[Geoserver-devel] Build failed in Jenkins: geoserver-master #814
See <http://ares.opengeo.org/jenkins/job/geoserver-master/814/changes&gt;
Changes:
[andrea.aime] GEOS-6692 do not assume that the subset envelope is using WGS84 lat lon
[andrea.aime] Adding missing pom file
[...truncated 20940 lines...]
        <SRS>EPSG:4326</SRS>
        <SRS>EPSG:900913</SRS>
        <LatLonBoundingBox minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/>
        <BoundingBox SRS="EPSG:4326" minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0"/>
        <BoundingBox SRS="EPSG:900913" minx="-2.003750834E7" miny="-2.003750834E7" maxx="2.003750834E7" maxy="2.003750834E7"/>
      </Layer>
      <Layer queryable="1">
        <Name>cite:Forests</Name>
        <Title>Forests</Title>
        <Abstract>abstract about Forests</Abstract>
      </Layer>
        <Name>cite:RoadSegments</Name>
        <Title>RoadSegments</Title>
        <Abstract>abstract about RoadSegments</Abstract>
      </Layer>
        <Name>cgf:MPoints</Name>
        <Title>MPoints</Title>
        <Abstract>abstract about MPoints</Abstract>
      </Layer>
        <Name>cite:Buildings</Name>
        <Title>Buildings</Title>
        <Abstract>abstract about Buildings</Abstract>
      </Layer>
        <Name>cite:NamedPlaces</Name>
        <Title>NamedPlaces</Title>
        <Abstract>abstract about NamedPlaces</Abstract>
      </Layer>
    </Layer>
  </Capability>
</WMT_MS_Capabilities>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.467 sec
Running org.geoserver.wps.jts.BeanProcessFactoryTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.308 sec
Running org.geoserver.wps.jts.GeometryProcessWPSTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.908 sec
Running org.geoserver.wps.process.ProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.88 sec
Running org.geoserver.wps.process.WPSConfigProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.766 sec
Running org.geoserver.wps.resource.WPSResourceManagerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.199 sec
Results :
Tests in error:
  testClipRectangle(org.geoserver.wps.gs.ClipProcessTest): java.util.HashMap cannot be cast to net.opengis.wfs.FeatureCollectionType
Tests run: 165, Failures: 0, Errors: 1, Skipped: 0
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.121s]
[INFO] Core Platform Module .............................. SUCCESS [15.256s]
[INFO] Open Web Service Module ........................... SUCCESS [16.182s]
[INFO] Main Module ....................................... SUCCESS [3:15.066s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.799s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:17.460s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:14.128s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.460s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:06.179s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:17.557s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:06.877s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:56.339s]
[INFO] Web Map Service Module ............................ SUCCESS [6:16.352s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:30.264s]
[INFO] REST Support Module ............................... SUCCESS [44.969s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.683s]
[INFO] Core UI Module .................................... SUCCESS [2:33.873s]
[INFO] WFS UI Module ..................................... SUCCESS [42.318s]
[INFO] Security UI Modules ............................... SUCCESS [0.340s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.161s]
[INFO] Printing Module ................................... SUCCESS [45.852s]
[INFO] Community Space ................................... SUCCESS [0.169s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [8.047s]
[INFO] Application Schema Support ........................ SUCCESS [0.157s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.650s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.787s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.197s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.175s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.613s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.750s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.469s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.894s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.415s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.025s]
[INFO] Excel Output Format ............................... SUCCESS [42.385s]
[INFO] Chart external graphics support ................... SUCCESS [1.232s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.927s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.734s]
[INFO] OWS request flow controller ....................... SUCCESS [29.001s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.213s]
[INFO] Web Processing Service Module ..................... FAILURE [4:32.698s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.102s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.097s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.193s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [53.766s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.211s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.236s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [29.206s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.287s]
[INFO] DXF WFS output format ............................. SUCCESS [41.152s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.259s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 23:08.052s (Wall Clock)
[INFO] Finished at: Sun Oct 05 09:30:39 UTC 2014
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 75.352 sec
Running org.geoserver.gwc.GWCQuotaStoreDisabledTest
[INFO] Final Memory: 61M/178M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.opengeo.org/jenkins/job/geoserver-master/815/changes&gt;
Changes:
[jdeolive] Creating zip entry for directories.
