[...truncated 2520 lines...]
[DEBUG] adding entry org/geoserver/importer/mosaic/MosaicIndex.java
[DEBUG] adding entry org/geoserver/importer/mosaic/TimeHandler.java
[DEBUG] adding entry org/geoserver/importer/mosaic/TimeMode.java
[DEBUG] adding entry org/geoserver/importer/RasterFormat.java
[DEBUG] adding entry org/geoserver/importer/RemoteData.java
[DEBUG] adding entry org/geoserver/importer/SpatialFile.java
[DEBUG] adding entry org/geoserver/importer/Table.java
[DEBUG] adding entry org/geoserver/importer/transform/AbstractCommandLineTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/AbstractInlineVectorTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/AbstractTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/AttributeRemapTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/AttributesToPointGeometryTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/CreateIndexTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/DateFormatTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/GdalAddoTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/GdalTranslateTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/GdalWarpTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/ImportTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/InlineVectorTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/IntegerFieldToDateTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/KMLPlacemarkTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/NumberFormatTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/PostTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/PreTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/RasterTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/RasterTransformChain.java
[DEBUG] adding entry org/geoserver/importer/transform/ReprojectTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/TransformChain.java
[DEBUG] adding entry org/geoserver/importer/transform/VectorTransform.java
[DEBUG] adding entry org/geoserver/importer/transform/VectorTransformChain.java
[DEBUG] adding entry org/geoserver/importer/UpdateMode.java
[DEBUG] adding entry org/geoserver/importer/ValidationException.java
[DEBUG] adding entry org/geoserver/importer/VectorFormat.java
[DEBUG] adding entry org/geoserver/importer/VFSWorker.java
[DEBUG] adding entry applicationContext.xml
[DEBUG] adding entry org/geoserver/importer/oracle_reserved_words.txt
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-core ---
[DEBUG] Configuring mojo pl.project13.maven:git-commit-id-plugin:2.0.4:revision from plugin realm ClassRealm[plugin>pl.project13.maven:git-commit-id-plugin:2.0.4, parent: sun.misc.Launcher$AppClassLoader@anonymised.com]
[DEBUG] Configuring mojo 'pl.project13.maven:git-commit-id-plugin:2.0.4:revision' with basic configurator -->
[DEBUG] (s) dateFormat = dd.MM.yyyy '@' HH:mm:ss z
[DEBUG] (s) dotGitDirectory = C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\.git
[DEBUG] (f) failOnNoGitDirectory = false
[DEBUG] (f) generateGitPropertiesFile = false
[DEBUG] (f) generateGitPropertiesFilename = src/main/resources/git.properties
[DEBUG] (s) prefix = build
[DEBUG] (f) project = MavenProject: org.geoserver.importer:gs-importer-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\pom.xml
[DEBUG] (f) skipPoms = false
[DEBUG] (s) verbose = false
[DEBUG] -- end configuration --
[INFO] [GitCommitIdMojo] Running on 'c:\.jenkins\jobs\GeoServer-Master\workspace\.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1394 from dpovey/geos-2613-2
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 13.01.2016 @ 21:57:25 CET
[INFO] [GitCommitIdMojo] build.timestamp = 14-gen-2016 11:00
[INFO] [GitCommitIdMojo] build.build.time = 14.01.2016 @ 08:56:48 CET
[INFO] [GitCommitIdMojo] build.branch = 04d22551daf1518bfbb7bcecf6d9d94b6bba51ff
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 04d2255
[INFO] [GitCommitIdMojo] build.commit.id = 04d22551daf1518bfbb7bcecf6d9d94b6bba51ff
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1394 from dpovey/geos-2613-2
[GEOS-2613] GeoJSON support for setting decimal places.
