[Geoserver-devel] Build failed in Jenkins: geoserver-master #8067
See <https://build.geoserver.org/job/geoserver-master/8067/display/redirect&gt;
[...truncated 1.78 MB...]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.17-SNAPSHOT/gs-importer-bdb-2.17-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.17-SNAPSHOT/gs-importer-bdb-2.17-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.17-SNAPSHOT [90/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/ocpsoft/ocpsoft-parent/6/ocpsoft-parent-6.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/ocpsoft/ocpsoft-parent/6/ocpsoft-parent-6.pom (18 kB at 3.6 MB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/ocpsoft/prettytime/prettytime/1.0.8.Final/prettytime-1.0.8.Final.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/ocpsoft/prettytime/prettytime/1.0.8.Final/prettytime-1.0.8.Final.jar
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/ocpsoft/prettytime/prettytime/1.0.8.Final/prettytime-1.0.8.Final.jar
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/ocpsoft/prettytime/prettytime/1.0.8.Final/prettytime-1.0.8.Final.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/ocpsoft/prettytime/prettytime/1.0.8.Final/prettytime-1.0.8.Final.jar (67 kB at 8.4 MB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-importer-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-importer-web ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-importer-web ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-importer-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-importer-web ---
[INFO] Copying 27 resources
[INFO] Copying 20 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-importer-web ---
[INFO] Compiling 33 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java&gt;: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-web ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-importer-web ---
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.747 s - in org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Running org.geoserver.importer.web.ImportTaskTableTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.903 s - in org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 25.064 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.733 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.829 s]
[INFO] Main Module ........................................ SUCCESS [01:11 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.041 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:31 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 46.090 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 20.893 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.443 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.278 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.280 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [01:25 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:15 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:44 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 22.688 s]
[INFO] gs-rest ............................................ SUCCESS [ 7.112 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:06 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:42 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.798 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 14.451 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 11.343 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.073 s]
[INFO] Core UI Module ..................................... SUCCESS [01:06 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 23.684 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 34.393 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 9.384 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.279 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.573 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.032 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:19 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:02 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.485 s]
[INFO] REST UI Module ..................................... SUCCESS [ 8.569 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.027 s]
[INFO] Printing Module .................................... SUCCESS [ 26.743 s]
[INFO] Community Space .................................... SUCCESS [ 0.020 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.018 s]
[INFO] Application Schema Integration Test ................ SUCCESS [06:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 11.296 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 9.082 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.115 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.372 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.516 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.782 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.235 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.786 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 7.041 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.537 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.018 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.293 s]
[INFO] OGR WFS ............................................ SUCCESS [ 6.339 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.017 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 13.801 s]
[INFO] Chart external graphics support .................... SUCCESS [ 2.303 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.531 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.309 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.594 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.498 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.665 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.046 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 18.497 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.046 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.349 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.273 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 14.658 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 14.791 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.037 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.242 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.201 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 24.371 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.591 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.016 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.752 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.017 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 7.501 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.327 s]
[INFO] Importer Core Module ............................... SUCCESS [ 29.931 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 25.940 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [03:00 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.843 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 25.093 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 17.435 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 17.921 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.787 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.933 s]
[INFO] REST SLD service ................................... SUCCESS [ 17.568 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 21.409 s]
[INFO] GeoFence Server .................................... SUCCESS [02:38 min]
[INFO] Authentication by unique url key ................... SUCCESS [ 46.225 s]
[INFO] BUILD FAILURE
[INFO] Total time: 21:06 min (Wall Clock)
[INFO] Finished at: 2019-09-13T14:00:09Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <https://build.geoserver.org/job/geoserver-master/8068/display/redirect&gt;