[...truncated 21111 lines...]
      </Layer>
      </Layer>
        <Name>cdf:Fifteen</Name>
        <Title>Fifteen</Title>
        <Abstract>abstract about Fifteen</Abstract>
      </Layer>
        <Name>cdf:Other</Name>
        <Title>Other</Title>
        <Abstract>abstract about Other</Abstract>
      </Layer>
      </Layer>
        <Name>cgf:Points</Name>
        <Title>Points</Title>
        <Abstract>abstract about Points</Abstract>
      </Layer>
      </Layer>
    </Layer>
  </Capability>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.995 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.633 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.940s]
[INFO] Core Platform Module .............................. SUCCESS [13.910s]
[INFO] Open Web Service Module ........................... SUCCESS [16.793s]
[INFO] Main Module ....................................... SUCCESS [3:17.546s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.766s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:18.269s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [42.078s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.029s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:09.385s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:16.995s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:09.239s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:42.797s]
[INFO] Web Map Service Module ............................ SUCCESS [6:08.036s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:29.686s]
[INFO] REST Support Module ............................... SUCCESS [44.244s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.266s]
[INFO] Core UI Module .................................... SUCCESS [2:26.732s]
[INFO] WFS UI Module ..................................... SUCCESS [46.317s]
[INFO] Security UI Modules ............................... SUCCESS [0.367s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.140s]
[INFO] Printing Module ................................... SUCCESS [37.258s]
[INFO] Community Space ................................... SUCCESS [0.141s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.162s]
[INFO] Application Schema Support ........................ SUCCESS [0.135s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.476s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.218s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.224s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.126s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.626s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.254s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.272s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.816s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.325s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [34.290s]
[INFO] Excel Output Format ............................... SUCCESS [41.817s]
[INFO] Chart external graphics support ................... SUCCESS [1.102s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.214s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.749s]
[INFO] OWS request flow controller ....................... SUCCESS [27.711s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.084s]
[INFO] Web Processing Service Module ..................... FAILURE [4:18.892s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [48.274s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.217s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.121s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [52.500s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.269s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.460s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [29.052s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.176s]
[INFO] DXF WFS output format ............................. SUCCESS [41.163s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.158s]
[INFO] Total time: 22:17.839s (Wall Clock)
[INFO] Finished at: Sun Oct 05 09:53:15 UTC 2014
[INFO] Final Memory: 61M/179M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/816/changes&gt;
Changes:
[juha.hyvarinen] Add support for XML3D output format in W3DS module.
[juha.hyvarinen] Add support for octet-stream output to XML3D request. This output format is used to optimize network traffic and only elevation information is returned.
[juha.hyvarinen] Add support for predefined LODset to XML3D output. Scale is from 1 to 10 and 10 is with maximum details.
[juha.hyvarinen] c) 2014 Open Source Geospatial Foundation (GSIP-118)
[...truncated 21257 lines...]