[WARNING] Failed to getClass for org.apache.maven.plugin.source.TestSourceJarMojo
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-importer-core ---
[DEBUG] Configuring mojo org.apache.maven.plugins:maven-source-plugin:2.2.1:test-jar from plugin realm ClassRealm[plugin>org.apache.maven.plugins:maven-source-plugin:2.2.1, parent: sun.misc.Launcher$AppClassLoader@anonymised.com]
[DEBUG] Configuring mojo 'org.apache.maven.plugins:maven-source-plugin:2.2.1:test-jar' with basic configurator -->
[DEBUG] (f) attach = true
[DEBUG] (f) classifier = test-sources
[DEBUG] (f) defaultManifestFile = C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\target\classes\META-INF\MANIFEST.MF
[DEBUG] (f) excludeResources = false
[DEBUG] (f) finalName = gs-importer-core-2.9-SNAPSHOT
[DEBUG] (f) forceCreation = false
[DEBUG] (f) includePom = false
[DEBUG] (f) outputDirectory = C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\target
[DEBUG] (f) reactorProjects = [MavenProject: org.geoserver:geoserver:2.9-SNAPSHOT @ c:\.jenkins\jobs\GeoServer-Master\workspace\src\pom.xml, MavenProject: org.geoserver:gs-platform:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\platform\pom.xml, MavenProject: org.geoserver:gs-ows:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\ows\pom.xml, MavenProject: org.geoserver:gs-main:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\main\pom.xml, MavenProject: org.geoserver:gs-security:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\security\pom.xml, MavenProject: org.geoserver.security:gs-sec-jdbc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\security\jdbc\pom.xml, MavenProject: org.geoserver.security:gs-sec-ldap:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\security\ldap\pom.xml, MavenProject: org.geoserver:gs-wcs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wcs\pom.xml, MavenProject: org.geoserver:gs-wcs1_0:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wcs1_0\pom.xml, MavenProject: org.geoserver:gs-wcs1_1:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wcs1_1\pom.xml, MavenProject: org.geoserver:gs-wcs2_0:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wcs2_0\pom.xml, MavenProject: org.geoserver:gs-wfs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\pom.xml, MavenProject: org.geoserver:gs-wms:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wms\pom.xml, MavenProject: org.geoserver:gs-kml:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\kml\pom.xml, MavenProject: org.geoserver:gs-gwc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\gwc\pom.xml, MavenProject: org.geoserver:gs-rest:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\rest\pom.xml, MavenProject: org.geoserver:gs-restconfig:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\restconfig\pom.xml, MavenProject: org.geoserver:web:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\pom.xml, MavenProject: org.geoserver.web:gs-web-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\core\pom.xml, MavenProject: org.geoserver.web:gs-web-wms:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\wms\pom.xml, MavenProject: org.geoserver.web:gs-web-gwc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\pom.xml, MavenProject: org.geoserver.web:gs-web-wfs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\wfs\pom.xml, MavenProject: org.geoserver.web:gs-web-demo:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\demo\pom.xml, MavenProject: org.geoserver.web:gs-web-wcs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\wcs\pom.xml, MavenProject: org.geoserver.web:gs-web-sec:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\security\pom.xml, MavenProject: org.geoserver.web:gs-web-sec-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\security\core\pom.xml, MavenProject: org.geoserver.web:gs-web-sec-jdbc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\security\jdbc\pom.xml, MavenProject: org.geoserver.web:gs-web-sec-ldap:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\security\ldap\pom.xml, MavenProject: org.geoserver.web:gs-web-rest:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\rest\pom.xml, MavenProject: org.geoserver.web:gs-web-app:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\app\pom.xml, MavenProject: org.geoserver:community:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\community\pom.xml, MavenProject: org.geoserver:extension:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\pom.xml, MavenProject: org.geoserver.extension:gs-app-schema:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\pom.xml, MavenProject: org.geoserver.extension:gs-app-schema-test:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\pom.xml, MavenProject: org.geoserver.extension:gs-sample-data-access-test:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\sample-data-access-test\pom.xml, MavenProject: org.geoserver.extension:gs-arcsde:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\arcsde\pom.xml, MavenProject: org.geoserver.extension:gs-geosearch:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\geosearch\pom.xml, MavenProject: org.geoserver.extension:gs-h2:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\h2\pom.xml, MavenProject: org.geoserver.extension:gs-sqlserver:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\sqlserver\pom.xml, MavenProject: org.geoserver.extension:gs-oracle:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\oracle\pom.xml, MavenProject: org.geoserver.extension:gs-mysql:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\mysql\pom.xml, MavenProject: org.geoserver.extension:gs-db2:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\db2\pom.xml, MavenProject: org.geoserver.extension:gs-imagemap:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\imagemap\pom.xml, MavenProject: org.geoserver.extension:gs-gdal:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\gdal\pom.xml, MavenProject: org.geoserver.extension:gs-jp2k:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\jp2k\pom.xml, MavenProject: org.geoserver.extension:gs-ogr:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\ogr\pom.xml, MavenProject: org.geoserver.extension:gs-ogr-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\ogr\ogr-core\pom.xml, MavenProject: org.geoserver.extension:gs-ogr-wfs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\ogr\ogr-wfs\pom.xml, MavenProject: org.geoserver.extension:gs-wps:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\pom.xml, MavenProject: org.geoserver.extension:gs-wps-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-core\pom.xml, MavenProject: org.geoserver.extension:gs-ogr-wps:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\ogr\ogr-wps\pom.xml, MavenProject: org.geoserver.extension:gs-excel:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\excel\pom.xml, MavenProject: org.geoserver.extension:gs-charts:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\charts\pom.xml, MavenProject: org.geoserver.extension:gs-feature-pregeneralized:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\feature-pregeneralized\pom.xml, MavenProject: org.geoserver.extension:gs-imagemosaic-jdbc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\imagemosaic-jdbc\pom.xml, MavenProject: org.geoserver.extension:gs-control-flow:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\control-flow\pom.xml, MavenProject: org.geoserver.extension:gs-wps-cluster-hazelcast:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-cluster-hazelcast\pom.xml, MavenProject: org.geoserver.extension:gs-web-wps:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\web-wps\pom.xml, MavenProject: org.geoserver.extension:gs-querylayer:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\querylayer\pom.xml, MavenProject: org.geoserver.extension:gs-teradata:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\teradata\pom.xml, MavenProject: org.geoserver.extension:gs-monitor:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\monitor\pom.xml, MavenProject: org.geoserver.extension:gs-monitor-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\monitor\core\pom.xml, MavenProject: org.geoserver.extension:gs-monitor-hibernate:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\monitor\hibernate\pom.xml, MavenProject: org.geoserver.extension:gs-security:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\security\pom.xml, MavenProject: org.geoserver.security:gs-sec-cas:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\security\cas\pom.xml, MavenProject: org.geoserver.extension:gs-web-sec:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\security\web\pom.xml, MavenProject: org.geoserver.security:gs-web-sec-cas:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\security\web\web-cas\pom.xml, MavenProject: org.geoserver:gs-xslt:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\xslt\pom.xml, MavenProject: org.geoserver.extension:gs-inspire:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\inspire\pom.xml, MavenProject: org.geoserver.extension:gs-css:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\css\pom.xml, MavenProject: org.geoserver:gs-csw:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\pom.xml, MavenProject: org.geoserver.csw:gs-csw-api:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\api\pom.xml, MavenProject: org.geoserver.csw:gs-csw-simple-store:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\simple-store\pom.xml, MavenProject: org.geoserver.csw:gs-csw-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\core\pom.xml, MavenProject: org.geoserver.csw:gs-web-csw:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\web-csw\pom.xml, MavenProject: org.geoserver.extension:gs-dxf:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\dxf\pom.xml, MavenProject: org.geoserver.extension:gs-dxf-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\dxf\core\pom.xml, MavenProject: org.geoserver.extension:gs-dxf-wps:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\dxf\wps\pom.xml, MavenProject: org.geoserver.extension:gs-printing:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\printing\pom.xml, MavenProject: org.geoserver.extension:gs-wcs2_0-eo:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wcs2_0-eo\pom.xml, MavenProject: org.geoserver.extension:gs-wcs2_0-eo-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wcs2_0-eo\core\pom.xml, MavenProject: org.geoserver.extension:gs-web-wcs2_0-eo:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wcs2_0-eo\web\pom.xml, MavenProject: org.geoserver.extension:gs-libjpeg-turbo:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\libjpeg-turbo\pom.xml, MavenProject: org.geoserver:gs-importer:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\pom.xml, MavenProject: org.geoserver.importer:gs-importer-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\pom.xml, MavenProject: org.geoserver.importer:gs-importer-rest:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\rest\pom.xml, MavenProject: org.geoserver.importer:gs-importer-bdb:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\bdb\pom.xml, MavenProject: org.geoserver.importer:gs-importer-web:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\web\pom.xml, MavenProject: org.geoserver.extension:gs-grib:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\grib\pom.xml, MavenProject: org.geoserver.extension:gs-netcdf:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\netcdf\pom.xml, MavenProject: org.geoserver.extension:gs-netcdf-out:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\netcdf-out\pom.xml, MavenProject: org.geoserver:gs-release:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\release\pom.xml]
[DEBUG] (f) skipSource = false
[DEBUG] (f) useDefaultExcludes = true
[DEBUG] (f) useDefaultManifestFile = false
[DEBUG] isUp2date: false (Destination C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\target\gs-importer-core-2.9-SNAPSHOT-test-sources.jar not found.)
[INFO] Building jar: C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\target\gs-importer-core-2.9-SNAPSHOT-test-sources.jar
[DEBUG] adding directory META-INF/
[DEBUG] adding entry META-INF/MANIFEST.MF
[DEBUG] adding directory org/
[DEBUG] adding directory org/geoserver/
[DEBUG] adding directory org/geoserver/importer/
[DEBUG] adding directory org/geoserver/importer/format/
[DEBUG] adding directory org/geoserver/importer/mosaic/
[DEBUG] adding directory org/geoserver/importer/transform/
[DEBUG] adding entry org/geoserver/importer/DataFormatTest.java
[DEBUG] adding entry org/geoserver/importer/DatesTest.java
[DEBUG] adding entry org/geoserver/importer/DirectoryTest.java
[DEBUG] adding entry org/geoserver/importer/FeatureDataConverterTest.java
[DEBUG] adding entry org/geoserver/importer/format/GMLFileFormatTest.java
[DEBUG] adding entry org/geoserver/importer/format/KMLFileFormatTest.java
[DEBUG] adding entry org/geoserver/importer/ImportContextTest.java
