[Geoserver-devel] Build failed in Jenkins: geoserver-master-live-docs #1819
See <http://build.geoserver.org/job/geoserver-master-live-docs/1819/display/redirect&gt;
[...truncated 383.50 KB...]
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom
Progress (1): 861 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom (861 B at 123 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom
Progress (1): 761 B Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom (761 B at 152 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom
Progress (1): 138 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom (138 B at 20 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom
Progress (1): 643 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom (643 B at 129 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom
Progress (1): 2.2/12 kBProgress (1): 5.0/12 kBProgress (1): 7.8/12 kBProgress (1): 11/12 kB Progress (1): 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom (12 kB at 2.0 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom
Progress (1): 1.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom (1.8 kB at 460 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom (1.6 kB at 406 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom
Progress (1): 2.2/2.7 kBProgress (1): 2.7 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom (2.7 kB at 678 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom
Progress (1): 767 B Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom (767 B at 192 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom
Progress (1): 1.2 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom (1.2 kB at 309 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom
Progress (1): 998 B Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom (998 B at 333 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom (1.6 kB at 404 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom
Progress (1): 1.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom (1.4 kB at 151 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom
Progress (1): 1.5 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom (1.5 kB at 165 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom
Progress (1): 765 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom (765 B at 255 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom
Progress (1): 2.2/5.3 kBProgress (1): 5.0/5.3 kBProgress (1): 5.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom (5.3 kB at 1.3 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom (9.8 kB at 490 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom
Progress (1): 2.2/2.4 kBProgress (1): 2.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom (2.4 kB at 340 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom
Progress (1): 2.2/4.4 kBProgress (1): 4.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom (4.4 kB at 1.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom (9.8 kB at 1.6 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar
Progress (1): 2.2/109 kBProgress (1): 5.0/109 kBProgress (1): 7.7/109 kBProgress (1): 10/109 kB Progress (1): 13/109 kBProgress (1): 16/109 kBProgress (1): 19/109 kBProgress (1): 21/109 kBProgress (1): 24/109 kBProgress (2): 24/109 kB | 2.2/8.3 kBProgress (2): 27/109 kB | 2.2/8.3 kBProgress (2): 27/109 kB | 5.0/8.3 kBProgress (2): 27/109 kB | 7.7/8.3 kBProgress (3): 27/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 30/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 30/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 32/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 32/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 32/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 32/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 36/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 36/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 40/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 45/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 45/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 49/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 49/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 49/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 49/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 49/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (3): 49/109 kB | 7.7/8.3 kB | 0/1.0 MBProgress (4): 49/109 kB | 7.7/8.3 kB | 0/1.0 MB | 2.2/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0/1.0 MB | 5.0/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0/1.0 MB | 5.0/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0/1.0 MB | 7.7/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0/1.0 MB | 7.7/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0/1.0 MB | 7.7/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0/1.0 MB | 10/224 kB Progress (4): 49/109 kB | 7.7/8.3 kB | 0/1.0 MB | 10/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0/1.0 MB | 13/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0/1.0 MB | 16/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0/1.0 MB | 19/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 19/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 19/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 21/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 21/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 21/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 24/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 27/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 30/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 30/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 32/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 32/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 32/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 32/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 36/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 40/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 45/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 45/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 49/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 49/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 49/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 49/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 53/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 57/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 61/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 61/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 65/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 65/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 65/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 65/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 69/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 73/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 77/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 77/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 81/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 81/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 81/224 kBProgress (4): 49/109 kB | 7.7/8.3 kB | 0.1/1.0 MB | 81/224 kBProgress (4): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB Progress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 2.2/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 5.0/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 7.7/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 10/44 kB Progress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 13/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 16/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 19/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 21/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 24/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 27/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 30/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 32/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 36/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 40/44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 44 kB Progress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 44 kBProgress (5): 49/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 44 kBProgress (5): 53/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 44 kBProgress (5): 57/109 kB | 8.3 kB | 0.1/1.0 MB | 81/224 kB | 44 kBProgress (5): 57/109 kB | 8.3 kB | 0.2/1.0 MB | 81/224 kB | 44 kBProgress (5): 57/109 kB | 8.3 kB | 0.2/1.0 MB | 81/224 kB | 44 kBProgress (5): 57/109 kB | 8.3 kB | 0.2/1.0 MB | 81/224 kB | 44 kBProgress (5): 57/109 kB | 8.3 kB | 0.2/1.0 MB | 81/224 kB | 44 kBProgress (5): 61/109 kB | 8.3 kB | 0.2/1.0 MB | 81/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 81/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 81/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 81/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 81/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 81/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 85/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 90/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 94/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 98/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 98/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 98/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 98/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 98/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 102/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 106/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 110/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 114/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 114/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 114/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 114/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 114/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 118/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 122/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 126/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 131/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 131/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 131/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 131/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 131/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 135/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 139/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 143/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 143/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 147/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 147/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 147/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 147/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 151/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 155/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 159/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 159/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.2/1.0 MB | 163/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 163/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 163/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 163/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 167/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 171/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 171/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 176/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 176/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 180/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 180/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 180/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 184/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 184/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 188/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 188/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 192/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 192/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 196/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 196/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 200/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 200/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 204/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 204/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 208/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 208/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 208/224 kB | 44 kBProgress (5): 65/109 kB | 8.3 kB | 0.3/1.0 MB | 212/224 kB | 44 kBProgress (5): 69/109 kB | 8.3 kB | 0.3/1.0 MB | 212/224 kB | 44 kBProgress (5): 73/109 kB | 8.3 kB | 0.3/1.0 MB | 212/224 kB | 44 kBProgress (5): 73/109 kB | 8.3 kB | 0.3/1.0 MB | 212/224 kB | 44 kBProgress (5): 73/109 kB | 8.3 kB | 0.3/1.0 MB | 217/224 kB | 44 kBProgress (5): 73/109 kB | 8.3 kB | 0.3/1.0 MB | 221/224 kB | 44 kBProgress (5): 73/109 kB | 8.3 kB | 0.3/1.0 MB | 221/224 kB | 44 kBProgress (5): 73/109 kB | 8.3 kB | 0.3/1.0 MB | 221/224 kB | 44 kBProgress (5): 73/109 kB | 8.3 kB | 0.3/1.0 MB | 221/224 kB | 44 kBProgress (5): 77/109 kB | 8.3 kB | 0.3/1.0 MB | 221/224 kB | 44 kBProgress (5): 81/109 kB | 8.3 kB | 0.3/1.0 MB | 221/224 kB | 44 kBProgress (5): 81/109 kB | 8.3 kB | 0.3/1.0 MB | 221/224 kB | 44 kBProgress (5): 81/109 kB | 8.3 kB | 0.3/1.0 MB | 221/224 kB | 44 kBProgress (5): 81/109 kB | 8.3 kB | 0.3/1.0 MB | 221/224 kB | 44 kBProgress (5): 81/109 kB | 8.3 kB | 0.3/1.0 MB | 224 kB | 44 kB Progress (5): 85/109 kB | 8.3 kB | 0.3/1.0 MB | 224 kB | 44 kBProgress (5): 90/109 kB | 8.3 kB | 0.3/1.0 MB | 224 kB | 44 kBProgress (5): 94/109 kB | 8.3 kB | 0.3/1.0 MB | 224 kB | 44 kBProgress (5): 98/109 kB | 8.3 kB | 0.3/1.0 MB | 224 kB | 44 kBProgress (5): 98/109 kB | 8.3 kB | 0.3/1.0 MB | 224 kB | 44 kBProgress (5): 98/109 kB | 8.3 kB | 0.3/1.0 MB | 224 kB | 44 kBProgress (5): 98/109 kB | 8.3 kB | 0.4/1.0 MB | 224 kB | 44 kBProgress (5): 98/109 kB | 8.3 kB | 0.4/1.0 MB | 224 kB | 44 kBProgress (5): 98/109 kB | 8.3 kB | 0.4/1.0 MB | 224 kB | 44 kBProgress (5): 102/109 kB | 8.3 kB | 0.4/1.0 MB | 224 kB | 44 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar (8.3 kB at 208 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar
Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar (224 kB at 5.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar
Progress (3): 102/109 kB | 0.4/1.0 MB | 44 kBProgress (3): 106/109 kB | 0.4/1.0 MB | 44 kBProgress (3): 109 kB | 0.4/1.0 MB | 44 kB Progress (3): 109 kB | 0.4/1.0 MB | 44 kBProgress (3): 109 kB | 0.4/1.0 MB | 44 kBProgress (3): 109 kB | 0.4/1.0 MB | 44 kBProgress (3): 109 kB | 0.4/1.0 MB | 44 kBProgress (3): 109 kB | 0.4/1.0 MB | 44 kBProgress (3): 109 kB | 0.4/1.0 MB | 44 kBProgress (3): 109 kB | 0.4/1.0 MB | 44 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar (109 kB at 2.5 MB/s)
Progress (3): 0.4/1.0 MB | 44 kB | 4.1/30 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar
Progress (3): 0.4/1.0 MB | 44 kB | 4.1/30 kBProgress (4): 0.4/1.0 MB | 44 kB | 4.1/30 kB | 2.2/80 kBProgress (4): 0.4/1.0 MB | 44 kB | 7.7/30 kB | 2.2/80 kBProgress (4): 0.4/1.0 MB | 44 kB | 12/30 kB | 2.2/80 kB Progress (4): 0.4/1.0 MB | 44 kB | 16/30 kB | 2.2/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar (44 kB at 894 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar
Progress (3): 0.4/1.0 MB | 20/30 kB | 2.2/80 kBProgress (3): 0.4/1.0 MB | 24/30 kB | 2.2/80 kBProgress (3): 0.4/1.0 MB | 28/30 kB | 2.2/80 kBProgress (3): 0.4/1.0 MB | 30 kB | 2.2/80 kB Progress (3): 0.4/1.0 MB | 30 kB | 5.0/80 kBProgress (3): 0.4/1.0 MB | 30 kB | 7.7/80 kBProgress (3): 0.4/1.0 MB | 30 kB | 10/80 kB Progress (3): 0.4/1.0 MB | 30 kB | 13/80 kBProgress (3): 0.4/1.0 MB | 30 kB | 16/80 kBProgress (3): 0.4/1.0 MB | 30 kB | 19/80 kBProgress (3): 0.4/1.0 MB | 30 kB | 21/80 kBProgress (4): 0.4/1.0 MB | 30 kB | 21/80 kB | 4.1/20 kBProgress (4): 0.4/1.0 MB | 30 kB | 24/80 kB | 4.1/20 kBProgress (4): 0.4/1.0 MB | 30 kB | 24/80 kB | 7.7/20 kBProgress (4): 0.4/1.0 MB | 30 kB | 24/80 kB | 12/20 kB Progress (4): 0.4/1.0 MB | 30 kB | 27/80 kB | 12/20 kBProgress (4): 0.4/1.0 MB | 30 kB | 27/80 kB | 16/20 kBProgress (4): 0.4/1.0 MB | 30 kB | 30/80 kB | 16/20 kBProgress (4): 0.4/1.0 MB | 30 kB | 30/80 kB | 20 kB Progress (4): 0.4/1.0 MB | 30 kB | 32/80 kB | 20 kBProgress (4): 0.4/1.0 MB | 30 kB | 36/80 kB | 20 kBProgress (4): 0.4/1.0 MB | 30 kB | 40/80 kB | 20 kBProgress (4): 0.4/1.0 MB | 30 kB | 45/80 kB | 20 kBProgress (4): 0.4/1.0 MB | 30 kB | 49/80 kB | 20 kBProgress (4): 0.4/1.0 MB | 30 kB | 53/80 kB | 20 kBProgress (4): 0.4/1.0 MB | 30 kB | 57/80 kB | 20 kBProgress (4): 0.4/1.0 MB | 30 kB | 61/80 kB | 20 kBProgress (4): 0.4/1.0 MB | 30 kB | 65/80 kB | 20 kBProgress (4): 0.4/1.0 MB | 30 kB | 69/80 kB | 20 kBProgress (4): 0.4/1.0 MB | 30 kB | 73/80 kB | 20 kBProgress (4): 0.4/1.0 MB | 30 kB | 77/80 kB | 20 kBProgress (4): 0.4/1.0 MB | 30 kB | 80 kB | 20 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar (20 kB at 358 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar
Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar (30 kB at 550 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar
Progress (2): 0.4/1.0 MB | 80 kBProgress (2): 0.4/1.0 MB | 80 kBProgress (2): 0.4/1.0 MB | 80 kBProgress (2): 0.4/1.0 MB | 80 kBProgress (2): 0.4/1.0 MB | 80 kBProgress (2): 0.4/1.0 MB | 80 kBProgress (2): 0.4/1.0 MB | 80 kBProgress (3): 0.4/1.0 MB | 80 kB | 4.1/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 7.7/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 12/195 kB Progress (3): 0.4/1.0 MB | 80 kB | 12/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 16/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 16/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 16/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 16/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 20/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 24/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 28/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 32/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 36/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 40/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 45/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 49/195 kBProgress (3): 0.4/1.0 MB | 80 kB | 53/195 kBProgress (4): 0.4/1.0 MB | 80 kB | 53/195 kB | 4.1/49 kBProgress (4): 0.4/1.0 MB | 80 kB | 57/195 kB | 4.1/49 kBProgress (4): 0.4/1.0 MB | 80 kB | 61/195 kB | 4.1/49 kBProgress (4): 0.4/1.0 MB | 80 kB | 65/195 kB | 4.1/49 kBProgress (4): 0.4/1.0 MB | 80 kB | 69/195 kB | 4.1/49 kBProgress (4): 0.4/1.0 MB | 80 kB | 73/195 kB | 4.1/49 kBProgress (4): 0.4/1.0 MB | 80 kB | 77/195 kB | 4.1/49 kBProgress (5): 0.4/1.0 MB | 80 kB | 77/195 kB | 4.1/49 kB | 4.1/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 81/195 kB | 4.1/49 kB | 4.1/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 81/195 kB | 4.1/49 kB | 7.6/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 81/195 kB | 4.1/49 kB | 12/121 kB Progress (5): 0.4/1.0 MB | 80 kB | 81/195 kB | 4.1/49 kB | 16/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 85/195 kB | 4.1/49 kB | 16/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 90/195 kB | 4.1/49 kB | 16/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 94/195 kB | 4.1/49 kB | 16/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 98/195 kB | 4.1/49 kB | 16/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 98/195 kB | 4.1/49 kB | 20/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 98/195 kB | 4.1/49 kB | 24/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 98/195 kB | 4.1/49 kB | 28/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 102/195 kB | 4.1/49 kB | 28/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 102/195 kB | 4.1/49 kB | 32/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 106/195 kB | 4.1/49 kB | 32/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 110/195 kB | 4.1/49 kB | 32/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 114/195 kB | 4.1/49 kB | 32/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 114/195 kB | 4.1/49 kB | 36/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 118/195 kB | 4.1/49 kB | 36/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 118/195 kB | 4.1/49 kB | 40/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 122/195 kB | 4.1/49 kB | 40/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 122/195 kB | 4.1/49 kB | 45/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 126/195 kB | 4.1/49 kB | 45/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 126/195 kB | 4.1/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 131/195 kB | 4.1/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 135/195 kB | 4.1/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 4.1/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 7.7/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 12/49 kB | 49/121 kB Progress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 16/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 20/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 24/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 28/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 32/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 36/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 40/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 45/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 49/49 kB | 49/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 49 kB | 49/121 kB Progress (5): 0.4/1.0 MB | 80 kB | 139/195 kB | 49 kB | 53/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 143/195 kB | 49 kB | 53/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 143/195 kB | 49 kB | 57/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 147/195 kB | 49 kB | 57/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 147/195 kB | 49 kB | 61/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 147/195 kB | 49 kB | 65/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 151/195 kB | 49 kB | 65/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 155/195 kB | 49 kB | 65/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 159/195 kB | 49 kB | 65/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 163/195 kB | 49 kB | 65/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 163/195 kB | 49 kB | 69/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 163/195 kB | 49 kB | 73/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 163/195 kB | 49 kB | 77/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 163/195 kB | 49 kB | 81/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 167/195 kB | 49 kB | 81/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 171/195 kB | 49 kB | 81/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 176/195 kB | 49 kB | 81/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 180/195 kB | 49 kB | 81/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 180/195 kB | 49 kB | 85/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 180/195 kB | 49 kB | 90/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 180/195 kB | 49 kB | 94/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 184/195 kB | 49 kB | 94/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 184/195 kB | 49 kB | 98/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 184/195 kB | 49 kB | 102/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 184/195 kB | 49 kB | 106/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 184/195 kB | 49 kB | 110/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 184/195 kB | 49 kB | 114/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 184/195 kB | 49 kB | 118/121 kBProgress (5): 0.4/1.0 MB | 80 kB | 184/195 kB | 49 kB | 121 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar (80 kB at 1.2 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar
Progress (4): 0.4/1.0 MB | 184/195 kB | 49 kB | 121 kBProgress (4): 0.5/1.0 MB | 184/195 kB | 49 kB | 121 kBProgress (4): 0.5/1.0 MB | 184/195 kB | 49 kB | 121 kBProgress (4): 0.5/1.0 MB | 184/195 kB | 49 kB | 121 kBProgress (4): 0.5/1.0 MB | 184/195 kB | 49 kB | 121 kBProgress (4): 0.5/1.0 MB | 184/195 kB | 49 kB | 121 kBProgress (4): 0.5/1.0 MB | 184/195 kB | 49 kB | 121 kBProgress (4): 0.5/1.0 MB | 184/195 kB | 49 kB | 121 kBProgress (4): 0.5/1.0 MB | 188/195 kB | 49 kB | 121 kBProgress (4): 0.5/1.0 MB | 192/195 kB | 49 kB | 121 kBProgress (4): 0.5/1.0 MB | 195 kB | 49 kB | 121 kB Progress (4): 0.5/1.0 MB | 195 kB | 49 kB | 121 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar (49 kB at 681 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar
Progress (3): 0.5/1.0 MB | 195 kB | 121 kBProgress (3): 0.5/1.0 MB | 195 kB | 121 kBProgress (3): 0.5/1.0 MB | 195 kB | 121 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar (195 kB at 2.7 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar
Progress (2): 0.5/1.0 MB | 121 kBProgress (2): 0.5/1.0 MB | 121 kBProgress (2): 0.5/1.0 MB | 121 kBProgress (2): 0.5/1.0 MB | 121 kBProgress (3): 0.5/1.0 MB | 121 kB | 4.1/80 kBProgress (3): 0.5/1.0 MB | 121 kB | 7.7/80 kBProgress (3): 0.5/1.0 MB | 121 kB | 12/80 kB Progress (3): 0.5/1.0 MB | 121 kB | 16/80 kBProgress (3): 0.5/1.0 MB | 121 kB | 20/80 kBProgress (3): 0.5/1.0 MB | 121 kB | 24/80 kBProgress (3): 0.5/1.0 MB | 121 kB | 28/80 kBProgress (3): 0.5/1.0 MB | 121 kB | 32/80 kBProgress (4): 0.5/1.0 MB | 121 kB | 32/80 kB | 4.1/12 kBProgress (4): 0.5/1.0 MB | 121 kB | 36/80 kB | 4.1/12 kBProgress (5): 0.5/1.0 MB | 121 kB | 36/80 kB | 4.1/12 kB | 4.1/251 kBProgress (5): 0.5/1.0 MB | 121 kB | 36/80 kB | 7.7/12 kB | 4.1/251 kBProgress (5): 0.5/1.0 MB | 121 kB | 36/80 kB | 12/12 kB | 4.1/251 kB Progress (5): 0.5/1.0 MB | 121 kB | 36/80 kB | 12/12 kB | 7.7/251 kBProgress (5): 0.5/1.0 MB | 121 kB | 36/80 kB | 12 kB | 7.7/251 kB Progress (5): 0.5/1.0 MB | 121 kB | 36/80 kB | 12 kB | 12/251 kB Progress (5): 0.5/1.0 MB | 121 kB | 36/80 kB | 12 kB | 16/251 kBProgress (5): 0.5/1.0 MB | 121 kB | 40/80 kB | 12 kB | 16/251 kBProgress (5): 0.5/1.0 MB | 121 kB | 40/80 kB | 12 kB | 20/251 kBProgress (5): 0.5/1.0 MB | 121 kB | 40/80 kB | 12 kB | 24/251 kBProgress (5): 0.5/1.0 MB | 121 kB | 40/80 kB | 12 kB | 24/251 kBProgress (5): 0.5/1.0 MB | 121 kB | 45/80 kB | 12 kB | 24/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar (121 kB at 1.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar
Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar (12 kB at 148 kB/s)
Progress (3): 0.5/1.0 MB | 49/80 kB | 24/251 kBProgress (3): 0.5/1.0 MB | 53/80 kB | 24/251 kBProgress (3): 0.5/1.0 MB | 57/80 kB | 24/251 kBProgress (3): 0.5/1.0 MB | 61/80 kB | 24/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 24/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 24/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 24/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 24/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 24/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 28/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 32/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 36/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 40/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 45/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 49/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 53/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 57/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 61/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 61/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 61/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 61/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 61/251 kBProgress (3): 0.5/1.0 MB | 65/80 kB | 61/251 kBProgress (3): 0.6/1.0 MB | 65/80 kB | 61/251 kBProgress (3): 0.6/1.0 MB | 69/80 kB | 61/251 kBProgress (3): 0.6/1.0 MB | 73/80 kB | 61/251 kBProgress (3): 0.6/1.0 MB | 77/80 kB | 61/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 61/251 kB Progress (3): 0.6/1.0 MB | 80 kB | 61/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 65/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 65/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 69/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 73/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 73/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 73/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 73/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 73/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 73/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 73/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 73/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 77/251 kBProgress (3): 0.6/1.0 MB | 80 kB | 81/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar (80 kB at 882 kB/s)
Progress (2): 0.6/1.0 MB | 85/251 kBProgress (2): 0.6/1.0 MB | 90/251 kBProgress (2): 0.6/1.0 MB | 94/251 kBProgress (2): 0.6/1.0 MB | 98/251 kBProgress (2): 0.6/1.0 MB | 98/251 kBProgress (2): 0.6/1.0 MB | 98/251 kBProgress (2): 0.6/1.0 MB | 98/251 kBProgress (2): 0.6/1.0 MB | 98/251 kBProgress (2): 0.6/1.0 MB | 98/251 kBProgress (2): 0.6/1.0 MB | 98/251 kBProgress (2): 0.6/1.0 MB | 98/251 kBProgress (2): 0.6/1.0 MB | 98/251 kBProgress (2): 0.6/1.0 MB | 102/251 kBProgress (2): 0.6/1.0 MB | 106/251 kBProgress (2): 0.6/1.0 MB | 110/251 kBProgress (2): 0.6/1.0 MB | 114/251 kBProgress (2): 0.6/1.0 MB | 118/251 kBProgress (2): 0.6/1.0 MB | 122/251 kBProgress (2): 0.6/1.0 MB | 126/251 kBProgress (2): 0.6/1.0 MB | 131/251 kBProgress (2): 0.6/1.0 MB | 135/251 kBProgress (2): 0.6/1.0 MB | 139/251 kBProgress (2): 0.6/1.0 MB | 143/251 kBProgress (2): 0.6/1.0 MB | 143/251 kBProgress (2): 0.6/1.0 MB | 143/251 kBProgress (2): 0.6/1.0 MB | 143/251 kBProgress (2): 0.6/1.0 MB | 143/251 kBProgress (2): 0.6/1.0 MB | 143/251 kBProgress (2): 0.6/1.0 MB | 147/251 kBProgress (2): 0.6/1.0 MB | 151/251 kBProgress (2): 0.6/1.0 MB | 151/251 kBProgress (2): 0.7/1.0 MB | 151/251 kBProgress (2): 0.7/1.0 MB | 151/251 kBProgress (2): 0.7/1.0 MB | 151/251 kBProgress (2): 0.7/1.0 MB | 151/251 kBProgress (2): 0.7/1.0 MB | 151/251 kBProgress (2): 0.7/1.0 MB | 151/251 kBProgress (2): 0.7/1.0 MB | 151/251 kBProgress (2): 0.7/1.0 MB | 155/251 kBProgress (2): 0.7/1.0 MB | 159/251 kBProgress (2): 0.7/1.0 MB | 163/251 kBProgress (2): 0.7/1.0 MB | 167/251 kBProgress (2): 0.7/1.0 MB | 171/251 kBProgress (2): 0.7/1.0 MB | 176/251 kBProgress (2): 0.7/1.0 MB | 180/251 kBProgress (2): 0.7/1.0 MB | 184/251 kBProgress (2): 0.7/1.0 MB | 184/251 kBProgress (2): 0.7/1.0 MB | 184/251 kBProgress (2): 0.7/1.0 MB | 188/251 kBProgress (2): 0.7/1.0 MB | 188/251 kBProgress (2): 0.7/1.0 MB | 192/251 kBProgress (2): 0.7/1.0 MB | 196/251 kBProgress (2): 0.7/1.0 MB | 200/251 kBProgress (2): 0.7/1.0 MB | 204/251 kBProgress (2): 0.7/1.0 MB | 208/251 kBProgress (2): 0.7/1.0 MB | 212/251 kBProgress (2): 0.7/1.0 MB | 217/251 kBProgress (2): 0.7/1.0 MB | 221/251 kBProgress (2): 0.7/1.0 MB | 225/251 kBProgress (2): 0.7/1.0 MB | 229/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.8/1.0 MB | 233/251 kBProgress (2): 0.8/1.0 MB | 233/251 kBProgress (2): 0.8/1.0 MB | 233/251 kBProgress (2): 0.8/1.0 MB | 233/251 kBProgress (2): 0.8/1.0 MB | 233/251 kBProgress (2): 0.8/1.0 MB | 237/251 kBProgress (2): 0.8/1.0 MB | 241/251 kBProgress (2): 0.8/1.0 MB | 245/251 kBProgress (2): 0.8/1.0 MB | 249/251 kBProgress (2): 0.8/1.0 MB | 251 kB Progress (2): 0.8/1.0 MB | 251 kBProgress (2): 0.8/1.0 MB | 251 kBProgress (2): 0.8/1.0 MB | 251 kBProgress (2): 0.8/1.0 MB | 251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar (251 kB at 2.2 MB/s)
Progress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (2): 0.8/1.0 MB | 0/1.3 MBProgress (2): 0.8/1.0 MB | 0/1.3 MBProgress (2): 0.8/1.0 MB | 0/1.3 MBProgress (2): 0.8/1.0 MB | 0/1.3 MBProgress (2): 0.8/1.0 MB | 0/1.3 MBProgress (2): 0.8/1.0 MB | 0/1.3 MBProgress (2): 0.8/1.0 MB | 0/1.3 MBProgress (2): 0.8/1.0 MB | 0/1.3 MBProgress (2): 0.8/1.0 MB | 0/1.3 MBProgress (2): 0.8/1.0 MB | 0/1.3 MBProgress (2): 0.8/1.0 MB | 0/1.3 MBProgress (2): 0.8/1.0 MB | 0/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MB Progress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar (1.0 MB at 6.4 MB/s)
Progress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar (1.3 MB at 6.5 MB/s)
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en&gt;
     [echo] Build directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.16-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;:137:Inline literal start-string without end-string.
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 45.823 s
[e[1;34mINFOe[m] Finished at: 2019-05-27T20:05:01Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://build.geoserver.org/job/geoserver-master-live-docs/1820/display/redirect&gt;
[...truncated 382.43 KB...]
