[Geoserver-devel] Build failed in Jenkins: geoserver-master #779
See <http://ares.opengeo.org/jenkins/job/geoserver-master/779/changes&gt;
Changes:
[daniele.romagnoli] GEOS-6648: Report proper uom, nilValue, ranges on GML GetCoverage requests
[...truncated 19506 lines...]
14 Sep 18:06:21 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler 'dispatcher'
14 Sep 18:06:21 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
14 Sep 18:06:21 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
14 Sep 18:06:21 WARN [geoserver.security] - Strong cryptography is NOT available
Download and installation the of unlimted length policy files is recommended
14 Sep 18:06:21 INFO [geoserver.security] - Start reloading user/grous for service named default
14 Sep 18:06:21 INFO [geoserver.security] - Reloading user/groups successful for service named default
14 Sep 18:06:21 INFO [geoserver.security] - Start encrypting configuration passwords using pbePasswordEncoder
14 Sep 18:06:21 INFO [geoserver.security] - End encrypting configuration passwords
14 Sep 18:06:22 INFO [geoserver.wcs] -
Request: getServiceInfo
14 Sep 18:06:22 WARN [geotools.xml] - Error parsing: http://schemas.opengis.net/wcs/geotiff/1.0/wcsGeotiff.xsd
Request: getCoverage
    extension:
        contents[0]:
            name = Scaling
            namespace = http://www.opengis.net/WCS_service-extension_scaling/1.0
            objectContent = net.opengis.wcs20.impl.ScalingTypeImpl@anonymised.com
    service = WCS
    version = 2.0.1
    baseUrl = http://localhost:8080/geoserver/
    coverageId = wcs__BlueMarble
    format = image/tiff
    extension:
        contents[0]:
            name = Scaling
    service = WCS
    version = 2.0.1
    format = image/tiff
14 Sep 18:06:23 INFO [geoserver.wcs] -
14 Sep 18:06:23 WARN [geotools.xml] - Error parsing: http://schemas.opengis.net/wcs/geotiff/1.0/wcsGeotiff.xsd
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.219 sec
Running org.geoserver.wps.GetCapabilitiesTest
    extension:
        contents[0]:
            name = Scaling
    service = WCS
    version = 2.0.1
    format = image/tiff
14 Sep 18:06:24 INFO [geoserver.wcs] -
14 Sep 18:06:24 WARN [geotools.xml] - Error parsing: http://schemas.opengis.net/wcs/geotiff/1.0/wcsGeotiff.xsd
    extension:
        contents[0]:
            name = Scaling
    service = WCS
    version = 2.0.1
    format = image/tiff
14 Sep 18:06:24 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Sun Sep 14 18:06:21 UTC 2014]; root of context hierarchy
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.912 sec
Results :
Failed tests: jpegMediaType(org.geoserver.wcs2_0.kvp.GeoTiffKvpTest): expected:<[multipart/related]> but was:<[application/xml]>
Tests run: 160, Failures: 1, Errors: 0, Skipped: 2
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO] Skipping KML support for GeoServer
[INFO]
[INFO] Skipping GeoWebCache (GWC) Module
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.623s]
[INFO] Core Platform Module .............................. SUCCESS [14.441s]
[INFO] Open Web Service Module ........................... SUCCESS [22.223s]
[INFO] Main Module ....................................... SUCCESS [3:20.265s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.653s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:16.458s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [44.163s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.661s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.964s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:19.157s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [2:07.640s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:47.051s]
[INFO] Web Map Service Module ............................ SUCCESS [5:12.689s]
[INFO] REST Support Module ............................... SUCCESS [44.935s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.472s]
[INFO] Core UI Module .................................... SUCCESS [2:26.641s]
[INFO] WFS UI Module ..................................... SUCCESS [43.065s]
[INFO] Security UI Modules ............................... SUCCESS [0.258s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.133s]
[INFO] Printing Module ................................... SUCCESS [40.715s]
[INFO] Community Space ................................... SUCCESS [0.237s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.404s]
[INFO] Application Schema Support ........................ SUCCESS [0.130s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.685s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [28.655s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.936s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [3.047s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.113s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.312s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.377s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.387s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.327s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.452s]
[INFO] Excel Output Format ............................... SUCCESS [40.496s]
[INFO] Chart external graphics support ................... SUCCESS [2.391s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.635s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.659s]
[INFO] OWS request flow controller ....................... SUCCESS [29.261s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.132s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.282s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.856s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [53.706s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.290s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [23.147s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.171s]
[INFO] DXF WFS output format ............................. SUCCESS [38.139s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [1.176s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 18:41.387s (Wall Clock)
[INFO] Finished at: Sun Sep 14 18:06:29 UTC 2014
[INFO] Final Memory: 58M/194M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <http://ares.opengeo.org/jenkins/job/geoserver-master/780/changes&gt;
Changes:
[ivanfm] Update pointsymbols.rst
[mike] Update pointsymbols.rst
[mike] update css stylemarks with windbarbs information
[mike] windbarbs example files
[...truncated 19474 lines...]
