See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1658/display/redirect>
Started by timer
Running as SYSTEM
Building remotely on FleetCloud i-06c43034afa637239 (linux-fleet) in workspace <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/>
Unpacking https://github.com/AdoptOpenJDK/openjdk8-binaries/releases/download/jdk8u212-b03/OpenJDK8U-jdk_x64_linux_hotspot_8u212b03.tar.gz to /tmp/jenkins-e79b8454/tools/hudson.model.JDK/OpenJDK_8u212 on FleetCloud i-06c43034afa637239
No credentials specified
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/> # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision ebbd0c53669d8c4f55c7ac90d4ab1dee7ce77b65 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f ebbd0c53669d8c4f55c7ac90d4ab1dee7ce77b65
Commit message: "Merge pull request #3773 from aaime/ogcapi_crosslink"
> git rev-list --no-walk ebbd0c53669d8c4f55c7ac90d4ab1dee7ce77b65 # timeout=10
Copied 1 artifact from "ojdbc7" build number 3
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins13462840641519449956.sh
+ mkdir /home/ubuntu/.geoserver
+ rm /home/ubuntu/.geotools/postgis.properties
rm: cannot remove '/home/ubuntu/.geotools/postgis.properties': No such file or directory
+ true
+ rm /home/ubuntu/.geotools/oracle.properties
rm: cannot remove '/home/ubuntu/.geotools/oracle.properties': No such file or directory
+ true
+ rm /home/ubuntu/.geoserver/postgis.properties
rm: cannot remove '/home/ubuntu/.geoserver/postgis.properties': No such file or directory
+ true
+ rm /home/ubuntu/.geoserver/oracle.properties
rm: cannot remove '/home/ubuntu/.geoserver/oracle.properties': No such file or directory
+ true
+ set +x
could not change directory to "<https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/">: Permission denied
psql: could not connect to server: No such file or directory
Is the server running locally and accepting
connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
psql: could not connect to server: Connection refused
Is the server running on host "localhost" (127.0.0.1) and accepting
TCP/IP connections on port 5432?
Build step 'Execute shell' marked build as failure
