See <https://build.geoserver.org/job/geoserver-master/7522/display/redirect>
[...truncated 1.24 MB...]
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.707 s - in org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Running org.geoserver.importer.web.ImportTaskTableTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.153 s - in org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [100/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 142.515 s - in org.geoserver.geofence.internal.InternalUserResolverTest
[INFO] Running org.geoserver.geofence.rest.AdminRulesRestControllerTest
Skipping test in AdminRulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.155 s - in org.geoserver.geofence.rest.AdminRulesRestControllerTest
[INFO] Running org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.791 s - in org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Running org.geoserver.geofence.rest.RulesRestControllerTest
Skipping test in RulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.574 s - in org.geoserver.geofence.rest.RulesRestControllerTest
[INFO] Running org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.982 s - in org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.041 s - in org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.627 s - in org.geoserver.geofence.web.GeofenceServerPageTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 17, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-geofence-server ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.16-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.16-SNAPSHOT/gs-geofence-server-2.16-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.703 s]
[INFO] Core Platform Module ............................... SUCCESS [ 9.350 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.943 s]
[INFO] Main Module ........................................ SUCCESS [ 51.970 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.051 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:19 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 38.518 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 15.618 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.510 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.020 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 12.577 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 55.172 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 59.797 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:52 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 16.312 s]
[INFO] gs-rest ............................................ SUCCESS [ 6.709 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 55.793 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:28 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.596 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.114 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.206 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.058 s]
[INFO] Core UI Module ..................................... SUCCESS [ 44.277 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 23.398 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:14 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.837 s]
[INFO] Demos Module ....................................... SUCCESS [ 11.514 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 7.518 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.041 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:00 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:55 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.283 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.407 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.034 s]
[INFO] Printing Module .................................... SUCCESS [ 6.686 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 3.983 s]
[INFO] Community Space .................................... SUCCESS [ 0.067 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.938 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.256 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.521 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.744 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.591 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.203 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.230 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.627 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.558 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.217 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.020 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.266 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.863 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.019 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:58 min]
[INFO] OGR WPS ............................................ SUCCESS [ 4.923 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.425 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.388 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.514 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.393 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.623 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 12.433 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 15.798 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.100 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.442 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.053 s]
[INFO] Core Monitor Extension ............................. SUCCESS [01:29 min]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.081 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.283 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.438 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 20.518 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.354 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.026 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.883 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.546 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [01:53 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.945 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.427 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.007 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.020 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.106 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [01:07 min]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.454 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.042 s]
[INFO] Importer Core Module ............................... SUCCESS [ 27.347 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 27.686 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [01:42 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 7.529 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 10.628 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 37.419 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [01:27 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.075 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 8.168 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.610 s]
[INFO] REST SLD service ................................... SUCCESS [01:19 min]
[INFO] GeoFence security integration ...................... SUCCESS [ 39.064 s]
[INFO] GeoFence Server .................................... SUCCESS [02:43 min]
[INFO] Authentication by unique url key ................... SUCCESS [01:27 min]
[INFO] BUILD FAILURE
[INFO] Total time: 22:12 min (Wall Clock)
[INFO] Finished at: 2019-08-07T14:12:50Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-netcdf-out: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/netcdf-out/target/surefire-reports> for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf-out