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom
Progress (1): 861 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom (861 B at 144 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom
Progress (1): 761 B Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom (761 B at 152 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom
Progress (1): 138 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom (138 B at 28 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom
Progress (1): 643 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom (643 B at 129 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom
Progress (1): 2.2/12 kBProgress (1): 5.0/12 kBProgress (1): 7.8/12 kBProgress (1): 11/12 kB Progress (1): 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom (12 kB at 2.0 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom
Progress (1): 1.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom (1.8 kB at 368 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom (1.6 kB at 232 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom
Progress (1): 2.2/2.7 kBProgress (1): 2.7 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom (2.7 kB at 452 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom
Progress (1): 767 B Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom (767 B at 192 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom
Progress (1): 1.2 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom (1.2 kB at 412 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom
Progress (1): 998 B Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom (998 B at 250 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom (1.6 kB at 404 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom
Progress (1): 1.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom (1.4 kB at 272 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom
Progress (1): 1.5 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom (1.5 kB at 297 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom
Progress (1): 765 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom (765 B at 51 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom
Progress (1): 2.2/5.3 kBProgress (1): 5.0/5.3 kBProgress (1): 5.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom (5.3 kB at 1.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom (9.8 kB at 2.0 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom
Progress (1): 2.2/2.4 kBProgress (1): 2.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom (2.4 kB at 477 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom
Progress (1): 2.2/4.4 kBProgress (1): 4.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom (4.4 kB at 1.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom (9.8 kB at 2.0 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar
Progress (1): 2.2/44 kBProgress (2): 2.2/44 kB | 2.2/8.3 kBProgress (2): 2.2/44 kB | 5.0/8.3 kBProgress (2): 5.0/44 kB | 5.0/8.3 kBProgress (3): 5.0/44 kB | 5.0/8.3 kB | 2.2/109 kBProgress (3): 5.0/44 kB | 7.7/8.3 kB | 2.2/109 kBProgress (3): 5.0/44 kB | 8.3 kB | 2.2/109 kB Progress (3): 5.0/44 kB | 8.3 kB | 5.0/109 kBProgress (3): 5.0/44 kB | 8.3 kB | 7.7/109 kBProgress (3): 5.0/44 kB | 8.3 kB | 10/109 kB Progress (3): 5.0/44 kB | 8.3 kB | 13/109 kBProgress (3): 7.7/44 kB | 8.3 kB | 13/109 kBProgress (3): 10/44 kB | 8.3 kB | 13/109 kB Progress (3): 13/44 kB | 8.3 kB | 13/109 kBProgress (3): 16/44 kB | 8.3 kB | 13/109 kBProgress (3): 19/44 kB | 8.3 kB | 13/109 kBProgress (3): 21/44 kB | 8.3 kB | 13/109 kBProgress (3): 24/44 kB | 8.3 kB | 13/109 kBProgress (3): 27/44 kB | 8.3 kB | 13/109 kBProgress (3): 30/44 kB | 8.3 kB | 13/109 kBProgress (3): 32/44 kB | 8.3 kB | 13/109 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar (8.3 kB at 417 kB/s)
Progress (2): 32/44 kB | 16/109 kBProgress (2): 36/44 kB | 16/109 kBProgress (3): 36/44 kB | 16/109 kB | 2.2/224 kBProgress (3): 36/44 kB | 19/109 kB | 2.2/224 kBProgress (3): 36/44 kB | 19/109 kB | 5.0/224 kBProgress (3): 36/44 kB | 19/109 kB | 7.7/224 kBProgress (3): 36/44 kB | 19/109 kB | 10/224 kB Progress (3): 36/44 kB | 21/109 kB | 10/224 kBProgress (3): 36/44 kB | 21/109 kB | 13/224 kBProgress (3): 36/44 kB | 24/109 kB | 13/224 kBProgress (3): 36/44 kB | 24/109 kB | 16/224 kBProgress (3): 36/44 kB | 27/109 kB | 16/224 kBProgress (3): 36/44 kB | 27/109 kB | 19/224 kBProgress (3): 36/44 kB | 30/109 kB | 19/224 kBProgress (3): 36/44 kB | 30/109 kB | 21/224 kBProgress (3): 36/44 kB | 32/109 kB | 21/224 kBProgress (3): 36/44 kB | 32/109 kB | 24/224 kBProgress (3): 36/44 kB | 32/109 kB | 27/224 kBProgress (3): 36/44 kB | 32/109 kB | 30/224 kBProgress (3): 36/44 kB | 32/109 kB | 32/224 kBProgress (3): 36/44 kB | 36/109 kB | 32/224 kBProgress (3): 36/44 kB | 40/109 kB | 32/224 kBProgress (3): 36/44 kB | 45/109 kB | 32/224 kBProgress (3): 36/44 kB | 45/109 kB | 36/224 kBProgress (3): 36/44 kB | 49/109 kB | 36/224 kBProgress (4): 36/44 kB | 49/109 kB | 36/224 kB | 0/1.0 MBProgress (4): 36/44 kB | 49/109 kB | 40/224 kB | 0/1.0 MBProgress (4): 36/44 kB | 49/109 kB | 45/224 kB | 0/1.0 MBProgress (4): 36/44 kB | 49/109 kB | 49/224 kB | 0/1.0 MBProgress (5): 36/44 kB | 49/109 kB | 49/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 53/109 kB | 49/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 53/109 kB | 49/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 57/109 kB | 49/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 57/109 kB | 53/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 61/109 kB | 53/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 61/109 kB | 57/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 61/109 kB | 57/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 65/109 kB | 57/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 65/109 kB | 61/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 65/109 kB | 65/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 65/109 kB | 65/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 65/109 kB | 65/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 65/109 kB | 65/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 65/109 kB | 65/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 65/109 kB | 69/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 65/109 kB | 73/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 65/109 kB | 73/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 65/109 kB | 77/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 69/109 kB | 77/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 69/109 kB | 81/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 69/109 kB | 81/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 73/109 kB | 81/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 73/109 kB | 81/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 77/109 kB | 81/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 81/109 kB | 81/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 81/109 kB | 81/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 81/109 kB | 81/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 81/109 kB | 85/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 81/109 kB | 90/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 81/109 kB | 94/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 81/109 kB | 98/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 81/109 kB | 98/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 85/109 kB | 98/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 85/109 kB | 98/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 85/109 kB | 98/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 90/109 kB | 98/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 90/109 kB | 102/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 90/109 kB | 106/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 90/109 kB | 106/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 90/109 kB | 110/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 90/109 kB | 114/224 kB | 0/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 90/109 kB | 114/224 kB | 0.1/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 90/109 kB | 114/224 kB | 0.1/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 90/109 kB | 114/224 kB | 0.1/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 94/109 kB | 114/224 kB | 0.1/1.0 MB | 2.2/30 kBProgress (5): 36/44 kB | 94/109 kB | 114/224 kB | 0.1/1.0 MB | 5.0/30 kBProgress (5): 36/44 kB | 94/109 kB | 114/224 kB | 0.1/1.0 MB | 7.7/30 kBProgress (5): 36/44 kB | 94/109 kB | 114/224 kB | 0.1/1.0 MB | 10/30 kB Progress (5): 36/44 kB | 94/109 kB | 114/224 kB | 0.1/1.0 MB | 13/30 kBProgress (5): 36/44 kB | 94/109 kB | 114/224 kB | 0.1/1.0 MB | 16/30 kBProgress (5): 36/44 kB | 94/109 kB | 114/224 kB | 0.1/1.0 MB | 19/30 kBProgress (5): 36/44 kB | 94/109 kB | 114/224 kB | 0.1/1.0 MB | 21/30 kBProgress (5): 36/44 kB | 94/109 kB | 114/224 kB | 0.1/1.0 MB | 24/30 kBProgress (5): 36/44 kB | 94/109 kB | 114/224 kB | 0.1/1.0 MB | 27/30 kBProgress (5): 36/44 kB | 94/109 kB | 114/224 kB | 0.1/1.0 MB | 30/30 kBProgress (5): 36/44 kB | 94/109 kB | 114/224 kB | 0.1/1.0 MB | 30 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar (30 kB at 1.6 MB/s)
Progress (4): 36/44 kB | 98/109 kB | 114/224 kB | 0.1/1.0 MBProgress (4): 36/44 kB | 102/109 kB | 114/224 kB | 0.1/1.0 MBProgress (4): 36/44 kB | 106/109 kB | 114/224 kB | 0.1/1.0 MBProgress (4): 36/44 kB | 109 kB | 114/224 kB | 0.1/1.0 MB Progress (4): 40/44 kB | 109 kB | 114/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 114/224 kB | 0.1/1.0 MB Progress (4): 44 kB | 109 kB | 114/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 118/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 122/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 126/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 131/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 131/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 131/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 131/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 131/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 135/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 139/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 143/224 kB | 0.1/1.0 MBProgress (4): 44 kB | 109 kB | 147/224 kB | 0.1/1.0 MBProgress (5): 44 kB | 109 kB | 147/224 kB | 0.1/1.0 MB | 2.2/80 kBProgress (5): 44 kB | 109 kB | 147/224 kB | 0.1/1.0 MB | 5.0/80 kBProgress (5): 44 kB | 109 kB | 147/224 kB | 0.1/1.0 MB | 7.7/80 kBProgress (5): 44 kB | 109 kB | 151/224 kB | 0.1/1.0 MB | 7.7/80 kBProgress (5): 44 kB | 109 kB | 155/224 kB | 0.1/1.0 MB | 7.7/80 kBProgress (5): 44 kB | 109 kB | 159/224 kB | 0.1/1.0 MB | 7.7/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar (44 kB at 1.8 MB/s)
Progress (4): 109 kB | 163/224 kB | 0.1/1.0 MB | 7.7/80 kBProgress (4): 109 kB | 163/224 kB | 0.1/1.0 MB | 10/80 kB Progress (4): 109 kB | 167/224 kB | 0.1/1.0 MB | 10/80 kBProgress (4): 109 kB | 171/224 kB | 0.1/1.0 MB | 10/80 kBProgress (4): 109 kB | 176/224 kB | 0.1/1.0 MB | 10/80 kBProgress (4): 109 kB | 180/224 kB | 0.1/1.0 MB | 10/80 kBProgress (4): 109 kB | 184/224 kB | 0.1/1.0 MB | 10/80 kBProgress (4): 109 kB | 188/224 kB | 0.1/1.0 MB | 10/80 kBProgress (4): 109 kB | 192/224 kB | 0.1/1.0 MB | 10/80 kBProgress (4): 109 kB | 196/224 kB | 0.1/1.0 MB | 10/80 kBProgress (5): 109 kB | 196/224 kB | 0.1/1.0 MB | 10/80 kB | 4.1/49 kBProgress (5): 109 kB | 196/224 kB | 0.1/1.0 MB | 10/80 kB | 7.7/49 kBProgress (5): 109 kB | 196/224 kB | 0.1/1.0 MB | 10/80 kB | 12/49 kB Progress (5): 109 kB | 196/224 kB | 0.1/1.0 MB | 10/80 kB | 16/49 kBProgress (5): 109 kB | 200/224 kB | 0.1/1.0 MB | 10/80 kB | 16/49 kBProgress (5): 109 kB | 200/224 kB | 0.1/1.0 MB | 10/80 kB | 20/49 kBProgress (5): 109 kB | 200/224 kB | 0.1/1.0 MB | 10/80 kB | 24/49 kBProgress (5): 109 kB | 200/224 kB | 0.1/1.0 MB | 10/80 kB | 28/49 kBProgress (5): 109 kB | 200/224 kB | 0.1/1.0 MB | 10/80 kB | 32/49 kBProgress (5): 109 kB | 204/224 kB | 0.1/1.0 MB | 10/80 kB | 32/49 kBProgress (5): 109 kB | 208/224 kB | 0.1/1.0 MB | 10/80 kB | 32/49 kBProgress (5): 109 kB | 212/224 kB | 0.1/1.0 MB | 10/80 kB | 32/49 kBProgress (5): 109 kB | 217/224 kB | 0.1/1.0 MB | 10/80 kB | 32/49 kBProgress (5): 109 kB | 221/224 kB | 0.1/1.0 MB | 10/80 kB | 32/49 kBProgress (5): 109 kB | 224 kB | 0.1/1.0 MB | 10/80 kB | 32/49 kB Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar (224 kB at 4.9 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar
Progress (4): 109 kB | 0.1/1.0 MB | 10/80 kB | 32/49 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar (109 kB at 2.5 MB/s)
Progress (3): 0.1/1.0 MB | 10/80 kB | 36/49 kB Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar
Progress (3): 0.1/1.0 MB | 13/80 kB | 36/49 kBProgress (3): 0.1/1.0 MB | 16/80 kB | 36/49 kBProgress (3): 0.1/1.0 MB | 19/80 kB | 36/49 kBProgress (3): 0.1/1.0 MB | 21/80 kB | 36/49 kBProgress (3): 0.1/1.0 MB | 24/80 kB | 36/49 kBProgress (3): 0.1/1.0 MB | 24/80 kB | 36/49 kBProgress (3): 0.1/1.0 MB | 27/80 kB | 36/49 kBProgress (3): 0.1/1.0 MB | 27/80 kB | 36/49 kBProgress (3): 0.1/1.0 MB | 27/80 kB | 40/49 kBProgress (3): 0.1/1.0 MB | 27/80 kB | 45/49 kBProgress (3): 0.1/1.0 MB | 27/80 kB | 49/49 kBProgress (3): 0.1/1.0 MB | 27/80 kB | 49 kB Progress (3): 0.1/1.0 MB | 30/80 kB | 49 kBProgress (3): 0.1/1.0 MB | 32/80 kB | 49 kBProgress (3): 0.1/1.0 MB | 32/80 kB | 49 kBProgress (3): 0.1/1.0 MB | 36/80 kB | 49 kBProgress (3): 0.1/1.0 MB | 40/80 kB | 49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 49 kB | 4.1/195 kBProgress (4): 0.1/1.0 MB | 45/80 kB | 49 kB | 4.1/195 kBProgress (4): 0.1/1.0 MB | 45/80 kB | 49 kB | 7.7/195 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 49 kB | 7.7/195 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 49 kB | 12/195 kB Progress (4): 0.1/1.0 MB | 49/80 kB | 49 kB | 16/195 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 49 kB | 16/195 kBProgress (4): 0.1/1.0 MB | 53/80 kB | 49 kB | 16/195 kBProgress (4): 0.1/1.0 MB | 57/80 kB | 49 kB | 16/195 kBProgress (4): 0.1/1.0 MB | 61/80 kB | 49 kB | 16/195 kBProgress (4): 0.1/1.0 MB | 65/80 kB | 49 kB | 16/195 kBProgress (4): 0.1/1.0 MB | 65/80 kB | 49 kB | 16/195 kBProgress (4): 0.1/1.0 MB | 65/80 kB | 49 kB | 16/195 kBProgress (5): 0.1/1.0 MB | 65/80 kB | 49 kB | 16/195 kB | 4.1/20 kBProgress (5): 0.1/1.0 MB | 65/80 kB | 49 kB | 20/195 kB | 4.1/20 kBProgress (5): 0.1/1.0 MB | 69/80 kB | 49 kB | 20/195 kB | 4.1/20 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar (49 kB at 1.2 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar
Progress (4): 0.1/1.0 MB | 69/80 kB | 20/195 kB | 4.1/20 kBProgress (4): 0.1/1.0 MB | 69/80 kB | 20/195 kB | 7.7/20 kBProgress (4): 0.1/1.0 MB | 73/80 kB | 20/195 kB | 7.7/20 kBProgress (4): 0.1/1.0 MB | 73/80 kB | 24/195 kB | 7.7/20 kBProgress (4): 0.1/1.0 MB | 77/80 kB | 24/195 kB | 7.7/20 kBProgress (4): 0.1/1.0 MB | 80 kB | 24/195 kB | 7.7/20 kB Progress (4): 0.1/1.0 MB | 80 kB | 24/195 kB | 12/20 kB Progress (4): 0.1/1.0 MB | 80 kB | 28/195 kB | 12/20 kBProgress (4): 0.1/1.0 MB | 80 kB | 28/195 kB | 16/20 kBProgress (4): 0.1/1.0 MB | 80 kB | 32/195 kB | 16/20 kBProgress (4): 0.1/1.0 MB | 80 kB | 32/195 kB | 16/20 kBProgress (4): 0.1/1.0 MB | 80 kB | 32/195 kB | 20 kB Progress (4): 0.1/1.0 MB | 80 kB | 32/195 kB | 20 kBProgress (4): 0.1/1.0 MB | 80 kB | 36/195 kB | 20 kBProgress (4): 0.1/1.0 MB | 80 kB | 40/195 kB | 20 kBProgress (4): 0.1/1.0 MB | 80 kB | 45/195 kB | 20 kBProgress (4): 0.1/1.0 MB | 80 kB | 49/195 kB | 20 kBProgress (5): 0.1/1.0 MB | 80 kB | 49/195 kB | 20 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 80 kB | 53/195 kB | 20 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 80 kB | 53/195 kB | 20 kB | 7.6/121 kBProgress (5): 0.1/1.0 MB | 80 kB | 57/195 kB | 20 kB | 7.6/121 kBProgress (5): 0.1/1.0 MB | 80 kB | 57/195 kB | 20 kB | 12/121 kB Progress (5): 0.1/1.0 MB | 80 kB | 57/195 kB | 20 kB | 16/121 kBProgress (5): 0.1/1.0 MB | 80 kB | 57/195 kB | 20 kB | 20/121 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar (80 kB at 1.7 MB/s)
Progress (4): 0.1/1.0 MB | 57/195 kB | 20 kB | 20/121 kBProgress (4): 0.1/1.0 MB | 57/195 kB | 20 kB | 20/121 kBProgress (4): 0.1/1.0 MB | 57/195 kB | 20 kB | 20/121 kBProgress (4): 0.1/1.0 MB | 57/195 kB | 20 kB | 20/121 kBProgress (4): 0.1/1.0 MB | 57/195 kB | 20 kB | 20/121 kBProgress (4): 0.1/1.0 MB | 57/195 kB | 20 kB | 20/121 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar (20 kB at 372 kB/s)
Progress (3): 0.1/1.0 MB | 61/195 kB | 20/121 kBProgress (3): 0.1/1.0 MB | 61/195 kB | 24/121 kBProgress (3): 0.2/1.0 MB | 61/195 kB | 24/121 kBProgress (3): 0.2/1.0 MB | 61/195 kB | 28/121 kBProgress (3): 0.2/1.0 MB | 61/195 kB | 28/121 kBProgress (3): 0.2/1.0 MB | 61/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 65/195 kB | 32/121 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar
Progress (3): 0.2/1.0 MB | 65/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 65/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 69/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 73/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 77/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 81/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 81/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 85/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 85/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 90/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 90/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 94/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 94/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 98/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 98/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 102/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 102/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 106/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 106/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 110/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 110/195 kB | 32/121 kBProgress (3): 0.2/1.0 MB | 114/195 kB | 32/121 kBProgress (4): 0.2/1.0 MB | 114/195 kB | 32/121 kB | 4.1/80 kBProgress (4): 0.2/1.0 MB | 114/195 kB | 32/121 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 114/195 kB | 32/121 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 118/195 kB | 32/121 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 118/195 kB | 32/121 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 122/195 kB | 32/121 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 122/195 kB | 32/121 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 126/195 kB | 32/121 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 126/195 kB | 32/121 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 126/195 kB | 32/121 kB | 12/80 kB Progress (4): 0.2/1.0 MB | 131/195 kB | 32/121 kB | 12/80 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 32/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 32/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 32/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 135/195 kB | 32/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 135/195 kB | 32/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 135/195 kB | 32/121 kB | 20/80 kBProgress (4): 0.2/1.0 MB | 139/195 kB | 32/121 kB | 20/80 kBProgress (4): 0.2/1.0 MB | 139/195 kB | 32/121 kB | 20/80 kBProgress (4): 0.2/1.0 MB | 139/195 kB | 32/121 kB | 24/80 kBProgress (4): 0.2/1.0 MB | 143/195 kB | 32/121 kB | 24/80 kBProgress (4): 0.2/1.0 MB | 143/195 kB | 32/121 kB | 28/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 28/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 32/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 32/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 32/80 kBProgress (4): 0.2/1.0 MB | 151/195 kB | 32/121 kB | 32/80 kBProgress (4): 0.2/1.0 MB | 151/195 kB | 32/121 kB | 32/80 kBProgress (4): 0.2/1.0 MB | 151/195 kB | 32/121 kB | 36/80 kBProgress (4): 0.2/1.0 MB | 155/195 kB | 32/121 kB | 36/80 kBProgress (4): 0.2/1.0 MB | 155/195 kB | 32/121 kB | 36/80 kBProgress (4): 0.2/1.0 MB | 155/195 kB | 32/121 kB | 40/80 kBProgress (4): 0.2/1.0 MB | 159/195 kB | 32/121 kB | 40/80 kBProgress (4): 0.2/1.0 MB | 159/195 kB | 32/121 kB | 45/80 kBProgress (4): 0.2/1.0 MB | 163/195 kB | 32/121 kB | 45/80 kBProgress (4): 0.2/1.0 MB | 163/195 kB | 32/121 kB | 49/80 kBProgress (4): 0.2/1.0 MB | 163/195 kB | 32/121 kB | 49/80 kBProgress (4): 0.3/1.0 MB | 163/195 kB | 32/121 kB | 49/80 kBProgress (4): 0.3/1.0 MB | 167/195 kB | 32/121 kB | 49/80 kBProgress (4): 0.3/1.0 MB | 167/195 kB | 32/121 kB | 49/80 kBProgress (4): 0.3/1.0 MB | 167/195 kB | 32/121 kB | 53/80 kBProgress (4): 0.3/1.0 MB | 171/195 kB | 32/121 kB | 53/80 kBProgress (4): 0.3/1.0 MB | 171/195 kB | 32/121 kB | 53/80 kBProgress (4): 0.3/1.0 MB | 171/195 kB | 32/121 kB | 57/80 kBProgress (4): 0.3/1.0 MB | 176/195 kB | 32/121 kB | 57/80 kBProgress (4): 0.3/1.0 MB | 176/195 kB | 32/121 kB | 61/80 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 32/121 kB | 61/80 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.3/1.0 MB | 184/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.3/1.0 MB | 184/195 kB | 32/121 kB | 69/80 kBProgress (4): 0.3/1.0 MB | 184/195 kB | 32/121 kB | 69/80 kBProgress (4): 0.3/1.0 MB | 188/195 kB | 32/121 kB | 69/80 kBProgress (4): 0.3/1.0 MB | 188/195 kB | 32/121 kB | 73/80 kBProgress (4): 0.3/1.0 MB | 188/195 kB | 32/121 kB | 73/80 kBProgress (4): 0.3/1.0 MB | 192/195 kB | 32/121 kB | 73/80 kBProgress (4): 0.3/1.0 MB | 192/195 kB | 32/121 kB | 77/80 kBProgress (4): 0.3/1.0 MB | 195 kB | 32/121 kB | 77/80 kB Progress (4): 0.3/1.0 MB | 195 kB | 32/121 kB | 80 kB Progress (4): 0.3/1.0 MB | 195 kB | 36/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 40/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 45/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 49/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 53/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 57/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 61/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 65/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 69/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 73/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 77/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 81/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 85/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 90/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 94/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 98/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 102/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 106/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 110/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 114/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 118/121 kB | 80 kBProgress (4): 0.3/1.0 MB | 195 kB | 121 kB | 80 kB Progress (5): 0.3/1.0 MB | 195 kB | 121 kB | 80 kB | 4.1/251 kBProgress (5): 0.3/1.0 MB | 195 kB | 121 kB | 80 kB | 7.7/251 kBProgress (5): 0.3/1.0 MB | 195 kB | 121 kB | 80 kB | 7.7/251 kBProgress (5): 0.3/1.0 MB | 195 kB | 121 kB | 80 kB | 12/251 kB Progress (5): 0.3/1.0 MB | 195 kB | 121 kB | 80 kB | 16/251 kBProgress (5): 0.3/1.0 MB | 195 kB | 121 kB | 80 kB | 16/251 kBProgress (5): 0.3/1.0 MB | 195 kB | 121 kB | 80 kB | 16/251 kBProgress (5): 0.3/1.0 MB | 195 kB | 121 kB | 80 kB | 16/251 kBProgress (5): 0.3/1.0 MB | 195 kB | 121 kB | 80 kB | 20/251 kBProgress (5): 0.3/1.0 MB | 195 kB | 121 kB | 80 kB | 24/251 kBProgress (5): 0.3/1.0 MB | 195 kB | 121 kB | 80 kB | 28/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar (195 kB at 2.7 MB/s)
Progress (4): 0.3/1.0 MB | 121 kB | 80 kB | 32/251 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar
Progress (4): 0.3/1.0 MB | 121 kB | 80 kB | 36/251 kBProgress (4): 0.3/1.0 MB | 121 kB | 80 kB | 40/251 kBProgress (4): 0.3/1.0 MB | 121 kB | 80 kB | 40/251 kBProgress (4): 0.3/1.0 MB | 121 kB | 80 kB | 40/251 kBProgress (4): 0.3/1.0 MB | 121 kB | 80 kB | 40/251 kBProgress (4): 0.3/1.0 MB | 121 kB | 80 kB | 40/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar (121 kB at 1.6 MB/s)
Progress (3): 0.3/1.0 MB | 80 kB | 40/251 kBProgress (3): 0.3/1.0 MB | 80 kB | 40/251 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar
Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar (80 kB at 1.0 MB/s)
Progress (2): 0.3/1.0 MB | 40/251 kBProgress (2): 0.3/1.0 MB | 45/251 kBProgress (2): 0.3/1.0 MB | 45/251 kBProgress (2): 0.3/1.0 MB | 49/251 kBProgress (2): 0.3/1.0 MB | 53/251 kBProgress (2): 0.3/1.0 MB | 57/251 kBProgress (2): 0.3/1.0 MB | 61/251 kBProgress (2): 0.3/1.0 MB | 61/251 kBProgress (2): 0.3/1.0 MB | 65/251 kBProgress (2): 0.3/1.0 MB | 65/251 kBProgress (2): 0.3/1.0 MB | 65/251 kBProgress (2): 0.3/1.0 MB | 65/251 kBProgress (2): 0.3/1.0 MB | 69/251 kBProgress (2): 0.3/1.0 MB | 73/251 kBProgress (2): 0.3/1.0 MB | 77/251 kBProgress (2): 0.3/1.0 MB | 81/251 kBProgress (2): 0.3/1.0 MB | 81/251 kBProgress (2): 0.3/1.0 MB | 85/251 kBProgress (2): 0.4/1.0 MB | 85/251 kBProgress (2): 0.4/1.0 MB | 90/251 kBProgress (2): 0.4/1.0 MB | 90/251 kBProgress (2): 0.4/1.0 MB | 94/251 kBProgress (2): 0.4/1.0 MB | 98/251 kBProgress (2): 0.4/1.0 MB | 98/251 kBProgress (2): 0.4/1.0 MB | 102/251 kBProgress (2): 0.4/1.0 MB | 106/251 kBProgress (2): 0.4/1.0 MB | 110/251 kBProgress (2): 0.4/1.0 MB | 114/251 kBProgress (2): 0.4/1.0 MB | 114/251 kBProgress (2): 0.4/1.0 MB | 114/251 kBProgress (2): 0.4/1.0 MB | 114/251 kBProgress (2): 0.4/1.0 MB | 114/251 kBProgress (2): 0.4/1.0 MB | 118/251 kBProgress (2): 0.4/1.0 MB | 122/251 kBProgress (2): 0.4/1.0 MB | 126/251 kBProgress (2): 0.4/1.0 MB | 131/251 kBProgress (2): 0.4/1.0 MB | 131/251 kBProgress (2): 0.4/1.0 MB | 131/251 kBProgress (2): 0.4/1.0 MB | 131/251 kBProgress (2): 0.4/1.0 MB | 135/251 kBProgress (2): 0.4/1.0 MB | 135/251 kBProgress (2): 0.4/1.0 MB | 139/251 kBProgress (2): 0.4/1.0 MB | 143/251 kBProgress (2): 0.4/1.0 MB | 147/251 kBProgress (2): 0.4/1.0 MB | 151/251 kBProgress (2): 0.4/1.0 MB | 155/251 kBProgress (2): 0.4/1.0 MB | 155/251 kBProgress (2): 0.4/1.0 MB | 159/251 kBProgress (2): 0.4/1.0 MB | 159/251 kBProgress (2): 0.4/1.0 MB | 163/251 kBProgress (2): 0.4/1.0 MB | 163/251 kBProgress (2): 0.4/1.0 MB | 163/251 kBProgress (2): 0.4/1.0 MB | 167/251 kBProgress (2): 0.4/1.0 MB | 171/251 kBProgress (2): 0.4/1.0 MB | 176/251 kBProgress (2): 0.4/1.0 MB | 180/251 kBProgress (2): 0.4/1.0 MB | 184/251 kBProgress (2): 0.4/1.0 MB | 188/251 kBProgress (2): 0.4/1.0 MB | 192/251 kBProgress (2): 0.4/1.0 MB | 196/251 kBProgress (2): 0.4/1.0 MB | 200/251 kBProgress (2): 0.4/1.0 MB | 204/251 kBProgress (2): 0.4/1.0 MB | 208/251 kBProgress (2): 0.4/1.0 MB | 212/251 kBProgress (2): 0.4/1.0 MB | 217/251 kBProgress (2): 0.4/1.0 MB | 221/251 kBProgress (2): 0.4/1.0 MB | 225/251 kBProgress (2): 0.4/1.0 MB | 229/251 kBProgress (2): 0.4/1.0 MB | 233/251 kBProgress (2): 0.4/1.0 MB | 237/251 kBProgress (2): 0.4/1.0 MB | 241/251 kBProgress (2): 0.4/1.0 MB | 245/251 kBProgress (2): 0.4/1.0 MB | 249/251 kBProgress (2): 0.4/1.0 MB | 251 kB Progress (3): 0.4/1.0 MB | 251 kB | 4.1/12 kBProgress (3): 0.4/1.0 MB | 251 kB | 7.7/12 kBProgress (3): 0.4/1.0 MB | 251 kB | 12/12 kB Progress (3): 0.4/1.0 MB | 251 kB | 12 kB Progress (3): 0.4/1.0 MB | 251 kB | 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar (251 kB at 2.8 MB/s)
Progress (2): 0.4/1.0 MB | 12 kBProgress (2): 0.4/1.0 MB | 12 kBProgress (2): 0.4/1.0 MB | 12 kBProgress (2): 0.4/1.0 MB | 12 kBProgress (2): 0.4/1.0 MB | 12 kBProgress (2): 0.4/1.0 MB | 12 kBProgress (2): 0.4/1.0 MB | 12 kBProgress (2): 0.4/1.0 MB | 12 kBProgress (2): 0.5/1.0 MB | 12 kBProgress (2): 0.5/1.0 MB | 12 kBProgress (2): 0.5/1.0 MB | 12 kBProgress (2): 0.5/1.0 MB | 12 kBProgress (2): 0.5/1.0 MB | 12 kBProgress (2): 0.5/1.0 MB | 12 kBProgress (2): 0.5/1.0 MB | 12 kBProgress (2): 0.5/1.0 MB | 12 kBProgress (2): 0.5/1.0 MB | 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar (12 kB at 126 kB/s)
Progress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0 MB Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar (1.0 MB at 7.5 MB/s)
Progress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar (1.3 MB at 4.8 MB/s)
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 45.524 s
[e[1;34mINFOe[m] Finished at: 2019-05-27T20:14:02Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
See <http://build.geoserver.org/job/geoserver-master-live-docs/1821/display/redirect&gt;
[...truncated 388.07 KB...]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
Progress (1): 861 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom (861 B at 96 kB/s)
Progress (1): 643 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom (643 B at 161 kB/s)
Progress (1): 2.2/12 kBProgress (1): 5.0/12 kBProgress (1): 7.8/12 kBProgress (1): 11/12 kB Progress (1): 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom (12 kB at 2.4 MB/s)
Progress (1): 1.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom (1.8 kB at 460 kB/s)
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom (1.6 kB at 406 kB/s)
Progress (1): 2.2/2.7 kBProgress (1): 2.7 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom (2.7 kB at 678 kB/s)
Progress (1): 767 B Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom (767 B at 384 kB/s)
Progress (1): 1.2 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom (1.2 kB at 309 kB/s)
Progress (1): 998 B Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom (998 B at 499 kB/s)
Progress (1): 1.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom (1.4 kB at 340 kB/s)
Progress (1): 1.5 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom (1.5 kB at 372 kB/s)
Progress (1): 765 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom (765 B at 191 kB/s)
Progress (1): 2.2/5.3 kBProgress (1): 5.0/5.3 kBProgress (1): 5.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom (5.3 kB at 1.3 MB/s)
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom (9.8 kB at 2.5 MB/s)
Progress (1): 2.2/4.4 kBProgress (1): 4.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom (4.4 kB at 730 kB/s)
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom (9.8 kB at 1.2 MB/s)
Progress (1): 2.2/224 kBProgress (1): 5.0/224 kBProgress (1): 7.7/224 kBProgress (1): 10/224 kB Progress (1): 13/224 kBProgress (1): 16/224 kBProgress (1): 19/224 kBProgress (1): 21/224 kBProgress (1): 24/224 kBProgress (1): 27/224 kBProgress (1): 30/224 kBProgress (1): 32/224 kBProgress (1): 36/224 kBProgress (1): 40/224 kBProgress (1): 45/224 kBProgress (1): 49/224 kBProgress (1): 53/224 kBProgress (1): 57/224 kBProgress (1): 61/224 kBProgress (1): 65/224 kBProgress (1): 69/224 kBProgress (1): 73/224 kBProgress (1): 77/224 kBProgress (1): 81/224 kBProgress (1): 85/224 kBProgress (1): 90/224 kBProgress (1): 94/224 kBProgress (1): 98/224 kBProgress (1): 102/224 kBProgress (1): 106/224 kBProgress (1): 110/224 kBProgress (1): 114/224 kBProgress (1): 118/224 kBProgress (1): 122/224 kBProgress (1): 126/224 kBProgress (1): 131/224 kBProgress (1): 135/224 kBProgress (1): 139/224 kBProgress (1): 143/224 kBProgress (1): 147/224 kBProgress (1): 151/224 kBProgress (1): 155/224 kBProgress (1): 159/224 kBProgress (1): 163/224 kBProgress (1): 167/224 kBProgress (1): 171/224 kBProgress (1): 176/224 kBProgress (1): 180/224 kBProgress (2): 180/224 kB | 2.2/8.3 kBProgress (2): 180/224 kB | 5.0/8.3 kBProgress (2): 180/224 kB | 7.7/8.3 kBProgress (2): 180/224 kB | 8.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar (8.3 kB at 490 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar
Progress (1): 184/224 kBProgress (1): 188/224 kBProgress (1): 192/224 kBProgress (1): 196/224 kBProgress (1): 200/224 kBProgress (1): 204/224 kBProgress (1): 208/224 kBProgress (1): 212/224 kBProgress (1): 217/224 kBProgress (1): 221/224 kBProgress (1): 224 kB Progress (2): 224 kB | 2.2/44 kBProgress (2): 224 kB | 5.0/44 kBProgress (3): 224 kB | 5.0/44 kB | 2.2/109 kBProgress (3): 224 kB | 7.7/44 kB | 2.2/109 kBProgress (3): 224 kB | 7.7/44 kB | 5.0/109 kBProgress (3): 224 kB | 10/44 kB | 5.0/109 kB Progress (3): 224 kB | 10/44 kB | 7.7/109 kBProgress (3): 224 kB | 13/44 kB | 7.7/109 kBProgress (3): 224 kB | 13/44 kB | 10/109 kB Progress (3): 224 kB | 16/44 kB | 10/109 kBProgress (3): 224 kB | 16/44 kB | 13/109 kBProgress (3): 224 kB | 16/44 kB | 16/109 kBProgress (3): 224 kB | 16/44 kB | 19/109 kBProgress (3): 224 kB | 20/44 kB | 19/109 kBProgress (3): 224 kB | 24/44 kB | 19/109 kBProgress (3): 224 kB | 24/44 kB | 21/109 kBProgress (3): 224 kB | 28/44 kB | 21/109 kBProgress (3): 224 kB | 28/44 kB | 24/109 kBProgress (3): 224 kB | 32/44 kB | 24/109 kBProgress (3): 224 kB | 32/44 kB | 27/109 kBProgress (3): 224 kB | 32/44 kB | 30/109 kBProgress (3): 224 kB | 36/44 kB | 30/109 kBProgress (3): 224 kB | 40/44 kB | 30/109 kBProgress (3): 224 kB | 44 kB | 30/109 kB Progress (4): 224 kB | 44 kB | 30/109 kB | 2.2/30 kBProgress (4): 224 kB | 44 kB | 30/109 kB | 5.0/30 kB Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar (224 kB at 9.3 MB/s)
Progress (3): 44 kB | 32/109 kB | 5.0/30 kBProgress (3): 44 kB | 32/109 kB | 7.7/30 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar
Progress (3): 44 kB | 32/109 kB | 11/30 kBProgress (3): 44 kB | 32/109 kB | 13/30 kBProgress (3): 44 kB | 32/109 kB | 16/30 kBProgress (3): 44 kB | 32/109 kB | 19/30 kBProgress (3): 44 kB | 32/109 kB | 21/30 kBProgress (3): 44 kB | 32/109 kB | 24/30 kBProgress (3): 44 kB | 32/109 kB | 27/30 kBProgress (3): 44 kB | 32/109 kB | 30/30 kBProgress (3): 44 kB | 32/109 kB | 30 kB Progress (4): 44 kB | 32/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 36/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 40/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 40/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 45/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 49/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 49/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 49/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 49/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 53/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 53/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 53/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 57/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 57/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 61/109 kB | 30 kB | 0/1.0 MBProgress (4): 44 kB | 61/109 kB | 30 kB | 0/1.0 MBProgress (5): 44 kB | 61/109 kB | 30 kB | 0/1.0 MB | 4.1/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar (44 kB at 1.3 MB/s)
Progress (4): 65/109 kB | 30 kB | 0/1.0 MB | 4.1/80 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar
Progress (4): 65/109 kB | 30 kB | 0/1.0 MB | 4.1/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar (30 kB at 916 kB/s)
Progress (3): 65/109 kB | 0/1.0 MB | 7.7/80 kBProgress (3): 65/109 kB | 0/1.0 MB | 12/80 kB Progress (3): 65/109 kB | 0/1.0 MB | 12/80 kBProgress (3): 65/109 kB | 0/1.0 MB | 16/80 kBProgress (3): 69/109 kB | 0/1.0 MB | 16/80 kBProgress (3): 69/109 kB | 0/1.0 MB | 16/80 kBProgress (3): 69/109 kB | 0/1.0 MB | 16/80 kBProgress (3): 69/109 kB | 0/1.0 MB | 16/80 kBProgress (3): 69/109 kB | 0/1.0 MB | 16/80 kBProgress (3): 69/109 kB | 0/1.0 MB | 16/80 kBProgress (4): 69/109 kB | 0/1.0 MB | 16/80 kB | 2.2/20 kBProgress (4): 69/109 kB | 0/1.0 MB | 16/80 kB | 5.0/20 kBProgress (4): 69/109 kB | 0/1.0 MB | 16/80 kB | 7.7/20 kBProgress (4): 69/109 kB | 0/1.0 MB | 16/80 kB | 10/20 kB Progress (4): 69/109 kB | 0.1/1.0 MB | 16/80 kB | 10/20 kBProgress (4): 69/109 kB | 0.1/1.0 MB | 16/80 kB | 13/20 kBProgress (4): 69/109 kB | 0.1/1.0 MB | 16/80 kB | 13/20 kBProgress (4): 69/109 kB | 0.1/1.0 MB | 16/80 kB | 16/20 kBProgress (4): 69/109 kB | 0.1/1.0 MB | 16/80 kB | 16/20 kBProgress (4): 69/109 kB | 0.1/1.0 MB | 16/80 kB | 19/20 kBProgress (4): 69/109 kB | 0.1/1.0 MB | 16/80 kB | 19/20 kBProgress (4): 69/109 kB | 0.1/1.0 MB | 16/80 kB | 20 kB Progress (4): 73/109 kB | 0.1/1.0 MB | 16/80 kB | 20 kBProgress (4): 77/109 kB | 0.1/1.0 MB | 16/80 kB | 20 kBProgress (4): 81/109 kB | 0.1/1.0 MB | 16/80 kB | 20 kBProgress (4): 81/109 kB | 0.1/1.0 MB | 16/80 kB | 20 kBProgress (4): 81/109 kB | 0.1/1.0 MB | 20/80 kB | 20 kBProgress (4): 85/109 kB | 0.1/1.0 MB | 20/80 kB | 20 kBProgress (4): 85/109 kB | 0.1/1.0 MB | 20/80 kB | 20 kBProgress (4): 85/109 kB | 0.1/1.0 MB | 20/80 kB | 20 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar (20 kB at 469 kB/s)
Progress (3): 85/109 kB | 0.1/1.0 MB | 24/80 kBProgress (3): 90/109 kB | 0.1/1.0 MB | 24/80 kBProgress (3): 90/109 kB | 0.1/1.0 MB | 24/80 kBProgress (3): 90/109 kB | 0.1/1.0 MB | 28/80 kBProgress (3): 90/109 kB | 0.1/1.0 MB | 32/80 kBProgress (3): 94/109 kB | 0.1/1.0 MB | 32/80 kBProgress (3): 94/109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 98/109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 98/109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 102/109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 102/109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 102/109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 106/109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 106/109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 109 kB | 0.1/1.0 MB | 36/80 kB Progress (3): 109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 109 kB | 0.1/1.0 MB | 36/80 kBProgress (3): 109 kB | 0.1/1.0 MB | 36/80 kBProgress (4): 109 kB | 0.1/1.0 MB | 36/80 kB | 2.2/195 kBProgress (4): 109 kB | 0.1/1.0 MB | 36/80 kB | 5.0/195 kBProgress (4): 109 kB | 0.1/1.0 MB | 36/80 kB | 7.7/195 kBProgress (5): 109 kB | 0.1/1.0 MB | 36/80 kB | 7.7/195 kB | 4.1/49 kBProgress (5): 109 kB | 0.1/1.0 MB | 36/80 kB | 10/195 kB | 4.1/49 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar (109 kB at 2.0 MB/s)
