[Geoserver-devel] Build failed in Jenkins: geoserver-master #906
See <http://ares.opengeo.org/jenkins/job/geoserver-master/906/changes&gt;
Changes:
[andrea.aime] [GEOS-6755] GSIP 119 - WPS clustering of asynchronous requests - architecture refactor to allow pluggable status sharing
[andrea.aime] [GEOS-6755] GSIP 119 - Hazelcast based status store
[andrea.aime] [GEOS-6755] GSIP 119 - Adding heartbeat so that long procesess not reporting progress won't have their resources expired by mistake
[...truncated 25490 lines...]
3796/3895 KB
3800/3895 KB
3804/3895 KB
3808/3895 KB
3812/3895 KB
3816/3895 KB
3820/3895 KB
3824/3895 KB
3828/3895 KB
3832/3895 KB
3836/3895 KB
3840/3895 KB
3844/3895 KB
3848/3895 KB
3852/3895 KB
3856/3895 KB
3860/3895 KB
3864/3895 KB
3868/3895 KB
3872/3895 KB
3876/3895 KB
3880/3895 KB
3884/3895 KB
3888/3895 KB
3890/3895 KB
3892/3895 KB
3895/3895 KB
Downloaded: http://repo.maven.apache.org/maven2/com/hazelcast/hazelcast/3.3.1/hazelcast-3.3.1.jar (3895 KB at 2362.0 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wps-cluster-hazelcast ---
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wps-cluster-hazelcast ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-cluster-hazelcast ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #810 from aaime/wps_cluster_hz
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 18.11.2014 @ 08:40:08 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 18-Nov-2014 08:42
[INFO] [GitCommitIdMojo] build.build.time = 18.11.2014 @ 09:14:34 UTC
[INFO] [GitCommitIdMojo] build.branch = 802bf193ba84c24329f39b69a7d4bbe978c17eff
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 802bf19
[INFO] [GitCommitIdMojo] build.commit.id = 802bf193ba84c24329f39b69a7d4bbe978c17eff
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #810 from aaime/wps_cluster_hz
WPS clustering - with Hazelcast based store
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-cluster-hazelcast ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-cluster-hazelcast ---
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/classes&gt;
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[13,26\] error: cannot find symbol
[ERROR] package org.geotools.filter
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[229,29\] error: cannot find symbol
[INFO] 2 errors
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping GWC UI Module
[INFO]
[INFO] Skipping REST UI Module
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [19.645s]
[INFO] Core Platform Module .............................. SUCCESS [15.258s]
[INFO] Open Web Service Module ........................... SUCCESS [20.245s]
[INFO] Main Module ....................................... SUCCESS [3:19.868s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.895s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:20.048s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [49.765s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.050s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:09.783s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:17.948s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:12.216s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:46.290s]
[INFO] Web Map Service Module ............................ SUCCESS [7:06.574s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:27.761s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:42.236s]
[INFO] REST Support Module ............................... SUCCESS [49.330s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:14.630s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.150s]
[INFO] Core UI Module .................................... SUCCESS [2:34.181s]
[INFO] WMS UI Module ..................................... SUCCESS [1:04.447s]
[INFO] WFS UI Module ..................................... SUCCESS [42.581s]
[INFO] Demoes Module ..................................... SUCCESS [1:06.786s]
[INFO] Security UI Modules ............................... SUCCESS [0.357s]
[INFO] Security UI Core Module ........................... SUCCESS [3:48.828s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.223s]
[INFO] Printing Module ................................... SUCCESS [40.237s]
[INFO] Community Space ................................... SUCCESS [0.172s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.681s]
[INFO] Application Schema Support ........................ SUCCESS [0.118s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.615s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.441s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.799s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.669s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.575s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.250s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.273s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.679s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.006s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.460s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.233s]
[INFO] Excel Output Format ............................... SUCCESS [43.578s]
[INFO] Chart external graphics support ................... SUCCESS [1.893s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.558s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.685s]
[INFO] OWS request flow controller ....................... SUCCESS [33.797s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.134s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:26.796s]
[INFO] Web process status sharing with Hazelcast ......... FAILURE [14.459s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.440s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.674s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.386s]
[INFO] Core Monitor Extension ............................ SUCCESS [28.444s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:00.767s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [54.970s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.217s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [24.461s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.300s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:45.569s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.133s]
[INFO] DXF WFS output format ............................. SUCCESS [40.993s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.139s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [57.479s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.349s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [33.560s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.221s]
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 31:50.075s (Wall Clock)
[INFO] Finished at: Tue Nov 18 09:14:46 UTC 2014
[INFO] Final Memory: 70M/206M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wps-cluster-hazelcast: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[229,29\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-cluster-hazelcast
See <http://ares.opengeo.org/jenkins/job/geoserver-master/907/&gt;