        <Abstract>abstract about DividedRoutes</Abstract>
      </Layer>
        <Name>cgf:Lines</Name>
        <Title>Lines</Title>
        <Abstract>abstract about Lines</Abstract>
      </Layer>
      </Layer>
        <Name>sf:AggregateGeoFeature</Name>
        <Title>AggregateGeoFeature</Title>
        <Abstract>abstract about AggregateGeoFeature</Abstract>
      </Layer>
        <Name>cite:Bridges</Name>
        <Title>Bridges</Title>
        <Abstract>abstract about Bridges</Abstract>
      </Layer>
        <Name>cgf:MLines</Name>
        <Title>MLines</Title>
        <Abstract>abstract about MLines</Abstract>
      </Layer>
        <Name>sf:GenericEntity</Name>
        <Title>GenericEntity</Title>
        <Abstract>abstract about GenericEntity</Abstract>
      </Layer>
        <Name>cgf:Polygons</Name>
        <Title>Polygons</Title>
        <Abstract>abstract about Polygons</Abstract>
      </Layer>
      </Layer>
      </Layer>
      </Layer>
      </Layer>
      </Layer>
      </Layer>
    </Layer>
  </Capability>
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.724s]
[INFO] Core Platform Module .............................. SUCCESS [13.866s]
[INFO] Open Web Service Module ........................... SUCCESS [16.315s]
[INFO] Main Module ....................................... SUCCESS [3:14.545s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.664s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:20.891s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [52.875s]
[INFO] Web Coverage Service Module ....................... SUCCESS [8.189s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.316s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:24.069s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:02.034s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:56.619s]
[INFO] Web Map Service Module ............................ SUCCESS [6:38.556s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:29.783s]
[INFO] REST Support Module ............................... SUCCESS [47.190s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.348s]
[INFO] Core UI Module .................................... SUCCESS [2:31.756s]
[INFO] WFS UI Module ..................................... SUCCESS [41.984s]
[INFO] Security UI Modules ............................... SUCCESS [0.289s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.151s]
[INFO] Printing Module ................................... SUCCESS [39.401s]
[INFO] Community Space ................................... SUCCESS [0.185s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.739s]
[INFO] Application Schema Support ........................ SUCCESS [0.117s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.175s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.987s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.377s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.064s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.547s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.286s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.342s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.924s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.493s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.358s]
[INFO] Excel Output Format ............................... SUCCESS [41.942s]
[INFO] Chart external graphics support ................... SUCCESS [1.612s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.015s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.753s]
[INFO] OWS request flow controller ....................... SUCCESS [33.120s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.212s]
[INFO] Web Processing Service Module ..................... FAILURE [4:31.734s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.789s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.680s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.158s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [51.835s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.149s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [23.291s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.300s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.181s]
[INFO] DXF WFS output format ............................. SUCCESS [40.017s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.162s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [56.177s]
[INFO] Total time: 23:25.296s (Wall Clock)
[INFO] Finished at: Sun Oct 05 12:56:10 UTC 2014
[INFO] Final Memory: 62M/195M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/817/&gt;
[...truncated 20891 lines...]
  at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
  at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
  at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
  at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
  at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
  at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
  at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:44)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1440)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1375)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:924)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:907)
  at org.geoserver.gwc.GWCDataSecurityTest.testCroppedMosaic(GWCDataSecurityTest.java:153)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Caused by: java.lang.ClassNotFoundException: com.sun.medialib.mlib.Image
  at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
  at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
  at java.security.AccessController.doPrivileged(Native Method)
  at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
  at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
  ... 176 more
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.436 sec
Running org.geoserver.wps.gs.VectorZonalStatsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 36.868 sec
Running org.geoserver.gwc.GWCIntegrationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.961 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.781 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.722 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.181 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.406 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.978 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.770s]
[INFO] Core Platform Module .............................. SUCCESS [15.624s]
[INFO] Open Web Service Module ........................... SUCCESS [17.143s]
[INFO] Main Module ....................................... SUCCESS [3:18.108s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.725s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:23.788s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [45.565s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.572s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:09.636s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:15.135s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:05.226s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:48.487s]
[INFO] Web Map Service Module ............................ SUCCESS [7:12.717s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:23.364s]
[INFO] REST Support Module ............................... SUCCESS [44.648s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.350s]
[INFO] Core UI Module .................................... SUCCESS [2:32.310s]
[INFO] WFS UI Module ..................................... SUCCESS [44.294s]
[INFO] Security UI Modules ............................... SUCCESS [0.133s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.165s]
[INFO] Printing Module ................................... SUCCESS [38.631s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.943s]
[INFO] Application Schema Support ........................ SUCCESS [0.112s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.095s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.931s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.616s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.156s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.632s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.332s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.290s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.480s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.533s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.516s]
[INFO] Excel Output Format ............................... SUCCESS [38.680s]
[INFO] Chart external graphics support ................... SUCCESS [1.712s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.398s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.778s]
[INFO] OWS request flow controller ....................... SUCCESS [30.009s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.227s]
[INFO] Web Processing Service Module ..................... FAILURE [4:32.732s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.793s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.487s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.188s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [51.833s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.180s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.480s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.361s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.367s]
[INFO] DXF WFS output format ............................. SUCCESS [45.055s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.245s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [54.973s]
[INFO] Total time: 23:24.170s (Wall Clock)
[INFO] Finished at: Sun Oct 05 15:06:37 UTC 2014
[INFO] Final Memory: 62M/200M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/818/changes&gt;
Changes:
[parker] Renamed aus_dem.tif to aus_dem.tiff. Top level pom file lists *.tiff
[parker] Fixed (most) of the failing tests in the BIL module. Changed test to
[parker] Changed expected content length for application/bil test to match
[...truncated 20884 lines...]