14 Sep 19:11:16 INFO [org.geoserver] - GeoServer configuration lock is enabled
14 Sep 19:11:16 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler 'dispatcher'
14 Sep 19:11:16 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler 'dispatcher'
14 Sep 19:11:16 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
14 Sep 19:11:16 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
14 Sep 19:11:16 WARN [geoserver.security] - Strong cryptography is NOT available
14 Sep 19:11:16 INFO [geoserver.security] - Start reloading user/grous for service named default
14 Sep 19:11:16 INFO [geoserver.security] - Reloading user/groups successful for service named default
14 Sep 19:11:16 INFO [geoserver.security] - Start encrypting configuration passwords using pbePasswordEncoder
14 Sep 19:11:16 INFO [geoserver.security] - End encrypting configuration passwords
14 Sep 19:11:16 INFO [geoserver.wcs] -
14 Sep 19:11:16 WARN [geotools.xml] - Error parsing: http://schemas.opengis.net/wcs/geotiff/1.0/wcsGeotiff.xsd
    extension:
        contents[0]:
            name = Scaling
    service = WCS
    version = 2.0.1
    format = image/tiff
14 Sep 19:11:17 INFO [geoserver.wcs] -
14 Sep 19:11:17 WARN [geotools.xml] - Error parsing: http://schemas.opengis.net/wcs/geotiff/1.0/wcsGeotiff.xsd
    extension:
        contents[0]:
            name = Scaling
    service = WCS
    version = 2.0.1
    format = image/tiff
    extension:
        contents[0]:
            name = Scaling
    service = WCS
    version = 2.0.1
    format = image/tiff
14 Sep 19:11:18 INFO [geoserver.wcs] -
14 Sep 19:11:18 WARN [geotools.xml] - Error parsing: http://schemas.opengis.net/wcs/geotiff/1.0/wcsGeotiff.xsd
    extension:
        contents[0]:
            name = Scaling
    service = WCS
    version = 2.0.1
    format = image/tiff
14 Sep 19:11:18 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Sun Sep 14 19:11:15 UTC 2014]; root of context hierarchy
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.258 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.470s]
[INFO] Core Platform Module .............................. SUCCESS [16.511s]
[INFO] Open Web Service Module ........................... SUCCESS [16.330s]
[INFO] Main Module ....................................... SUCCESS [3:17.173s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.737s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:22.202s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [43.779s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.190s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:17.210s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:23.773s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [2:05.049s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:46.491s]
[INFO] Web Map Service Module ............................ SUCCESS [5:15.363s]
[INFO] REST Support Module ............................... SUCCESS [44.313s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.030s]
[INFO] Core UI Module .................................... SUCCESS [2:21.914s]
[INFO] WFS UI Module ..................................... SUCCESS [41.525s]
[INFO] Security UI Modules ............................... SUCCESS [0.129s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.121s]
[INFO] Printing Module ................................... SUCCESS [39.333s]
[INFO] Community Space ................................... SUCCESS [0.110s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [8.748s]
[INFO] Application Schema Support ........................ SUCCESS [0.154s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.743s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.909s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.590s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.221s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.581s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.300s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.319s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.777s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.287s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.710s]
[INFO] Excel Output Format ............................... SUCCESS [39.321s]
[INFO] Chart external graphics support ................... SUCCESS [1.855s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.488s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.479s]
[INFO] OWS request flow controller ....................... SUCCESS [28.214s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.077s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [48.416s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.779s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [53.554s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.190s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [20.964s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.227s]
[INFO] DXF WFS output format ............................. SUCCESS [40.527s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.158s]
[INFO] Total time: 18:42.674s (Wall Clock)
[INFO] Finished at: Sun Sep 14 19:11:23 UTC 2014
[INFO] Final Memory: 59M/175M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/781/changes&gt;
Changes:
[mike] Update CONTRIBUTING.md
[...truncated 19608 lines...]