Progress (4): 0.1/1.0 MB | 36/80 kB | 10/195 kB | 7.7/49 kBProgress (4): 0.1/1.0 MB | 36/80 kB | 10/195 kB | 12/49 kB Progress (4): 0.1/1.0 MB | 36/80 kB | 10/195 kB | 16/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 10/195 kB | 16/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 13/195 kB | 16/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 16/195 kB | 16/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 16/195 kB | 20/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 19/195 kB | 20/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 19/195 kB | 24/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 21/195 kB | 24/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 21/195 kB | 28/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 24/195 kB | 28/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 24/195 kB | 32/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 27/195 kB | 32/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 30/195 kB | 32/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 32/195 kB | 32/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 36/195 kB | 32/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 36/195 kB | 36/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 40/195 kB | 36/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 40/195 kB | 40/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 45/195 kB | 40/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 45/195 kB | 45/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 49/195 kB | 45/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 49/195 kB | 49/49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 49/195 kB | 49 kB Progress (4): 0.1/1.0 MB | 40/80 kB | 53/195 kB | 49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 57/195 kB | 49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 61/195 kB | 49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 65/195 kB | 49 kBProgress (4): 0.1/1.0 MB | 40/80 kB | 69/195 kB | 49 kBProgress (5): 0.1/1.0 MB | 40/80 kB | 69/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 40/80 kB | 69/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 40/80 kB | 73/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 40/80 kB | 77/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 40/80 kB | 81/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 45/80 kB | 81/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 45/80 kB | 85/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 45/80 kB | 90/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 45/80 kB | 94/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 45/80 kB | 98/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 49/80 kB | 98/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 49/80 kB | 102/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 49/80 kB | 106/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 49/80 kB | 110/195 kB | 49 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 49/80 kB | 114/195 kB | 49 kB | 4.1/121 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar (49 kB at 845 kB/s)
Progress (4): 0.1/1.0 MB | 49/80 kB | 118/195 kB | 4.1/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 122/195 kB | 4.1/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 126/195 kB | 4.1/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 131/195 kB | 4.1/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 135/195 kB | 4.1/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 139/195 kB | 4.1/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 143/195 kB | 4.1/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 147/195 kB | 4.1/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 151/195 kB | 4.1/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 151/195 kB | 4.1/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 151/195 kB | 4.1/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 151/195 kB | 7.6/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 151/195 kB | 12/121 kB Progress (4): 0.1/1.0 MB | 49/80 kB | 151/195 kB | 12/121 kBProgress (4): 0.1/1.0 MB | 49/80 kB | 151/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49/80 kB | 151/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49/80 kB | 151/195 kB | 20/121 kBProgress (5): 0.2/1.0 MB | 49/80 kB | 151/195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 151/195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 155/195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 159/195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 163/195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 167/195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 171/195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 176/195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 180/195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 184/195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 188/195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 192/195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 195 kB | 20/121 kB | 4.1/80 kB Progress (5): 0.2/1.0 MB | 53/80 kB | 195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 195 kB | 20/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 195 kB | 24/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 195 kB | 28/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 53/80 kB | 195 kB | 32/121 kB | 4.1/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar (195 kB at 2.8 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar
Progress (4): 0.2/1.0 MB | 53/80 kB | 32/121 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 53/80 kB | 32/121 kB | 12/80 kB Progress (4): 0.2/1.0 MB | 53/80 kB | 32/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 57/80 kB | 32/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 61/80 kB | 32/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 65/80 kB | 32/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 65/80 kB | 36/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 65/80 kB | 40/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 65/80 kB | 45/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 65/80 kB | 49/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 69/80 kB | 49/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 73/80 kB | 49/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 77/80 kB | 49/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 16/80 kB Progress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 20/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 24/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 28/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 32/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 36/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 40/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 45/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 49/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 49/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 49/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 49/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 49/121 kB | 49/80 kBProgress (4): 0.2/1.0 MB | 80 kB | 53/121 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 80 kB | 53/121 kB | 49/80 kB | 4.1/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 53/121 kB | 49/80 kB | 7.7/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 53/121 kB | 49/80 kB | 12/251 kB Progress (5): 0.2/1.0 MB | 80 kB | 53/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 57/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 61/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 61/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 61/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 61/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 61/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 49/80 kB | 20/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 49/80 kB | 24/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 49/80 kB | 28/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 49/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 53/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 57/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 61/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 80 kB | 65/121 kB | 65/80 kB | 32/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar (80 kB at 1.0 MB/s)
Progress (4): 0.2/1.0 MB | 69/121 kB | 65/80 kB | 32/251 kBProgress (4): 0.2/1.0 MB | 73/121 kB | 65/80 kB | 32/251 kBProgress (4): 0.2/1.0 MB | 77/121 kB | 65/80 kB | 32/251 kBProgress (4): 0.2/1.0 MB | 77/121 kB | 65/80 kB | 36/251 kBProgress (4): 0.2/1.0 MB | 77/121 kB | 65/80 kB | 40/251 kBProgress (4): 0.2/1.0 MB | 81/121 kB | 65/80 kB | 40/251 kBProgress (4): 0.2/1.0 MB | 81/121 kB | 65/80 kB | 40/251 kBProgress (4): 0.2/1.0 MB | 81/121 kB | 65/80 kB | 40/251 kBProgress (4): 0.2/1.0 MB | 81/121 kB | 65/80 kB | 40/251 kBProgress (4): 0.2/1.0 MB | 81/121 kB | 65/80 kB | 40/251 kBProgress (4): 0.2/1.0 MB | 81/121 kB | 69/80 kB | 40/251 kBProgress (4): 0.2/1.0 MB | 81/121 kB | 73/80 kB | 40/251 kBProgress (4): 0.2/1.0 MB | 81/121 kB | 77/80 kB | 40/251 kBProgress (4): 0.2/1.0 MB | 81/121 kB | 80 kB | 40/251 kB Progress (4): 0.2/1.0 MB | 81/121 kB | 80 kB | 45/251 kBProgress (4): 0.2/1.0 MB | 81/121 kB | 80 kB | 49/251 kBProgress (5): 0.2/1.0 MB | 81/121 kB | 80 kB | 49/251 kB | 4.1/12 kBProgress (5): 0.2/1.0 MB | 81/121 kB | 80 kB | 49/251 kB | 7.7/12 kBProgress (5): 0.2/1.0 MB | 81/121 kB | 80 kB | 49/251 kB | 12/12 kB Progress (5): 0.2/1.0 MB | 81/121 kB | 80 kB | 49/251 kB | 12 kB Progress (5): 0.2/1.0 MB | 81/121 kB | 80 kB | 53/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 85/121 kB | 80 kB | 53/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 90/121 kB | 80 kB | 53/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 90/121 kB | 80 kB | 57/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 90/121 kB | 80 kB | 57/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 90/121 kB | 80 kB | 57/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 90/121 kB | 80 kB | 57/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 90/121 kB | 80 kB | 57/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 94/121 kB | 80 kB | 57/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 98/121 kB | 80 kB | 57/251 kB | 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar (80 kB at 912 kB/s)
Progress (4): 0.2/1.0 MB | 98/121 kB | 61/251 kB | 12 kBProgress (4): 0.2/1.0 MB | 98/121 kB | 65/251 kB | 12 kBProgress (4): 0.2/1.0 MB | 102/121 kB | 65/251 kB | 12 kBProgress (4): 0.2/1.0 MB | 102/121 kB | 65/251 kB | 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar (12 kB at 135 kB/s)
Progress (3): 0.3/1.0 MB | 102/121 kB | 65/251 kBProgress (3): 0.3/1.0 MB | 102/121 kB | 69/251 kBProgress (3): 0.3/1.0 MB | 102/121 kB | 73/251 kBProgress (3): 0.3/1.0 MB | 102/121 kB | 77/251 kBProgress (3): 0.3/1.0 MB | 102/121 kB | 81/251 kBProgress (3): 0.3/1.0 MB | 102/121 kB | 81/251 kBProgress (3): 0.3/1.0 MB | 102/121 kB | 81/251 kBProgress (3): 0.3/1.0 MB | 106/121 kB | 81/251 kBProgress (3): 0.3/1.0 MB | 110/121 kB | 81/251 kBProgress (3): 0.3/1.0 MB | 114/121 kB | 81/251 kBProgress (3): 0.3/1.0 MB | 118/121 kB | 81/251 kBProgress (3): 0.3/1.0 MB | 121 kB | 81/251 kB Progress (3): 0.3/1.0 MB | 121 kB | 85/251 kBProgress (3): 0.3/1.0 MB | 121 kB | 90/251 kBProgress (3): 0.3/1.0 MB | 121 kB | 94/251 kBProgress (3): 0.3/1.0 MB | 121 kB | 98/251 kBProgress (3): 0.3/1.0 MB | 121 kB | 98/251 kBProgress (3): 0.3/1.0 MB | 121 kB | 98/251 kBProgress (4): 0.3/1.0 MB | 121 kB | 98/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 98/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 98/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 98/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 98/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 98/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 98/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 98/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 98/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 98/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 102/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 106/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 110/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 121 kB | 114/251 kB | 0/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar (121 kB at 1.2 MB/s)
Progress (3): 0.3/1.0 MB | 118/251 kB | 0/1.3 MBProgress (3): 0.3/1.0 MB | 122/251 kB | 0/1.3 MBProgress (3): 0.3/1.0 MB | 126/251 kB | 0/1.3 MBProgress (3): 0.3/1.0 MB | 131/251 kB | 0/1.3 MBProgress (3): 0.3/1.0 MB | 131/251 kB | 0/1.3 MBProgress (3): 0.3/1.0 MB | 131/251 kB | 0/1.3 MBProgress (3): 0.3/1.0 MB | 131/251 kB | 0/1.3 MBProgress (3): 0.3/1.0 MB | 131/251 kB | 0/1.3 MBProgress (3): 0.3/1.0 MB | 131/251 kB | 0/1.3 MBProgress (3): 0.3/1.0 MB | 131/251 kB | 0/1.3 MBProgress (3): 0.3/1.0 MB | 131/251 kB | 0/1.3 MBProgress (3): 0.3/1.0 MB | 131/251 kB | 0.1/1.3 MBProgress (3): 0.3/1.0 MB | 131/251 kB | 0.1/1.3 MBProgress (3): 0.3/1.0 MB | 131/251 kB | 0.1/1.3 MBProgress (3): 0.3/1.0 MB | 135/251 kB | 0.1/1.3 MBProgress (3): 0.3/1.0 MB | 139/251 kB | 0.1/1.3 MBProgress (3): 0.3/1.0 MB | 143/251 kB | 0.1/1.3 MBProgress (3): 0.3/1.0 MB | 147/251 kB | 0.1/1.3 MBProgress (3): 0.3/1.0 MB | 147/251 kB | 0.1/1.3 MBProgress (3): 0.3/1.0 MB | 147/251 kB | 0.1/1.3 MBProgress (3): 0.3/1.0 MB | 147/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 147/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 147/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 151/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 151/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 151/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 155/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 159/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 163/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 163/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 163/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 163/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 163/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 163/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 163/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 167/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 167/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 171/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 171/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 176/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 180/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 180/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 180/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 180/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 180/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 180/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 180/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 180/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 184/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 188/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 188/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 192/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 192/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 192/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 196/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 196/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 196/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 196/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 196/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 196/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 200/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 200/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 204/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 208/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 208/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 212/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 212/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 212/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 212/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 212/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 212/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 212/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 217/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 221/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 221/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 225/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 229/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 229/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 229/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 229/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 229/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 229/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 229/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 229/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 233/251 kB | 0.1/1.3 MBProgress (3): 0.4/1.0 MB | 233/251 kB | 0.1/1.3 MBProgress (3): 0.5/1.0 MB | 233/251 kB | 0.1/1.3 MBProgress (3): 0.5/1.0 MB | 233/251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 237/251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 237/251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 241/251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 241/251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 245/251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 249/251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 249/251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 249/251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MB Progress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.5/1.0 MB | 251 kB | 0.2/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar (251 kB at 1.9 MB/s)
Progress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.6/1.0 MB | 0.2/1.3 MBProgress (2): 0.6/1.0 MB | 0.2/1.3 MBProgress (2): 0.6/1.0 MB | 0.2/1.3 MBProgress (2): 0.6/1.0 MB | 0.2/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.6/1.3 MBProgress (2): 0.7/1.0 MB | 0.6/1.3 MBProgress (2): 0.7/1.0 MB | 0.6/1.3 MBProgress (2): 0.7/1.0 MB | 0.6/1.3 MBProgress (2): 0.7/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MB Progress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar (1.0 MB at 5.6 MB/s)
Progress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar (1.3 MB at 6.4 MB/s)
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en&gt;
     [echo] Build directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.16-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;:137:Inline literal start-string without end-string.
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 45.336 s
[e[1;34mINFOe[m] Finished at: 2019-05-27T20:24:02Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://build.geoserver.org/job/geoserver-master-live-docs/1822/display/redirect&gt;
[...truncated 398.00 KB...]
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom
Progress (1): 861 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom (861 B at 172 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom
Progress (1): 761 B Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom (761 B at 190 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom
Progress (1): 138 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom (138 B at 28 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom
Progress (1): 643 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom (643 B at 161 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom
Progress (1): 2.2/12 kBProgress (1): 5.0/12 kBProgress (1): 7.8/12 kBProgress (1): 11/12 kB Progress (1): 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom (12 kB at 2.0 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom
Progress (1): 1.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom (1.8 kB at 263 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom (1.6 kB at 325 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom
Progress (1): 2.2/2.7 kBProgress (1): 2.7 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom (2.7 kB at 678 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom
Progress (1): 767 B Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom (767 B at 192 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom
Progress (1): 1.2 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom (1.2 kB at 412 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom
Progress (1): 998 B Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom (998 B at 333 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom (1.6 kB at 539 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom
Progress (1): 1.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom (1.4 kB at 340 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom
Progress (1): 1.5 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom (1.5 kB at 372 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom
Progress (1): 765 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom (765 B at 191 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom
Progress (1): 2.8/5.3 kBProgress (1): 5.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom (5.3 kB at 1.8 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom
Progress (1): 2.8/9.8 kBProgress (1): 5.5/9.8 kBProgress (1): 8.3/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom (9.8 kB at 2.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom
Progress (1): 2.2/2.4 kBProgress (1): 2.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom (2.4 kB at 596 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom
Progress (1): 2.2/4.4 kBProgress (1): 4.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom (4.4 kB at 1.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom (9.8 kB at 2.4 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar
Progress (1): 2.8/8.3 kBProgress (1): 5.5/8.3 kBProgress (2): 5.5/8.3 kB | 2.2/224 kBProgress (2): 8.3/8.3 kB | 2.2/224 kBProgress (2): 8.3 kB | 2.2/224 kB Progress (2): 8.3 kB | 5.0/224 kBProgress (2): 8.3 kB | 7.7/224 kBProgress (2): 8.3 kB | 10/224 kB Progress (2): 8.3 kB | 13/224 kBProgress (2): 8.3 kB | 16/224 kBProgress (2): 8.3 kB | 19/224 kBProgress (2): 8.3 kB | 21/224 kBProgress (2): 8.3 kB | 24/224 kBProgress (2): 8.3 kB | 27/224 kBProgress (2): 8.3 kB | 30/224 kBProgress (2): 8.3 kB | 32/224 kBProgress (3): 8.3 kB | 32/224 kB | 0/1.0 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar (8.3 kB at 833 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar
Progress (2): 32/224 kB | 0/1.0 MBProgress (2): 32/224 kB | 0/1.0 MBProgress (2): 32/224 kB | 0/1.0 MBProgress (2): 32/224 kB | 0/1.0 MBProgress (2): 36/224 kB | 0/1.0 MBProgress (2): 40/224 kB | 0/1.0 MBProgress (2): 45/224 kB | 0/1.0 MBProgress (2): 49/224 kB | 0/1.0 MBProgress (2): 49/224 kB | 0/1.0 MBProgress (2): 49/224 kB | 0/1.0 MBProgress (3): 49/224 kB | 0/1.0 MB | 2.2/109 kBProgress (3): 49/224 kB | 0/1.0 MB | 2.2/109 kBProgress (3): 49/224 kB | 0/1.0 MB | 2.2/109 kBProgress (3): 49/224 kB | 0/1.0 MB | 2.2/109 kBProgress (4): 49/224 kB | 0/1.0 MB | 2.2/109 kB | 2.2/30 kBProgress (4): 49/224 kB | 0/1.0 MB | 2.2/109 kB | 2.2/30 kBProgress (4): 49/224 kB | 0/1.0 MB | 2.2/109 kB | 5.0/30 kBProgress (4): 49/224 kB | 0/1.0 MB | 2.2/109 kB | 5.0/30 kBProgress (4): 49/224 kB | 0/1.0 MB | 2.2/109 kB | 7.7/30 kBProgress (5): 49/224 kB | 0/1.0 MB | 2.2/109 kB | 7.7/30 kB | 2.2/44 kBProgress (5): 49/224 kB | 0/1.0 MB | 2.2/109 kB | 10/30 kB | 2.2/44 kB Progress (5): 49/224 kB | 0/1.0 MB | 2.2/109 kB | 13/30 kB | 2.2/44 kBProgress (5): 49/224 kB | 0/1.0 MB | 2.2/109 kB | 13/30 kB | 2.2/44 kBProgress (5): 49/224 kB | 0/1.0 MB | 2.2/109 kB | 13/30 kB | 2.2/44 kBProgress (5): 49/224 kB | 0/1.0 MB | 2.2/109 kB | 16/30 kB | 2.2/44 kBProgress (5): 49/224 kB | 0/1.0 MB | 5.0/109 kB | 16/30 kB | 2.2/44 kBProgress (5): 49/224 kB | 0/1.0 MB | 5.0/109 kB | 19/30 kB | 2.2/44 kBProgress (5): 49/224 kB | 0/1.0 MB | 5.0/109 kB | 19/30 kB | 5.0/44 kBProgress (5): 49/224 kB | 0/1.0 MB | 5.0/109 kB | 19/30 kB | 5.0/44 kBProgress (5): 49/224 kB | 0/1.0 MB | 5.0/109 kB | 21/30 kB | 5.0/44 kBProgress (5): 49/224 kB | 0/1.0 MB | 5.0/109 kB | 21/30 kB | 5.0/44 kBProgress (5): 49/224 kB | 0/1.0 MB | 5.0/109 kB | 24/30 kB | 5.0/44 kBProgress (5): 53/224 kB | 0/1.0 MB | 5.0/109 kB | 24/30 kB | 5.0/44 kBProgress (5): 57/224 kB | 0/1.0 MB | 5.0/109 kB | 24/30 kB | 5.0/44 kBProgress (5): 61/224 kB | 0/1.0 MB | 5.0/109 kB | 24/30 kB | 5.0/44 kBProgress (5): 65/224 kB | 0/1.0 MB | 5.0/109 kB | 24/30 kB | 5.0/44 kBProgress (5): 65/224 kB | 0/1.0 MB | 5.0/109 kB | 24/30 kB | 7.7/44 kBProgress (5): 65/224 kB | 0/1.0 MB | 7.7/109 kB | 24/30 kB | 7.7/44 kBProgress (5): 65/224 kB | 0/1.0 MB | 7.7/109 kB | 24/30 kB | 10/44 kB Progress (5): 65/224 kB | 0.1/1.0 MB | 7.7/109 kB | 24/30 kB | 10/44 kBProgress (5): 65/224 kB | 0.1/1.0 MB | 7.7/109 kB | 27/30 kB | 10/44 kBProgress (5): 65/224 kB | 0.1/1.0 MB | 7.7/109 kB | 27/30 kB | 10/44 kBProgress (5): 65/224 kB | 0.1/1.0 MB | 7.7/109 kB | 30/30 kB | 10/44 kBProgress (5): 65/224 kB | 0.1/1.0 MB | 10/109 kB | 30/30 kB | 10/44 kB Progress (5): 69/224 kB | 0.1/1.0 MB | 10/109 kB | 30/30 kB | 10/44 kBProgress (5): 73/224 kB | 0.1/1.0 MB | 10/109 kB | 30/30 kB | 10/44 kBProgress (5): 73/224 kB | 0.1/1.0 MB | 10/109 kB | 30/30 kB | 10/44 kBProgress (5): 73/224 kB | 0.1/1.0 MB | 10/109 kB | 30 kB | 10/44 kB Progress (5): 73/224 kB | 0.1/1.0 MB | 10/109 kB | 30 kB | 10/44 kBProgress (5): 73/224 kB | 0.1/1.0 MB | 10/109 kB | 30 kB | 13/44 kBProgress (5): 73/224 kB | 0.1/1.0 MB | 13/109 kB | 30 kB | 13/44 kBProgress (5): 77/224 kB | 0.1/1.0 MB | 13/109 kB | 30 kB | 13/44 kBProgress (5): 81/224 kB | 0.1/1.0 MB | 13/109 kB | 30 kB | 13/44 kBProgress (5): 81/224 kB | 0.1/1.0 MB | 13/109 kB | 30 kB | 16/44 kBProgress (5): 81/224 kB | 0.1/1.0 MB | 16/109 kB | 30 kB | 16/44 kBProgress (5): 81/224 kB | 0.1/1.0 MB | 16/109 kB | 30 kB | 16/44 kBProgress (5): 81/224 kB | 0.1/1.0 MB | 19/109 kB | 30 kB | 16/44 kBProgress (5): 81/224 kB | 0.1/1.0 MB | 19/109 kB | 30 kB | 19/44 kBProgress (5): 81/224 kB | 0.1/1.0 MB | 19/109 kB | 30 kB | 19/44 kBProgress (5): 81/224 kB | 0.1/1.0 MB | 19/109 kB | 30 kB | 19/44 kBProgress (5): 81/224 kB | 0.1/1.0 MB | 19/109 kB | 30 kB | 19/44 kBProgress (5): 85/224 kB | 0.1/1.0 MB | 19/109 kB | 30 kB | 19/44 kBProgress (5): 90/224 kB | 0.1/1.0 MB | 19/109 kB | 30 kB | 19/44 kBProgress (5): 94/224 kB | 0.1/1.0 MB | 19/109 kB | 30 kB | 19/44 kBProgress (5): 98/224 kB | 0.1/1.0 MB | 19/109 kB | 30 kB | 19/44 kBProgress (5): 98/224 kB | 0.1/1.0 MB | 19/109 kB | 30 kB | 21/44 kBProgress (5): 98/224 kB | 0.1/1.0 MB | 21/109 kB | 30 kB | 21/44 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar (30 kB at 1.7 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar
Progress (4): 98/224 kB | 0.1/1.0 MB | 21/109 kB | 21/44 kBProgress (4): 98/224 kB | 0.1/1.0 MB | 24/109 kB | 21/44 kBProgress (4): 98/224 kB | 0.1/1.0 MB | 24/109 kB | 21/44 kBProgress (4): 98/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kBProgress (4): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kBProgress (4): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kBProgress (4): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kBProgress (4): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kBProgress (4): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kBProgress (4): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kBProgress (4): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kBProgress (5): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kB | 2.2/80 kBProgress (5): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kB | 2.2/80 kBProgress (5): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kB | 5.0/80 kBProgress (5): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kB | 5.0/80 kBProgress (5): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kB | 7.7/80 kBProgress (5): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kB | 7.7/80 kBProgress (5): 102/224 kB | 0.1/1.0 MB | 24/109 kB | 24/44 kB | 10/80 kB Progress (5): 102/224 kB | 0.1/1.0 MB | 27/109 kB | 24/44 kB | 10/80 kBProgress (5): 102/224 kB | 0.1/1.0 MB | 27/109 kB | 24/44 kB | 13/80 kBProgress (5): 102/224 kB | 0.1/1.0 MB | 27/109 kB | 24/44 kB | 13/80 kBProgress (5): 102/224 kB | 0.1/1.0 MB | 27/109 kB | 24/44 kB | 16/80 kBProgress (5): 106/224 kB | 0.1/1.0 MB | 27/109 kB | 24/44 kB | 16/80 kBProgress (5): 110/224 kB | 0.1/1.0 MB | 27/109 kB | 24/44 kB | 16/80 kBProgress (5): 114/224 kB | 0.1/1.0 MB | 27/109 kB | 24/44 kB | 16/80 kBProgress (5): 114/224 kB | 0.1/1.0 MB | 30/109 kB | 24/44 kB | 16/80 kBProgress (5): 114/224 kB | 0.1/1.0 MB | 32/109 kB | 24/44 kB | 16/80 kBProgress (5): 118/224 kB | 0.1/1.0 MB | 32/109 kB | 24/44 kB | 16/80 kBProgress (5): 122/224 kB | 0.1/1.0 MB | 32/109 kB | 24/44 kB | 16/80 kBProgress (5): 126/224 kB | 0.1/1.0 MB | 32/109 kB | 24/44 kB | 16/80 kBProgress (5): 131/224 kB | 0.1/1.0 MB | 32/109 kB | 24/44 kB | 16/80 kBProgress (5): 135/224 kB | 0.1/1.0 MB | 32/109 kB | 24/44 kB | 16/80 kBProgress (5): 135/224 kB | 0.1/1.0 MB | 32/109 kB | 27/44 kB | 16/80 kBProgress (5): 135/224 kB | 0.1/1.0 MB | 32/109 kB | 27/44 kB | 19/80 kBProgress (5): 139/224 kB | 0.1/1.0 MB | 32/109 kB | 27/44 kB | 19/80 kBProgress (5): 143/224 kB | 0.1/1.0 MB | 32/109 kB | 27/44 kB | 19/80 kBProgress (5): 143/224 kB | 0.1/1.0 MB | 32/109 kB | 30/44 kB | 19/80 kBProgress (5): 143/224 kB | 0.1/1.0 MB | 32/109 kB | 30/44 kB | 21/80 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 32/109 kB | 30/44 kB | 21/80 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 32/109 kB | 30/44 kB | 24/80 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 32/109 kB | 30/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 32/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 36/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 40/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.2/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.3/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.3/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.3/1.0 MB | 45/109 kB | 32/44 kB | 27/80 kBProgress (5): 147/224 kB | 0.3/1.0 MB | 45/109 kB | 32/44 kB | 30/80 kBProgress (5): 147/224 kB | 0.3/1.0 MB | 45/109 kB | 36/44 kB | 30/80 kBProgress (5): 147/224 kB | 0.3/1.0 MB | 45/109 kB | 40/44 kB | 30/80 kBProgress (5): 147/224 kB | 0.3/1.0 MB | 45/109 kB | 44 kB | 30/80 kB Progress (5): 151/224 kB | 0.3/1.0 MB | 45/109 kB | 44 kB | 30/80 kBProgress (5): 151/224 kB | 0.3/1.0 MB | 49/109 kB | 44 kB | 30/80 kBProgress (5): 155/224 kB | 0.3/1.0 MB | 49/109 kB | 44 kB | 30/80 kBProgress (5): 155/224 kB | 0.3/1.0 MB | 49/109 kB | 44 kB | 32/80 kBProgress (5): 159/224 kB | 0.3/1.0 MB | 49/109 kB | 44 kB | 32/80 kBProgress (5): 163/224 kB | 0.3/1.0 MB | 49/109 kB | 44 kB | 32/80 kBProgress (5): 163/224 kB | 0.3/1.0 MB | 49/109 kB | 44 kB | 36/80 kBProgress (5): 163/224 kB | 0.3/1.0 MB | 49/109 kB | 44 kB | 40/80 kBProgress (5): 163/224 kB | 0.3/1.0 MB | 49/109 kB | 44 kB | 45/80 kBProgress (5): 163/224 kB | 0.3/1.0 MB | 49/109 kB | 44 kB | 49/80 kBProgress (5): 163/224 kB | 0.3/1.0 MB | 53/109 kB | 44 kB | 49/80 kBProgress (5): 163/224 kB | 0.3/1.0 MB | 57/109 kB | 44 kB | 49/80 kBProgress (5): 163/224 kB | 0.3/1.0 MB | 57/109 kB | 44 kB | 53/80 kBProgress (5): 163/224 kB | 0.3/1.0 MB | 61/109 kB | 44 kB | 53/80 kBProgress (5): 163/224 kB | 0.3/1.0 MB | 61/109 kB | 44 kB | 57/80 kBProgress (5): 163/224 kB | 0.3/1.0 MB | 61/109 kB | 44 kB | 61/80 kBProgress (5): 163/224 kB | 0.3/1.0 MB | 61/109 kB | 44 kB | 65/80 kBProgress (5): 167/224 kB | 0.3/1.0 MB | 61/109 kB | 44 kB | 65/80 kBProgress (5): 167/224 kB | 0.3/1.0 MB | 65/109 kB | 44 kB | 65/80 kBProgress (5): 171/224 kB | 0.3/1.0 MB | 65/109 kB | 44 kB | 65/80 kBProgress (5): 171/224 kB | 0.3/1.0 MB | 65/109 kB | 44 kB | 69/80 kBProgress (5): 176/224 kB | 0.3/1.0 MB | 65/109 kB | 44 kB | 69/80 kBProgress (5): 176/224 kB | 0.3/1.0 MB | 65/109 kB | 44 kB | 73/80 kBProgress (5): 180/224 kB | 0.3/1.0 MB | 65/109 kB | 44 kB | 73/80 kBProgress (5): 180/224 kB | 0.3/1.0 MB | 65/109 kB | 44 kB | 77/80 kBProgress (5): 180/224 kB | 0.3/1.0 MB | 65/109 kB | 44 kB | 80 kB Progress (5): 180/224 kB | 0.3/1.0 MB | 69/109 kB | 44 kB | 80 kBProgress (5): 184/224 kB | 0.3/1.0 MB | 69/109 kB | 44 kB | 80 kBProgress (5): 188/224 kB | 0.3/1.0 MB | 69/109 kB | 44 kB | 80 kBProgress (5): 192/224 kB | 0.3/1.0 MB | 69/109 kB | 44 kB | 80 kBProgress (5): 196/224 kB | 0.3/1.0 MB | 69/109 kB | 44 kB | 80 kBProgress (5): 200/224 kB | 0.3/1.0 MB | 69/109 kB | 44 kB | 80 kBProgress (5): 204/224 kB | 0.3/1.0 MB | 69/109 kB | 44 kB | 80 kBProgress (5): 208/224 kB | 0.3/1.0 MB | 69/109 kB | 44 kB | 80 kBProgress (5): 212/224 kB | 0.3/1.0 MB | 69/109 kB | 44 kB | 80 kBProgress (5): 217/224 kB | 0.3/1.0 MB | 69/109 kB | 44 kB | 80 kBProgress (5): 221/224 kB | 0.3/1.0 MB | 69/109 kB | 44 kB | 80 kBProgress (5): 224 kB | 0.3/1.0 MB | 69/109 kB | 44 kB | 80 kB Progress (5): 224 kB | 0.3/1.0 MB | 73/109 kB | 44 kB | 80 kBProgress (5): 224 kB | 0.3/1.0 MB | 77/109 kB | 44 kB | 80 kBProgress (5): 224 kB | 0.3/1.0 MB | 81/109 kB | 44 kB | 80 kBProgress (5): 224 kB | 0.3/1.0 MB | 81/109 kB | 44 kB | 80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar (44 kB at 894 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar
Progress (4): 224 kB | 0.3/1.0 MB | 81/109 kB | 80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar (80 kB at 1.6 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar
Progress (3): 224 kB | 0.3/1.0 MB | 81/109 kBProgress (3): 224 kB | 0.3/1.0 MB | 81/109 kBProgress (3): 224 kB | 0.3/1.0 MB | 81/109 kBProgress (3): 224 kB | 0.3/1.0 MB | 81/109 kBProgress (3): 224 kB | 0.3/1.0 MB | 81/109 kBProgress (3): 224 kB | 0.3/1.0 MB | 81/109 kBProgress (3): 224 kB | 0.3/1.0 MB | 81/109 kBProgress (3): 224 kB | 0.3/1.0 MB | 81/109 kBProgress (3): 224 kB | 0.3/1.0 MB | 81/109 kBProgress (3): 224 kB | 0.3/1.0 MB | 81/109 kB Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar (224 kB at 3.8 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar
Progress (2): 0.3/1.0 MB | 85/109 kBProgress (2): 0.3/1.0 MB | 90/109 kBProgress (2): 0.3/1.0 MB | 94/109 kBProgress (2): 0.3/1.0 MB | 98/109 kBProgress (2): 0.3/1.0 MB | 102/109 kBProgress (2): 0.3/1.0 MB | 106/109 kBProgress (2): 0.3/1.0 MB | 109 kB Progress (3): 0.3/1.0 MB | 109 kB | 4.1/20 kBProgress (3): 0.3/1.0 MB | 109 kB | 8.2/20 kBProgress (3): 0.3/1.0 MB | 109 kB | 12/20 kB Progress (3): 0.3/1.0 MB | 109 kB | 16/20 kBProgress (3): 0.3/1.0 MB | 109 kB | 16/20 kBProgress (3): 0.3/1.0 MB | 109 kB | 16/20 kBProgress (3): 0.3/1.0 MB | 109 kB | 20 kB Progress (3): 0.3/1.0 MB | 109 kB | 20 kBProgress (3): 0.3/1.0 MB | 109 kB | 20 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 4.1/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 8.2/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 12/49 kB Progress (4): 0.3/1.0 MB | 109 kB | 20 kB | 16/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 20/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 25/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 29/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 33/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 33/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 33/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 33/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 33/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 37/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 41/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 45/49 kBProgress (4): 0.3/1.0 MB | 109 kB | 20 kB | 49 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar (109 kB at 1.8 MB/s)
Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar (20 kB at 323 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar
Progress (2): 0.3/1.0 MB | 49 kBProgress (3): 0.3/1.0 MB | 49 kB | 4.1/195 kBProgress (3): 0.3/1.0 MB | 49 kB | 7.7/195 kBProgress (3): 0.3/1.0 MB | 49 kB | 12/195 kB Progress (3): 0.3/1.0 MB | 49 kB | 16/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 16/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 16/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 16/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 20/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 24/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 28/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 32/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 32/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 32/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 32/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 32/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 36/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 40/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 45/195 kBProgress (3): 0.4/1.0 MB | 49 kB | 49/195 kBProgress (4): 0.4/1.0 MB | 49 kB | 49/195 kB | 4.1/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 49/195 kB | 8.2/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 49/195 kB | 12/121 kB Progress (4): 0.4/1.0 MB | 49 kB | 49/195 kB | 16/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 53/195 kB | 16/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 57/195 kB | 16/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 61/195 kB | 16/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 65/195 kB | 16/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 65/195 kB | 20/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 65/195 kB | 25/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 65/195 kB | 29/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 65/195 kB | 33/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 69/195 kB | 33/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 73/195 kB | 33/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 77/195 kB | 33/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 81/195 kB | 33/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 81/195 kB | 37/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 81/195 kB | 41/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 81/195 kB | 45/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 81/195 kB | 49/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 85/195 kB | 49/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 90/195 kB | 49/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 94/195 kB | 49/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 98/195 kB | 49/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 98/195 kB | 53/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 98/195 kB | 57/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 98/195 kB | 61/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 98/195 kB | 66/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 102/195 kB | 66/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 106/195 kB | 66/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 110/195 kB | 66/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 114/195 kB | 66/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 114/195 kB | 70/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 114/195 kB | 74/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 114/195 kB | 78/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 114/195 kB | 82/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 118/195 kB | 82/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 122/195 kB | 82/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 126/195 kB | 82/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 131/195 kB | 82/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 131/195 kB | 86/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 131/195 kB | 90/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 131/195 kB | 94/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 131/195 kB | 98/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 135/195 kB | 98/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 139/195 kB | 98/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 143/195 kB | 98/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 147/195 kB | 98/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 147/195 kB | 102/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 147/195 kB | 106/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 147/195 kB | 111/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 147/195 kB | 115/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 147/195 kB | 119/121 kBProgress (4): 0.4/1.0 MB | 49 kB | 147/195 kB | 121 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar
Progress (4): 0.4/1.0 MB | 49 kB | 151/195 kB | 121 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar (49 kB at 690 kB/s)
Progress (3): 0.4/1.0 MB | 151/195 kB | 121 kB Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar
Progress (3): 0.4/1.0 MB | 155/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 155/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 159/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 159/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 163/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 163/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 167/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 171/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 171/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 176/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 176/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 180/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 180/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 180/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 180/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 180/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 184/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 184/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 184/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 188/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 192/195 kB | 121 kBProgress (3): 0.4/1.0 MB | 195 kB | 121 kB Progress (3): 0.4/1.0 MB | 195 kB | 121 kBProgress (3): 0.4/1.0 MB | 195 kB | 121 kBProgress (3): 0.4/1.0 MB | 195 kB | 121 kBProgress (3): 0.4/1.0 MB | 195 kB | 121 kBProgress (3): 0.4/1.0 MB | 195 kB | 121 kB Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar (121 kB at 1.6 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar
Progress (3): 0.4/1.0 MB | 195 kB | 4.1/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 4.1/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 4.1/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 7.7/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 7.7/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar (195 kB at 2.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar
Progress (2): 0.5/1.0 MB | 7.7/251 kBProgress (3): 0.5/1.0 MB | 7.7/251 kB | 2.8/80 kBProgress (3): 0.5/1.0 MB | 7.7/251 kB | 2.8/80 kBProgress (3): 0.5/1.0 MB | 7.7/251 kB | 2.8/80 kBProgress (3): 0.5/1.0 MB | 7.7/251 kB | 2.8/80 kBProgress (3): 0.5/1.0 MB | 7.7/251 kB | 5.5/80 kBProgress (3): 0.5/1.0 MB | 7.7/251 kB | 5.5/80 kBProgress (3): 0.5/1.0 MB | 7.7/251 kB | 5.5/80 kBProgress (3): 0.5/1.0 MB | 7.7/251 kB | 8.3/80 kBProgress (3): 0.5/1.0 MB | 7.7/251 kB | 11/80 kB Progress (3): 0.5/1.0 MB | 7.7/251 kB | 14/80 kBProgress (3): 0.5/1.0 MB | 7.7/251 kB | 14/80 kBProgress (3): 0.5/1.0 MB | 12/251 kB | 14/80 kB Progress (3): 0.5/1.0 MB | 16/251 kB | 14/80 kBProgress (3): 0.5/1.0 MB | 20/251 kB | 14/80 kBProgress (3): 0.5/1.0 MB | 24/251 kB | 14/80 kBProgress (3): 0.5/1.0 MB | 28/251 kB | 14/80 kBProgress (3): 0.5/1.0 MB | 32/251 kB | 14/80 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 14/80 kB | 4.1/12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 16/80 kB | 4.1/12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 16/80 kB | 4.1/12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 16/80 kB | 7.7/12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 19/80 kB | 7.7/12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 19/80 kB | 7.7/12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 19/80 kB | 7.7/12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 19/80 kB | 12/12 kB Progress (4): 0.5/1.0 MB | 32/251 kB | 19/80 kB | 12/12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 19/80 kB | 12 kB Progress (4): 0.5/1.0 MB | 32/251 kB | 22/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 22/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 25/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 25/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 25/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 25/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 25/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.5/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (4): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kBProgress (5): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.6/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 32/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 36/251 kB | 27/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 36/251 kB | 30/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 36/251 kB | 30/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 36/251 kB | 30/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 36/251 kB | 33/80 kB | 12 kB | 0.1/1.3 MBProgress (5): 0.7/1.0 MB | 36/251 kB | 33/80 kB | 12 kB | 0.2/1.3 MBProgress (5): 0.7/1.0 MB | 40/251 kB | 33/80 kB | 12 kB | 0.2/1.3 MBProgress (5): 0.7/1.0 MB | 40/251 kB | 33/80 kB | 12 kB | 0.2/1.3 MBProgress (5): 0.7/1.0 MB | 45/251 kB | 33/80 kB | 12 kB | 0.2/1.3 MBProgress (5): 0.7/1.0 MB | 49/251 kB | 33/80 kB | 12 kB | 0.2/1.3 MBProgress (5): 0.7/1.0 MB | 49/251 kB | 33/80 kB | 12 kB | 0.2/1.3 MBProgress (5): 0.7/1.0 MB | 49/251 kB | 33/80 kB | 12 kB | 0.2/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar (12 kB at 113 kB/s)
Progress (4): 0.7/1.0 MB | 49/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 53/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 57/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 61/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 65/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 65/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 65/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 65/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 65/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 65/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 65/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 65/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 65/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 65/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 65/251 kB | 33/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 65/251 kB | 37/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 69/251 kB | 37/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 69/251 kB | 41/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 73/251 kB | 41/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 73/251 kB | 45/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 77/251 kB | 45/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 77/251 kB | 49/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 81/251 kB | 49/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 81/251 kB | 49/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 81/251 kB | 53/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 85/251 kB | 53/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 85/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 90/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 94/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 98/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 102/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 106/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 110/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 114/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 118/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 122/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 126/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 131/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 135/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 139/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 143/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 147/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 151/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 155/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 159/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 163/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 167/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 171/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 176/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 180/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 184/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 188/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 192/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 196/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 200/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 204/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 208/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 212/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 217/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 221/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 225/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 229/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 233/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 237/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 241/251 kB | 57/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 241/251 kB | 61/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 241/251 kB | 61/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 241/251 kB | 61/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 241/251 kB | 61/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 241/251 kB | 61/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 241/251 kB | 61/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 241/251 kB | 66/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 241/251 kB | 66/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 241/251 kB | 66/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 241/251 kB | 70/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 245/251 kB | 70/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 245/251 kB | 74/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 245/251 kB | 78/80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 245/251 kB | 80 kB | 0.2/1.3 MB Progress (4): 0.7/1.0 MB | 249/251 kB | 80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 251 kB | 80 kB | 0.2/1.3 MB Progress (4): 0.7/1.0 MB | 251 kB | 80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 251 kB | 80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 251 kB | 80 kB | 0.2/1.3 MBProgress (4): 0.7/1.0 MB | 251 kB | 80 kB | 0.2/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar (80 kB at 617 kB/s)
Progress (3): 0.7/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0.2/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0.2/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar (251 kB at 1.9 MB/s)
Progress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.3/1.3 MBProgress (2): 0.7/1.0 MB | 0.3/1.3 MBProgress (2): 0.7/1.0 MB | 0.3/1.3 MBProgress (2): 0.7/1.0 MB | 0.3/1.3 MBProgress (2): 0.7/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.4/1.3 MBProgress (2): 0.8/1.0 MB | 0.4/1.3 MBProgress (2): 0.8/1.0 MB | 0.4/1.3 MBProgress (2): 0.8/1.0 MB | 0.4/1.3 MBProgress (2): 0.8/1.0 MB | 0.4/1.3 MBProgress (2): 0.8/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0 MB | 0.6/1.3 MB Progress (2): 1.0 MB | 0.6/1.3 MBProgress (2): 1.0 MB | 0.6/1.3 MBProgress (2): 1.0 MB | 0.6/1.3 MBProgress (2): 1.0 MB | 0.6/1.3 MBProgress (2): 1.0 MB | 0.6/1.3 MBProgress (2): 1.0 MB | 0.6/1.3 MBProgress (2): 1.0 MB | 0.6/1.3 MBProgress (2): 1.0 MB | 0.6/1.3 MBProgress (2): 1.0 MB | 0.6/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar (1.0 MB at 5.9 MB/s)
Progress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar (1.3 MB at 6.5 MB/s)
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en&gt;
     [echo] Build directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.16-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;:137:Inline literal start-string without end-string.
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 45.860 s
[e[1;34mINFOe[m] Finished at: 2019-05-27T20:33:52Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://build.geoserver.org/job/geoserver-master-live-docs/1823/display/redirect&gt;
[...truncated 391.75 KB...]
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom
Progress (1): 861 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom (861 B at 172 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom
Progress (1): 761 B Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom (761 B at 254 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom
Progress (1): 138 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom (138 B at 34 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom
Progress (1): 643 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom (643 B at 214 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom
Progress (1): 2.2/12 kBProgress (1): 5.0/12 kBProgress (1): 7.8/12 kBProgress (1): 11/12 kB Progress (1): 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom (12 kB at 491 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom
Progress (1): 1.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom (1.8 kB at 614 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom (1.6 kB at 542 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom
Progress (1): 2.2/2.7 kBProgress (1): 2.7 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom (2.7 kB at 903 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom
Progress (1): 767 B Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom (767 B at 256 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom
Progress (1): 1.2 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom (1.2 kB at 412 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom
Progress (1): 998 B Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom (998 B at 250 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom (1.6 kB at 539 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom
Progress (1): 1.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom (1.4 kB at 453 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom
Progress (1): 1.5 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom (1.5 kB at 496 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom
Progress (1): 765 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom (765 B at 255 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom
Progress (1): 2.2/5.3 kBProgress (1): 5.0/5.3 kBProgress (1): 5.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom (5.3 kB at 1.8 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom (9.8 kB at 2.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom
Progress (1): 2.2/2.4 kBProgress (1): 2.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom (2.4 kB at 596 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom
Progress (1): 2.2/4.4 kBProgress (1): 4.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom (4.4 kB at 1.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom (9.8 kB at 2.0 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar
Progress (1): 0/1.0 MBProgress (2): 0/1.0 MB | 2.2/8.3 kBProgress (2): 0/1.0 MB | 2.2/8.3 kBProgress (2): 0/1.0 MB | 2.2/8.3 kBProgress (2): 0/1.0 MB | 5.0/8.3 kBProgress (2): 0/1.0 MB | 5.0/8.3 kBProgress (2): 0/1.0 MB | 7.7/8.3 kBProgress (2): 0/1.0 MB | 7.7/8.3 kBProgress (2): 0/1.0 MB | 8.3 kB Progress (2): 0/1.0 MB | 8.3 kBProgress (2): 0/1.0 MB | 8.3 kBProgress (2): 0/1.0 MB | 8.3 kBProgress (2): 0/1.0 MB | 8.3 kBProgress (2): 0/1.0 MB | 8.3 kBProgress (2): 0/1.0 MB | 8.3 kBProgress (2): 0/1.0 MB | 8.3 kBProgress (2): 0/1.0 MB | 8.3 kBProgress (2): 0/1.0 MB | 8.3 kBProgress (3): 0/1.0 MB | 8.3 kB | 2.2/109 kBProgress (3): 0/1.0 MB | 8.3 kB | 2.2/109 kBProgress (3): 0/1.0 MB | 8.3 kB | 2.2/109 kBProgress (3): 0/1.0 MB | 8.3 kB | 5.0/109 kBProgress (3): 0/1.0 MB | 8.3 kB | 7.7/109 kBProgress (3): 0/1.0 MB | 8.3 kB | 10/109 kB Progress (3): 0.1/1.0 MB | 8.3 kB | 10/109 kBProgress (3): 0.1/1.0 MB | 8.3 kB | 10/109 kBProgress (3): 0.1/1.0 MB | 8.3 kB | 10/109 kBProgress (3): 0.1/1.0 MB | 8.3 kB | 13/109 kBProgress (3): 0.1/1.0 MB | 8.3 kB | 13/109 kBProgress (3): 0.1/1.0 MB | 8.3 kB | 16/109 kBProgress (3): 0.1/1.0 MB | 8.3 kB | 19/109 kBProgress (4): 0.1/1.0 MB | 8.3 kB | 19/109 kB | 2.2/224 kBProgress (4): 0.1/1.0 MB | 8.3 kB | 21/109 kB | 2.2/224 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar (8.3 kB at 1.0 MB/s)
Progress (3): 0.1/1.0 MB | 24/109 kB | 2.2/224 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar
Progress (3): 0.1/1.0 MB | 27/109 kB | 2.2/224 kBProgress (3): 0.1/1.0 MB | 30/109 kB | 2.2/224 kBProgress (3): 0.1/1.0 MB | 30/109 kB | 2.2/224 kBProgress (3): 0.1/1.0 MB | 30/109 kB | 5.0/224 kBProgress (3): 0.1/1.0 MB | 30/109 kB | 5.0/224 kBProgress (3): 0.1/1.0 MB | 30/109 kB | 5.0/224 kBProgress (3): 0.1/1.0 MB | 30/109 kB | 5.0/224 kBProgress (3): 0.1/1.0 MB | 30/109 kB | 7.7/224 kBProgress (3): 0.1/1.0 MB | 30/109 kB | 10/224 kB Progress (3): 0.1/1.0 MB | 30/109 kB | 13/224 kBProgress (3): 0.1/1.0 MB | 30/109 kB | 16/224 kBProgress (4): 0.1/1.0 MB | 30/109 kB | 16/224 kB | 2.2/30 kBProgress (4): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 2.2/30 kBProgress (4): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 5.0/30 kBProgress (4): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 7.7/30 kBProgress (4): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB Progress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 2.2/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 5.0/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 7.7/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 10/44 kB Progress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 13/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 16/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 19/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 21/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 24/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 27/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 30/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 32/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 36/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 40/44 kBProgress (5): 0.1/1.0 MB | 30/109 kB | 19/224 kB | 10/30 kB | 44 kB Progress (5): 0.1/1.0 MB | 32/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 36/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 40/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 45/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 49/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 53/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 57/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 61/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 65/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 69/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 73/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 77/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 81/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 85/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 90/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 90/109 kB | 19/224 kB | 10/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 90/109 kB | 19/224 kB | 13/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 90/109 kB | 21/224 kB | 13/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 90/109 kB | 21/224 kB | 13/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 90/109 kB | 21/224 kB | 13/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 90/109 kB | 21/224 kB | 16/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 94/109 kB | 21/224 kB | 16/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 94/109 kB | 21/224 kB | 19/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 98/109 kB | 21/224 kB | 19/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 98/109 kB | 21/224 kB | 21/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 98/109 kB | 24/224 kB | 21/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 98/109 kB | 24/224 kB | 21/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 98/109 kB | 24/224 kB | 24/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 98/109 kB | 24/224 kB | 27/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 102/109 kB | 24/224 kB | 27/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 102/109 kB | 24/224 kB | 30/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 106/109 kB | 24/224 kB | 30/30 kB | 44 kBProgress (5): 0.1/1.0 MB | 106/109 kB | 24/224 kB | 30 kB | 44 kB Progress (5): 0.1/1.0 MB | 106/109 kB | 27/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 27/224 kB | 30 kB | 44 kB Progress (5): 0.1/1.0 MB | 109 kB | 30/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 30/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 30/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 30/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 30/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 32/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 32/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 32/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 32/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 32/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 36/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 40/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 45/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 49/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 53/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 57/224 kB | 30 kB | 44 kBProgress (5): 0.1/1.0 MB | 109 kB | 61/224 kB | 30 kB | 44 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar (109 kB at 5.0 MB/s)
Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar (30 kB at 1.4 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar
Progress (3): 0.1/1.0 MB | 65/224 kB | 44 kBProgress (3): 0.1/1.0 MB | 65/224 kB | 44 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar (44 kB at 1.7 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar
Progress (2): 0.1/1.0 MB | 65/224 kBProgress (2): 0.1/1.0 MB | 65/224 kBProgress (2): 0.1/1.0 MB | 65/224 kBProgress (2): 0.1/1.0 MB | 69/224 kBProgress (2): 0.1/1.0 MB | 73/224 kBProgress (3): 0.1/1.0 MB | 73/224 kB | 4.1/80 kBProgress (3): 0.1/1.0 MB | 77/224 kB | 4.1/80 kBProgress (3): 0.1/1.0 MB | 77/224 kB | 7.7/80 kBProgress (3): 0.1/1.0 MB | 77/224 kB | 12/80 kB Progress (3): 0.1/1.0 MB | 81/224 kB | 12/80 kBProgress (3): 0.2/1.0 MB | 81/224 kB | 12/80 kBProgress (3): 0.2/1.0 MB | 81/224 kB | 12/80 kBProgress (3): 0.2/1.0 MB | 81/224 kB | 12/80 kBProgress (3): 0.2/1.0 MB | 81/224 kB | 12/80 kBProgress (3): 0.2/1.0 MB | 81/224 kB | 12/80 kBProgress (3): 0.2/1.0 MB | 81/224 kB | 12/80 kBProgress (3): 0.2/1.0 MB | 81/224 kB | 12/80 kBProgress (3): 0.2/1.0 MB | 81/224 kB | 12/80 kBProgress (4): 0.2/1.0 MB | 81/224 kB | 12/80 kB | 2.2/49 kBProgress (4): 0.2/1.0 MB | 81/224 kB | 12/80 kB | 2.2/49 kBProgress (4): 0.2/1.0 MB | 81/224 kB | 12/80 kB | 2.2/49 kBProgress (4): 0.2/1.0 MB | 81/224 kB | 12/80 kB | 5.0/49 kBProgress (4): 0.2/1.0 MB | 81/224 kB | 16/80 kB | 5.0/49 kBProgress (4): 0.2/1.0 MB | 81/224 kB | 16/80 kB | 7.7/49 kBProgress (4): 0.2/1.0 MB | 81/224 kB | 16/80 kB | 10/49 kB Progress (4): 0.2/1.0 MB | 81/224 kB | 16/80 kB | 13/49 kBProgress (4): 0.2/1.0 MB | 81/224 kB | 20/80 kB | 13/49 kBProgress (4): 0.2/1.0 MB | 81/224 kB | 24/80 kB | 13/49 kBProgress (4): 0.2/1.0 MB | 81/224 kB | 24/80 kB | 16/49 kBProgress (4): 0.2/1.0 MB | 81/224 kB | 24/80 kB | 16/49 kBProgress (5): 0.2/1.0 MB | 81/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 85/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 85/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 90/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 94/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 98/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 98/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 98/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 98/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 98/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 102/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 106/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 110/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 114/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 114/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 114/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 114/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 114/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 118/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 122/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 126/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 131/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 131/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 131/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 131/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 131/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 135/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 139/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 143/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 147/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.2/1.0 MB | 147/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 147/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 147/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 147/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 147/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 147/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 147/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 147/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.3/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.4/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.4/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.4/1.0 MB | 151/224 kB | 24/80 kB | 16/49 kB | 4.1/20 kBProgress (5): 0.4/1.0 MB | 151/224 kB | 24/80 kB | 19/49 kB | 4.1/20 kBProgress (5): 0.4/1.0 MB | 151/224 kB | 24/80 kB | 19/49 kB | 7.7/20 kBProgress (5): 0.4/1.0 MB | 151/224 kB | 24/80 kB | 19/49 kB | 12/20 kB Progress (5): 0.4/1.0 MB | 151/224 kB | 24/80 kB | 19/49 kB | 16/20 kBProgress (5): 0.4/1.0 MB | 151/224 kB | 24/80 kB | 21/49 kB | 16/20 kBProgress (5): 0.4/1.0 MB | 151/224 kB | 24/80 kB | 21/49 kB | 20 kB Progress (5): 0.4/1.0 MB | 151/224 kB | 24/80 kB | 24/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 151/224 kB | 24/80 kB | 27/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 151/224 kB | 24/80 kB | 30/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 151/224 kB | 28/80 kB | 30/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 151/224 kB | 32/80 kB | 30/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 155/224 kB | 32/80 kB | 30/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 155/224 kB | 36/80 kB | 30/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 155/224 kB | 36/80 kB | 32/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 155/224 kB | 40/80 kB | 32/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 155/224 kB | 45/80 kB | 32/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 155/224 kB | 49/80 kB | 32/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 49/80 kB | 32/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 53/80 kB | 32/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 53/80 kB | 36/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 57/80 kB | 36/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 57/80 kB | 40/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 61/80 kB | 40/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 61/80 kB | 45/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 65/80 kB | 45/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 65/80 kB | 49/49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 65/80 kB | 49 kB | 20 kB Progress (5): 0.4/1.0 MB | 159/224 kB | 69/80 kB | 49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 73/80 kB | 49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 77/80 kB | 49 kB | 20 kBProgress (5): 0.4/1.0 MB | 159/224 kB | 80 kB | 49 kB | 20 kB Progress (5): 0.4/1.0 MB | 163/224 kB | 80 kB | 49 kB | 20 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar (20 kB at 493 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar
Progress (4): 0.4/1.0 MB | 163/224 kB | 80 kB | 49 kBProgress (4): 0.4/1.0 MB | 163/224 kB | 80 kB | 49 kBProgress (4): 0.4/1.0 MB | 163/224 kB | 80 kB | 49 kBProgress (4): 0.4/1.0 MB | 163/224 kB | 80 kB | 49 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar (49 kB at 1.2 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar
Progress (3): 0.4/1.0 MB | 163/224 kB | 80 kBProgress (3): 0.4/1.0 MB | 163/224 kB | 80 kBProgress (3): 0.4/1.0 MB | 163/224 kB | 80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar (80 kB at 1.9 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar
Progress (2): 0.4/1.0 MB | 167/224 kBProgress (2): 0.4/1.0 MB | 171/224 kBProgress (2): 0.4/1.0 MB | 176/224 kBProgress (2): 0.4/1.0 MB | 180/224 kBProgress (3): 0.4/1.0 MB | 180/224 kB | 4.1/121 kBProgress (3): 0.4/1.0 MB | 180/224 kB | 7.6/121 kBProgress (3): 0.4/1.0 MB | 180/224 kB | 12/121 kB Progress (3): 0.4/1.0 MB | 180/224 kB | 16/121 kBProgress (3): 0.4/1.0 MB | 180/224 kB | 16/121 kBProgress (3): 0.4/1.0 MB | 180/224 kB | 20/121 kBProgress (3): 0.4/1.0 MB | 180/224 kB | 24/121 kBProgress (3): 0.4/1.0 MB | 180/224 kB | 24/121 kBProgress (3): 0.4/1.0 MB | 180/224 kB | 28/121 kBProgress (3): 0.4/1.0 MB | 180/224 kB | 32/121 kBProgress (3): 0.4/1.0 MB | 180/224 kB | 32/121 kBProgress (3): 0.4/1.0 MB | 180/224 kB | 32/121 kBProgress (3): 0.4/1.0 MB | 180/224 kB | 32/121 kBProgress (3): 0.4/1.0 MB | 184/224 kB | 32/121 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 32/121 kB | 2.2/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 36/121 kB | 2.2/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 36/121 kB | 5.0/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 40/121 kB | 5.0/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 45/121 kB | 5.0/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 45/121 kB | 7.7/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 49/121 kB | 7.7/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 49/121 kB | 10/80 kB Progress (4): 0.4/1.0 MB | 184/224 kB | 49/121 kB | 13/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 49/121 kB | 16/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 49/121 kB | 19/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 53/121 kB | 19/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 57/121 kB | 19/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 57/121 kB | 21/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 61/121 kB | 21/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 65/121 kB | 21/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 65/121 kB | 24/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 65/121 kB | 27/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 65/121 kB | 30/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 65/121 kB | 32/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 69/121 kB | 32/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 73/121 kB | 32/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 77/121 kB | 32/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 81/121 kB | 32/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 81/121 kB | 36/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 81/121 kB | 40/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 81/121 kB | 45/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 81/121 kB | 49/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 85/121 kB | 49/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 90/121 kB | 49/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 94/121 kB | 49/80 kBProgress (4): 0.4/1.0 MB | 184/224 kB | 98/121 kB | 49/80 kBProgress (4): 0.4/1.0 MB | 188/224 kB | 98/121 kB | 49/80 kBProgress (4): 0.4/1.0 MB | 188/224 kB | 98/121 kB | 53/80 kBProgress (4): 0.4/1.0 MB | 188/224 kB | 98/121 kB | 57/80 kBProgress (4): 0.4/1.0 MB | 188/224 kB | 98/121 kB | 61/80 kBProgress (4): 0.4/1.0 MB | 188/224 kB | 98/121 kB | 65/80 kBProgress (4): 0.4/1.0 MB | 192/224 kB | 98/121 kB | 65/80 kBProgress (5): 0.4/1.0 MB | 192/224 kB | 98/121 kB | 65/80 kB | 4.1/195 kBProgress (5): 0.4/1.0 MB | 192/224 kB | 98/121 kB | 69/80 kB | 4.1/195 kBProgress (5): 0.4/1.0 MB | 192/224 kB | 98/121 kB | 69/80 kB | 7.7/195 kBProgress (5): 0.4/1.0 MB | 192/224 kB | 98/121 kB | 73/80 kB | 7.7/195 kBProgress (5): 0.4/1.0 MB | 192/224 kB | 98/121 kB | 73/80 kB | 12/195 kB Progress (5): 0.4/1.0 MB | 192/224 kB | 98/121 kB | 77/80 kB | 12/195 kBProgress (5): 0.4/1.0 MB | 192/224 kB | 98/121 kB | 80 kB | 12/195 kB Progress (5): 0.4/1.0 MB | 196/224 kB | 98/121 kB | 80 kB | 12/195 kBProgress (5): 0.4/1.0 MB | 196/224 kB | 98/121 kB | 80 kB | 12/195 kBProgress (5): 0.4/1.0 MB | 196/224 kB | 98/121 kB | 80 kB | 12/195 kBProgress (5): 0.4/1.0 MB | 196/224 kB | 98/121 kB | 80 kB | 12/195 kBProgress (5): 0.4/1.0 MB | 196/224 kB | 98/121 kB | 80 kB | 12/195 kBProgress (5): 0.4/1.0 MB | 196/224 kB | 98/121 kB | 80 kB | 12/195 kBProgress (5): 0.4/1.0 MB | 196/224 kB | 98/121 kB | 80 kB | 12/195 kBProgress (5): 0.4/1.0 MB | 196/224 kB | 98/121 kB | 80 kB | 12/195 kBProgress (5): 0.4/1.0 MB | 196/224 kB | 98/121 kB | 80 kB | 12/195 kBProgress (5): 0.4/1.0 MB | 200/224 kB | 98/121 kB | 80 kB | 12/195 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar (80 kB at 1.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar
Progress (4): 0.4/1.0 MB | 204/224 kB | 98/121 kB | 12/195 kBProgress (4): 0.4/1.0 MB | 208/224 kB | 98/121 kB | 12/195 kBProgress (4): 0.4/1.0 MB | 212/224 kB | 98/121 kB | 12/195 kBProgress (4): 0.4/1.0 MB | 212/224 kB | 102/121 kB | 12/195 kBProgress (4): 0.4/1.0 MB | 212/224 kB | 106/121 kB | 12/195 kBProgress (4): 0.4/1.0 MB | 212/224 kB | 110/121 kB | 12/195 kBProgress (4): 0.4/1.0 MB | 212/224 kB | 114/121 kB | 12/195 kBProgress (4): 0.4/1.0 MB | 212/224 kB | 114/121 kB | 12/195 kBProgress (4): 0.4/1.0 MB | 212/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.4/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.5/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.6/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.6/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.6/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.6/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.6/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.6/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.6/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.6/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.6/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.6/1.0 MB | 217/224 kB | 114/121 kB | 16/195 kBProgress (4): 0.6/1.0 MB | 217/224 kB | 118/121 kB | 16/195 kBProgress (4): 0.6/1.0 MB | 217/224 kB | 118/121 kB | 20/195 kBProgress (4): 0.6/1.0 MB | 221/224 kB | 118/121 kB | 20/195 kBProgress (4): 0.6/1.0 MB | 221/224 kB | 118/121 kB | 24/195 kBProgress (4): 0.6/1.0 MB | 224 kB | 118/121 kB | 24/195 kB Progress (4): 0.6/1.0 MB | 224 kB | 118/121 kB | 28/195 kBProgress (4): 0.6/1.0 MB | 224 kB | 118/121 kB | 32/195 kBProgress (4): 0.6/1.0 MB | 224 kB | 118/121 kB | 36/195 kBProgress (4): 0.6/1.0 MB | 224 kB | 118/121 kB | 40/195 kBProgress (4): 0.6/1.0 MB | 224 kB | 118/121 kB | 45/195 kBProgress (4): 0.6/1.0 MB | 224 kB | 118/121 kB | 49/195 kBProgress (4): 0.6/1.0 MB | 224 kB | 118/121 kB | 49/195 kBProgress (4): 0.6/1.0 MB | 224 kB | 118/121 kB | 49/195 kBProgress (4): 0.6/1.0 MB | 224 kB | 121 kB | 49/195 kB Progress (5): 0.6/1.0 MB | 224 kB | 121 kB | 49/195 kB | 4.1/251 kBProgress (5): 0.6/1.0 MB | 224 kB | 121 kB | 49/195 kB | 4.1/251 kBProgress (5): 0.6/1.0 MB | 224 kB | 121 kB | 49/195 kB | 4.1/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar (224 kB at 3.3 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar
Progress (4): 0.6/1.0 MB | 121 kB | 53/195 kB | 4.1/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 57/195 kB | 4.1/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 61/195 kB | 4.1/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 4.1/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 4.1/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 4.1/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 7.7/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 12/251 kB Progress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 16/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 16/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 16/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 20/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 24/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 28/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 32/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 36/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 40/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 45/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 65/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 69/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 73/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 77/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 81/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 81/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 81/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 85/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 90/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 94/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 98/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 98/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 102/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 106/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 110/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 114/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 114/195 kB | 49/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 114/195 kB | 53/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 114/195 kB | 57/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 114/195 kB | 61/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 114/195 kB | 65/251 kBProgress (4): 0.6/1.0 MB | 121 kB | 114/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 114/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 114/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 118/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 122/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 126/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 131/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 135/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 139/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 143/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 65/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 69/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 73/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 77/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 81/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 81/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 81/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 85/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 90/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 94/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 98/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 102/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 106/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 110/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 114/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 114/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 118/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 122/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 126/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 131/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 135/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 139/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 143/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 147/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 151/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 155/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 159/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 163/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 167/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 171/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 176/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 180/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 184/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 188/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 192/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 196/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 200/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 204/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 208/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 212/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 217/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 221/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 225/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 229/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 233/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 237/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 241/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 245/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 249/251 kBProgress (4): 0.7/1.0 MB | 121 kB | 147/195 kB | 251 kB Progress (4): 0.7/1.0 MB | 121 kB | 151/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 155/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 159/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 163/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 163/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 163/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 163/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 167/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 171/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 176/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 180/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 184/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 188/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 192/195 kB | 251 kBProgress (4): 0.7/1.0 MB | 121 kB | 195 kB | 251 kB Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar (121 kB at 1.4 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar
Progress (3): 0.7/1.0 MB | 195 kB | 251 kBProgress (3): 0.7/1.0 MB | 195 kB | 251 kBProgress (3): 0.7/1.0 MB | 195 kB | 251 kBProgress (3): 0.7/1.0 MB | 195 kB | 251 kBProgress (3): 0.7/1.0 MB | 195 kB | 251 kBProgress (3): 0.7/1.0 MB | 195 kB | 251 kBProgress (3): 0.7/1.0 MB | 195 kB | 251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar (195 kB at 2.1 MB/s)
Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar (251 kB at 2.6 MB/s)
Progress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (1): 0.7/1.0 MBProgress (2): 0.7/1.0 MB | 4.1/12 kBProgress (2): 0.7/1.0 MB | 7.7/12 kBProgress (2): 0.7/1.0 MB | 12/12 kB Progress (2): 0.7/1.0 MB | 12 kB Progress (2): 0.7/1.0 MB | 12 kBProgress (2): 0.7/1.0 MB | 12 kBProgress (2): 0.7/1.0 MB | 12 kBProgress (2): 0.8/1.0 MB | 12 kBProgress (2): 0.8/1.0 MB | 12 kBProgress (2): 0.8/1.0 MB | 12 kBProgress (2): 0.8/1.0 MB | 12 kBProgress (2): 0.8/1.0 MB | 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar (12 kB at 124 kB/s)
Progress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.8/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 0.9/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0/1.0 MBProgress (1): 1.0 MB Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar (1.0 MB at 9.2 MB/s)
Progress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.1/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.2/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar (1.3 MB at 6.6 MB/s)
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en&gt;
     [echo] Build directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.16-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;:137:Inline literal start-string without end-string.
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 45.130 s
[e[1;34mINFOe[m] Finished at: 2019-05-27T20:49:02Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://build.geoserver.org/job/geoserver-master-live-docs/1824/display/redirect&gt;
[...truncated 395.10 KB...]
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom
Progress (1): 861 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom (861 B at 172 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom
Progress (1): 761 B Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom (761 B at 30 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom
Progress (1): 138 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom (138 B at 17 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom
Progress (1): 643 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom (643 B at 161 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom
Progress (1): 2.2/12 kBProgress (1): 5.0/12 kBProgress (1): 7.8/12 kBProgress (1): 11/12 kB Progress (1): 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom (12 kB at 2.4 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom
Progress (1): 1.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom (1.8 kB at 142 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom (1.6 kB at 325 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom
Progress (1): 2.2/2.7 kBProgress (1): 2.7 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom (2.7 kB at 339 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom
Progress (1): 767 B Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom (767 B at 192 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom
Progress (1): 1.2 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom (1.2 kB at 412 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom
Progress (1): 998 B Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom (998 B at 250 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom (1.6 kB at 270 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom
Progress (1): 1.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom (1.4 kB at 54 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom
Progress (1): 1.5 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom (1.5 kB at 372 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom
Progress (1): 765 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom (765 B at 255 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom
Progress (1): 2.2/5.3 kBProgress (1): 5.0/5.3 kBProgress (1): 5.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom (5.3 kB at 1.3 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom (9.8 kB at 2.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom
Progress (1): 2.2/2.4 kBProgress (1): 2.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom (2.4 kB at 596 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom
Progress (1): 2.2/4.4 kBProgress (1): 4.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom (4.4 kB at 1.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom (9.8 kB at 2.4 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar
Progress (1): 2.2/8.3 kBProgress (1): 5.0/8.3 kBProgress (1): 7.7/8.3 kBProgress (1): 8.3 kB Progress (2): 8.3 kB | 0/1.0 MBProgress (2): 8.3 kB | 0/1.0 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar (8.3 kB at 833 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar
Progress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (2): 0/1.0 MB | 2.2/109 kBProgress (2): 0/1.0 MB | 5.0/109 kBProgress (2): 0/1.0 MB | 7.7/109 kBProgress (2): 0/1.0 MB | 10/109 kB Progress (2): 0/1.0 MB | 13/109 kBProgress (2): 0/1.0 MB | 16/109 kBProgress (3): 0/1.0 MB | 16/109 kB | 2.2/30 kBProgress (3): 0/1.0 MB | 16/109 kB | 5.0/30 kBProgress (4): 0/1.0 MB | 16/109 kB | 5.0/30 kB | 2.2/224 kBProgress (4): 0/1.0 MB | 16/109 kB | 7.7/30 kB | 2.2/224 kBProgress (4): 0/1.0 MB | 16/109 kB | 7.7/30 kB | 5.0/224 kBProgress (4): 0/1.0 MB | 16/109 kB | 10/30 kB | 5.0/224 kB Progress (5): 0/1.0 MB | 16/109 kB | 10/30 kB | 5.0/224 kB | 2.2/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 10/30 kB | 7.7/224 kB | 2.2/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 13/30 kB | 7.7/224 kB | 2.2/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 13/30 kB | 10/224 kB | 2.2/44 kB Progress (5): 0/1.0 MB | 16/109 kB | 16/30 kB | 10/224 kB | 2.2/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 16/30 kB | 13/224 kB | 2.2/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 19/30 kB | 13/224 kB | 2.2/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 19/30 kB | 16/224 kB | 2.2/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 21/30 kB | 16/224 kB | 2.2/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 21/30 kB | 19/224 kB | 2.2/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 21/30 kB | 21/224 kB | 2.2/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 24/30 kB | 21/224 kB | 2.2/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 24/30 kB | 21/224 kB | 5.0/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 24/30 kB | 24/224 kB | 5.0/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 27/30 kB | 24/224 kB | 5.0/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 27/30 kB | 24/224 kB | 7.7/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 27/30 kB | 27/224 kB | 7.7/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 30/30 kB | 27/224 kB | 7.7/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 30/30 kB | 27/224 kB | 10/44 kB Progress (5): 0/1.0 MB | 16/109 kB | 30 kB | 27/224 kB | 10/44 kB Progress (5): 0/1.0 MB | 16/109 kB | 30 kB | 30/224 kB | 10/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 30 kB | 30/224 kB | 13/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 30 kB | 32/224 kB | 13/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 30 kB | 32/224 kB | 16/44 kBProgress (5): 0/1.0 MB | 16/109 kB | 30 kB | 32/224 kB | 19/44 kBProgress (5): 0/1.0 MB | 19/109 kB | 30 kB | 32/224 kB | 19/44 kBProgress (5): 0/1.0 MB | 19/109 kB | 30 kB | 36/224 kB | 19/44 kBProgress (5): 0/1.0 MB | 19/109 kB | 30 kB | 36/224 kB | 21/44 kBProgress (5): 0/1.0 MB | 19/109 kB | 30 kB | 40/224 kB | 21/44 kBProgress (5): 0/1.0 MB | 19/109 kB | 30 kB | 45/224 kB | 21/44 kBProgress (5): 0/1.0 MB | 21/109 kB | 30 kB | 45/224 kB | 21/44 kBProgress (5): 0/1.0 MB | 21/109 kB | 30 kB | 49/224 kB | 21/44 kBProgress (5): 0/1.0 MB | 24/109 kB | 30 kB | 49/224 kB | 21/44 kBProgress (5): 0/1.0 MB | 24/109 kB | 30 kB | 49/224 kB | 24/44 kBProgress (5): 0/1.0 MB | 24/109 kB | 30 kB | 53/224 kB | 24/44 kBProgress (5): 0/1.0 MB | 27/109 kB | 30 kB | 53/224 kB | 24/44 kBProgress (5): 0/1.0 MB | 27/109 kB | 30 kB | 57/224 kB | 24/44 kBProgress (5): 0/1.0 MB | 27/109 kB | 30 kB | 61/224 kB | 24/44 kBProgress (5): 0/1.0 MB | 27/109 kB | 30 kB | 65/224 kB | 24/44 kBProgress (5): 0/1.0 MB | 27/109 kB | 30 kB | 65/224 kB | 27/44 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar (30 kB at 2.0 MB/s)
Progress (4): 0/1.0 MB | 27/109 kB | 69/224 kB | 27/44 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar
Progress (4): 0/1.0 MB | 27/109 kB | 73/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 27/109 kB | 77/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 27/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 30/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 32/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 36/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 40/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 45/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 49/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 53/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 57/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 61/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 65/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 69/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 73/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 77/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 81/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 85/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 90/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 94/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 98/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 102/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 106/109 kB | 81/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 109 kB | 81/224 kB | 27/44 kB Progress (4): 0/1.0 MB | 109 kB | 85/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 109 kB | 90/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 109 kB | 94/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 109 kB | 98/224 kB | 27/44 kBProgress (4): 0/1.0 MB | 109 kB | 98/224 kB | 27/44 kBProgress (5): 0/1.0 MB | 109 kB | 98/224 kB | 27/44 kB | 2.2/80 kBProgress (5): 0/1.0 MB | 109 kB | 102/224 kB | 27/44 kB | 2.2/80 kBProgress (5): 0/1.0 MB | 109 kB | 106/224 kB | 27/44 kB | 2.2/80 kBProgress (5): 0/1.0 MB | 109 kB | 110/224 kB | 27/44 kB | 2.2/80 kBProgress (5): 0/1.0 MB | 109 kB | 114/224 kB | 27/44 kB | 2.2/80 kBProgress (5): 0/1.0 MB | 109 kB | 114/224 kB | 27/44 kB | 5.0/80 kBProgress (5): 0/1.0 MB | 109 kB | 118/224 kB | 27/44 kB | 5.0/80 kBProgress (5): 0/1.0 MB | 109 kB | 122/224 kB | 27/44 kB | 5.0/80 kBProgress (5): 0/1.0 MB | 109 kB | 126/224 kB | 27/44 kB | 5.0/80 kBProgress (5): 0/1.0 MB | 109 kB | 131/224 kB | 27/44 kB | 5.0/80 kBProgress (5): 0/1.0 MB | 109 kB | 131/224 kB | 27/44 kB | 7.7/80 kBProgress (5): 0/1.0 MB | 109 kB | 131/224 kB | 27/44 kB | 10/80 kB Progress (5): 0/1.0 MB | 109 kB | 135/224 kB | 27/44 kB | 10/80 kBProgress (5): 0/1.0 MB | 109 kB | 139/224 kB | 27/44 kB | 10/80 kBProgress (5): 0/1.0 MB | 109 kB | 143/224 kB | 27/44 kB | 10/80 kBProgress (5): 0/1.0 MB | 109 kB | 147/224 kB | 27/44 kB | 10/80 kBProgress (5): 0/1.0 MB | 109 kB | 147/224 kB | 27/44 kB | 13/80 kBProgress (5): 0/1.0 MB | 109 kB | 147/224 kB | 27/44 kB | 16/80 kBProgress (5): 0/1.0 MB | 109 kB | 151/224 kB | 27/44 kB | 16/80 kBProgress (5): 0/1.0 MB | 109 kB | 155/224 kB | 27/44 kB | 16/80 kBProgress (5): 0/1.0 MB | 109 kB | 159/224 kB | 27/44 kB | 16/80 kBProgress (5): 0/1.0 MB | 109 kB | 163/224 kB | 27/44 kB | 16/80 kBProgress (5): 0/1.0 MB | 109 kB | 163/224 kB | 27/44 kB | 19/80 kBProgress (5): 0/1.0 MB | 109 kB | 167/224 kB | 27/44 kB | 19/80 kBProgress (5): 0/1.0 MB | 109 kB | 171/224 kB | 27/44 kB | 19/80 kBProgress (5): 0/1.0 MB | 109 kB | 176/224 kB | 27/44 kB | 19/80 kBProgress (5): 0/1.0 MB | 109 kB | 180/224 kB | 27/44 kB | 19/80 kBProgress (5): 0/1.0 MB | 109 kB | 180/224 kB | 27/44 kB | 19/80 kBProgress (5): 0/1.0 MB | 109 kB | 184/224 kB | 27/44 kB | 19/80 kBProgress (5): 0/1.0 MB | 109 kB | 188/224 kB | 27/44 kB | 19/80 kBProgress (5): 0/1.0 MB | 109 kB | 192/224 kB | 27/44 kB | 19/80 kBProgress (5): 0/1.0 MB | 109 kB | 196/224 kB | 27/44 kB | 19/80 kBProgress (5): 0/1.0 MB | 109 kB | 196/224 kB | 27/44 kB | 21/80 kBProgress (5): 0/1.0 MB | 109 kB | 196/224 kB | 27/44 kB | 24/80 kBProgress (5): 0/1.0 MB | 109 kB | 196/224 kB | 27/44 kB | 24/80 kBProgress (5): 0/1.0 MB | 109 kB | 200/224 kB | 27/44 kB | 24/80 kBProgress (5): 0/1.0 MB | 109 kB | 204/224 kB | 27/44 kB | 24/80 kBProgress (5): 0/1.0 MB | 109 kB | 208/224 kB | 27/44 kB | 24/80 kBProgress (5): 0/1.0 MB | 109 kB | 212/224 kB | 27/44 kB | 24/80 kBProgress (5): 0/1.0 MB | 109 kB | 212/224 kB | 27/44 kB | 24/80 kBProgress (5): 0/1.0 MB | 109 kB | 212/224 kB | 27/44 kB | 27/80 kBProgress (5): 0/1.0 MB | 109 kB | 212/224 kB | 27/44 kB | 30/80 kBProgress (5): 0/1.0 MB | 109 kB | 212/224 kB | 27/44 kB | 30/80 kBProgress (5): 0/1.0 MB | 109 kB | 217/224 kB | 27/44 kB | 30/80 kBProgress (5): 0/1.0 MB | 109 kB | 221/224 kB | 27/44 kB | 30/80 kBProgress (5): 0/1.0 MB | 109 kB | 224 kB | 27/44 kB | 30/80 kB Progress (5): 0/1.0 MB | 109 kB | 224 kB | 27/44 kB | 30/80 kBProgress (5): 0/1.0 MB | 109 kB | 224 kB | 27/44 kB | 30/80 kBProgress (5): 0/1.0 MB | 109 kB | 224 kB | 27/44 kB | 30/80 kBProgress (5): 0/1.0 MB | 109 kB | 224 kB | 27/44 kB | 30/80 kBProgress (5): 0/1.0 MB | 109 kB | 224 kB | 27/44 kB | 32/80 kBProgress (5): 0/1.0 MB | 109 kB | 224 kB | 27/44 kB | 36/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar (224 kB at 6.4 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar
Progress (4): 0/1.0 MB | 109 kB | 27/44 kB | 40/80 kBProgress (4): 0/1.0 MB | 109 kB | 27/44 kB | 45/80 kBProgress (4): 0/1.0 MB | 109 kB | 27/44 kB | 49/80 kBProgress (4): 0/1.0 MB | 109 kB | 30/44 kB | 49/80 kBProgress (4): 0.1/1.0 MB | 109 kB | 30/44 kB | 49/80 kBProgress (4): 0.1/1.0 MB | 109 kB | 30/44 kB | 49/80 kBProgress (4): 0.1/1.0 MB | 109 kB | 30/44 kB | 49/80 kBProgress (4): 0.1/1.0 MB | 109 kB | 32/44 kB | 49/80 kBProgress (4): 0.1/1.0 MB | 109 kB | 32/44 kB | 53/80 kBProgress (4): 0.1/1.0 MB | 109 kB | 32/44 kB | 57/80 kBProgress (5): 0.1/1.0 MB | 109 kB | 32/44 kB | 57/80 kB | 4.1/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 32/44 kB | 57/80 kB | 7.7/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 32/44 kB | 57/80 kB | 12/49 kB Progress (5): 0.1/1.0 MB | 109 kB | 32/44 kB | 57/80 kB | 16/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 32/44 kB | 57/80 kB | 16/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 36/44 kB | 57/80 kB | 16/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 36/44 kB | 57/80 kB | 20/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 40/44 kB | 57/80 kB | 20/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 40/44 kB | 61/80 kB | 20/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 44 kB | 61/80 kB | 20/49 kB Progress (5): 0.1/1.0 MB | 109 kB | 44 kB | 61/80 kB | 24/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 44 kB | 61/80 kB | 28/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 44 kB | 61/80 kB | 32/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 44 kB | 65/80 kB | 32/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 44 kB | 65/80 kB | 36/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 44 kB | 65/80 kB | 40/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 44 kB | 65/80 kB | 45/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 44 kB | 65/80 kB | 49/49 kBProgress (5): 0.1/1.0 MB | 109 kB | 44 kB | 65/80 kB | 49 kB Progress (5): 0.1/1.0 MB | 109 kB | 44 kB | 65/80 kB | 49 kBProgress (5): 0.1/1.0 MB | 109 kB | 44 kB | 65/80 kB | 49 kBProgress (5): 0.1/1.0 MB | 109 kB | 44 kB | 65/80 kB | 49 kBProgress (5): 0.1/1.0 MB | 109 kB | 44 kB | 65/80 kB | 49 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar (49 kB at 1.3 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar
Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar (109 kB at 2.7 MB/s)
Progress (3): 0.1/1.0 MB | 44 kB | 69/80 kBProgress (3): 0.1/1.0 MB | 44 kB | 73/80 kBProgress (3): 0.1/1.0 MB | 44 kB | 77/80 kBProgress (3): 0.1/1.0 MB | 44 kB | 80 kB Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar
Progress (3): 0.1/1.0 MB | 44 kB | 80 kBProgress (3): 0.1/1.0 MB | 44 kB | 80 kBProgress (3): 0.1/1.0 MB | 44 kB | 80 kBProgress (3): 0.1/1.0 MB | 44 kB | 80 kBProgress (4): 0.1/1.0 MB | 44 kB | 80 kB | 4.1/20 kBProgress (4): 0.1/1.0 MB | 44 kB | 80 kB | 7.7/20 kBProgress (4): 0.1/1.0 MB | 44 kB | 80 kB | 12/20 kB Progress (4): 0.1/1.0 MB | 44 kB | 80 kB | 16/20 kBProgress (4): 0.1/1.0 MB | 44 kB | 80 kB | 20 kB Progress (4): 0.1/1.0 MB | 44 kB | 80 kB | 20 kBProgress (4): 0.1/1.0 MB | 44 kB | 80 kB | 20 kBProgress (4): 0.1/1.0 MB | 44 kB | 80 kB | 20 kBProgress (4): 0.1/1.0 MB | 44 kB | 80 kB | 20 kBProgress (4): 0.1/1.0 MB | 44 kB | 80 kB | 20 kBProgress (4): 0.1/1.0 MB | 44 kB | 80 kB | 20 kBProgress (4): 0.1/1.0 MB | 44 kB | 80 kB | 20 kBProgress (4): 0.1/1.0 MB | 44 kB | 80 kB | 20 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar (80 kB at 1.6 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar
Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar (20 kB at 394 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar
Progress (3): 0.1/1.0 MB | 44 kB | 4.1/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 7.7/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 12/195 kB Progress (3): 0.1/1.0 MB | 44 kB | 16/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 20/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 24/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 28/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 32/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 32/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 32/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 32/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 32/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 36/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 40/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 45/195 kBProgress (3): 0.1/1.0 MB | 44 kB | 49/195 kBProgress (4): 0.1/1.0 MB | 44 kB | 49/195 kB | 4.1/80 kBProgress (4): 0.1/1.0 MB | 44 kB | 49/195 kB | 7.7/80 kBProgress (4): 0.1/1.0 MB | 44 kB | 49/195 kB | 12/80 kB Progress (4): 0.1/1.0 MB | 44 kB | 53/195 kB | 12/80 kBProgress (4): 0.1/1.0 MB | 44 kB | 53/195 kB | 16/80 kBProgress (5): 0.1/1.0 MB | 44 kB | 53/195 kB | 16/80 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 57/195 kB | 16/80 kB | 4.1/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 57/195 kB | 16/80 kB | 7.6/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 61/195 kB | 16/80 kB | 7.6/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 61/195 kB | 16/80 kB | 12/121 kB Progress (5): 0.1/1.0 MB | 44 kB | 65/195 kB | 16/80 kB | 12/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 65/195 kB | 16/80 kB | 16/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 65/195 kB | 20/80 kB | 16/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 65/195 kB | 24/80 kB | 16/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 65/195 kB | 28/80 kB | 16/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 65/195 kB | 32/80 kB | 16/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 69/195 kB | 32/80 kB | 16/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 69/195 kB | 32/80 kB | 20/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 73/195 kB | 32/80 kB | 20/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 73/195 kB | 32/80 kB | 24/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 77/195 kB | 32/80 kB | 24/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 77/195 kB | 32/80 kB | 28/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 81/195 kB | 32/80 kB | 28/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 81/195 kB | 32/80 kB | 32/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 81/195 kB | 36/80 kB | 32/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 81/195 kB | 40/80 kB | 32/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 81/195 kB | 45/80 kB | 32/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 81/195 kB | 49/80 kB | 32/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 85/195 kB | 49/80 kB | 32/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 85/195 kB | 49/80 kB | 36/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 90/195 kB | 49/80 kB | 36/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 90/195 kB | 49/80 kB | 40/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 94/195 kB | 49/80 kB | 40/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 94/195 kB | 49/80 kB | 45/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 98/195 kB | 49/80 kB | 45/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 98/195 kB | 49/80 kB | 49/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 98/195 kB | 53/80 kB | 49/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 98/195 kB | 57/80 kB | 49/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 98/195 kB | 61/80 kB | 49/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 98/195 kB | 65/80 kB | 49/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 102/195 kB | 65/80 kB | 49/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 102/195 kB | 65/80 kB | 53/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 106/195 kB | 65/80 kB | 53/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 106/195 kB | 65/80 kB | 57/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 110/195 kB | 65/80 kB | 57/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 110/195 kB | 65/80 kB | 61/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 114/195 kB | 65/80 kB | 61/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 114/195 kB | 65/80 kB | 65/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 114/195 kB | 69/80 kB | 65/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 114/195 kB | 73/80 kB | 65/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 114/195 kB | 77/80 kB | 65/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 114/195 kB | 80 kB | 65/121 kB Progress (5): 0.1/1.0 MB | 44 kB | 118/195 kB | 80 kB | 65/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 118/195 kB | 80 kB | 69/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 122/195 kB | 80 kB | 69/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 122/195 kB | 80 kB | 73/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 126/195 kB | 80 kB | 73/121 kBProgress (5): 0.1/1.0 MB | 44 kB | 126/195 kB | 80 kB | 77/121 kBProgress (5): 0.2/1.0 MB | 44 kB | 126/195 kB | 80 kB | 77/121 kBProgress (5): 0.2/1.0 MB | 44 kB | 126/195 kB | 80 kB | 77/121 kBProgress (5): 0.2/1.0 MB | 44 kB | 126/195 kB | 80 kB | 77/121 kBProgress (5): 0.2/1.0 MB | 44 kB | 126/195 kB | 80 kB | 77/121 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar (44 kB at 742 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar
Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar (80 kB at 1.4 MB/s)
Progress (3): 0.2/1.0 MB | 131/195 kB | 77/121 kBProgress (3): 0.2/1.0 MB | 131/195 kB | 81/121 kBProgress (3): 0.2/1.0 MB | 131/195 kB | 81/121 kBProgress (3): 0.2/1.0 MB | 131/195 kB | 85/121 kBProgress (3): 0.2/1.0 MB | 131/195 kB | 85/121 kBProgress (3): 0.2/1.0 MB | 131/195 kB | 90/121 kBProgress (3): 0.2/1.0 MB | 131/195 kB | 90/121 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 90/121 kB | 4.1/251 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 90/121 kB | 7.7/251 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 94/121 kB | 7.7/251 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 94/121 kB | 12/251 kB Progress (4): 0.2/1.0 MB | 131/195 kB | 98/121 kB | 12/251 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 98/121 kB | 16/251 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 102/121 kB | 16/251 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 106/121 kB | 16/251 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 110/121 kB | 16/251 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 114/121 kB | 16/251 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 118/121 kB | 16/251 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 121 kB | 16/251 kB Progress (5): 0.2/1.0 MB | 131/195 kB | 121 kB | 16/251 kB | 4.1/12 kBProgress (5): 0.2/1.0 MB | 131/195 kB | 121 kB | 16/251 kB | 7.7/12 kBProgress (5): 0.2/1.0 MB | 131/195 kB | 121 kB | 16/251 kB | 12/12 kB Progress (5): 0.2/1.0 MB | 131/195 kB | 121 kB | 16/251 kB | 12 kB Progress (5): 0.2/1.0 MB | 135/195 kB | 121 kB | 16/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 121 kB | 20/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 121 kB | 24/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 121 kB | 28/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 121 kB | 32/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 121 kB | 36/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 121 kB | 40/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 121 kB | 45/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 121 kB | 49/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 121 kB | 53/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 139/195 kB | 121 kB | 53/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 139/195 kB | 121 kB | 57/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 143/195 kB | 121 kB | 57/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 143/195 kB | 121 kB | 61/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 121 kB | 61/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 121 kB | 65/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 151/195 kB | 121 kB | 65/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 151/195 kB | 121 kB | 69/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 155/195 kB | 121 kB | 69/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 155/195 kB | 121 kB | 73/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 159/195 kB | 121 kB | 73/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 159/195 kB | 121 kB | 77/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 163/195 kB | 121 kB | 77/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 163/195 kB | 121 kB | 81/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 167/195 kB | 121 kB | 81/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 167/195 kB | 121 kB | 85/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 171/195 kB | 121 kB | 85/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 171/195 kB | 121 kB | 90/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 176/195 kB | 121 kB | 90/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 176/195 kB | 121 kB | 94/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 180/195 kB | 121 kB | 94/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 180/195 kB | 121 kB | 98/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 184/195 kB | 121 kB | 98/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 184/195 kB | 121 kB | 102/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 188/195 kB | 121 kB | 102/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 188/195 kB | 121 kB | 106/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 192/195 kB | 121 kB | 106/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 192/195 kB | 121 kB | 110/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 110/251 kB | 12 kB Progress (5): 0.2/1.0 MB | 195 kB | 121 kB | 114/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 118/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 118/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 122/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 126/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 131/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 131/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 131/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 135/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 135/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 139/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 139/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 143/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kB | 12 kBProgress (5): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kB | 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar (12 kB at 169 kB/s)
Progress (4): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kBProgress (4): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar
Progress (4): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kBProgress (4): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kBProgress (4): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kBProgress (4): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kBProgress (4): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kBProgress (4): 0.2/1.0 MB | 195 kB | 121 kB | 147/251 kBProgress (4): 0.2/1.0 MB | 195 kB | 121 kB | 151/251 kBProgress (4): 0.2/1.0 MB | 195 kB | 121 kB | 155/251 kBProgress (4): 0.2/1.0 MB | 195 kB | 121 kB | 159/251 kBProgress (4): 0.2/1.0 MB | 195 kB | 121 kB | 159/251 kBProgress (4): 0.2/1.0 MB | 195 kB | 121 kB | 163/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 121 kB | 163/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 121 kB | 163/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 121 kB | 163/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 121 kB | 163/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 121 kB | 163/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 121 kB | 163/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 121 kB | 163/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar (121 kB at 1.6 MB/s)
Progress (3): 0.3/1.0 MB | 195 kB | 167/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 171/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 176/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 180/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 184/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 188/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 192/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 196/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 200/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 204/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 208/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 212/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 217/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 221/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 225/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 229/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 233/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 237/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 241/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 245/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 249/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar (195 kB at 2.4 MB/s)
Progress (2): 0.3/1.0 MB | 251 kBProgress (2): 0.3/1.0 MB | 251 kBProgress (2): 0.3/1.0 MB | 251 kBProgress (2): 0.3/1.0 MB | 251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar (251 kB at 3.0 MB/s)
Progress (1): 0.3/1.0 MBProgress (1): 0.3/1.0 MBProgress (1): 0.3/1.0 MBProgress (1): 0.3/1.0 MBProgress (1): 0.3/1.0 MBProgress (1): 0.3/1.0 MBProgress (1): 0.3/1.0 MBProgress (1): 0.3/1.0 MBProgress (1): 0.3/1.0 MBProgress (1): 0.3/1.0 MBProgress (1): 0.3/1.0 MBProgress (1): 0.3/1.0 MBProgress (1): 0.3/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.4/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.5/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 0.9/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MB Progress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.8/1.3 MBProgress (2): 1.0 MB | 0.8/1.3 MBProgress (2): 1.0 MB | 0.8/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar (1.0 MB at 6.9 MB/s)
Progress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar (1.3 MB at 7.6 MB/s)
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en&gt;
     [echo] Build directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.16-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;:137:Inline literal start-string without end-string.
