See <https://build.geoserver.org/job/geoserver-master/7665/display/redirect?page=changes>
Changes:
[Andrea Aime] [GEOS-9308] LayerInfo.getAbstract always returns nothing as the
[...truncated 1.23 MB...]
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.771 s - in org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Running org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-web ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-importer-web ---
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.878 s - in org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Running org.geoserver.importer.web.ImportTaskTableTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.912 s - in org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [100/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.173 s - in org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.073 s]
[INFO] Core Platform Module ............................... SUCCESS [ 9.214 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.277 s]
[INFO] Main Module ........................................ SUCCESS [ 52.247 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.062 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:20 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.384 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 16.236 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.424 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.165 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 12.806 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 58.818 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:03 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:47 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 15.795 s]
[INFO] gs-rest ............................................ SUCCESS [ 6.864 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 53.766 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:24 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.202 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.044 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 8.711 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.052 s]
[INFO] Core UI Module ..................................... SUCCESS [ 49.722 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 26.922 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 38.211 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.340 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.846 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.062 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.039 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:02 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [04:04 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.960 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.330 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.030 s]
[INFO] Printing Module .................................... SUCCESS [ 6.507 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 4.745 s]
[INFO] Community Space .................................... SUCCESS [ 0.061 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.022 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:32 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.009 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.210 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.591 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.738 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.566 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.204 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.205 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.396 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.529 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.223 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.267 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.504 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.025 s]
[INFO] Web Processing Service Module ...................... SUCCESS [09:31 min]
[INFO] OGR WPS ............................................ SUCCESS [ 6.583 s]
[INFO] Excel Output Format ................................ SUCCESS [ 7.723 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.406 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.403 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.411 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.514 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.693 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 22.112 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.367 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.403 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.027 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 59.527 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.424 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.037 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.396 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.270 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 21.418 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.485 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.028 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 3.503 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.338 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 23.047 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.079 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.131 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.232 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.253 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [01:57 min]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.428 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.038 s]
[INFO] Importer Core Module ............................... SUCCESS [ 29.794 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 35.186 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 11.919 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 10.173 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 10.325 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [01:36 min]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:05 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.826 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.960 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.604 s]
[INFO] REST SLD service ................................... SUCCESS [04:50 min]
[INFO] GeoFence security integration ...................... SUCCESS [04:42 min]
[INFO] GeoFence Server .................................... FAILURE [ 48.760 s]
[INFO] Authentication by unique url key ................... SUCCESS [04:04 min]
[INFO] BUILD FAILURE
[INFO] Total time: 29:28 min (Wall Clock)
[INFO] Finished at: 2019-08-22T06:51:45Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-geofence-server: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/surefire-reports> for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geofence-server
