[Geoserver-devel] Build failed in Jenkins: geoserver-master-app-schema-online #1159
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1159/display/redirect?page=changes&gt;
Changes:
[Alessio Fabiani] [Fixes GEOS-8701] - Importer rest interface does not configure time
[Daniele Romagnoli] GEOT-6008: Documentation update for ImageMosaic multilevel sidecar
[Alessio Fabiani] - REST API docs and requested changes on PR
[github] [GEOS-8724] Intermittent build failure in NamespacesWfsTest (#2870)
[...truncated 87.27 KB...]
T E S T S
Running org.geoserver.test.SampleDataAccessWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.486 sec
Results :
[INFO]
[INFO] Building Application Schema Integration Online Test with Postgis Database 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-postgis-test ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-postgis-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-postgis-test ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/src/main/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-postgis-test ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-postgis-test ---
[INFO] Copying 178 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-postgis-test ---
[INFO] Compiling 140 source files to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/test-classes&gt;
[WARNING] <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java&gt;:\[26,21\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java&gt;:\[159,11\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java&gt;:\[165,12\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java&gt;:\[165,39\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-app-schema-postgis-test ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports&gt;
T E S T S
Running org.geoserver.test.BBox3DTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 17.461 sec
Running org.geoserver.test.BBoxFilterTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.621 sec
Running org.geoserver.test.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.939 sec
Running org.geoserver.test.ConnectionUsageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.511 sec
Running org.geoserver.test.DefaultIdTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.88 sec
Running org.geoserver.test.DuplicatePropertiesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.042 sec
Running org.geoserver.test.DuplicateTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.663 sec
Running org.geoserver.test.EncodeIfEmptyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.067 sec
Running org.geoserver.test.FeatureChainingSharedConnectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.602 sec
Running org.geoserver.test.FeatureChainingWfsTest
Tests run: 33, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 22.916 sec
Running org.geoserver.test.FeatureGML32Test
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.444 sec
Running org.geoserver.test.GUChainNoIDMFTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.892 sec
Running org.geoserver.test.GetPropertyValueTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.216 sec
Running org.geoserver.test.Gsml30WfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.49 sec
Running org.geoserver.test.Gsml32BoreholeIntervalWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.845 sec
Running org.geoserver.test.Gsml32BoreholeWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.865 sec
Running org.geoserver.test.IdFunctionWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.868 sec
Running org.geoserver.test.IdFunctionWfsWithJoiningTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.697 sec
Running org.geoserver.test.IdNotEncodedTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.704 sec
Running org.geoserver.test.InvalidColumnTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.462 sec
Running org.geoserver.test.IsolatedNamespacesWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.758 sec
Running org.geoserver.test.LocalResolveFeatureChainingByRefTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.995 sec
Running org.geoserver.test.LocalResolveTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.592 sec
Running org.geoserver.test.MappingNameTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.486 sec
Running org.geoserver.test.MeasureTypeBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.478 sec
Running org.geoserver.test.MultivaluedXlinkHrefTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.813 sec
Running org.geoserver.test.NamespacesWfsTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.602 sec
Running org.geoserver.test.NestedIdSupportTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.452 sec
Running org.geoserver.test.Observation_2_0_WfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.754 sec
Running org.geoserver.test.PagingTest
Tests run: 10, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 9.616 sec <<< FAILURE!
testGetFeatureWithFilter(org.geoserver.test.PagingTest) Time elapsed: 6594 sec <<< FAILURE!