  ... 176 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 34.408 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.051 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.729 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.877 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.266 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.484 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.098 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.85 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.809s]
[INFO] Core Platform Module .............................. SUCCESS [13.963s]
[INFO] Open Web Service Module ........................... SUCCESS [16.301s]
[INFO] Main Module ....................................... SUCCESS [3:16.301s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.168s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:21.286s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [44.104s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.113s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:07.683s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:19.746s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:05.595s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:47.252s]
[INFO] Web Map Service Module ............................ SUCCESS [7:09.273s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:25.702s]
[INFO] REST Support Module ............................... SUCCESS [44.418s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.270s]
[INFO] Core UI Module .................................... SUCCESS [2:28.077s]
[INFO] WFS UI Module ..................................... SUCCESS [44.104s]
[INFO] Security UI Modules ............................... SUCCESS [0.151s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.176s]
[INFO] Printing Module ................................... SUCCESS [36.486s]
[INFO] Community Space ................................... SUCCESS [0.225s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.558s]
[INFO] Application Schema Support ........................ SUCCESS [0.133s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.941s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.133s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.134s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.529s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.266s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.297s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.739s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.407s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.881s]
[INFO] Excel Output Format ............................... SUCCESS [40.289s]
[INFO] Chart external graphics support ................... SUCCESS [2.036s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.373s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.707s]
[INFO] OWS request flow controller ....................... SUCCESS [31.005s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.285s]
[INFO] Web Processing Service Module ..................... FAILURE [4:37.763s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.772s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.839s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.134s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [54.100s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.197s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.409s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.827s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.397s]
[INFO] DXF WFS output format ............................. SUCCESS [40.632s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.257s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [56.387s]
[INFO] Total time: 23:15.550s (Wall Clock)
[INFO] Finished at: Sun Oct 05 20:01:01 UTC 2014
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
On Sun, Oct 5, 2014 at 10:01 PM, <monitor@anonymised.com> wrote:
Results :
Tests in error:
Weird, I cannot reproduce from maven nor from Eclipse... what's going on
here?
GeoSolutions for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I don't know...the error looks completely unrelated to my change. I see that the same test failure popped up a couple times last month (on September 6 and 7).
Maybe a class loader issue? The test is failing after parsing a binary servlet response. My change to the BIL test also dealt with interpreting a binary response. Maybe the BIL plugin is pulling in an unexpected version of some class or dependency, causing a later test failure?
Parker
On 10/5/14, 1:19 PM, Andrea Aime wrote:
On Sun, Oct 5, 2014 at 10:01 PM, <monitor@anonymised.com <mailto:monitor@anonymised.com>> wrote:
    Results :
    Tests in error:
Weird, I cannot reproduce from maven nor from Eclipse... what's going on here?
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
See <http://ares.opengeo.org/jenkins/job/geoserver-master/819/&gt;
[...truncated 21222 lines...]
