarchyHelperTest
Running org.geoserver.security.impl.SecureCatalogImplFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.security.impl.SecureCatalogImplTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.089 sec
Running org.geoserver.security.impl.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.805 sec
Running org.geoserver.security.impl.SecureTreeNodeTest
Running org.geoserver.security.password.GeoServerMultiplexingPasswordEncoderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.security.password.GeoserverPasswordEncoderTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.741 sec
Running org.geoserver.security.password.MasterPasswordChangeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.378 sec
Running org.geoserver.security.password.URLMasterPasswordProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.792 sec
Running org.geoserver.security.rememberme.RememberMeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.186 sec
Running org.geoserver.security.validation.FilterConfigValidatorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.029 sec
Running org.geoserver.security.validation.MasterPasswordChangeValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.validation.PasswordValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.038 sec
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.88 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.132 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.86 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.911 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.708 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.497 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.225 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.046 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.007 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.237 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.377 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.077 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.216 sec
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.493 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.12 sec
Results :
Tests in error:
  testMissingNullValuesInCoverageDimensions(org.geoserver.catalog.ResourcePoolTest): Error persisting CoverageInfoImpl[DEM] to workspaces/wcs/DEM/DEM/coverage.xml
  testCascadeWorkspace(org.geoserver.catalog.impl.CascadeRemovalReporterTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testCascadeLayer(org.geoserver.catalog.impl.CascadeRemovalReporterTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testCascadeStore(org.geoserver.catalog.impl.CascadeRemovalReporterTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testMosaicParameters(org.geoserver.catalog.impl.CatalogBuilderIntTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testLargeNDMosaic(org.geoserver.catalog.impl.CatalogBuilderIntTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testFeatureTypeNoSRS(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testEmptyLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testFeatureType(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testLatLonBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testGeometryless(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testSingleBandedCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testLookupSRSDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testSetupBoundsDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testMetadataFromFeatueSource(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testEmptyBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testWMSLayer130crs84(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testMultiBandCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testWMSLayer111(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  testWMSLayer130(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
Tests run: 608, Failures: 0, Errors: 21, Skipped: 1
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.622s]
[INFO] Core Platform Module .............................. SUCCESS [21.455s]
[INFO] Open Web Service Module ........................... SUCCESS [15.809s]
[INFO] Main Module ....................................... FAILURE [3:20.495s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [1.269s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.306s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.299s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.179s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.207s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.616s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.538s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.396s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.018s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.673s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [5.270s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.658s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.326s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.241s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.161s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 4:10.031s (Wall Clock)
[INFO] Finished at: Thu Aug 21 00:09:43 UTC 2014
[INFO] Final Memory: 39M/202M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.opengeo.org/jenkins/job/geoserver-master/727/changes&gt;
Changes:
[rini.angreani] Very basic test for paging works.
[rini.angreani] Test denormalised view for paging.
[rini.angreani] Make all online tests pass with paging changes.
[rini.angreani] More test cases
[rini.angreani] Paging documentation update for app-schema.
[...truncated 24565 lines...]