java.lang.AssertionError: expected:<1> but was:<3>
  at org.junit.Assert.fail(Assert.java:88)
  at org.junit.Assert.failNotEquals(Assert.java:743)
  at org.junit.Assert.assertEquals(Assert.java:118)
  at org.junit.Assert.assertEquals(Assert.java:555)
  at org.junit.Assert.assertEquals(Assert.java:542)
  at org.geoserver.test.AbstractAppSchemaTestSupport.assertXpathCount(AbstractAppSchemaTestSupport.java:372)
  at org.geoserver.test.PagingTest.testGetFeatureWithFilter(PagingTest.java:428)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
Running org.geoserver.test.PolymorphismInlineWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.754 sec
Running org.geoserver.test.PolymorphismWfsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.147 sec
Running org.geoserver.test.PropertyEncodingOrderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.531 sec
Running org.geoserver.test.PropertySelectionTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.432 sec
Running org.geoserver.test.Reprojection3DTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.719 sec
Running org.geoserver.test.RestconfigWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.984 sec
Running org.geoserver.test.SRSReprojectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.205 sec
Running org.geoserver.test.SRSWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.726 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.216 sec
Running org.geoserver.test.SecondaryNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.65 sec
Running org.geoserver.test.SecuredFeatureChainingTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.949 sec
Running org.geoserver.test.SimpleAttributeFeatureChainWfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.992 sec
Running org.geoserver.test.SortByTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.472 sec
Running org.geoserver.test.SpecimenWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.381 sec
Running org.geoserver.test.StringConstantIdWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.394 sec
Running org.geoserver.test.SubstitutionGroupCoverageWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.026 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.926 sec
Running org.geoserver.test.TimeSeriesInlineWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.077 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.039 sec
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.852 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.292 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.904 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.005 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.041 sec
Running org.geoserver.test.XPathPredicateTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.513 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.5 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.571 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.834 sec
Running org.geoserver.test.web.Gml311LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.487 sec
Running org.geoserver.test.web.Gml32LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.175 sec
Results :
Failed tests: testGetFeatureWithFilter(org.geoserver.test.PagingTest): expected:<1> but was:<3>
Tests run: 208, Failures: 1, Errors: 0, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 2.662 s]
[INFO] Application Schema Integration Test ................ FAILURE [46:25 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.023 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [05:59 min]
[INFO] BUILD FAILURE
[INFO] Total time: 52:36 min
[INFO] Finished at: 2018-05-09T21:54:51+00:00
[INFO] Final Memory: 55M/333M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-postgis-test: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
Checking what is going on ... I have the same failure locally without my commit.
Maybe something on GeoTools side ?
Changes:
  T E S T S
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
  T E S T S
Results :
[INFO]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Check out the vibrant tech community on one of the world's most
Geoserver-devel mailing list
Nuno Oliveira
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
  The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Looks like this failure is caused by this GeoTools commit:
commit 3d33f397d3a5e598585c38f72a9695b71be0702a
[GEOT-5920] WFSClient fails when a function is used in a query (#1883)
fix for GEOT-5920
Strange how this is only affecting an App-Schema test when executed with an online database.
Ian any idea ? I will only have time to dig into this on the App-Schema side during the WE …
On 05/10/2018 10:17 AM, Nuno Oliveira wrote:
Checking what is going on … I have the same failure locally without my commit.
See https://build.geoserver.org/job/geoserver-master-app-schema-online/1159/display/redirect?page=changes
Changes:
[…truncated 87.27 KB…]
T E S T S
Results :
[INFO]
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-postgis-test —
[INFO] Deleting https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-postgis-test —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-postgis-test —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/src/main/java
[INFO] skip non existing resourceDirectory https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/src/main/resources
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-postgis-test —
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-postgis-test —
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-postgis-test —
[INFO] Compiling 140 source files to https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/test-classes
[WARNING] https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java:[26,21] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java:[159,11] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java:[165,12] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java:[165,39] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-app-schema-postgis-test —
[INFO] Surefire report directory: https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports
T E S T S
Results :
[INFO]
[INFO] Application Schema Support … SUCCESS [ 2.662 s]
[INFO] Application Schema Integration Test … FAILURE [46:25 min]
[INFO] Sample DataAccess Integration Test … SUCCESS [ 9.023 s]
[ERROR]
[ERROR] Please refer to https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/target/surefire-reports for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR] Please refer to https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-app-schema-test
Build step ‘Invoke top-level Maven targets’ marked build as failure
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Hi Nuno,
the only recent change that might seem to be even remotely related is this one:
which had some changes in the XML parsing of filters:
https://github.com/geotools/geotools/commit/3d33f397d3a5e598585c38f72a9695b71be0702a
Are those app-schema tests parsing filters from XML?
On Thu, May 10, 2018 at 11:17 AM, Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1159/display/redirect?page=changes>
Changes:
T E S T S
Results :
[INFO]
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target>
[INFO]
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/src/main/resources>
[INFO]
[INFO]
[INFO]
[INFO] Compiling 140 source files to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/test-classes>
[WARNING] <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:[26,21] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:[159,11] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:[165,12] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:[165,39] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[INFO]
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports>
T E S T S
Results :
[INFO]
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
Geoserver-devel@anonymised.comrge.net
Nuno Oliveira
@nmcoliveira
Software Engineer
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Nuno,
I can confirm that the failure occurs locally and without your recent commit. I created a Jira issue:
[GEOS-8738] gs-app-schema-postgis-test build fails in PagingTest
https://osgeo-org.atlassian.net/browse/GEOS-8738
Kind regards,
Ben.