      </Layer>
        <Name>cite:Streams</Name>
        <Title>Streams</Title>
        <Abstract>abstract about Streams</Abstract>
      </Layer>
        <Name>cdf:Seven</Name>
        <Title>Seven</Title>
        <Abstract>abstract about Seven</Abstract>
      </Layer>
        <Name>cdf:Locks</Name>
        <Title>Locks</Title>
        <Abstract>abstract about Locks</Abstract>
      </Layer>
        <Name>cite:Ponds</Name>
        <Title>Ponds</Title>
        <Abstract>abstract about Ponds</Abstract>
      </Layer>
        <Name>cdf:Updates</Name>
        <Title>Updates</Title>
        <Abstract>abstract about Updates</Abstract>
      </Layer>
        <Name>cdf:Deletes</Name>
        <Title>Deletes</Title>
        <Abstract>abstract about Deletes</Abstract>
      </Layer>
    </Layer>
  </Capability>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.736 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.791 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.585s]
[INFO] Core Platform Module .............................. SUCCESS [15.070s]
[INFO] Open Web Service Module ........................... SUCCESS [16.364s]
[INFO] Main Module ....................................... SUCCESS [3:15.603s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.716s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:19.465s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [43.920s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.675s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:07.441s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:19.647s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:06.944s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:42.376s]
[INFO] Web Map Service Module ............................ SUCCESS [6:02.241s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:29.350s]
[INFO] REST Support Module ............................... SUCCESS [45.650s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.881s]
[INFO] Core UI Module .................................... SUCCESS [2:33.253s]
[INFO] WFS UI Module ..................................... SUCCESS [41.483s]
[INFO] Security UI Modules ............................... SUCCESS [0.290s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.167s]
[INFO] Printing Module ................................... SUCCESS [36.297s]
[INFO] Community Space ................................... SUCCESS [0.171s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.261s]
[INFO] Application Schema Support ........................ SUCCESS [0.129s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.223s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.608s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.199s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.063s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.506s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.249s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.320s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.942s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.317s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [34.566s]
[INFO] Excel Output Format ............................... SUCCESS [41.435s]
[INFO] Chart external graphics support ................... SUCCESS [1.732s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.421s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.674s]
[INFO] OWS request flow controller ....................... SUCCESS [27.194s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.187s]
[INFO] Web Processing Service Module ..................... FAILURE [4:25.723s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.428s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.265s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.245s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [57.878s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.182s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.037s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.668s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.434s]
[INFO] DXF WFS output format ............................. SUCCESS [43.094s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.184s]
[INFO] Total time: 22:25.502s (Wall Clock)
[INFO] Finished at: Sun Oct 05 20:53:40 UTC 2014
[INFO] Final Memory: 61M/176M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/820/changes&gt;
Changes:
[Ben.Caradoc-Davies] Fixed jms-cluster artifactId and removed inconsistent property activation
[...truncated 21100 lines...]