14 Sep 19:36:12 INFO [org.geoserver] - GeoServer configuration lock is enabled
14 Sep 19:36:12 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler 'dispatcher'
14 Sep 19:36:12 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler 'dispatcher'
14 Sep 19:36:12 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
14 Sep 19:36:12 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
14 Sep 19:36:12 WARN [geoserver.security] - Strong cryptography is NOT available
14 Sep 19:36:12 INFO [geoserver.security] - Start reloading user/grous for service named default
14 Sep 19:36:12 INFO [geoserver.security] - Reloading user/groups successful for service named default
14 Sep 19:36:12 INFO [geoserver.security] - Start encrypting configuration passwords using pbePasswordEncoder
14 Sep 19:36:12 INFO [geoserver.security] - End encrypting configuration passwords
14 Sep 19:36:13 INFO [geoserver.wcs] -
14 Sep 19:36:13 WARN [geotools.xml] - Error parsing: http://schemas.opengis.net/wcs/geotiff/1.0/wcsGeotiff.xsd
    extension:
        contents[0]:
            name = Scaling
    service = WCS
    version = 2.0.1
    format = image/tiff
    extension:
        contents[0]:
            name = Scaling
    service = WCS
    version = 2.0.1
    format = image/tiff
    extension:
        contents[0]:
            name = Scaling
    service = WCS
    version = 2.0.1
    format = image/tiff
14 Sep 19:36:14 INFO [geoserver.wcs] -
14 Sep 19:36:14 WARN [geotools.xml] - Error parsing: http://schemas.opengis.net/wcs/geotiff/1.0/wcsGeotiff.xsd
    extension:
        contents[0]:
            name = Scaling
    service = WCS
    version = 2.0.1
    format = image/tiff
14 Sep 19:36:14 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Sun Sep 14 19:36:12 UTC 2014]; root of context hierarchy
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.913 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.986s]
[INFO] Core Platform Module .............................. SUCCESS [14.153s]
[INFO] Open Web Service Module ........................... SUCCESS [16.272s]
[INFO] Main Module ....................................... SUCCESS [3:17.455s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.800s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:19.116s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [44.690s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.727s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:10.224s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:17.309s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [2:02.931s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:46.886s]
[INFO] Web Map Service Module ............................ SUCCESS [5:06.989s]
[INFO] REST Support Module ............................... SUCCESS [48.851s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.330s]
[INFO] Core UI Module .................................... SUCCESS [2:30.224s]
[INFO] WFS UI Module ..................................... SUCCESS [42.291s]
[INFO] Security UI Modules ............................... SUCCESS [0.140s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.162s]
[INFO] Printing Module ................................... SUCCESS [33.553s]
[INFO] Community Space ................................... SUCCESS [0.182s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [8.800s]
[INFO] Application Schema Support ........................ SUCCESS [0.137s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.141s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.995s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.785s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.140s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.536s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.269s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.342s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.775s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.419s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.291s]
[INFO] Excel Output Format ............................... SUCCESS [42.613s]
[INFO] Chart external graphics support ................... SUCCESS [1.411s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.025s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.796s]
[INFO] OWS request flow controller ....................... SUCCESS [27.546s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.121s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [47.636s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.868s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [53.005s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.152s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [21.043s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.337s]
[INFO] DXF WFS output format ............................. SUCCESS [38.218s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.131s]
[INFO] Total time: 18:31.994s (Wall Clock)
[INFO] Finished at: Sun Sep 14 19:36:19 UTC 2014
[INFO] Final Memory: 58M/195M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/782/changes&gt;