[DEBUG] adding entry org/geoserver/importer/ImporterDataTest.java
[DEBUG] adding entry org/geoserver/importer/ImporterDbTestBase.java
[DEBUG] adding entry org/geoserver/importer/ImporterDbTestSupport.java
[DEBUG] adding entry org/geoserver/importer/ImporterTest.java
[DEBUG] adding entry org/geoserver/importer/ImporterTestSupport.java
[DEBUG] adding entry org/geoserver/importer/ImporterTestUtils.java
[DEBUG] adding entry org/geoserver/importer/ImportTransformTest.java
[DEBUG] adding entry org/geoserver/importer/MemoryImportStoreTest.java
[DEBUG] adding entry org/geoserver/importer/mosaic/ImporterMosaicTest.java
[DEBUG] adding entry org/geoserver/importer/OracleImportTest.java
[DEBUG] adding entry org/geoserver/importer/SQLServerImportTest.java
[DEBUG] adding entry org/geoserver/importer/transform/GdalTransformTest.java
[DEBUG] adding entry org/geoserver/importer/transform/KMLPlacemarkTransformTest.java
[DEBUG] adding entry org/geoserver/importer/transform/TransformTest.java
[DEBUG] adding directory org/geoserver/importer/test-data/
[DEBUG] adding directory org/geoserver/importer/test-data/csv/
[DEBUG] adding directory org/geoserver/importer/test-data/geojson/
[DEBUG] adding directory org/geoserver/importer/test-data/geotiff/
[DEBUG] adding directory org/geoserver/importer/test-data/gml/
[DEBUG] adding directory org/geoserver/importer/test-data/h2/
[DEBUG] adding directory org/geoserver/importer/test-data/kml/
[DEBUG] adding directory org/geoserver/importer/test-data/mosaic/
[DEBUG] adding directory org/geoserver/importer/test-data/random/
[DEBUG] adding directory org/geoserver/importer/test-data/shape/
[DEBUG] adding entry org/geoserver/importer/test-data/csv/locations.zip
[DEBUG] adding entry org/geoserver/importer/test-data/geojson/jagged.json
[DEBUG] adding entry org/geoserver/importer/test-data/geojson/line.json.zip
[DEBUG] adding entry org/geoserver/importer/test-data/geojson/point.json.zip
[DEBUG] adding entry org/geoserver/importer/test-data/geojson/polygon.json.zip
[DEBUG] adding entry org/geoserver/importer/test-data/geotiff/box_gcp_fixed.tif.bz2
[DEBUG] adding entry org/geoserver/importer/test-data/geotiff/EmissiveCampania.tif.bz2
[DEBUG] adding entry org/geoserver/importer/test-data/gml/poi.gml2.gml
[DEBUG] adding entry org/geoserver/importer/test-data/gml/poi.gml3.gml
[DEBUG] adding entry org/geoserver/importer/test-data/gml/states.gml2.gml
[DEBUG] adding entry org/geoserver/importer/test-data/gml/states.gml2.xsd
[DEBUG] adding entry org/geoserver/importer/test-data/gml/states.gml3.gml
[DEBUG] adding entry org/geoserver/importer/test-data/gml/states.gml3.xsd
[DEBUG] adding entry org/geoserver/importer/test-data/gml/streams.gml2.gml
[DEBUG] adding entry org/geoserver/importer/test-data/gml/streams.gml3.gml
[DEBUG] adding entry org/geoserver/importer/test-data/h2/cookbook.zip
[DEBUG] adding entry org/geoserver/importer/test-data/kml/sample.zip
[DEBUG] adding entry org/geoserver/importer/test-data/mosaic/bm.zip
[DEBUG] adding entry org/geoserver/importer/test-data/mosaic/bm_time.zip
[DEBUG] adding entry org/geoserver/importer/test-data/random/random.dat
[DEBUG] adding entry org/geoserver/importer/test-data/shape/archsites_epsg_prj.zip
[DEBUG] adding entry org/geoserver/importer/test-data/shape/archsites_no_crs.zip
[DEBUG] adding entry org/geoserver/importer/test-data/shape/bugsites_esri_prj.tar.gz
[DEBUG] adding entry org/geoserver/importer/test-data/shape/ivan.zip
[DEBUG] adding entry org/geoserver/importer/test-data/shape/ming_time.zip
[DEBUG] adding entry org/geoserver/importer/test-data/shape/readme.txt
[DEBUG] adding entry org/geoserver/importer/test-data/shape/restricted.zip
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-importer-core ---
[DEBUG] Configuring mojo org.apache.maven.plugins:maven-dependency-plugin:2.1:copy-dependencies from plugin realm ClassRealm[plugin>org.apache.maven.plugins:maven-dependency-plugin:2.1, parent: sun.misc.Launcher$AppClassLoader@anonymised.com]
[DEBUG] Configuring mojo 'org.apache.maven.plugins:maven-dependency-plugin:2.1:copy-dependencies' with basic configurator -->
[DEBUG] (s) copyPom = false
[DEBUG] (f) excludeTransitive = false
[DEBUG] (s) failOnMissingClassifierArtifact = true
[DEBUG] (f) includeArtifactIds = gt-api,gwc-core