      </Layer>
      </Layer>
      </Layer>
        <Name>cite:MapNeatline</Name>
        <Title>MapNeatline</Title>
        <Abstract>abstract about MapNeatline</Abstract>
      </Layer>
      </Layer>
      </Layer>
      </Layer>
    </Layer>
  </Capability>
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.238s]
[INFO] Core Platform Module .............................. SUCCESS [15.436s]
[INFO] Open Web Service Module ........................... SUCCESS [16.399s]
[INFO] Main Module ....................................... SUCCESS [3:19.109s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.743s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:19.908s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [43.646s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.519s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:10.014s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:14.229s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:11.196s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:43.573s]
[INFO] Web Map Service Module ............................ SUCCESS [7:03.313s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:24.030s]
[INFO] REST Support Module ............................... SUCCESS [48.714s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.282s]
[INFO] Core UI Module .................................... SUCCESS [2:28.416s]
[INFO] WFS UI Module ..................................... SUCCESS [42.821s]
[INFO] Security UI Modules ............................... SUCCESS [0.371s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.170s]
[INFO] Printing Module ................................... SUCCESS [39.247s]
[INFO] Community Space ................................... SUCCESS [0.131s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.230s]
[INFO] Application Schema Support ........................ SUCCESS [0.147s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.753s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.599s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.605s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.052s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.527s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.293s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.303s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.177s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.531s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.358s]
[INFO] Excel Output Format ............................... SUCCESS [39.875s]
[INFO] Chart external graphics support ................... SUCCESS [1.753s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.046s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.797s]
[INFO] OWS request flow controller ....................... SUCCESS [27.478s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.333s]
[INFO] Web Processing Service Module ..................... FAILURE [4:39.281s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.612s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.058s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.166s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [52.586s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.206s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [24.805s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.317s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.242s]
[INFO] DXF WFS output format ............................. SUCCESS [41.015s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.205s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [57.165s]
[INFO] Total time: 23:32.803s (Wall Clock)
[INFO] Finished at: Mon Oct 06 05:21:20 UTC 2014
[INFO] Final Memory: 62M/199M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
On Sun, Oct 5, 2014 at 10:36 PM, Parker Abercrombie <
September 6 and 7).
Yes, they are, WPS does not depend on dds
Hum... not sure. Maybe Justin has an idea
Ing. Andrea Aime
@geowolf
Technical Lead
I am also investigating. According to our Jenkins, the failure started with this upstream change in GeoTools master (which seems to make sense):
Commit 20224518e20744992ee665ca702fc4d7da1388f9 by dwinslow
Reproject envelope for RectangularClip if required
The file was modified modules/unsupported/process-feature/src/main/java/org/geotools/process/vector/RectangularClipProcess.java
The file was added modules/unsupported/process-feature/src/test/java/org/geotools/process/vector/RectangularClipProcessTest.java
<parker.abercrombie@anonymised.com <mailto:parker.abercrombie@anonymised.com>> wrote:
    test failure?
Ing. Andrea Aime
@geowolf
Technical Lead
stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti,
copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento
contrario ai principi dettati dal D.Lgs. 196/2003.
Slashdot TV. Videos for Nerds. Stuff that Matters.
http://pubads.g.doubleclick.net/gampad/clk?id=160591471&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Mineral Resources Flagship
Australian Resources Research Centre
On Mon, Oct 6, 2014 at 8:17 AM, Ben Caradoc-Davies <
Hum... same process for sure, but how does that connect with the inability
to parse the request?
I would have expected a change in gt-xsd-* to cause the issue
Ing. Andrea Aime
@geowolf
Technical Lead
inability to parse the request?
Indeed. It is pretty freaky. And yet reverting 20224518e20744992ee665ca702fc4d7da1388f9 fixes the build.
Software Engineer
Ah, got it. The new code tests for null featuresCRS but does not test for null clip.getCoordinateReferenceSystem(), and when it is null we get the failure (the hashmap is a parsed exception response):
06 Oct 15:43:21 ERROR [geoserver.wps] - Process execution failed
org.geotools.process.ProcessException: java.lang.NullPointerException: Unable to transform referenced envelope, crs has not yet been provided.
  at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:565)
  at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:228)
  at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:1)
  at java.util.concurrent.FutureTask.run(FutureTask.java:262)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
  at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.NullPointerException: Unable to transform referenced envelope, crs has not yet been provided.
  at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:658)
  at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:624)
  at org.geotools.process.vector.RectangularClipProcess.execute(RectangularClipProcess.java:54)
  at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:549)
  ... 6 more
Software Engineer
On Mon, Oct 6, 2014 at 9:24 AM, Ben Caradoc-Davies <
Wait, you mean you can reproduce the failure?
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Oct 6, 2014 at 9:48 AM, Ben Caradoc-Davies <
        ... 6 more
Ah ok, makes sense. Are you fixing it, or shall I go ahead?
This should be on David's plate, but it's simple, don't feel like leaving
it there for another 12 hours
Ing. Andrea Aime
@geowolf
Technical Lead
See <http://ares.opengeo.org/jenkins/job/geoserver-master/821/&gt;
[...truncated 20721 lines...]