Changes:
T E S T S
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
at org\.geoserver\.test\.PagingTest\.testGetFeatureWithFilter\(PagingTest\.java:428\)
at sun\.reflect\.NativeMethodAccessorImpl\.invoke0\(Native Method\)
at sun\.reflect\.NativeMethodAccessorImpl\.invoke\(NativeMethodAccessorImpl\.java:62\)
at sun\.reflect\.DelegatingMethodAccessorImpl\.invoke\(DelegatingMethodAccessorImpl\.java:43\)
at java\.lang\.reflect\.Method\.invoke\(Method\.java:498\)
at org\.junit\.runners\.model\.FrameworkMethod$1\.runReflectiveCall\(FrameworkMethod\.java:47\)
at org\.junit\.internal\.runners\.model\.ReflectiveCallable\.run\(ReflectiveCallable\.java:12\)
at org\.junit\.runners\.model\.FrameworkMethod\.invokeExplosively\(FrameworkMethod\.java:44\)
at org\.junit\.internal\.runners\.statements\.InvokeMethod\.evaluate\(InvokeMethod\.java:17\)
at org\.junit\.internal\.runners\.statements\.RunBefores\.evaluate\(RunBefores\.java:26\)
at org\.junit\.internal\.runners\.statements\.RunAfters\.evaluate\(RunAfters\.java:27\)
at org\.junit\.rules\.RunRules\.evaluate\(RunRules\.java:20\)
at org\.junit\.runners\.ParentRunner\.runLeaf\(ParentRunner\.java:271\)
at org\.junit\.runners\.BlockJUnit4ClassRunner\.runChild\(BlockJUnit4ClassRunner\.java:70\)
at org\.junit\.runners\.BlockJUnit4ClassRunner\.runChild\(BlockJUnit4ClassRunner\.java:50\)
at org\.junit\.runners\.ParentRunner$3\.run\(ParentRunner\.java:238\)
at org\.junit\.runners\.ParentRunner$1\.schedule\(ParentRunner\.java:63\)
at org\.junit\.runners\.ParentRunner\.runChildren\(ParentRunner\.java:236\)
at org\.junit\.runners\.ParentRunner\.access$000\(ParentRunner\.java:53\)
at org\.junit\.runners\.ParentRunner$2\.evaluate\(ParentRunner\.java:229\)
at org\.junit\.runners\.ParentRunner\.run\(ParentRunner\.java:309\)
at org\.apache\.maven\.surefire\.junit4\.JUnit4Provider\.execute\(JUnit4Provider\.java:252\)
at org\.apache\.maven\.surefire\.junit4\.JUnit4Provider\.executeTestSet\(JUnit4Provider\.java:141\)
at org\.apache\.maven\.surefire\.junit4\.JUnit4Provider\.invoke\(JUnit4Provider\.java:112\)
at org\.apache\.maven\.surefire\.util\.ReflectionUtils\.invokeMethodWithArray\(ReflectionUtils\.java:189\)
at org\.apache\.maven\.surefire\.booter\.ProviderFactory$ProviderProxy\.invoke\(ProviderFactory\.java:165\)
at org\.apache\.maven\.surefire\.booter\.ProviderFactory\.invokeProvider\(ProviderFactory\.java:85\)
at org\.apache\.maven\.surefire\.booter\.ForkedBooter\.runSuitesInProcess\(ForkedBooter\.java:115\)
at org\.apache\.maven\.surefire\.booter\.ForkedBooter\.main\(ForkedBooter\.java:75\)
Results :
[INFO]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/&gt;
New Zealand
That one should should only have affected like filters, and even then should have had no effect on standard behaviour.
Ian
Changes:
T E S T S
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
Nuno Oliveira
@nmcoliveira
Software Engineer
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1160/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] WFS3 work on collections
[Andrea Aime] Updating to the latest imageio-ext, for consistency with GeoTools
[Andrea Aime] Adding jackson XML support in WFS3 module
[Andrea Aime] Switching count to limit, some fixes on paths lookups
[...truncated 88.41 KB...]