[WARNING] * question, not against maven-core *
[WARNING] *****************************************************************
[WARNING] The following plugins are not marked @threadSafe in Importer Core Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Query:
   feature type: MappedFeatureType
   filter: [ shape intersects POLYGON ((-1.365 52.475, -1.235 52.475, -1.235 52.525, -1.365 52.525, -1.365 52.475)) ]
   [properties: ALL ]
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-kml/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-kml/12-SNAPSHOT/maven-metadata.xml
966/966 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-kml/12-SNAPSHOT/maven-metadata.xml (966 B at 14.7 KB/sec)
Query:
   [properties: ALL ]
Query:
   filter: [[ shape intersects POLYGON ((-1.365 53.475, -1.235 53.475, -1.235 53.525, -1.365 53.525, -1.365 53.475)) ] AND [[ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = http://urn.opengis.net ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = a ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = b ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = c ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = d ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = e ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = f ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = g ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = h ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = i ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = j ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = k ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = l ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = m ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = n ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = o ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = p ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = q ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = r ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = S ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = t ]]]
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Downloading: http://maven.geo-solutions.it/org/geotools/gt-arcsde-common/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-arcsde-common/12-SNAPSHOT/maven-metadata.xml
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-importer-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/core/target&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.295 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-importer-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #676 from riniangreani/wfs20paginggeoserver
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 21.08.2014 @ 07:51:45 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 21-Aug-2014 07:54
[INFO] [GitCommitIdMojo] build.build.time = 21.08.2014 @ 08:38:51 UTC
[INFO] [GitCommitIdMojo] build.branch = 647b919e76be328ae10073506fbb98972399be48
[INFO] [GitCommitIdMojo] build.commit.user.email = rini.angreani@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = riniangreani
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 647b919
[INFO] [GitCommitIdMojo] build.commit.id = 647b919e76be328ae10073506fbb98972399be48
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #676 from riniangreani/wfs20paginggeoserver
Tests for app-schema paging
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-importer-core ---
[INFO] Copying 0 resource
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-importer-core ---
[INFO] Compiling 79 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/core/target/classes&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.544 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.435 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.66 sec
Running org.geoserver.test.XlinkGeometryTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-core ---
[INFO] Copying 20 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-importer-core ---
[INFO] Compiling 25 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/core/target/test-classes&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.959 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.007 sec
Results :
Failed tests: testSecureFeatureContent(org.geoserver.test.SecuredFeatureChainingTest): expected:<1> but was:<0>
Tests run: 151, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-importer-core ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/importer/core/target/surefire-reports&gt;
T E S T S
Running org.geoserver.importer.DataFormatTest
[INFO]
[INFO] GeoServer ......................................... SUCCESS [14.244s]
[INFO] Core Platform Module .............................. SUCCESS [16.100s]
[INFO] Open Web Service Module ........................... SUCCESS [24.827s]
[INFO] Main Module ....................................... SUCCESS [6:56.737s]
[INFO] GeoServer Security Modules ........................ SUCCESS [3.104s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:39.549s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:26.926s]
[INFO] Web Coverage Service Module ....................... SUCCESS [12.749s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:12.939s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:15.616s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:15.335s]
[INFO] Web Feature Service Module ........................ SUCCESS [5:33.884s]
[INFO] Web Map Service Module ............................ SUCCESS [5:54.950s]
[INFO] KML support for GeoServer ......................... SUCCESS [2:23.054s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [3:27.174s]
[INFO] REST Support Module ............................... SUCCESS [1:06.941s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:00.499s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.927s]
[INFO] Core UI Module .................................... SUCCESS [3:44.675s]
[INFO] WMS UI Module ..................................... SUCCESS [1:30.036s]
[INFO] GWC UI Module ..................................... SUCCESS [1:37.089s]
[INFO] WFS UI Module ..................................... SUCCESS [41.557s]
[INFO] Demoes Module ..................................... SUCCESS [1:21.069s]
[INFO] WCS UI Module ..................................... SUCCESS [1:07.526s]
[INFO] Security UI Modules ............................... SUCCESS [0.428s]
[INFO] Security UI Core Module ........................... SUCCESS [3:57.879s]
[INFO] REST UI Module .................................... SUCCESS [46.391s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.399s]
[INFO] Printing Module ................................... SUCCESS [2:03.842s]
[INFO] Community Space ................................... SUCCESS [0.196s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [16.218s]
[INFO] Application Schema Support ........................ SUCCESS [0.193s]
[INFO] Application Schema Integration Test ............... FAILURE [4:16.275s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.899s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [56.480s]
[INFO] GeoSearch Index Module ............................ SUCCESS [52.974s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.512s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.236s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.638s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.486s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.526s]
[INFO] ImageMap Output Format ............................ SUCCESS [23.031s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.396s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [2.084s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.699s]
[INFO] Excel Output Format ............................... SUCCESS [2:10.545s]
[INFO] Chart external graphics support ................... SUCCESS [2.006s]
[INFO] Feature Generalization Extension .................. SUCCESS [22.904s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.051s]
[INFO] OWS request flow controller ....................... SUCCESS [20.983s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.312s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:18.407s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:32.668s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.194s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [7.812s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [8.244s]
[INFO] Core Monitor Extension ............................ SUCCESS [1:06.513s]
[INFO] XLST based WFS output format ...................... SUCCESS [58.513s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [59.775s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [1:16.760s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [8.130s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [28.425s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [24.647s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.332s]
[INFO] DXF WFS output format ............................. SUCCESS [43.823s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [54.805s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.268s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [58.444s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [33.406s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.339s]
[INFO] Total time: 44:52.046s (Wall Clock)
[INFO] Finished at: Thu Aug 21 08:39:09 UTC 2014
[INFO] Final Memory: 72M/177M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
See <http://ares.opengeo.org/jenkins/job/geoserver-master/728/&gt;
[...truncated 25599 lines...]