  ... 176 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 35.899 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.165 sec
Running org.geoserver.wps.gs.UniqueProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.368 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.148 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.639 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.441 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.105 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.997 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.226 sec
Results :
Tests in error:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.314s]
[INFO] Core Platform Module .............................. SUCCESS [15.247s]
[INFO] Open Web Service Module ........................... SUCCESS [25.509s]
[INFO] Main Module ....................................... SUCCESS [3:25.034s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.785s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:18.761s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [46.373s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.937s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.669s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:19.509s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:10.006s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:43.428s]
[INFO] Web Map Service Module ............................ SUCCESS [7:03.258s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:24.486s]
[INFO] REST Support Module ............................... SUCCESS [44.563s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.298s]
[INFO] Core UI Module .................................... SUCCESS [2:35.737s]
[INFO] WFS UI Module ..................................... SUCCESS [44.986s]
[INFO] Security UI Modules ............................... SUCCESS [0.400s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.134s]
[INFO] Printing Module ................................... SUCCESS [38.262s]
[INFO] Community Space ................................... SUCCESS [0.182s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.182s]
[INFO] Application Schema Support ........................ SUCCESS [0.115s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.204s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.466s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.248s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [8.039s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.548s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.707s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.686s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.016s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.390s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.958s]
[INFO] Excel Output Format ............................... SUCCESS [42.840s]
[INFO] Chart external graphics support ................... SUCCESS [1.983s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.837s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.870s]
[INFO] OWS request flow controller ....................... SUCCESS [26.530s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.287s]
[INFO] Web Processing Service Module ..................... FAILURE [4:26.054s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [48.760s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.497s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.316s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [54.558s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.207s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [24.444s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.656s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.241s]
[INFO] DXF WFS output format ............................. SUCCESS [40.606s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.366s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [57.192s]
[INFO] Total time: 23:38.753s (Wall Clock)
[INFO] Finished at: Mon Oct 06 07:58:01 UTC 2014
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
<Ben.Caradoc-Davies@anonymised.com <mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
    20224518e20744992ee665ca702fc4__d7da1388f9 fixes the build.
Sure can. And I have a fix.
Software Engineer
leaving it there for another 12 hours
Agreed. Must fix now.
Two options (or both):
(1) Test for null crs on the clip in geotools. Or is it correct to throw where the clip has no crs and the data has a crs?
(2) Add a crs attribute in geoserver and fix the axis order (below). But then is the test later too loose?
Ready to push both fixes, just not sure if they are both appropriate or too lax.
Kind regards,
Ben.
diff --git a/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/gs/ClipProcessTest.java b/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/gs/ClipProcessTest.java
index 966b626..695e8a3 100644
--- a/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/gs/ClipProcessTest.java
+++ b/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/gs/ClipProcessTest.java
@@ -42,9 +42,9 @@ public class ClipProcessTest extends WPSTestSupport {
                  + "<wps:Input>"
                  + "<ows:Identifier>clip</ows:Identifier>"
                  + "<wps:Data>"
- + "<ows:BoundingBox>"
- + "<ows:LowerCorner>-100 40</ows:LowerCorner>"
- + "<ows:UpperCorner>-90 45</ows:UpperCorner>"
+ + "<ows:BoundingBox crs=\"urn:x-ogc:def:crs:EPSG:4326\">"
+ + "<ows:LowerCorner>40 -100</ows:LowerCorner>"
+ + "<ows:UpperCorner>45 -90</ows:UpperCorner>"
                  + "</ows:BoundingBox>"
                  + "</wps:Data>"
                  + "</wps:Input>"
Software Engineer
On Mon, Oct 6, 2014 at 10:06 AM, Ben Caradoc-Davies <
This one please, the code should be resilient to bad inputs (and sometimes
it's true that data and clip
do not have a CRS, not everybody uses geotools for georeferenced
information) :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