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 45.431 s
[e[1;34mINFOe[m] Finished at: 2019-05-27T20:59:02Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://build.geoserver.org/job/geoserver-master-live-docs/1825/display/redirect&gt;
[...truncated 399.52 KB...]
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom
Progress (1): 861 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom (861 B at 172 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom
Progress (1): 761 B Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom (761 B at 152 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom
Progress (1): 138 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom (138 B at 14 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom
Progress (1): 643 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom (643 B at 161 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom
Progress (1): 2.2/12 kBProgress (1): 5.0/12 kBProgress (1): 7.8/12 kBProgress (1): 11/12 kB Progress (1): 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom (12 kB at 2.0 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom
Progress (1): 1.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom (1.8 kB at 368 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom (1.6 kB at 325 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom
Progress (1): 2.2/2.7 kBProgress (1): 2.7 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom (2.7 kB at 542 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom
Progress (1): 767 B Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom (767 B at 192 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom
Progress (1): 1.2 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom (1.2 kB at 309 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom
Progress (1): 998 B Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom (998 B at 250 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom (1.6 kB at 404 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom
Progress (1): 1.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom (1.4 kB at 272 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom
Progress (1): 1.5 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom (1.5 kB at 297 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom
Progress (1): 765 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom (765 B at 153 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom
Progress (1): 2.2/5.3 kBProgress (1): 3.1/5.3 kBProgress (1): 5.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom (5.3 kB at 1.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom
Progress (1): 2.2/9.8 kBProgress (1): 2.5/9.8 kBProgress (1): 5.3/9.8 kBProgress (1): 8.0/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom (9.8 kB at 2.0 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom
Progress (1): 2.2/2.4 kBProgress (1): 2.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom (2.4 kB at 596 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom
Progress (1): 2.2/4.4 kBProgress (1): 4.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom (4.4 kB at 876 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom (9.8 kB at 1.6 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar
Progress (1): 2.2/224 kBProgress (1): 5.0/224 kBProgress (1): 7.7/224 kBProgress (1): 10/224 kB Progress (1): 13/224 kBProgress (1): 16/224 kBProgress (1): 19/224 kBProgress (1): 21/224 kBProgress (1): 24/224 kBProgress (1): 27/224 kBProgress (1): 30/224 kBProgress (1): 32/224 kBProgress (1): 36/224 kBProgress (1): 40/224 kBProgress (1): 45/224 kBProgress (1): 49/224 kBProgress (1): 53/224 kBProgress (1): 57/224 kBProgress (1): 61/224 kBProgress (1): 65/224 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar
Progress (1): 69/224 kBProgress (1): 73/224 kBProgress (1): 77/224 kBProgress (1): 81/224 kBProgress (2): 81/224 kB | 2.2/109 kBProgress (2): 85/224 kB | 2.2/109 kBProgress (2): 90/224 kB | 2.2/109 kBProgress (2): 94/224 kB | 2.2/109 kBProgress (2): 98/224 kB | 2.2/109 kBProgress (3): 98/224 kB | 2.2/109 kB | 2.8/8.3 kBProgress (3): 98/224 kB | 5.0/109 kB | 2.8/8.3 kBProgress (3): 98/224 kB | 5.0/109 kB | 5.5/8.3 kBProgress (3): 102/224 kB | 5.0/109 kB | 5.5/8.3 kBProgress (3): 106/224 kB | 5.0/109 kB | 5.5/8.3 kBProgress (3): 110/224 kB | 5.0/109 kB | 5.5/8.3 kBProgress (3): 114/224 kB | 5.0/109 kB | 5.5/8.3 kBProgress (3): 114/224 kB | 5.0/109 kB | 8.3/8.3 kBProgress (3): 114/224 kB | 7.7/109 kB | 8.3/8.3 kBProgress (3): 118/224 kB | 7.7/109 kB | 8.3/8.3 kBProgress (4): 118/224 kB | 7.7/109 kB | 8.3/8.3 kB | 2.2/44 kBProgress (4): 122/224 kB | 7.7/109 kB | 8.3/8.3 kB | 2.2/44 kBProgress (4): 126/224 kB | 7.7/109 kB | 8.3/8.3 kB | 2.2/44 kBProgress (4): 126/224 kB | 7.7/109 kB | 8.3/8.3 kB | 5.0/44 kBProgress (4): 131/224 kB | 7.7/109 kB | 8.3/8.3 kB | 5.0/44 kBProgress (4): 131/224 kB | 7.7/109 kB | 8.3/8.3 kB | 7.7/44 kBProgress (4): 131/224 kB | 7.7/109 kB | 8.3/8.3 kB | 10/44 kB Progress (4): 131/224 kB | 7.7/109 kB | 8.3/8.3 kB | 13/44 kBProgress (4): 131/224 kB | 7.7/109 kB | 8.3 kB | 13/44 kB Progress (5): 131/224 kB | 7.7/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 131/224 kB | 7.7/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 131/224 kB | 7.7/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 131/224 kB | 7.7/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 131/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MB Progress (5): 135/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 139/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 143/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 147/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 151/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 155/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 159/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 163/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 167/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 171/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 176/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 10/109 kB | 8.3 kB | 13/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 10/109 kB | 8.3 kB | 16/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 16/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 19/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 19/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 19/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 180/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 184/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 188/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 192/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 196/224 kB | 13/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 196/224 kB | 16/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 196/224 kB | 19/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 200/224 kB | 19/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 204/224 kB | 19/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 208/224 kB | 19/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MBProgress (5): 212/224 kB | 19/109 kB | 8.3 kB | 21/44 kB | 0.1/1.0 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar (8.3 kB at 214 kB/s)
Progress (4): 212/224 kB | 19/109 kB | 24/44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 19/109 kB | 24/44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 19/109 kB | 24/44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 21/109 kB | 24/44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 21/109 kB | 27/44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 21/109 kB | 27/44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 24/109 kB | 27/44 kB | 0.1/1.0 MB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar
Progress (4): 217/224 kB | 24/109 kB | 27/44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 24/109 kB | 30/44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 24/109 kB | 30/44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 24/109 kB | 32/44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 24/109 kB | 36/44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 24/109 kB | 40/44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 24/109 kB | 44 kB | 0.1/1.0 MB Progress (4): 217/224 kB | 27/109 kB | 44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 27/109 kB | 44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 30/109 kB | 44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 30/109 kB | 44 kB | 0.1/1.0 MBProgress (4): 217/224 kB | 32/109 kB | 44 kB | 0.1/1.0 MBProgress (4): 221/224 kB | 32/109 kB | 44 kB | 0.1/1.0 MBProgress (4): 224 kB | 32/109 kB | 44 kB | 0.1/1.0 MB Progress (4): 224 kB | 36/109 kB | 44 kB | 0.1/1.0 MBProgress (4): 224 kB | 36/109 kB | 44 kB | 0.1/1.0 MBProgress (4): 224 kB | 36/109 kB | 44 kB | 0.1/1.0 MBProgress (5): 224 kB | 36/109 kB | 44 kB | 0.1/1.0 MB | 2.2/30 kBProgress (5): 224 kB | 36/109 kB | 44 kB | 0.1/1.0 MB | 5.0/30 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar (44 kB at 1.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar
Progress (4): 224 kB | 40/109 kB | 0.1/1.0 MB | 5.0/30 kBProgress (4): 224 kB | 40/109 kB | 0.1/1.0 MB | 7.7/30 kBProgress (4): 224 kB | 45/109 kB | 0.1/1.0 MB | 7.7/30 kBProgress (4): 224 kB | 45/109 kB | 0.1/1.0 MB | 10/30 kB Progress (4): 224 kB | 49/109 kB | 0.1/1.0 MB | 10/30 kBProgress (4): 224 kB | 49/109 kB | 0.1/1.0 MB | 10/30 kBProgress (4): 224 kB | 49/109 kB | 0.1/1.0 MB | 10/30 kBProgress (4): 224 kB | 49/109 kB | 0.1/1.0 MB | 10/30 kBProgress (4): 224 kB | 49/109 kB | 0.1/1.0 MB | 13/30 kBProgress (4): 224 kB | 53/109 kB | 0.1/1.0 MB | 13/30 kBProgress (4): 224 kB | 53/109 kB | 0.1/1.0 MB | 16/30 kBProgress (4): 224 kB | 57/109 kB | 0.1/1.0 MB | 16/30 kBProgress (4): 224 kB | 61/109 kB | 0.1/1.0 MB | 16/30 kBProgress (4): 224 kB | 61/109 kB | 0.1/1.0 MB | 19/30 kBProgress (4): 224 kB | 65/109 kB | 0.1/1.0 MB | 19/30 kBProgress (4): 224 kB | 65/109 kB | 0.1/1.0 MB | 21/30 kBProgress (4): 224 kB | 65/109 kB | 0.1/1.0 MB | 24/30 kBProgress (4): 224 kB | 65/109 kB | 0.1/1.0 MB | 27/30 kBProgress (4): 224 kB | 69/109 kB | 0.1/1.0 MB | 27/30 kBProgress (4): 224 kB | 69/109 kB | 0.1/1.0 MB | 30/30 kBProgress (4): 224 kB | 73/109 kB | 0.1/1.0 MB | 30/30 kBProgress (4): 224 kB | 73/109 kB | 0.1/1.0 MB | 30 kB Progress (4): 224 kB | 77/109 kB | 0.1/1.0 MB | 30 kBProgress (4): 224 kB | 81/109 kB | 0.1/1.0 MB | 30 kBProgress (4): 224 kB | 81/109 kB | 0.1/1.0 MB | 30 kBProgress (5): 224 kB | 81/109 kB | 0.1/1.0 MB | 30 kB | 4.1/80 kBProgress (5): 224 kB | 81/109 kB | 0.1/1.0 MB | 30 kB | 7.7/80 kBProgress (5): 224 kB | 81/109 kB | 0.1/1.0 MB | 30 kB | 12/80 kB Progress (5): 224 kB | 81/109 kB | 0.1/1.0 MB | 30 kB | 16/80 kBProgress (5): 224 kB | 85/109 kB | 0.1/1.0 MB | 30 kB | 16/80 kBProgress (5): 224 kB | 90/109 kB | 0.1/1.0 MB | 30 kB | 16/80 kBProgress (5): 224 kB | 94/109 kB | 0.1/1.0 MB | 30 kB | 16/80 kBProgress (5): 224 kB | 94/109 kB | 0.1/1.0 MB | 30 kB | 20/80 kBProgress (5): 224 kB | 94/109 kB | 0.1/1.0 MB | 30 kB | 24/80 kBProgress (5): 224 kB | 98/109 kB | 0.1/1.0 MB | 30 kB | 24/80 kBProgress (5): 224 kB | 98/109 kB | 0.1/1.0 MB | 30 kB | 28/80 kBProgress (5): 224 kB | 98/109 kB | 0.1/1.0 MB | 30 kB | 32/80 kBProgress (5): 224 kB | 102/109 kB | 0.1/1.0 MB | 30 kB | 32/80 kBProgress (5): 224 kB | 102/109 kB | 0.1/1.0 MB | 30 kB | 36/80 kBProgress (5): 224 kB | 102/109 kB | 0.1/1.0 MB | 30 kB | 40/80 kBProgress (5): 224 kB | 106/109 kB | 0.1/1.0 MB | 30 kB | 40/80 kBProgress (5): 224 kB | 106/109 kB | 0.1/1.0 MB | 30 kB | 45/80 kBProgress (5): 224 kB | 109 kB | 0.1/1.0 MB | 30 kB | 45/80 kB Progress (5): 224 kB | 109 kB | 0.1/1.0 MB | 30 kB | 49/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar (30 kB at 657 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar
Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar (109 kB at 1.9 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar
Progress (3): 224 kB | 0.1/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.1/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.1/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.1/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.1/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.1/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.1/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.1/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 49/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 53/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 57/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 61/80 kBProgress (3): 224 kB | 0.2/1.0 MB | 65/80 kBProgress (4): 224 kB | 0.2/1.0 MB | 65/80 kB | 4.1/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 65/80 kB | 8.2/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 65/80 kB | 12/49 kB Progress (4): 224 kB | 0.2/1.0 MB | 65/80 kB | 16/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 69/80 kB | 16/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 73/80 kB | 16/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 77/80 kB | 16/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 16/49 kB Progress (4): 224 kB | 0.2/1.0 MB | 80 kB | 20/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 25/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 29/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 33/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 33/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 33/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 37/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 41/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 45/49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 49 kB Progress (4): 224 kB | 0.2/1.0 MB | 80 kB | 49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 49 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 49 kBProgress (5): 224 kB | 0.2/1.0 MB | 80 kB | 49 kB | 4.1/20 kBProgress (5): 224 kB | 0.2/1.0 MB | 80 kB | 49 kB | 7.7/20 kBProgress (5): 224 kB | 0.2/1.0 MB | 80 kB | 49 kB | 12/20 kB Progress (5): 224 kB | 0.2/1.0 MB | 80 kB | 49 kB | 16/20 kBProgress (5): 224 kB | 0.2/1.0 MB | 80 kB | 49 kB | 20 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar (49 kB at 754 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar
Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar (224 kB at 3.3 MB/s)
Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar (80 kB at 1.2 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar
Progress (2): 0.2/1.0 MB | 20 kBProgress (2): 0.2/1.0 MB | 20 kBProgress (2): 0.2/1.0 MB | 20 kBProgress (2): 0.2/1.0 MB | 20 kBProgress (2): 0.2/1.0 MB | 20 kBProgress (2): 0.2/1.0 MB | 20 kBProgress (2): 0.2/1.0 MB | 20 kBProgress (2): 0.2/1.0 MB | 20 kBProgress (2): 0.2/1.0 MB | 20 kBProgress (2): 0.3/1.0 MB | 20 kBProgress (2): 0.3/1.0 MB | 20 kBProgress (2): 0.3/1.0 MB | 20 kBProgress (2): 0.3/1.0 MB | 20 kBProgress (2): 0.3/1.0 MB | 20 kBProgress (2): 0.3/1.0 MB | 20 kBProgress (2): 0.3/1.0 MB | 20 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar (20 kB at 278 kB/s)
Progress (2): 0.3/1.0 MB | 4.1/80 kBProgress (2): 0.3/1.0 MB | 7.7/80 kBProgress (2): 0.3/1.0 MB | 12/80 kB Progress (2): 0.3/1.0 MB | 16/80 kBProgress (2): 0.3/1.0 MB | 20/80 kBProgress (2): 0.3/1.0 MB | 24/80 kBProgress (2): 0.3/1.0 MB | 28/80 kBProgress (2): 0.3/1.0 MB | 32/80 kBProgress (2): 0.3/1.0 MB | 36/80 kBProgress (2): 0.3/1.0 MB | 40/80 kBProgress (2): 0.3/1.0 MB | 45/80 kBProgress (2): 0.3/1.0 MB | 49/80 kBProgress (2): 0.3/1.0 MB | 53/80 kBProgress (2): 0.3/1.0 MB | 57/80 kBProgress (2): 0.3/1.0 MB | 61/80 kBProgress (2): 0.3/1.0 MB | 65/80 kBProgress (2): 0.3/1.0 MB | 65/80 kBProgress (2): 0.3/1.0 MB | 65/80 kBProgress (3): 0.3/1.0 MB | 65/80 kB | 4.1/195 kBProgress (3): 0.3/1.0 MB | 65/80 kB | 7.7/195 kBProgress (3): 0.3/1.0 MB | 65/80 kB | 12/195 kB Progress (3): 0.3/1.0 MB | 69/80 kB | 12/195 kB Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar
Progress (3): 0.3/1.0 MB | 73/80 kB | 12/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 16/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 20/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 24/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.3/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.4/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.4/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.4/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.4/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.4/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.4/1.0 MB | 73/80 kB | 28/195 kBProgress (3): 0.4/1.0 MB | 73/80 kB | 28/195 kBProgress (4): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 2.8/121 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 2.8/121 kB | 2.2/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 5.5/121 kB | 2.2/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 5.5/121 kB | 5.0/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 8.3/121 kB | 5.0/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 8.3/121 kB | 7.7/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 11/121 kB | 7.7/251 kB Progress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 11/121 kB | 10/251 kB Progress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 14/121 kB | 10/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 14/121 kB | 13/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 16/121 kB | 13/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 16/121 kB | 16/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 19/121 kB | 16/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 19/121 kB | 19/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 22/121 kB | 19/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 25/121 kB | 19/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 25/121 kB | 21/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 21/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 24/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 27/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 30/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 32/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 36/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 40/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 45/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 49/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 53/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 57/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 61/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 65/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 69/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 73/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 77/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 81/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 85/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 90/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 94/251 kBProgress (5): 0.4/1.0 MB | 73/80 kB | 28/195 kB | 27/121 kB | 98/251 kBProgress (5): 0.4/1.0 MB | 77/80 kB | 28/195 kB | 27/121 kB | 98/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 28/195 kB | 27/121 kB | 98/251 kB Progress (5): 0.4/1.0 MB | 80 kB | 32/195 kB | 27/121 kB | 98/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 32/195 kB | 30/121 kB | 98/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 32/195 kB | 33/121 kB | 98/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 36/195 kB | 33/121 kB | 98/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 36/195 kB | 37/121 kB | 98/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 36/195 kB | 41/121 kB | 98/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 36/195 kB | 41/121 kB | 102/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 36/195 kB | 41/121 kB | 106/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 36/195 kB | 41/121 kB | 110/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 36/195 kB | 41/121 kB | 114/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 40/195 kB | 41/121 kB | 114/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 40/195 kB | 45/121 kB | 114/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 40/195 kB | 49/121 kB | 114/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 45/195 kB | 49/121 kB | 114/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 49/195 kB | 49/121 kB | 114/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 49/195 kB | 49/121 kB | 118/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 49/195 kB | 53/121 kB | 118/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 49/195 kB | 57/121 kB | 118/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 49/195 kB | 61/121 kB | 118/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 49/195 kB | 66/121 kB | 118/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 53/195 kB | 66/121 kB | 118/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 57/195 kB | 66/121 kB | 118/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 61/195 kB | 66/121 kB | 118/251 kBProgress (5): 0.4/1.0 MB | 80 kB | 65/195 kB | 66/121 kB | 118/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar (80 kB at 863 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar
Progress (4): 0.4/1.0 MB | 69/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 73/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 77/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 81/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 85/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 90/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 94/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 98/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 102/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 106/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 110/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 114/195 kB | 66/121 kB | 118/251 kBProgress (5): 0.4/1.0 MB | 114/195 kB | 66/121 kB | 118/251 kB | 4.1/12 kBProgress (5): 0.4/1.0 MB | 114/195 kB | 66/121 kB | 118/251 kB | 8.2/12 kBProgress (5): 0.4/1.0 MB | 114/195 kB | 66/121 kB | 118/251 kB | 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar (12 kB at 121 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar
Progress (4): 0.4/1.0 MB | 114/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 114/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 114/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 66/121 kB | 118/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 66/121 kB | 122/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 70/121 kB | 122/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 70/121 kB | 126/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 74/121 kB | 126/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 74/121 kB | 131/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 78/121 kB | 131/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 131/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 135/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 139/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 139/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 143/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 147/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 147/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 151/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 151/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 155/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 155/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 159/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 82/121 kB | 163/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 86/121 kB | 163/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 90/121 kB | 163/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 94/121 kB | 163/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 98/121 kB | 163/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 98/121 kB | 167/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 98/121 kB | 171/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 98/121 kB | 176/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 98/121 kB | 180/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 102/121 kB | 180/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 106/121 kB | 180/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 111/121 kB | 180/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 115/121 kB | 180/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 115/121 kB | 184/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 115/121 kB | 188/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 119/121 kB | 188/251 kBProgress (4): 0.4/1.0 MB | 118/195 kB | 121 kB | 188/251 kB Progress (4): 0.4/1.0 MB | 122/195 kB | 121 kB | 188/251 kBProgress (4): 0.4/1.0 MB | 126/195 kB | 121 kB | 188/251 kBProgress (4): 0.4/1.0 MB | 131/195 kB | 121 kB | 188/251 kBProgress (4): 0.4/1.0 MB | 131/195 kB | 121 kB | 188/251 kBProgress (4): 0.4/1.0 MB | 135/195 kB | 121 kB | 188/251 kBProgress (4): 0.4/1.0 MB | 135/195 kB | 121 kB | 188/251 kBProgress (4): 0.4/1.0 MB | 135/195 kB | 121 kB | 188/251 kBProgress (4): 0.4/1.0 MB | 135/195 kB | 121 kB | 192/251 kBProgress (4): 0.4/1.0 MB | 135/195 kB | 121 kB | 196/251 kBProgress (4): 0.4/1.0 MB | 135/195 kB | 121 kB | 196/251 kBProgress (4): 0.4/1.0 MB | 135/195 kB | 121 kB | 196/251 kBProgress (4): 0.4/1.0 MB | 135/195 kB | 121 kB | 200/251 kBProgress (4): 0.4/1.0 MB | 135/195 kB | 121 kB | 204/251 kBProgress (4): 0.4/1.0 MB | 135/195 kB | 121 kB | 208/251 kBProgress (4): 0.4/1.0 MB | 135/195 kB | 121 kB | 212/251 kBProgress (5): 0.4/1.0 MB | 135/195 kB | 121 kB | 212/251 kB | 0/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar (121 kB at 1.1 MB/s)
Progress (4): 0.4/1.0 MB | 135/195 kB | 212/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 135/195 kB | 212/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 135/195 kB | 217/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 135/195 kB | 217/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 139/195 kB | 217/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 139/195 kB | 217/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 143/195 kB | 217/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 143/195 kB | 221/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 143/195 kB | 225/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 143/195 kB | 229/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 143/195 kB | 233/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 143/195 kB | 237/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 143/195 kB | 241/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 143/195 kB | 245/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 147/195 kB | 245/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 147/195 kB | 245/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 147/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 147/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 147/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 151/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 155/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 159/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 159/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.4/1.0 MB | 163/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 163/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 163/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 163/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 167/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 171/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 176/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 176/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 180/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 180/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 180/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 180/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 184/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 188/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 192/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 192/195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MB Progress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.5/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.6/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 249/251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0/1.3 MB Progress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0.1/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0.1/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0.1/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0.1/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0.1/1.3 MBProgress (4): 0.7/1.0 MB | 195 kB | 251 kB | 0.1/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar (251 kB at 2.0 MB/s)
Progress (3): 0.7/1.0 MB | 195 kB | 0.1/1.3 MBProgress (3): 0.7/1.0 MB | 195 kB | 0.1/1.3 MBProgress (3): 0.7/1.0 MB | 195 kB | 0.1/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar (195 kB at 1.5 MB/s)
Progress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MB Progress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar (1.0 MB at 6.5 MB/s)
Progress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar (1.3 MB at 7.0 MB/s)
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en&gt;
     [echo] Build directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.16-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;:137:Inline literal start-string without end-string.
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 45.877 s
[e[1;34mINFOe[m] Finished at: 2019-05-27T21:18:03Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://build.geoserver.org/job/geoserver-master-live-docs/1826/display/redirect&gt;
[...truncated 396.87 KB...]
