See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/327/changes>
Changes:
[ben] Revert "Print ResourceTest HTML responses as Strings before parsing to debug parse failure on Windows"
[ben] Fix gs-restconfig ResourceTest on Windows [GEOS-7407/GSIP-137]
[...truncated 593 lines...]
961/961 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data/15-SNAPSHOT/maven-metadata.xml (961 B at 1.5 KB/sec)
Downloading: http://www.hibernatespatial.org/repository/org/geotools/jdbc/gt-jdbc-postgis/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/jdbc/gt-jdbc-postgis/15-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-postgis/15-SNAPSHOT/maven-metadata.xml
967/967 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-postgis/15-SNAPSHOT/maven-metadata.xml (967 B at 1.4 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/jdbc/gt-jdbc/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/jdbc/gt-jdbc/15-SNAPSHOT/maven-metadata.xml
576/576 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc/15-SNAPSHOT/maven-metadata.xml (576 B at 0.9 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/jdbc/gt-jdbc-oracle/15-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-oracle/15-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geotools/jdbc/gt-jdbc-oracle/15-SNAPSHOT/maven-metadata.xml
966/966 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-oracle/15-SNAPSHOT/maven-metadata.xml (966 B at 1.4 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geoserver/web/gs-web-core/2.9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/web/gs-web-core/2.9-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geoserver/web/gs-web-core/2.9-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geoserver/web/gs-web-core/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 12.7 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geoserver/web/2.9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/web/2.9-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geoserver/web/2.9-SNAPSHOT/maven-metadata.xml
784/784 B
Downloaded: https://repo.boundlessgeo.com/main/org/geoserver/web/2.9-SNAPSHOT/maven-metadata.xml (784 B at 6.0 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geoserver/web/gs-web-demo/2.9-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geoserver/web/gs-web-demo/2.9-SNAPSHOT/maven-metadata.xml
Downloading: http://www.hibernatespatial.org/repository/org/geoserver/web/gs-web-demo/2.9-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: https://repo.boundlessgeo.com/main/org/geoserver/web/gs-web-demo/2.9-SNAPSHOT/maven-metadata.xml (2 KB at 1.5 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-test ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-app-schema-test ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-app-schema-test ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Fix gs-restconfig ResourceTest on Windows [GEOS-7407/GSIP-137]
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 17.02.2016 @ 05:20:57 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 17-Feb-2016 20:40
[INFO] [GitCommitIdMojo] build.build.time = 17.02.2016 @ 20:40:50 UTC
[INFO] [GitCommitIdMojo] build.branch = 3f26c66017e665b9ebbfc2b14f8f196371104ac8
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3f26c66
[INFO] [GitCommitIdMojo] build.commit.id = 3f26c66017e665b9ebbfc2b14f8f196371104ac8
[INFO] [GitCommitIdMojo] build.commit.message.full = Fix gs-restconfig ResourceTest on Windows [GEOS-7407/GSIP-137]
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-test ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/main/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-test ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-test ---
[INFO] Copying 139 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-test ---
[INFO] Compiling 128 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/target/test-classes>
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] error: error reading /var/lib/jenkins/.m2/repository/org/geotools/gt-coverage/15-SNAPSHOT/gt-coverage-15-SNAPSHOT.jar; error in opening zip file
[INFO] 1 error
[INFO]
[INFO] Building Sample DataAccess Integration Test 2.9-SNAPSHOT
Downloading: http://www.hibernatespatial.org/repository/org/geotools/gt-sample-data-access/15-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data-access/15-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-sample-data-access/15-SNAPSHOT/maven-metadata.xml
968/968 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data-access/15-SNAPSHOT/maven-metadata.xml (968 B at 1.6 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-sample-data-access-test ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-sample-data-access-test ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-sample-data-access-test ---
[INFO] [GitCommitIdMojo] build.build.time = 17.02.2016 @ 20:40:52 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-sample-data-access-test ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/src/main/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-sample-data-access-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sample-data-access-test ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sample-data-access-test ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/target/test-classes>
[INFO] 1 error
[INFO]
[INFO] Building Application Schema Integration Online Test with Postgis Database 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-postgis-test ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-app-schema-postgis-test ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-app-schema-postgis-test ---
[INFO] [GitCommitIdMojo] build.build.time = 17.02.2016 @ 20:40:54 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-postgis-test ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/src/main/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-postgis-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-postgis-test ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-postgis-test ---
[INFO] Compiling 128 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/test-classes>
[INFO] 1 error
[INFO] Reactor Summary:
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 1.573 s]
[INFO] Application Schema Integration Test ................ FAILURE [ 36.028 s]
[INFO] Sample DataAccess Integration Test ................. FAILURE [ 1.698 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [ 1.737 s]
[INFO] BUILD FAILURE
[INFO] Total time: 43.745 s
[INFO] Finished at: 2016-02-17T20:40:55+00:00
[INFO] Final Memory: 63M/334M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-app-schema-test: Compilation failure
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-sample-data-access-test: Compilation failure
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-app-schema-postgis-test: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