T E S T S
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.394 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 20.337 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.008 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.074 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.353 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.761 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.135 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.048 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.069 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.735 sec
Tests run: 33, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 24.24 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.469 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.728 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.266 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.366 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.84 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.973 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.074 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.04 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.574 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.967 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.257 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.729 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.436 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.447 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.939 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.164 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.423 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.221 sec
Tests run: 10, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 26.47 sec <<< FAILURE!
testGetFeatureWithFilter(org.geoserver.test.PagingTest) Time elapsed: 18360 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.599 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.134 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.603 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.253 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.477 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.53 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.24 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.176 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.202 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.531 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.784 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.628 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.833 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.636 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.448 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.814 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.03 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.907 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.846 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.209 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.307 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.894 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.145 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.009 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.608 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.606 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.841 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.425 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.275 sec
Results :
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 2.889 s]
[INFO] Application Schema Integration Test ................ FAILURE [46:02 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.949 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [06:51 min]
[INFO] Total time: 53:06 min
[INFO] Finished at: 2018-05-10T21:32:14+00:00
[INFO] Final Memory: 55M/293M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Reverting the GEOT-5920 change fixes the PagingTest postgis failure.
PagingTest uses ogc:PropertyIsLike. Unusually, it places the literal before the property name:
<ogc:PropertyIsLike wildCard="*" singleChar="#" escapeChar="!">
<ogc:Literal>M*</ogc:Literal>
<ogc:PropertyName>gml:name</ogc:PropertyName>
</ogc:PropertyIsLike>
There is another one like this at DataReferenceWfsOnlineTest:878 in testFilteringNestedMultiValuedAttribute that also fails with the GEOT-5920 change.
Changing the order of these ogc:PropertyIsLike children so that ogc:PropertyName comes before ogc:Literal fixes both online tests (with postgis), even with the GEOT-5920 change.
https://github.com/geoserver/geoserver/pull/2879
I am guessing that SQL generation does not support this order after the GEOT-5920 change, but GeoTools LikeFilterImpl comparison does, leading to the pass running with the offline properties file fixture and a fail running online with postgis.
So, is this unusual order permitted and a bug in GeoTools or is this a bug in PagingTest and DataReferenceWfsOnlineTest? We should agree on this point before the pull request is merged.
Kind regards,
Ben.
Ian
On Thu, 10 May 2018, 10:51 Andrea Aime, <andrea.aime@anonymised.com>
wrote:
Hi Nuno,
one:
Director
New Zealand
Good catch, I’ll check the spec to see if either order is supported but since we used to allow it I think we should continue to.
I’ll add another test to GeoTools to catch this and see why my change broke it.
Ian
Ian Turton
I’ve checked the spec and a like filter contains a sequence of PropertyName and Literal - so technically the App-schema test is invalid but so is including a function (which is what I want to do).
But I can’t seem to create a test case where the like filter is created backwards I’ve taken a snippet of code from Ben’s test
String f = “<ogc:Filter xmlns:ogc="[http://www.opengis.net/ogc\](http://www.opengis.net/ogc\)”><ogc:PropertyIsLike wildCard="" singleChar="#" escapeChar="!">\n" +
"ogc:LiteralM
</ogc:Literal>\n" +
ogc:PropertyNamegml:name</ogc:PropertyName>\n” +
“</ogc:PropertyIsLike></ogc:Filter>”;
Configuration configuration = new org.geotools.filter.v1_0.OGCConfiguration();
Parser parser = new Parser( configuration );
Filter filter = (Filter) parser.parse( new ByteArrayInputStream(f.getBytes()) );
Document doc = encode(filter, OGC.Filter);
print(doc);
But that gives me the following filter:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<ogc:Filter xmlns:ogc=“http://www.opengis.net/ogc” xmlns:gml=“http://www.opengis.net/gml” xmlns:xs=“http://www.w3.org/2001/XMLSchema”>
<ogc:PropertyIsLike escape=“!” singleChar=“#” wildCard="">
ogc:LiteralM
</ogc:Literal>
</ogc:Filter>
With no PropertyName at all. So now I need to figure out how GeoServer builds the filter in a GetFeature query and how the PagingTest actually works.