[DEBUG] (f) includeGroupIds = org.geotools,org.geowebcache
[DEBUG] (s) local = id: local
url: file:///C:/Windows/system32/config/systemprofile/.m2/repository/
layout: none
[DEBUG] (s) markersDirectory = C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\target\dependency-maven-plugin-markers
[DEBUG] (f) outputAbsoluteArtifactFilename = false
[DEBUG] (s) outputDirectory = C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\target\dependency
[DEBUG] (f) overWriteIfNewer = true
[DEBUG] (f) overWriteReleases = false
[DEBUG] (f) overWriteSnapshots = false
[DEBUG] (s) remoteRepos = [ id: boundless
url: https://repo.boundlessgeo.com/main/
layout: default
snapshots: [enabled => true, update => daily]
releases: [enabled => true, update => daily]
, id: osgeo
url: http://download.osgeo.org/webdav/geotools/
layout: default
, id: maven-restlet
url: http://maven.restlet.org
layout: default
snapshots: [enabled => false, update => daily]
, id: hibspat
url: http://www.hibernatespatial.org/repository
layout: default
, id: central
url: http://repo.maven.apache.org/maven2
layout: default
[DEBUG] (f) silent = false
[DEBUG] (s) stripVersion = false
[DEBUG] (f) type = java-source
[DEBUG] (s) useRepositoryLayout = false
[DEBUG] (s) useSubDirectoryPerArtifact = false
[DEBUG] (s) useSubDirectoryPerType = false
[INFO] Copying gt-api-15-SNAPSHOT.jar to C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\target\dependency\gt-api-15-SNAPSHOT.jar
[INFO] Copying gwc-core-1.9-SNAPSHOT.jar to C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\target\dependency\gwc-core-1.9-SNAPSHOT.jar
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-importer-core ---
[DEBUG] Configuring mojo org.apache.maven.plugins:maven-install-plugin:2.3.1:install from plugin realm ClassRealm[plugin>org.apache.maven.plugins:maven-install-plugin:2.3.1, parent: sun.misc.Launcher$AppClassLoader@anonymised.com]
[DEBUG] Configuring mojo 'org.apache.maven.plugins:maven-install-plugin:2.3.1:install' with basic configurator -->
[DEBUG] (f) artifact = org.geoserver.importer:gs-importer-core:jar:2.9-SNAPSHOT
[DEBUG] (f) attachedArtifacts = [org.geoserver.importer:gs-importer-core:test-jar:tests:2.9-SNAPSHOT, org.geoserver.importer:gs-importer-core:java-source:sources:2.9-SNAPSHOT, org.geoserver.importer:gs-importer-core:java-source:test-sources:2.9-SNAPSHOT]
[DEBUG] (f) createChecksum = false
[DEBUG] (f) localRepository = id: local
layout: none
[DEBUG] (f) packaging = jar
[DEBUG] (f) pomFile = C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\pom.xml
[DEBUG] (f) updateReleaseInfo = false
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\target\gs-importer-core-2.9-SNAPSHOT.jar to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\importer\gs-importer-core\2.9-SNAPSHOT\gs-importer-core-2.9-SNAPSHOT.jar
[DEBUG] Writing resolution tracking file C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\importer\gs-importer-core\2.9-SNAPSHOT\_maven.repositories
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\pom.xml to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\importer\gs-importer-core\2.9-SNAPSHOT\gs-importer-core-2.9-SNAPSHOT.pom
[DEBUG] Installing org.geoserver.importer:gs-importer-core:2.9-SNAPSHOT/maven-metadata.xml to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\importer\gs-importer-core\2.9-SNAPSHOT\maven-metadata-local.xml
[DEBUG] Installing org.geoserver.importer:gs-importer-core/maven-metadata.xml to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\importer\gs-importer-core\maven-metadata-local.xml
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\target\gs-importer-core-2.9-SNAPSHOT-tests.jar to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\importer\gs-importer-core\2.9-SNAPSHOT\gs-importer-core-2.9-SNAPSHOT-tests.jar
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\target\gs-importer-core-2.9-SNAPSHOT-sources.jar to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\importer\gs-importer-core\2.9-SNAPSHOT\gs-importer-core-2.9-SNAPSHOT-sources.jar
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\target\gs-importer-core-2.9-SNAPSHOT-test-sources.jar to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\importer\gs-importer-core\2.9-SNAPSHOT\gs-importer-core-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving disabled