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom
Progress (1): 861 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom (861 B at 172 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom
Progress (1): 761 B Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom (761 B at 152 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom
Progress (1): 138 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom (138 B at 34 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom
Progress (1): 643 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom (643 B at 214 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom
Progress (1): 2.2/12 kBProgress (1): 5.0/12 kBProgress (1): 7.8/12 kBProgress (1): 11/12 kB Progress (1): 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom (12 kB at 2.9 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom
Progress (1): 1.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom (1.8 kB at 614 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom (1.6 kB at 542 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom
Progress (1): 2.2/2.7 kBProgress (1): 2.7 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom (2.7 kB at 903 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom
Progress (1): 767 B Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom (767 B at 256 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom
Progress (1): 1.2 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom (1.2 kB at 412 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom
Progress (1): 998 B Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom (998 B at 125 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom (1.6 kB at 809 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom
Progress (1): 1.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom (1.4 kB at 453 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom
Progress (1): 1.5 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom (1.5 kB at 372 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom
Progress (1): 765 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom (765 B at 191 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom
Progress (1): 2.2/5.3 kBProgress (1): 5.0/5.3 kBProgress (1): 5.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom (5.3 kB at 1.3 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom (9.8 kB at 2.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom
Progress (1): 2.2/2.4 kBProgress (1): 2.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom (2.4 kB at 477 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom
Progress (1): 2.2/4.4 kBProgress (1): 4.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom (4.4 kB at 1.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom (9.8 kB at 2.0 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar
Progress (1): 2.2/224 kBProgress (2): 2.2/224 kB | 2.2/8.3 kBProgress (2): 2.2/224 kB | 5.0/8.3 kBProgress (2): 5.0/224 kB | 5.0/8.3 kBProgress (2): 5.0/224 kB | 7.7/8.3 kBProgress (2): 5.0/224 kB | 8.3 kB Progress (2): 7.7/224 kB | 8.3 kBProgress (2): 10/224 kB | 8.3 kB Progress (2): 13/224 kB | 8.3 kBProgress (2): 16/224 kB | 8.3 kBProgress (2): 19/224 kB | 8.3 kBProgress (2): 21/224 kB | 8.3 kBProgress (2): 24/224 kB | 8.3 kBProgress (2): 27/224 kB | 8.3 kBProgress (2): 30/224 kB | 8.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar (8.3 kB at 926 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar
Progress (1): 32/224 kBProgress (2): 32/224 kB | 2.2/109 kBProgress (2): 36/224 kB | 2.2/109 kBProgress (2): 36/224 kB | 5.0/109 kBProgress (2): 36/224 kB | 7.7/109 kBProgress (3): 36/224 kB | 7.7/109 kB | 2.2/44 kBProgress (3): 36/224 kB | 10/109 kB | 2.2/44 kB Progress (3): 40/224 kB | 10/109 kB | 2.2/44 kBProgress (3): 45/224 kB | 10/109 kB | 2.2/44 kBProgress (3): 45/224 kB | 10/109 kB | 5.0/44 kBProgress (3): 49/224 kB | 10/109 kB | 5.0/44 kBProgress (4): 49/224 kB | 10/109 kB | 5.0/44 kB | 2.2/30 kBProgress (4): 49/224 kB | 13/109 kB | 5.0/44 kB | 2.2/30 kBProgress (4): 49/224 kB | 13/109 kB | 5.0/44 kB | 5.0/30 kBProgress (4): 49/224 kB | 13/109 kB | 5.0/44 kB | 7.7/30 kBProgress (4): 49/224 kB | 13/109 kB | 5.0/44 kB | 10/30 kB Progress (4): 49/224 kB | 16/109 kB | 5.0/44 kB | 10/30 kBProgress (4): 49/224 kB | 16/109 kB | 7.7/44 kB | 10/30 kBProgress (4): 49/224 kB | 16/109 kB | 7.7/44 kB | 13/30 kBProgress (4): 49/224 kB | 19/109 kB | 7.7/44 kB | 13/30 kBProgress (4): 49/224 kB | 19/109 kB | 7.7/44 kB | 16/30 kBProgress (4): 49/224 kB | 19/109 kB | 7.7/44 kB | 19/30 kBProgress (4): 49/224 kB | 21/109 kB | 7.7/44 kB | 19/30 kBProgress (4): 49/224 kB | 21/109 kB | 7.7/44 kB | 21/30 kBProgress (4): 49/224 kB | 24/109 kB | 7.7/44 kB | 21/30 kBProgress (4): 49/224 kB | 24/109 kB | 7.7/44 kB | 24/30 kBProgress (4): 49/224 kB | 24/109 kB | 7.7/44 kB | 27/30 kBProgress (4): 49/224 kB | 27/109 kB | 7.7/44 kB | 27/30 kBProgress (4): 49/224 kB | 27/109 kB | 7.7/44 kB | 30/30 kBProgress (4): 49/224 kB | 27/109 kB | 7.7/44 kB | 30 kB Progress (4): 49/224 kB | 30/109 kB | 7.7/44 kB | 30 kBProgress (4): 49/224 kB | 32/109 kB | 7.7/44 kB | 30 kBProgress (4): 53/224 kB | 32/109 kB | 7.7/44 kB | 30 kBProgress (4): 57/224 kB | 32/109 kB | 7.7/44 kB | 30 kBProgress (4): 61/224 kB | 32/109 kB | 7.7/44 kB | 30 kBProgress (4): 65/224 kB | 32/109 kB | 7.7/44 kB | 30 kBProgress (4): 65/224 kB | 36/109 kB | 7.7/44 kB | 30 kBProgress (4): 65/224 kB | 40/109 kB | 7.7/44 kB | 30 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar (30 kB at 2.2 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar
Progress (3): 65/224 kB | 40/109 kB | 10/44 kBProgress (3): 65/224 kB | 40/109 kB | 13/44 kBProgress (3): 65/224 kB | 40/109 kB | 16/44 kBProgress (3): 65/224 kB | 45/109 kB | 16/44 kBProgress (3): 65/224 kB | 49/109 kB | 16/44 kBProgress (3): 69/224 kB | 49/109 kB | 16/44 kBProgress (3): 69/224 kB | 49/109 kB | 19/44 kBProgress (3): 69/224 kB | 49/109 kB | 21/44 kBProgress (3): 69/224 kB | 53/109 kB | 21/44 kBProgress (3): 69/224 kB | 57/109 kB | 21/44 kBProgress (3): 69/224 kB | 61/109 kB | 21/44 kBProgress (3): 69/224 kB | 65/109 kB | 21/44 kBProgress (4): 69/224 kB | 65/109 kB | 21/44 kB | 2.2/80 kBProgress (4): 69/224 kB | 65/109 kB | 21/44 kB | 5.0/80 kBProgress (4): 69/224 kB | 65/109 kB | 21/44 kB | 7.7/80 kBProgress (4): 69/224 kB | 69/109 kB | 21/44 kB | 7.7/80 kBProgress (4): 69/224 kB | 73/109 kB | 21/44 kB | 7.7/80 kBProgress (4): 69/224 kB | 73/109 kB | 21/44 kB | 10/80 kB Progress (4): 69/224 kB | 77/109 kB | 21/44 kB | 10/80 kBProgress (4): 73/224 kB | 77/109 kB | 21/44 kB | 10/80 kBProgress (4): 73/224 kB | 77/109 kB | 24/44 kB | 10/80 kBProgress (4): 73/224 kB | 81/109 kB | 24/44 kB | 10/80 kBProgress (4): 73/224 kB | 81/109 kB | 27/44 kB | 10/80 kBProgress (5): 73/224 kB | 81/109 kB | 27/44 kB | 10/80 kB | 0/1.0 MBProgress (5): 73/224 kB | 81/109 kB | 27/44 kB | 13/80 kB | 0/1.0 MBProgress (5): 77/224 kB | 81/109 kB | 27/44 kB | 13/80 kB | 0/1.0 MBProgress (5): 77/224 kB | 81/109 kB | 27/44 kB | 16/80 kB | 0/1.0 MBProgress (5): 77/224 kB | 81/109 kB | 27/44 kB | 19/80 kB | 0/1.0 MBProgress (5): 77/224 kB | 81/109 kB | 27/44 kB | 21/80 kB | 0/1.0 MBProgress (5): 77/224 kB | 81/109 kB | 30/44 kB | 21/80 kB | 0/1.0 MBProgress (5): 77/224 kB | 81/109 kB | 30/44 kB | 24/80 kB | 0/1.0 MBProgress (5): 77/224 kB | 81/109 kB | 30/44 kB | 27/80 kB | 0/1.0 MBProgress (5): 81/224 kB | 81/109 kB | 30/44 kB | 27/80 kB | 0/1.0 MBProgress (5): 81/224 kB | 81/109 kB | 30/44 kB | 30/80 kB | 0/1.0 MBProgress (5): 81/224 kB | 81/109 kB | 30/44 kB | 32/80 kB | 0/1.0 MBProgress (5): 81/224 kB | 81/109 kB | 30/44 kB | 36/80 kB | 0/1.0 MBProgress (5): 81/224 kB | 81/109 kB | 30/44 kB | 40/80 kB | 0/1.0 MBProgress (5): 81/224 kB | 81/109 kB | 32/44 kB | 40/80 kB | 0/1.0 MBProgress (5): 81/224 kB | 81/109 kB | 32/44 kB | 45/80 kB | 0/1.0 MBProgress (5): 81/224 kB | 81/109 kB | 32/44 kB | 49/80 kB | 0/1.0 MBProgress (5): 81/224 kB | 81/109 kB | 32/44 kB | 53/80 kB | 0/1.0 MBProgress (5): 81/224 kB | 81/109 kB | 32/44 kB | 57/80 kB | 0/1.0 MBProgress (5): 81/224 kB | 81/109 kB | 32/44 kB | 61/80 kB | 0/1.0 MBProgress (5): 81/224 kB | 81/109 kB | 32/44 kB | 65/80 kB | 0/1.0 MBProgress (5): 85/224 kB | 81/109 kB | 32/44 kB | 65/80 kB | 0/1.0 MBProgress (5): 85/224 kB | 81/109 kB | 32/44 kB | 69/80 kB | 0/1.0 MBProgress (5): 85/224 kB | 81/109 kB | 36/44 kB | 69/80 kB | 0/1.0 MBProgress (5): 85/224 kB | 81/109 kB | 36/44 kB | 69/80 kB | 0/1.0 MBProgress (5): 85/224 kB | 81/109 kB | 36/44 kB | 73/80 kB | 0/1.0 MBProgress (5): 85/224 kB | 81/109 kB | 36/44 kB | 77/80 kB | 0/1.0 MBProgress (5): 85/224 kB | 81/109 kB | 36/44 kB | 80 kB | 0/1.0 MB Progress (5): 85/224 kB | 85/109 kB | 36/44 kB | 80 kB | 0/1.0 MBProgress (5): 85/224 kB | 85/109 kB | 40/44 kB | 80 kB | 0/1.0 MBProgress (5): 90/224 kB | 85/109 kB | 40/44 kB | 80 kB | 0/1.0 MBProgress (5): 90/224 kB | 90/109 kB | 40/44 kB | 80 kB | 0/1.0 MBProgress (5): 90/224 kB | 94/109 kB | 40/44 kB | 80 kB | 0/1.0 MBProgress (5): 94/224 kB | 94/109 kB | 40/44 kB | 80 kB | 0/1.0 MBProgress (5): 94/224 kB | 94/109 kB | 40/44 kB | 80 kB | 0/1.0 MBProgress (5): 98/224 kB | 94/109 kB | 40/44 kB | 80 kB | 0/1.0 MBProgress (5): 98/224 kB | 98/109 kB | 40/44 kB | 80 kB | 0/1.0 MBProgress (5): 98/224 kB | 98/109 kB | 44 kB | 80 kB | 0/1.0 MB Progress (5): 98/224 kB | 98/109 kB | 44 kB | 80 kB | 0/1.0 MBProgress (5): 98/224 kB | 98/109 kB | 44 kB | 80 kB | 0/1.0 MBProgress (5): 98/224 kB | 102/109 kB | 44 kB | 80 kB | 0/1.0 MBProgress (5): 98/224 kB | 102/109 kB | 44 kB | 80 kB | 0/1.0 MBProgress (5): 102/224 kB | 102/109 kB | 44 kB | 80 kB | 0/1.0 MBProgress (5): 102/224 kB | 106/109 kB | 44 kB | 80 kB | 0/1.0 MBProgress (5): 106/224 kB | 106/109 kB | 44 kB | 80 kB | 0/1.0 MBProgress (5): 106/224 kB | 106/109 kB | 44 kB | 80 kB | 0/1.0 MBProgress (5): 110/224 kB | 106/109 kB | 44 kB | 80 kB | 0/1.0 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar (80 kB at 2.9 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar
Progress (4): 110/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 110/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 110/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 110/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 110/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 110/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 110/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 110/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 110/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 110/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 114/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 118/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 122/224 kB | 109 kB | 44 kB | 0/1.0 MBProgress (4): 126/224 kB | 109 kB | 44 kB | 0/1.0 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar (109 kB at 3.3 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar
Progress (3): 131/224 kB | 44 kB | 0/1.0 MBProgress (3): 135/224 kB | 44 kB | 0/1.0 MBProgress (3): 139/224 kB | 44 kB | 0/1.0 MBProgress (3): 143/224 kB | 44 kB | 0/1.0 MBProgress (3): 147/224 kB | 44 kB | 0/1.0 MBProgress (3): 151/224 kB | 44 kB | 0/1.0 MBProgress (3): 155/224 kB | 44 kB | 0/1.0 MBProgress (3): 159/224 kB | 44 kB | 0/1.0 MBProgress (3): 163/224 kB | 44 kB | 0/1.0 MBProgress (3): 163/224 kB | 44 kB | 0.1/1.0 MBProgress (3): 163/224 kB | 44 kB | 0.1/1.0 MBProgress (3): 163/224 kB | 44 kB | 0.1/1.0 MBProgress (3): 163/224 kB | 44 kB | 0.1/1.0 MBProgress (4): 163/224 kB | 44 kB | 0.1/1.0 MB | 4.1/20 kBProgress (4): 163/224 kB | 44 kB | 0.1/1.0 MB | 7.7/20 kBProgress (4): 163/224 kB | 44 kB | 0.1/1.0 MB | 12/20 kB Progress (4): 163/224 kB | 44 kB | 0.1/1.0 MB | 16/20 kBProgress (4): 163/224 kB | 44 kB | 0.1/1.0 MB | 20 kB Progress (5): 163/224 kB | 44 kB | 0.1/1.0 MB | 20 kB | 4.1/49 kBProgress (5): 163/224 kB | 44 kB | 0.1/1.0 MB | 20 kB | 4.1/49 kBProgress (5): 163/224 kB | 44 kB | 0.1/1.0 MB | 20 kB | 4.1/49 kBProgress (5): 163/224 kB | 44 kB | 0.1/1.0 MB | 20 kB | 4.1/49 kBProgress (5): 163/224 kB | 44 kB | 0.1/1.0 MB | 20 kB | 4.1/49 kBProgress (5): 163/224 kB | 44 kB | 0.1/1.0 MB | 20 kB | 7.7/49 kBProgress (5): 167/224 kB | 44 kB | 0.1/1.0 MB | 20 kB | 7.7/49 kBProgress (5): 171/224 kB | 44 kB | 0.1/1.0 MB | 20 kB | 7.7/49 kBProgress (5): 176/224 kB | 44 kB | 0.1/1.0 MB | 20 kB | 7.7/49 kBProgress (5): 180/224 kB | 44 kB | 0.1/1.0 MB | 20 kB | 7.7/49 kBProgress (5): 180/224 kB | 44 kB | 0.1/1.0 MB | 20 kB | 12/49 kB Progress (5): 180/224 kB | 44 kB | 0.1/1.0 MB | 20 kB | 16/49 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar (20 kB at 505 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar
Progress (4): 184/224 kB | 44 kB | 0.1/1.0 MB | 16/49 kBProgress (4): 188/224 kB | 44 kB | 0.1/1.0 MB | 16/49 kBProgress (4): 192/224 kB | 44 kB | 0.1/1.0 MB | 16/49 kBProgress (4): 196/224 kB | 44 kB | 0.1/1.0 MB | 16/49 kBProgress (4): 196/224 kB | 44 kB | 0.1/1.0 MB | 20/49 kBProgress (4): 196/224 kB | 44 kB | 0.1/1.0 MB | 20/49 kBProgress (4): 196/224 kB | 44 kB | 0.1/1.0 MB | 20/49 kBProgress (4): 196/224 kB | 44 kB | 0.1/1.0 MB | 20/49 kBProgress (4): 196/224 kB | 44 kB | 0.1/1.0 MB | 20/49 kBProgress (4): 196/224 kB | 44 kB | 0.1/1.0 MB | 24/49 kBProgress (4): 196/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kBProgress (4): 196/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kBProgress (4): 196/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kBProgress (4): 196/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kBProgress (4): 196/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kBProgress (4): 200/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kBProgress (4): 204/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kBProgress (4): 208/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kBProgress (4): 212/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kBProgress (4): 212/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kBProgress (5): 212/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kB | 4.1/195 kBProgress (5): 212/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kB | 7.7/195 kBProgress (5): 212/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kB | 12/195 kB Progress (5): 212/224 kB | 44 kB | 0.1/1.0 MB | 28/49 kB | 16/195 kBProgress (5): 212/224 kB | 44 kB | 0.1/1.0 MB | 32/49 kB | 16/195 kBProgress (5): 212/224 kB | 44 kB | 0.1/1.0 MB | 32/49 kB | 20/195 kBProgress (5): 217/224 kB | 44 kB | 0.1/1.0 MB | 32/49 kB | 20/195 kBProgress (5): 217/224 kB | 44 kB | 0.1/1.0 MB | 32/49 kB | 20/195 kBProgress (5): 221/224 kB | 44 kB | 0.1/1.0 MB | 32/49 kB | 20/195 kBProgress (5): 221/224 kB | 44 kB | 0.1/1.0 MB | 32/49 kB | 20/195 kBProgress (5): 224 kB | 44 kB | 0.1/1.0 MB | 32/49 kB | 20/195 kB Progress (5): 224 kB | 44 kB | 0.1/1.0 MB | 36/49 kB | 20/195 kBProgress (5): 224 kB | 44 kB | 0.1/1.0 MB | 36/49 kB | 20/195 kBProgress (5): 224 kB | 44 kB | 0.1/1.0 MB | 36/49 kB | 24/195 kBProgress (5): 224 kB | 44 kB | 0.1/1.0 MB | 40/49 kB | 24/195 kBProgress (5): 224 kB | 44 kB | 0.1/1.0 MB | 45/49 kB | 24/195 kBProgress (5): 224 kB | 44 kB | 0.1/1.0 MB | 45/49 kB | 28/195 kBProgress (5): 224 kB | 44 kB | 0.1/1.0 MB | 45/49 kB | 32/195 kBProgress (5): 224 kB | 44 kB | 0.1/1.0 MB | 45/49 kB | 32/195 kBProgress (5): 224 kB | 44 kB | 0.1/1.0 MB | 45/49 kB | 32/195 kBProgress (5): 224 kB | 44 kB | 0.1/1.0 MB | 45/49 kB | 32/195 kBProgress (5): 224 kB | 44 kB | 0.1/1.0 MB | 45/49 kB | 32/195 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar (44 kB at 912 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar
Progress (4): 224 kB | 0.1/1.0 MB | 49/49 kB | 32/195 kBProgress (4): 224 kB | 0.2/1.0 MB | 49/49 kB | 32/195 kB Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar (224 kB at 4.2 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar
Progress (4): 0.2/1.0 MB | 49/49 kB | 32/195 kB | 4.1/121 kBProgress (4): 0.2/1.0 MB | 49/49 kB | 32/195 kB | 7.6/121 kBProgress (4): 0.2/1.0 MB | 49/49 kB | 32/195 kB | 12/121 kB Progress (4): 0.2/1.0 MB | 49/49 kB | 32/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 32/195 kB | 16/121 kB Progress (4): 0.2/1.0 MB | 49 kB | 36/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 40/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 45/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 49/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 53/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 57/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 61/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 65/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 65/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 65/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 65/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 69/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 73/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 77/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 81/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 85/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 90/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 94/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 98/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 102/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 106/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 110/195 kB | 16/121 kBProgress (4): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kB | 7.7/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kB | 12/80 kB Progress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kB | 20/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kB | 24/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kB | 28/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kB | 32/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kB | 36/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kB | 40/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kB | 45/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 16/121 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 20/121 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 24/121 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 28/121 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 114/195 kB | 32/121 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 118/195 kB | 32/121 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 122/195 kB | 32/121 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 126/195 kB | 32/121 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 131/195 kB | 32/121 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 49 kB | 131/195 kB | 32/121 kB | 49/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar (49 kB at 743 kB/s)
Progress (4): 0.2/1.0 MB | 131/195 kB | 32/121 kB | 49/80 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 32/121 kB | 49/80 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 32/121 kB | 49/80 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 32/121 kB | 53/80 kB Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar
Progress (4): 0.2/1.0 MB | 131/195 kB | 32/121 kB | 57/80 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 32/121 kB | 61/80 kBProgress (4): 0.2/1.0 MB | 131/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.2/1.0 MB | 135/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.2/1.0 MB | 135/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.2/1.0 MB | 135/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.2/1.0 MB | 139/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.2/1.0 MB | 139/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.2/1.0 MB | 139/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.2/1.0 MB | 143/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 65/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 69/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 69/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 69/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 69/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 73/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 77/80 kBProgress (4): 0.2/1.0 MB | 147/195 kB | 32/121 kB | 80 kB Progress (4): 0.2/1.0 MB | 151/195 kB | 32/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 151/195 kB | 32/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 151/195 kB | 32/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 151/195 kB | 36/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 151/195 kB | 40/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 151/195 kB | 45/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 151/195 kB | 49/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 155/195 kB | 49/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 159/195 kB | 49/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 163/195 kB | 49/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 163/195 kB | 49/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 163/195 kB | 49/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 163/195 kB | 49/121 kB | 80 kBProgress (4): 0.2/1.0 MB | 163/195 kB | 49/121 kB | 80 kBProgress (5): 0.2/1.0 MB | 163/195 kB | 49/121 kB | 80 kB | 4.1/251 kBProgress (5): 0.2/1.0 MB | 167/195 kB | 49/121 kB | 80 kB | 4.1/251 kBProgress (5): 0.2/1.0 MB | 167/195 kB | 53/121 kB | 80 kB | 4.1/251 kBProgress (5): 0.2/1.0 MB | 167/195 kB | 53/121 kB | 80 kB | 7.7/251 kBProgress (5): 0.2/1.0 MB | 167/195 kB | 53/121 kB | 80 kB | 7.7/251 kBProgress (5): 0.2/1.0 MB | 167/195 kB | 53/121 kB | 80 kB | 7.7/251 kBProgress (5): 0.2/1.0 MB | 167/195 kB | 57/121 kB | 80 kB | 7.7/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar (80 kB at 1.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar
Progress (4): 0.2/1.0 MB | 167/195 kB | 57/121 kB | 12/251 kBProgress (4): 0.2/1.0 MB | 167/195 kB | 57/121 kB | 16/251 kBProgress (4): 0.2/1.0 MB | 171/195 kB | 57/121 kB | 16/251 kBProgress (4): 0.2/1.0 MB | 176/195 kB | 57/121 kB | 16/251 kBProgress (4): 0.2/1.0 MB | 180/195 kB | 57/121 kB | 16/251 kBProgress (4): 0.2/1.0 MB | 180/195 kB | 57/121 kB | 16/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 57/121 kB | 16/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 57/121 kB | 16/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 57/121 kB | 16/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 57/121 kB | 20/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 57/121 kB | 24/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 57/121 kB | 28/251 kBProgress (4): 0.3/1.0 MB | 184/195 kB | 57/121 kB | 28/251 kBProgress (4): 0.3/1.0 MB | 188/195 kB | 57/121 kB | 28/251 kBProgress (4): 0.3/1.0 MB | 192/195 kB | 57/121 kB | 28/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 57/121 kB | 28/251 kB Progress (4): 0.3/1.0 MB | 195 kB | 61/121 kB | 28/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 65/121 kB | 28/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 69/121 kB | 28/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 73/121 kB | 28/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 77/121 kB | 28/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 81/121 kB | 28/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 81/121 kB | 32/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar (195 kB at 2.6 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar
Progress (3): 0.3/1.0 MB | 81/121 kB | 32/251 kBProgress (3): 0.3/1.0 MB | 81/121 kB | 32/251 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 32/251 kB | 4.1/12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 32/251 kB | 7.7/12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 32/251 kB | 12/12 kB Progress (4): 0.3/1.0 MB | 81/121 kB | 32/251 kB | 12 kB Progress (4): 0.3/1.0 MB | 81/121 kB | 32/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 36/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 36/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 40/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 45/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 49/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 49/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 53/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 57/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 61/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 65/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 69/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 73/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 73/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 73/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 77/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 77/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 81/121 kB | 81/251 kB | 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar (12 kB at 152 kB/s)
Progress (3): 0.3/1.0 MB | 81/121 kB | 85/251 kBProgress (3): 0.3/1.0 MB | 81/121 kB | 85/251 kBProgress (3): 0.3/1.0 MB | 81/121 kB | 90/251 kBProgress (3): 0.3/1.0 MB | 81/121 kB | 90/251 kBProgress (3): 0.3/1.0 MB | 81/121 kB | 90/251 kBProgress (3): 0.3/1.0 MB | 81/121 kB | 94/251 kBProgress (3): 0.3/1.0 MB | 81/121 kB | 94/251 kBProgress (3): 0.3/1.0 MB | 81/121 kB | 98/251 kBProgress (3): 0.3/1.0 MB | 85/121 kB | 98/251 kBProgress (3): 0.3/1.0 MB | 85/121 kB | 98/251 kBProgress (3): 0.3/1.0 MB | 85/121 kB | 102/251 kBProgress (3): 0.3/1.0 MB | 85/121 kB | 106/251 kBProgress (3): 0.3/1.0 MB | 85/121 kB | 110/251 kBProgress (3): 0.3/1.0 MB | 85/121 kB | 110/251 kBProgress (3): 0.3/1.0 MB | 85/121 kB | 114/251 kBProgress (3): 0.3/1.0 MB | 90/121 kB | 114/251 kBProgress (3): 0.3/1.0 MB | 90/121 kB | 114/251 kBProgress (3): 0.3/1.0 MB | 94/121 kB | 114/251 kBProgress (3): 0.3/1.0 MB | 98/121 kB | 114/251 kBProgress (3): 0.3/1.0 MB | 98/121 kB | 114/251 kBProgress (3): 0.3/1.0 MB | 98/121 kB | 114/251 kBProgress (4): 0.3/1.0 MB | 98/121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 98/121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 98/121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 98/121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 98/121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 98/121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 98/121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 98/121 kB | 114/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 98/121 kB | 118/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 98/121 kB | 118/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 98/121 kB | 122/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 98/121 kB | 126/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 102/121 kB | 126/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 102/121 kB | 126/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 106/121 kB | 126/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 110/121 kB | 126/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 110/121 kB | 126/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 110/121 kB | 126/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 110/121 kB | 126/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 110/121 kB | 126/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 110/121 kB | 126/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 110/121 kB | 131/251 kB | 0/1.3 MBProgress (4): 0.3/1.0 MB | 110/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.3/1.0 MB | 110/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.3/1.0 MB | 110/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.3/1.0 MB | 110/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.3/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.3/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.3/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.3/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 114/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 118/121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 131/251 kB | 0.1/1.3 MB Progress (4): 0.4/1.0 MB | 121 kB | 131/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 135/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 135/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 135/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 135/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 135/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 139/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 143/251 kB | 0.1/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 143/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 143/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 147/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 151/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 155/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 159/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 163/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 167/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 171/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 176/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 180/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 184/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 188/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 192/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 196/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 200/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 204/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 208/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 212/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 217/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 221/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 225/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 229/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 233/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 237/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 241/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 245/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 249/251 kB | 0.2/1.3 MBProgress (4): 0.4/1.0 MB | 121 kB | 251 kB | 0.2/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar (251 kB at 2.4 MB/s)
Progress (3): 0.4/1.0 MB | 121 kB | 0.2/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar (121 kB at 1.1 MB/s)
Progress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.4/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.2/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.5/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.3/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.6/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.4/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.7/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.5/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.8/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 0.9/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.6/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0/1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MB Progress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MBProgress (2): 1.0 MB | 0.7/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar (1.0 MB at 6.5 MB/s)
Progress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar (1.3 MB at 7.0 MB/s)
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en&gt;
     [echo] Build directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.16-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;:137:Inline literal start-string without end-string.
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 45.246 s
[e[1;34mINFOe[m] Finished at: 2019-05-27T21:29:02Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://build.geoserver.org/job/geoserver-master-live-docs/1827/display/redirect?page=changes&gt;
Changes:
[gabriel.roldan] Speed up data_dir load by making ConfigurationPasswordEncryptionHelper
[...truncated 397.97 KB...]