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-sec-jdbc ---
[INFO] [GitCommitIdMojo] build.timestamp = 21-Aug-2014 09:48
[INFO] [GitCommitIdMojo] build.build.time = 21.08.2014 @ 10:25:40 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-sec-jdbc ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/src/main/resources&gt;
[INFO] Copying 7 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-sec-jdbc ---
[INFO] Compiling 8 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/target/classes&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.899 sec
Running org.geoserver.test.TimeSeriesWfsTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-sec-jdbc ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-sec-jdbc ---
[INFO] Compiling 13 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/target/test-classes&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.04 sec
Running org.geoserver.test.ValidationTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-sec-jdbc ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.web.jdbc.JDBCConnectionPanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.528 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.727 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Query:
   filter: [ shape intersects POLYGON ((-1.3650000000000033 52.475133749539246, -1.235000000000003 52.475133749539246, -1.235000000000003 52.52485219413131, -1.3650000000000033 52.52485219413131, -1.3650000000000033 52.475133749539246)) ]
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.465 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.452 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.039 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.275 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.289 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 31.031 sec
Running org.geoserver.security.web.jdbc.group.JDBCConfirmRemovalGroupPanelTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.083 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.462 sec
Running org.geoserver.security.web.jdbc.group.JDBCEditGroupPageTest
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.315s]
[INFO] Core Platform Module .............................. SUCCESS [15.568s]
[INFO] Open Web Service Module ........................... SUCCESS [16.670s]
[INFO] Main Module ....................................... SUCCESS [3:20.008s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.135s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:37.125s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:03.505s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.200s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:07.681s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:18.149s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:06.368s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:52.482s]
[INFO] Web Map Service Module ............................ SUCCESS [5:23.684s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:25.921s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:40.198s]
[INFO] REST Support Module ............................... SUCCESS [47.258s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:48.150s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.580s]
[INFO] Core UI Module .................................... SUCCESS [2:26.718s]
[INFO] WMS UI Module ..................................... SUCCESS [1:02.879s]
[INFO] GWC UI Module ..................................... SUCCESS [1:45.443s]
[INFO] WFS UI Module ..................................... SUCCESS [43.444s]
[INFO] Demoes Module ..................................... SUCCESS [58.109s]
[INFO] WCS UI Module ..................................... SUCCESS [52.936s]
[INFO] Security UI Modules ............................... SUCCESS [0.245s]
[INFO] Security UI Core Module ........................... SUCCESS [4:08.773s]
[INFO] REST UI Module .................................... SUCCESS [42.249s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.274s]
[INFO] Printing Module ................................... SUCCESS [39.984s]
[INFO] Community Space ................................... SUCCESS [0.248s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.047s]
[INFO] Application Schema Integration Test ............... FAILURE [4:33.570s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.729s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.438s]
[INFO] GeoSearch Index Module ............................ SUCCESS [43.522s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.820s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.498s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.629s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.532s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.735s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.925s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.918s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.709s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.506s]
[INFO] Excel Output Format ............................... SUCCESS [39.285s]
[INFO] Chart external graphics support ................... SUCCESS [1.811s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.759s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.841s]
[INFO] OWS request flow controller ....................... SUCCESS [33.453s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.407s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:32.263s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:04.791s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.154s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.599s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.242s]
[INFO] Core Monitor Extension ............................ SUCCESS [26.246s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [15.462s]
[INFO] XLST based WFS output format ...................... SUCCESS [58.499s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [56.041s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [56.945s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.239s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [21.974s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [31.394s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:52.555s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.177s]
[INFO] DXF WFS output format ............................. SUCCESS [38.072s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [42.049s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.193s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [49.252s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [34.931s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [32.548s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.440s]
[INFO] Importer Core Module .............................. SUCCESS [1:52.303s]
[INFO] Total time: 37:57.292s (Wall Clock)
[INFO] Finished at: Thu Aug 21 10:26:26 UTC 2014
[INFO] Final Memory: 75M/212M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/729/changes&gt;