Ian
PS note to self next time shoot yourself before messing with the XML :slight_smile:
Ian Turton
OK This should be resolved by https://github.com/geotools/geotools/pull/1889 which I’ll merge when the Travis tests pass.
I don’t have app-schema configured locally so I missed the issue in my local tests.
Ian
Ian Turton
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1161/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Updating Jackson to the latest stable release, 2.9.5
[Andrea Aime] Updating OpenAPI output to the latest version of the spec
[Andrea Aime] Remind users to expose primary keys when using the opensearch store
[Andrea Aime] Adding swagger dependencies to WFS3
[...truncated 90.88 KB...]
T E S T S
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.311 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.08 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.099 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.956 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.297 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.888 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.87 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.801 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.743 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.647 sec
Tests run: 33, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 24.263 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.426 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.626 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.457 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.334 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.819 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.76 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.934 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.951 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.803 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.673 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.879 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.202 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.937 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.656 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.607 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.912 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.098 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.869 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.704 sec
Tests run: 10, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 10.701 sec <<< FAILURE!
testGetFeatureWithFilter(org.geoserver.test.PagingTest) Time elapsed: 7624 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.713 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.102 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.53 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.497 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.499 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.435 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.306 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.351 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.091 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.635 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.027 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.069 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.021 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.647 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.305 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.83 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.816 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.144 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.111 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.872 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.037 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.792 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.094 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.278 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.488 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.618 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.693 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.935 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.029 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.199 sec
Results :
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 2.961 s]
[INFO] Application Schema Integration Test ................ FAILURE [45:58 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.842 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [06:01 min]
[INFO] Total time: 52:13 min
[INFO] Finished at: 2018-05-11T21:31:21+00:00
[INFO] Final Memory: 56M/327M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Ian, that works for me locally. Thanks!
The Jenkins geoserver-master-app-schema-online still failed because it ran on apollo-slave-02 and the geotools-master build with your change ran on apollo-slave-01 and we had forgotten to use the Maven "-U" option to force snapshot updates on geoserver-master-app-schema-online so it was using stale GeoTools snapshots. I added "-U" to geoserver-master-app-schema-online and kicked the build. (I also added it to geoserver-master-nightly.) We will soon see if this fixes the build.
Kind regards,
Ben.
which I'll merge when the Travis tests pass.
I don't have app-schema configured locally so I missed the issue in my
local tests.
Ian
On Fri, 11 May 2018 at 10:18, Ian Turton <ijturton@anonymised.com> wrote:
I've checked the spec and a like filter contains a sequence of
But I can't seem to create a test case where the like filter is created
backwards I've taken a snippet of code from Ben's test
String f = "<ogc:Filter xmlns:ogc=\"http://www.opengis.net/ogc\\&quot;&gt;&lt;ogc:PropertyIsLike
wildCard=\"*\" singleChar=\"#\" escapeChar=\"!\">\n" +
                 "<ogc:Literal>M*</ogc:Literal>\n" +
                 "<ogc:PropertyName>gml:name</ogc:PropertyName>\n" +
                 "</ogc:PropertyIsLike></ogc:Filter>";
         print(doc);
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:gml="
http://www.opengis.net/gml&quot; xmlns:xs="http://www.w3.org/2001/XMLSchema&quot;&gt;
<ogc:PropertyIsLike escape="!" singleChar="#" wildCard="*">
</ogc:Filter>
works.
Ian
On Fri, 11 May 2018 at 09:03, Ian Turton <ijturton@anonymised.com> wrote:
Good catch, I'll check the spec to see if either order is supported but
I'll add another test to GeoTools to catch this and see why my change
broke it.
Ian
On Fri, 11 May 2018 at 03:08, Ben Caradoc-Davies <ben@anonymised.com>
GEOT-5920 change.
Kind regards,
Ben.
Ian
wrote:
Hi Nuno,
this
one:
Director
New Zealand
Ian Turton
Ian Turton
Director
New Zealand
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1162/display/redirect&gt;
Build fixed now. Thanks again, Ian.
Kind regards,
Ben.
Kind regards,
Ben.
local tests.
Ian
print(doc);
</ogc:Filter>
works.
Ian
broke it.
Ian
GEOT-5920 change.
Kind regards,
Ben.
Ian
wrote:
Hi Nuno,
this
one:
Director
New Zealand
Ian Turton
Ian Turton
Director
New Zealand
Great, thanks for letting me know.
Ian
Ian Turton
