[Geoserver-devel] Build failed in Jenkins: geoserver-master-app-schema-online #742
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/742/&gt;
[...truncated 918 lines...]
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-postgis-test ---
[INFO] Compiling 130 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/test-classes&gt;
[WARNING] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java&gt;:\[26,21\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java&gt;:\[159,11\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java&gt;:\[165,12\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java&gt;:\[165,39\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-app-schema-postgis-test ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports&gt;
T E S T S
Running org.geoserver.test.BBox3DTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 18.545 sec
Running org.geoserver.test.BBoxFilterTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.765 sec
Running org.geoserver.test.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.03 sec
Running org.geoserver.test.DefaultIdTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.567 sec
Running org.geoserver.test.DuplicatePropertiesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.856 sec
Running org.geoserver.test.DuplicateTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 21.518 sec
Running org.geoserver.test.EncodeIfEmptyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.332 sec
Running org.geoserver.test.FeatureChainingWfsTest
Tests run: 27, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.218 sec
Running org.geoserver.test.FeatureGML32Test
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.115 sec
Running org.geoserver.test.GUChainNoIDMFTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.682 sec
Running org.geoserver.test.GetPropertyValueTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.827 sec
Running org.geoserver.test.Gsml30WfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.806 sec
Running org.geoserver.test.Gsml32BoreholeIntervalWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.696 sec
Running org.geoserver.test.Gsml32BoreholeWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.707 sec
Running org.geoserver.test.IdFunctionWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.067 sec
Running org.geoserver.test.IdFunctionWfsWithJoiningTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.935 sec
Running org.geoserver.test.IdNotEncodedTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.791 sec
Running org.geoserver.test.InvalidColumnTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.392 sec
Running org.geoserver.test.LocalResolveFeatureChainingByRefTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.89 sec
Running org.geoserver.test.LocalResolveTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.729 sec
Running org.geoserver.test.MappingNameTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.704 sec
Running org.geoserver.test.MeasureTypeBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.273 sec
Running org.geoserver.test.MultivaluedXlinkHrefTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.775 sec
Running org.geoserver.test.NestedIdSupportTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.993 sec
Running org.geoserver.test.Observation_2_0_WfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.612 sec
Running org.geoserver.test.PagingTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.242 sec
Running org.geoserver.test.PolymorphismInlineWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.101 sec
Running org.geoserver.test.PolymorphismWfsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.287 sec
Running org.geoserver.test.PropertyEncodingOrderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.599 sec
Running org.geoserver.test.PropertySelectionTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.723 sec
Running org.geoserver.test.Reprojection3DTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.816 sec
Running org.geoserver.test.RestconfigWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.14 sec
Running org.geoserver.test.SRSReprojectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.747 sec
Running org.geoserver.test.SRSWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.876 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.881 sec
Running org.geoserver.test.SecondaryNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.285 sec
Running org.geoserver.test.SecuredFeatureChainingTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.394 sec
Running org.geoserver.test.SimpleAttributeFeatureChainWfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.443 sec
Running org.geoserver.test.SortByTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.954 sec
Running org.geoserver.test.SpecimenWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.376 sec
Running org.geoserver.test.StringConstantIdWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.848 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.454 sec
Running org.geoserver.test.TimeSeriesInlineWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.08 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.455 sec
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.135 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.9 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.264 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.229 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.863 sec
Running org.geoserver.test.XPathPredicateTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.686 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.065 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.818 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.662 sec
Running org.geoserver.test.web.Gml311LinksTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 7.122 sec <<< FAILURE!
testGml311Links(org.geoserver.test.web.Gml311LinksTest) Time elapsed: 7113 sec <<< ERROR!
java.lang.NoClassDefFoundError: org/geoserver/web/demo/MapPreviewPage
  at org.geoserver.test.web.AbstractMapPreviewPageTest.testAppSchemaGmlLinks(AbstractMapPreviewPageTest.java:30)
  at org.geoserver.test.web.Gml311LinksTest.testGml311Links(Gml311LinksTest.java:32)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
Caused by: java.lang.ClassNotFoundException: org.geoserver.web.demo.MapPreviewPage
  at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
  at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
  ... 36 more
Running org.geoserver.test.web.Gml32LinksTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.584 sec <<< FAILURE!
testGml32Links(org.geoserver.test.web.Gml32LinksTest) Time elapsed: 1578 sec <<< ERROR!
  at org.geoserver.test.web.Gml32LinksTest.testGml32Links(Gml32LinksTest.java:27)
Results :
Tests in error:
  testGml311Links(org.geoserver.test.web.Gml311LinksTest): org/geoserver/web/demo/MapPreviewPage
  testGml32Links(org.geoserver.test.web.Gml32LinksTest): org/geoserver/web/demo/MapPreviewPage
Tests run: 182, Failures: 0, Errors: 2, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 5.823 s]
[INFO] Application Schema Integration Test ................ FAILURE [09:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 15.232 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [03:26 min]
[INFO] BUILD FAILURE
[INFO] Total time: 13:37 min
[INFO] Finished at: 2017-03-31T21:50:21+00:00
[INFO] Final Memory: 55M/570M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-postgis-test: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/743/&gt;