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom
Progress (1): 861 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom (861 B at 57 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom
Progress (1): 761 B Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom (761 B at 190 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom
Progress (1): 138 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom (138 B at 34 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom
Progress (1): 643 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom (643 B at 161 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom
Progress (1): 2.2/12 kBProgress (1): 5.0/12 kBProgress (1): 7.8/12 kBProgress (1): 11/12 kB Progress (1): 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom (12 kB at 2.9 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom
Progress (1): 1.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom (1.8 kB at 460 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom (1.6 kB at 325 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom
Progress (1): 2.2/2.7 kBProgress (1): 2.7 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom (2.7 kB at 678 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom
Progress (1): 767 B Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom (767 B at 192 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom
Progress (1): 1.2 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom (1.2 kB at 309 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom
Progress (1): 998 B Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom (998 B at 250 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom (1.6 kB at 404 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom
Progress (1): 1.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom (1.4 kB at 453 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom
Progress (1): 1.5 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom (1.5 kB at 372 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom
Progress (1): 765 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom (765 B at 255 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom
Progress (1): 2.2/5.3 kBProgress (1): 5.0/5.3 kBProgress (1): 5.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom (5.3 kB at 1.3 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom (9.8 kB at 2.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom
Progress (1): 2.2/2.4 kBProgress (1): 2.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom (2.4 kB at 596 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom
Progress (1): 2.2/4.4 kBProgress (1): 4.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom (4.4 kB at 1.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom (9.8 kB at 2.4 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar
Progress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (1): 0/1.0 MBProgress (2): 0/1.0 MB | 2.2/8.3 kBProgress (2): 0/1.0 MB | 2.2/8.3 kBProgress (2): 0/1.0 MB | 5.0/8.3 kBProgress (2): 0/1.0 MB | 7.7/8.3 kBProgress (2): 0/1.0 MB | 8.3 kB Progress (3): 0/1.0 MB | 8.3 kB | 2.2/109 kBProgress (3): 0/1.0 MB | 8.3 kB | 2.2/109 kBProgress (3): 0/1.0 MB | 8.3 kB | 5.0/109 kBProgress (3): 0/1.0 MB | 8.3 kB | 5.0/109 kBProgress (3): 0/1.0 MB | 8.3 kB | 5.0/109 kBProgress (3): 0/1.0 MB | 8.3 kB | 5.0/109 kBProgress (3): 0/1.0 MB | 8.3 kB | 7.7/109 kBProgress (3): 0/1.0 MB | 8.3 kB | 10/109 kB Progress (3): 0/1.0 MB | 8.3 kB | 13/109 kBProgress (3): 0.1/1.0 MB | 8.3 kB | 13/109 kBProgress (3): 0.1/1.0 MB | 8.3 kB | 16/109 kBProgress (3): 0.1/1.0 MB | 8.3 kB | 16/109 kBProgress (4): 0.1/1.0 MB | 8.3 kB | 16/109 kB | 2.2/224 kBProgress (4): 0.1/1.0 MB | 8.3 kB | 16/109 kB | 2.2/224 kBProgress (4): 0.1/1.0 MB | 8.3 kB | 19/109 kB | 2.2/224 kBProgress (4): 0.1/1.0 MB | 8.3 kB | 19/109 kB | 2.2/224 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 19/109 kB | 2.2/224 kB | 2.2/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 21/109 kB | 2.2/224 kB | 2.2/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 21/109 kB | 5.0/224 kB | 2.2/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 24/109 kB | 5.0/224 kB | 2.2/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 24/109 kB | 5.0/224 kB | 5.0/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 27/109 kB | 5.0/224 kB | 5.0/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 27/109 kB | 5.0/224 kB | 5.0/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 27/109 kB | 5.0/224 kB | 7.7/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 27/109 kB | 5.0/224 kB | 7.7/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 30/109 kB | 5.0/224 kB | 7.7/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 30/109 kB | 5.0/224 kB | 7.7/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 30/109 kB | 5.0/224 kB | 7.7/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 30/109 kB | 5.0/224 kB | 10/44 kB Progress (5): 0.1/1.0 MB | 8.3 kB | 30/109 kB | 7.7/224 kB | 10/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 30/109 kB | 7.7/224 kB | 13/44 kBProgress (5): 0.1/1.0 MB | 8.3 kB | 30/109 kB | 10/224 kB | 13/44 kB Progress (5): 0.1/1.0 MB | 8.3 kB | 30/109 kB | 10/224 kB | 16/44 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar (8.3 kB at 757 kB/s)
Progress (4): 0.1/1.0 MB | 32/109 kB | 10/224 kB | 16/44 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar
Progress (4): 0.1/1.0 MB | 32/109 kB | 10/224 kB | 16/44 kBProgress (4): 0.1/1.0 MB | 32/109 kB | 10/224 kB | 19/44 kBProgress (4): 0.1/1.0 MB | 32/109 kB | 10/224 kB | 21/44 kBProgress (4): 0.1/1.0 MB | 32/109 kB | 13/224 kB | 21/44 kBProgress (4): 0.1/1.0 MB | 32/109 kB | 13/224 kB | 24/44 kBProgress (4): 0.1/1.0 MB | 32/109 kB | 13/224 kB | 24/44 kBProgress (4): 0.1/1.0 MB | 32/109 kB | 13/224 kB | 27/44 kBProgress (4): 0.1/1.0 MB | 32/109 kB | 13/224 kB | 27/44 kBProgress (4): 0.1/1.0 MB | 36/109 kB | 13/224 kB | 27/44 kBProgress (4): 0.1/1.0 MB | 36/109 kB | 13/224 kB | 27/44 kBProgress (4): 0.1/1.0 MB | 36/109 kB | 13/224 kB | 30/44 kBProgress (4): 0.1/1.0 MB | 40/109 kB | 13/224 kB | 30/44 kBProgress (4): 0.1/1.0 MB | 40/109 kB | 16/224 kB | 30/44 kBProgress (4): 0.1/1.0 MB | 40/109 kB | 16/224 kB | 32/44 kBProgress (4): 0.1/1.0 MB | 45/109 kB | 16/224 kB | 32/44 kBProgress (4): 0.1/1.0 MB | 45/109 kB | 19/224 kB | 32/44 kBProgress (4): 0.1/1.0 MB | 49/109 kB | 19/224 kB | 32/44 kBProgress (4): 0.1/1.0 MB | 49/109 kB | 21/224 kB | 32/44 kBProgress (4): 0.1/1.0 MB | 49/109 kB | 21/224 kB | 32/44 kBProgress (4): 0.1/1.0 MB | 49/109 kB | 21/224 kB | 32/44 kBProgress (4): 0.1/1.0 MB | 49/109 kB | 21/224 kB | 36/44 kBProgress (4): 0.1/1.0 MB | 49/109 kB | 24/224 kB | 36/44 kBProgress (4): 0.1/1.0 MB | 49/109 kB | 24/224 kB | 40/44 kBProgress (4): 0.1/1.0 MB | 49/109 kB | 24/224 kB | 44 kB Progress (4): 0.1/1.0 MB | 49/109 kB | 24/224 kB | 44 kBProgress (4): 0.1/1.0 MB | 53/109 kB | 24/224 kB | 44 kBProgress (4): 0.1/1.0 MB | 53/109 kB | 27/224 kB | 44 kBProgress (4): 0.1/1.0 MB | 57/109 kB | 27/224 kB | 44 kBProgress (4): 0.1/1.0 MB | 57/109 kB | 27/224 kB | 44 kBProgress (4): 0.1/1.0 MB | 57/109 kB | 30/224 kB | 44 kBProgress (4): 0.1/1.0 MB | 61/109 kB | 30/224 kB | 44 kBProgress (5): 0.1/1.0 MB | 61/109 kB | 30/224 kB | 44 kB | 2.2/30 kBProgress (5): 0.1/1.0 MB | 65/109 kB | 30/224 kB | 44 kB | 2.2/30 kBProgress (5): 0.1/1.0 MB | 65/109 kB | 32/224 kB | 44 kB | 2.2/30 kBProgress (5): 0.1/1.0 MB | 65/109 kB | 32/224 kB | 44 kB | 5.0/30 kBProgress (5): 0.1/1.0 MB | 65/109 kB | 32/224 kB | 44 kB | 7.7/30 kBProgress (5): 0.1/1.0 MB | 65/109 kB | 32/224 kB | 44 kB | 7.7/30 kBProgress (5): 0.1/1.0 MB | 65/109 kB | 32/224 kB | 44 kB | 7.7/30 kBProgress (5): 0.1/1.0 MB | 65/109 kB | 36/224 kB | 44 kB | 7.7/30 kBProgress (5): 0.1/1.0 MB | 65/109 kB | 36/224 kB | 44 kB | 10/30 kB Progress (5): 0.1/1.0 MB | 65/109 kB | 40/224 kB | 44 kB | 10/30 kBProgress (5): 0.1/1.0 MB | 65/109 kB | 40/224 kB | 44 kB | 10/30 kBProgress (5): 0.1/1.0 MB | 65/109 kB | 45/224 kB | 44 kB | 10/30 kBProgress (5): 0.1/1.0 MB | 69/109 kB | 45/224 kB | 44 kB | 10/30 kBProgress (5): 0.1/1.0 MB | 69/109 kB | 49/224 kB | 44 kB | 10/30 kBProgress (5): 0.1/1.0 MB | 69/109 kB | 49/224 kB | 44 kB | 10/30 kBProgress (5): 0.1/1.0 MB | 69/109 kB | 49/224 kB | 44 kB | 13/30 kBProgress (5): 0.1/1.0 MB | 73/109 kB | 49/224 kB | 44 kB | 13/30 kBProgress (5): 0.1/1.0 MB | 77/109 kB | 49/224 kB | 44 kB | 13/30 kBProgress (5): 0.1/1.0 MB | 77/109 kB | 49/224 kB | 44 kB | 16/30 kBProgress (5): 0.1/1.0 MB | 81/109 kB | 49/224 kB | 44 kB | 16/30 kBProgress (5): 0.1/1.0 MB | 81/109 kB | 49/224 kB | 44 kB | 19/30 kBProgress (5): 0.1/1.0 MB | 81/109 kB | 49/224 kB | 44 kB | 21/30 kBProgress (5): 0.1/1.0 MB | 81/109 kB | 53/224 kB | 44 kB | 21/30 kBProgress (5): 0.1/1.0 MB | 81/109 kB | 57/224 kB | 44 kB | 21/30 kBProgress (5): 0.1/1.0 MB | 81/109 kB | 57/224 kB | 44 kB | 24/30 kBProgress (5): 0.1/1.0 MB | 81/109 kB | 61/224 kB | 44 kB | 24/30 kBProgress (5): 0.1/1.0 MB | 81/109 kB | 61/224 kB | 44 kB | 24/30 kBProgress (5): 0.1/1.0 MB | 81/109 kB | 65/224 kB | 44 kB | 24/30 kBProgress (5): 0.1/1.0 MB | 81/109 kB | 65/224 kB | 44 kB | 24/30 kBProgress (5): 0.1/1.0 MB | 85/109 kB | 65/224 kB | 44 kB | 24/30 kBProgress (5): 0.1/1.0 MB | 90/109 kB | 65/224 kB | 44 kB | 24/30 kBProgress (5): 0.1/1.0 MB | 94/109 kB | 65/224 kB | 44 kB | 24/30 kBProgress (5): 0.1/1.0 MB | 98/109 kB | 65/224 kB | 44 kB | 24/30 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar (44 kB at 2.6 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar
Progress (4): 0.1/1.0 MB | 98/109 kB | 69/224 kB | 24/30 kBProgress (4): 0.1/1.0 MB | 98/109 kB | 73/224 kB | 24/30 kBProgress (4): 0.1/1.0 MB | 98/109 kB | 77/224 kB | 24/30 kBProgress (4): 0.1/1.0 MB | 98/109 kB | 81/224 kB | 24/30 kBProgress (4): 0.1/1.0 MB | 98/109 kB | 81/224 kB | 27/30 kBProgress (4): 0.1/1.0 MB | 98/109 kB | 81/224 kB | 27/30 kBProgress (4): 0.1/1.0 MB | 98/109 kB | 81/224 kB | 30/30 kBProgress (4): 0.1/1.0 MB | 102/109 kB | 81/224 kB | 30/30 kBProgress (4): 0.1/1.0 MB | 102/109 kB | 81/224 kB | 30 kB Progress (4): 0.1/1.0 MB | 102/109 kB | 81/224 kB | 30 kBProgress (4): 0.1/1.0 MB | 106/109 kB | 81/224 kB | 30 kBProgress (4): 0.1/1.0 MB | 106/109 kB | 85/224 kB | 30 kBProgress (4): 0.1/1.0 MB | 109 kB | 85/224 kB | 30 kB Progress (4): 0.1/1.0 MB | 109 kB | 90/224 kB | 30 kBProgress (4): 0.1/1.0 MB | 109 kB | 94/224 kB | 30 kBProgress (4): 0.1/1.0 MB | 109 kB | 98/224 kB | 30 kBProgress (4): 0.2/1.0 MB | 109 kB | 98/224 kB | 30 kBProgress (4): 0.2/1.0 MB | 109 kB | 98/224 kB | 30 kBProgress (4): 0.2/1.0 MB | 109 kB | 98/224 kB | 30 kBProgress (4): 0.2/1.0 MB | 109 kB | 102/224 kB | 30 kBProgress (4): 0.2/1.0 MB | 109 kB | 102/224 kB | 30 kBProgress (4): 0.2/1.0 MB | 109 kB | 106/224 kB | 30 kBProgress (4): 0.2/1.0 MB | 109 kB | 110/224 kB | 30 kBProgress (4): 0.2/1.0 MB | 109 kB | 114/224 kB | 30 kBProgress (4): 0.2/1.0 MB | 109 kB | 114/224 kB | 30 kBProgress (4): 0.2/1.0 MB | 109 kB | 114/224 kB | 30 kBProgress (4): 0.2/1.0 MB | 109 kB | 114/224 kB | 30 kBProgress (4): 0.2/1.0 MB | 109 kB | 114/224 kB | 30 kBProgress (5): 0.2/1.0 MB | 109 kB | 114/224 kB | 30 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 109 kB | 114/224 kB | 30 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 109 kB | 114/224 kB | 30 kB | 7.7/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar (30 kB at 1.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar
Progress (4): 0.2/1.0 MB | 109 kB | 118/224 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 109 kB | 122/224 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 109 kB | 126/224 kB | 7.7/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar (109 kB at 5.2 MB/s)
Progress (3): 0.2/1.0 MB | 126/224 kB | 12/80 kBProgress (3): 0.2/1.0 MB | 126/224 kB | 12/80 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar
Progress (3): 0.2/1.0 MB | 126/224 kB | 16/80 kBProgress (3): 0.2/1.0 MB | 131/224 kB | 16/80 kBProgress (3): 0.2/1.0 MB | 131/224 kB | 20/80 kBProgress (3): 0.2/1.0 MB | 131/224 kB | 24/80 kBProgress (3): 0.2/1.0 MB | 135/224 kB | 24/80 kBProgress (3): 0.2/1.0 MB | 135/224 kB | 28/80 kBProgress (3): 0.2/1.0 MB | 139/224 kB | 28/80 kBProgress (3): 0.2/1.0 MB | 139/224 kB | 32/80 kBProgress (3): 0.2/1.0 MB | 139/224 kB | 32/80 kBProgress (3): 0.2/1.0 MB | 139/224 kB | 32/80 kBProgress (3): 0.2/1.0 MB | 139/224 kB | 36/80 kBProgress (3): 0.2/1.0 MB | 139/224 kB | 40/80 kBProgress (3): 0.2/1.0 MB | 139/224 kB | 45/80 kBProgress (3): 0.2/1.0 MB | 139/224 kB | 45/80 kBProgress (3): 0.2/1.0 MB | 139/224 kB | 49/80 kBProgress (3): 0.2/1.0 MB | 139/224 kB | 49/80 kBProgress (3): 0.2/1.0 MB | 139/224 kB | 49/80 kBProgress (3): 0.2/1.0 MB | 139/224 kB | 49/80 kBProgress (4): 0.2/1.0 MB | 139/224 kB | 49/80 kB | 2.2/20 kBProgress (4): 0.2/1.0 MB | 139/224 kB | 53/80 kB | 2.2/20 kBProgress (4): 0.2/1.0 MB | 139/224 kB | 57/80 kB | 2.2/20 kBProgress (4): 0.2/1.0 MB | 139/224 kB | 61/80 kB | 2.2/20 kBProgress (4): 0.2/1.0 MB | 139/224 kB | 65/80 kB | 2.2/20 kBProgress (4): 0.2/1.0 MB | 139/224 kB | 65/80 kB | 2.2/20 kBProgress (4): 0.2/1.0 MB | 139/224 kB | 65/80 kB | 2.2/20 kBProgress (4): 0.2/1.0 MB | 139/224 kB | 65/80 kB | 5.0/20 kBProgress (4): 0.2/1.0 MB | 143/224 kB | 65/80 kB | 5.0/20 kBProgress (4): 0.2/1.0 MB | 143/224 kB | 65/80 kB | 5.0/20 kBProgress (4): 0.2/1.0 MB | 147/224 kB | 65/80 kB | 5.0/20 kBProgress (4): 0.2/1.0 MB | 147/224 kB | 65/80 kB | 5.0/20 kBProgress (4): 0.2/1.0 MB | 147/224 kB | 65/80 kB | 7.7/20 kBProgress (4): 0.2/1.0 MB | 147/224 kB | 69/80 kB | 7.7/20 kBProgress (4): 0.2/1.0 MB | 147/224 kB | 73/80 kB | 7.7/20 kBProgress (4): 0.2/1.0 MB | 147/224 kB | 77/80 kB | 7.7/20 kBProgress (4): 0.2/1.0 MB | 147/224 kB | 80 kB | 7.7/20 kB Progress (4): 0.2/1.0 MB | 147/224 kB | 80 kB | 10/20 kB Progress (4): 0.2/1.0 MB | 151/224 kB | 80 kB | 10/20 kBProgress (5): 0.2/1.0 MB | 151/224 kB | 80 kB | 10/20 kB | 4.1/49 kBProgress (5): 0.2/1.0 MB | 151/224 kB | 80 kB | 10/20 kB | 4.1/49 kBProgress (5): 0.2/1.0 MB | 151/224 kB | 80 kB | 10/20 kB | 4.1/49 kBProgress (5): 0.2/1.0 MB | 151/224 kB | 80 kB | 10/20 kB | 7.7/49 kBProgress (5): 0.2/1.0 MB | 155/224 kB | 80 kB | 10/20 kB | 7.7/49 kBProgress (5): 0.2/1.0 MB | 155/224 kB | 80 kB | 10/20 kB | 12/49 kB Progress (5): 0.2/1.0 MB | 159/224 kB | 80 kB | 10/20 kB | 12/49 kBProgress (5): 0.2/1.0 MB | 159/224 kB | 80 kB | 10/20 kB | 16/49 kBProgress (5): 0.2/1.0 MB | 159/224 kB | 80 kB | 10/20 kB | 16/49 kBProgress (5): 0.2/1.0 MB | 159/224 kB | 80 kB | 13/20 kB | 16/49 kBProgress (5): 0.2/1.0 MB | 159/224 kB | 80 kB | 13/20 kB | 16/49 kBProgress (5): 0.2/1.0 MB | 159/224 kB | 80 kB | 16/20 kB | 16/49 kBProgress (5): 0.2/1.0 MB | 159/224 kB | 80 kB | 19/20 kB | 16/49 kBProgress (5): 0.2/1.0 MB | 159/224 kB | 80 kB | 20 kB | 16/49 kB Progress (5): 0.2/1.0 MB | 159/224 kB | 80 kB | 20 kB | 16/49 kBProgress (5): 0.3/1.0 MB | 159/224 kB | 80 kB | 20 kB | 16/49 kBProgress (5): 0.3/1.0 MB | 159/224 kB | 80 kB | 20 kB | 16/49 kBProgress (5): 0.3/1.0 MB | 159/224 kB | 80 kB | 20 kB | 16/49 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar (80 kB at 3.6 MB/s)
Progress (4): 0.3/1.0 MB | 163/224 kB | 20 kB | 16/49 kB Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar
Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar (20 kB at 857 kB/s)
Progress (3): 0.3/1.0 MB | 163/224 kB | 16/49 kBProgress (3): 0.3/1.0 MB | 163/224 kB | 20/49 kBProgress (3): 0.3/1.0 MB | 163/224 kB | 20/49 kBProgress (3): 0.3/1.0 MB | 163/224 kB | 24/49 kBProgress (3): 0.3/1.0 MB | 163/224 kB | 24/49 kBProgress (3): 0.3/1.0 MB | 163/224 kB | 28/49 kBProgress (3): 0.3/1.0 MB | 167/224 kB | 28/49 kBProgress (3): 0.3/1.0 MB | 171/224 kB | 28/49 kBProgress (3): 0.3/1.0 MB | 171/224 kB | 32/49 kBProgress (3): 0.3/1.0 MB | 171/224 kB | 32/49 kB Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar
Progress (3): 0.3/1.0 MB | 171/224 kB | 32/49 kBProgress (3): 0.3/1.0 MB | 171/224 kB | 32/49 kBProgress (3): 0.3/1.0 MB | 171/224 kB | 32/49 kBProgress (3): 0.3/1.0 MB | 171/224 kB | 32/49 kBProgress (4): 0.3/1.0 MB | 171/224 kB | 32/49 kB | 4.1/195 kBProgress (4): 0.3/1.0 MB | 171/224 kB | 32/49 kB | 4.1/195 kBProgress (4): 0.3/1.0 MB | 171/224 kB | 32/49 kB | 7.7/195 kBProgress (4): 0.3/1.0 MB | 176/224 kB | 32/49 kB | 7.7/195 kBProgress (4): 0.3/1.0 MB | 176/224 kB | 32/49 kB | 12/195 kB Progress (4): 0.3/1.0 MB | 180/224 kB | 32/49 kB | 12/195 kBProgress (4): 0.3/1.0 MB | 180/224 kB | 32/49 kB | 16/195 kBProgress (4): 0.3/1.0 MB | 180/224 kB | 32/49 kB | 20/195 kBProgress (4): 0.3/1.0 MB | 184/224 kB | 32/49 kB | 20/195 kBProgress (4): 0.3/1.0 MB | 184/224 kB | 32/49 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 188/224 kB | 32/49 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 192/224 kB | 32/49 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 196/224 kB | 32/49 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 200/224 kB | 32/49 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 204/224 kB | 32/49 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 208/224 kB | 32/49 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 212/224 kB | 32/49 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 212/224 kB | 32/49 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 212/224 kB | 36/49 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 212/224 kB | 36/49 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 212/224 kB | 36/49 kB | 28/195 kBProgress (4): 0.3/1.0 MB | 212/224 kB | 40/49 kB | 28/195 kBProgress (4): 0.3/1.0 MB | 212/224 kB | 40/49 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 217/224 kB | 40/49 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 221/224 kB | 40/49 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 40/49 kB | 32/195 kB Progress (4): 0.3/1.0 MB | 224 kB | 40/49 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 45/49 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49/49 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 32/195 kB Progress (4): 0.3/1.0 MB | 224 kB | 49 kB | 36/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 40/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 45/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 49/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 49/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 49/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 49/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 49/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 53/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 57/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 61/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 65/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 65/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 65/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 69/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 69/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 73/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 73/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 77/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 81/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 85/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 90/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 94/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 94/195 kBProgress (4): 0.3/1.0 MB | 224 kB | 49 kB | 98/195 kBProgress (4): 0.4/1.0 MB | 224 kB | 49 kB | 98/195 kB Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar (224 kB at 6.1 MB/s)
Progress (3): 0.4/1.0 MB | 49 kB | 102/195 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar (49 kB at 1.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar
Progress (2): 0.4/1.0 MB | 102/195 kB Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar
Progress (2): 0.4/1.0 MB | 106/195 kBProgress (2): 0.4/1.0 MB | 110/195 kBProgress (2): 0.4/1.0 MB | 110/195 kBProgress (2): 0.4/1.0 MB | 114/195 kBProgress (2): 0.4/1.0 MB | 118/195 kBProgress (2): 0.4/1.0 MB | 122/195 kBProgress (2): 0.4/1.0 MB | 126/195 kBProgress (2): 0.4/1.0 MB | 131/195 kBProgress (2): 0.4/1.0 MB | 131/195 kBProgress (2): 0.4/1.0 MB | 131/195 kBProgress (2): 0.4/1.0 MB | 131/195 kBProgress (2): 0.4/1.0 MB | 131/195 kBProgress (2): 0.4/1.0 MB | 135/195 kBProgress (2): 0.4/1.0 MB | 139/195 kBProgress (2): 0.4/1.0 MB | 143/195 kBProgress (2): 0.4/1.0 MB | 147/195 kBProgress (2): 0.4/1.0 MB | 151/195 kBProgress (2): 0.4/1.0 MB | 155/195 kBProgress (2): 0.4/1.0 MB | 155/195 kBProgress (2): 0.4/1.0 MB | 159/195 kBProgress (2): 0.4/1.0 MB | 159/195 kBProgress (2): 0.4/1.0 MB | 163/195 kBProgress (2): 0.4/1.0 MB | 163/195 kBProgress (2): 0.4/1.0 MB | 163/195 kBProgress (3): 0.4/1.0 MB | 163/195 kB | 4.1/251 kBProgress (3): 0.4/1.0 MB | 163/195 kB | 7.7/251 kBProgress (3): 0.4/1.0 MB | 163/195 kB | 12/251 kB Progress (3): 0.4/1.0 MB | 163/195 kB | 16/251 kBProgress (3): 0.4/1.0 MB | 167/195 kB | 16/251 kBProgress (3): 0.4/1.0 MB | 171/195 kB | 16/251 kBProgress (3): 0.4/1.0 MB | 176/195 kB | 16/251 kBProgress (3): 0.4/1.0 MB | 176/195 kB | 16/251 kBProgress (3): 0.4/1.0 MB | 180/195 kB | 16/251 kBProgress (3): 0.4/1.0 MB | 180/195 kB | 16/251 kBProgress (3): 0.4/1.0 MB | 180/195 kB | 16/251 kBProgress (3): 0.4/1.0 MB | 180/195 kB | 16/251 kBProgress (3): 0.4/1.0 MB | 184/195 kB | 16/251 kBProgress (3): 0.4/1.0 MB | 188/195 kB | 16/251 kBProgress (3): 0.4/1.0 MB | 192/195 kB | 16/251 kBProgress (3): 0.4/1.0 MB | 195 kB | 16/251 kB Progress (4): 0.4/1.0 MB | 195 kB | 16/251 kB | 2.2/121 kBProgress (4): 0.4/1.0 MB | 195 kB | 16/251 kB | 5.0/121 kBProgress (4): 0.4/1.0 MB | 195 kB | 16/251 kB | 5.0/121 kBProgress (4): 0.4/1.0 MB | 195 kB | 20/251 kB | 5.0/121 kBProgress (5): 0.4/1.0 MB | 195 kB | 20/251 kB | 5.0/121 kB | 4.1/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 20/251 kB | 5.0/121 kB | 4.1/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 20/251 kB | 5.0/121 kB | 7.7/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 24/251 kB | 5.0/121 kB | 7.7/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 24/251 kB | 5.0/121 kB | 12/80 kB Progress (5): 0.4/1.0 MB | 195 kB | 24/251 kB | 7.7/121 kB | 12/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 24/251 kB | 7.7/121 kB | 16/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 28/251 kB | 7.7/121 kB | 16/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 28/251 kB | 10/121 kB | 16/80 kB Progress (5): 0.4/1.0 MB | 195 kB | 32/251 kB | 10/121 kB | 16/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 32/251 kB | 10/121 kB | 16/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 32/251 kB | 13/121 kB | 16/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 32/251 kB | 13/121 kB | 20/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 32/251 kB | 13/121 kB | 20/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 32/251 kB | 16/121 kB | 20/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 32/251 kB | 16/121 kB | 24/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 32/251 kB | 16/121 kB | 28/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 32/251 kB | 19/121 kB | 28/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 36/251 kB | 19/121 kB | 28/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 36/251 kB | 19/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 40/251 kB | 19/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 40/251 kB | 21/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 45/251 kB | 21/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 49/251 kB | 21/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 49/251 kB | 24/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 49/251 kB | 24/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 49/251 kB | 24/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 49/251 kB | 24/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 53/251 kB | 24/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 53/251 kB | 24/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 53/251 kB | 27/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 57/251 kB | 27/121 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 57/251 kB | 27/121 kB | 36/80 kBProgress (5): 0.4/1.0 MB | 195 kB | 57/251 kB | 27/121 kB | 36/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar (195 kB at 4.8 MB/s)
Progress (4): 0.4/1.0 MB | 57/251 kB | 27/121 kB | 40/80 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar
Progress (4): 0.5/1.0 MB | 57/251 kB | 27/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 61/251 kB | 27/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 61/251 kB | 27/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 61/251 kB | 30/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 65/251 kB | 30/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 65/251 kB | 30/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 65/251 kB | 32/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 69/251 kB | 32/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 73/251 kB | 32/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 77/251 kB | 32/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 81/251 kB | 32/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 81/251 kB | 36/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 81/251 kB | 40/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 81/251 kB | 45/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 81/251 kB | 49/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 85/251 kB | 49/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 90/251 kB | 49/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 94/251 kB | 49/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 94/251 kB | 53/121 kB | 40/80 kBProgress (4): 0.5/1.0 MB | 98/251 kB | 53/121 kB | 40/80 kBProgress (5): 0.5/1.0 MB | 98/251 kB | 53/121 kB | 40/80 kB | 4.1/12 kBProgress (5): 0.5/1.0 MB | 98/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 102/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 106/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 110/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 114/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 118/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 122/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 126/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 131/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 135/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 139/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 143/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 147/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 151/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 155/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 159/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 163/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 167/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 171/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 176/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 180/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 184/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 188/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 192/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 196/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 200/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 204/251 kB | 53/121 kB | 40/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 204/251 kB | 53/121 kB | 45/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 208/251 kB | 53/121 kB | 45/80 kB | 7.7/12 kBProgress (5): 0.5/1.0 MB | 208/251 kB | 53/121 kB | 45/80 kB | 12/12 kB Progress (5): 0.5/1.0 MB | 208/251 kB | 57/121 kB | 45/80 kB | 12/12 kBProgress (5): 0.5/1.0 MB | 208/251 kB | 57/121 kB | 45/80 kB | 12/12 kBProgress (5): 0.5/1.0 MB | 208/251 kB | 57/121 kB | 45/80 kB | 12 kB Progress (5): 0.5/1.0 MB | 208/251 kB | 57/121 kB | 49/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 212/251 kB | 57/121 kB | 49/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 212/251 kB | 57/121 kB | 49/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 212/251 kB | 57/121 kB | 49/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 212/251 kB | 57/121 kB | 49/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 212/251 kB | 57/121 kB | 53/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 212/251 kB | 57/121 kB | 57/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 212/251 kB | 57/121 kB | 61/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 212/251 kB | 57/121 kB | 65/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 212/251 kB | 57/121 kB | 65/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 212/251 kB | 61/121 kB | 65/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 217/251 kB | 61/121 kB | 65/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 217/251 kB | 65/121 kB | 65/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 221/251 kB | 65/121 kB | 65/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 221/251 kB | 65/121 kB | 69/80 kB | 12 kBProgress (5): 0.5/1.0 MB | 225/251 kB | 65/121 kB | 69/80 kB | 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar (12 kB at 243 kB/s)
Progress (4): 0.5/1.0 MB | 225/251 kB | 65/121 kB | 69/80 kBProgress (4): 0.5/1.0 MB | 225/251 kB | 69/121 kB | 69/80 kBProgress (4): 0.5/1.0 MB | 225/251 kB | 69/121 kB | 73/80 kBProgress (4): 0.5/1.0 MB | 225/251 kB | 69/121 kB | 73/80 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar
Progress (4): 0.5/1.0 MB | 225/251 kB | 69/121 kB | 73/80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 69/121 kB | 73/80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 69/121 kB | 77/80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 73/121 kB | 77/80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 73/121 kB | 80 kB Progress (4): 0.5/1.0 MB | 229/251 kB | 77/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 81/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 81/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 81/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 81/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 81/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 85/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 90/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 94/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 229/251 kB | 98/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 233/251 kB | 98/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 237/251 kB | 98/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 237/251 kB | 98/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 241/251 kB | 98/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 241/251 kB | 98/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 245/251 kB | 98/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 245/251 kB | 98/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 245/251 kB | 98/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 249/251 kB | 98/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 251 kB | 98/121 kB | 80 kB Progress (4): 0.5/1.0 MB | 251 kB | 102/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 251 kB | 106/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 251 kB | 110/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 251 kB | 110/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 251 kB | 114/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 251 kB | 114/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 251 kB | 114/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 251 kB | 114/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 251 kB | 118/121 kB | 80 kBProgress (4): 0.5/1.0 MB | 251 kB | 121 kB | 80 kB Progress (4): 0.5/1.0 MB | 251 kB | 121 kB | 80 kBProgress (4): 0.5/1.0 MB | 251 kB | 121 kB | 80 kBProgress (4): 0.6/1.0 MB | 251 kB | 121 kB | 80 kBProgress (4): 0.6/1.0 MB | 251 kB | 121 kB | 80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar (80 kB at 1.5 MB/s)
Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar (251 kB at 4.6 MB/s)
Progress (2): 0.6/1.0 MB | 121 kBProgress (2): 0.6/1.0 MB | 121 kBProgress (2): 0.6/1.0 MB | 121 kBProgress (2): 0.6/1.0 MB | 121 kB Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar (121 kB at 2.2 MB/s)
Progress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (1): 0.6/1.0 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MB Progress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.4/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar (1.0 MB at 12 MB/s)
Progress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar (1.3 MB at 11 MB/s)
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en&gt;
     [echo] Build directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.16-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;:137:Inline literal start-string without end-string.
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 56.126 s
[e[1;34mINFOe[m] Finished at: 2019-05-31T11:44:44Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://build.geoserver.org/job/geoserver-master-live-docs/1828/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Add extensibility of common preview formats via beans (#3521)
[...truncated 389.62 KB...]
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom
Progress (1): 861 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom (861 B at 215 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom
Progress (1): 761 B Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom (761 B at 190 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom
Progress (1): 138 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom (138 B at 34 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom
Progress (1): 643 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom (643 B at 214 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom
Progress (1): 2.2/12 kBProgress (1): 5.0/12 kBProgress (1): 7.8/12 kBProgress (1): 11/12 kB Progress (1): 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom (12 kB at 3.9 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom
Progress (1): 1.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom (1.8 kB at 460 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom (1.6 kB at 542 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom
Progress (1): 2.2/2.7 kBProgress (1): 2.7 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom (2.7 kB at 903 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom
Progress (1): 767 B Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom (767 B at 256 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom
Progress (1): 1.2 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom (1.2 kB at 412 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom
Progress (1): 998 B Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom (998 B at 333 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom (1.6 kB at 404 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom
Progress (1): 1.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom (1.4 kB at 453 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom
Progress (1): 1.5 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom (1.5 kB at 496 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom
Progress (1): 765 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom (765 B at 255 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom
Progress (1): 2.2/5.3 kBProgress (1): 5.0/5.3 kBProgress (1): 5.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom (5.3 kB at 1.3 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom
Progress (1): 2.8/9.8 kBProgress (1): 5.5/9.8 kBProgress (1): 8.3/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom (9.8 kB at 3.3 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom
Progress (1): 2.2/2.4 kBProgress (1): 2.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom (2.4 kB at 794 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom
Progress (1): 2.2/4.4 kBProgress (1): 4.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom (4.4 kB at 1.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom
Progress (1): 2.2/9.8 kBProgress (1): 5.0/9.8 kBProgress (1): 7.8/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom (9.8 kB at 2.4 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar
Progress (1): 2.2/44 kBProgress (2): 2.2/44 kB | 2.2/109 kBProgress (2): 5.0/44 kB | 2.2/109 kBProgress (2): 7.7/44 kB | 2.2/109 kBProgress (2): 7.7/44 kB | 5.0/109 kBProgress (2): 10/44 kB | 5.0/109 kB Progress (2): 10/44 kB | 7.7/109 kBProgress (3): 10/44 kB | 7.7/109 kB | 2.2/8.3 kBProgress (3): 10/44 kB | 10/109 kB | 2.2/8.3 kB Progress (3): 13/44 kB | 10/109 kB | 2.2/8.3 kBProgress (3): 13/44 kB | 13/109 kB | 2.2/8.3 kBProgress (3): 13/44 kB | 13/109 kB | 5.0/8.3 kBProgress (3): 16/44 kB | 13/109 kB | 5.0/8.3 kBProgress (3): 16/44 kB | 16/109 kB | 5.0/8.3 kBProgress (3): 16/44 kB | 16/109 kB | 7.7/8.3 kBProgress (3): 19/44 kB | 16/109 kB | 7.7/8.3 kBProgress (3): 19/44 kB | 19/109 kB | 7.7/8.3 kBProgress (3): 19/44 kB | 19/109 kB | 8.3 kB Progress (4): 19/44 kB | 19/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 21/44 kB | 19/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 21/44 kB | 21/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 21/44 kB | 21/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 21/44 kB | 24/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 24/44 kB | 24/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 24/44 kB | 24/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 24/44 kB | 27/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 27/44 kB | 27/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 27/44 kB | 27/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 27/44 kB | 30/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 30/44 kB | 30/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 30/44 kB | 30/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 30/44 kB | 32/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 32/44 kB | 32/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 32/44 kB | 32/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 32/44 kB | 32/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 32/44 kB | 32/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 32/44 kB | 36/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 36/44 kB | 36/109 kB | 8.3 kB | 0/1.0 MBProgress (4): 36/44 kB | 40/109 kB | 8.3 kB | 0/1.0 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar (8.3 kB at 1.4 MB/s)
Progress (3): 36/44 kB | 40/109 kB | 0/1.0 MB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar
Progress (3): 40/44 kB | 40/109 kB | 0/1.0 MBProgress (3): 40/44 kB | 40/109 kB | 0/1.0 MBProgress (3): 40/44 kB | 45/109 kB | 0/1.0 MBProgress (3): 40/44 kB | 49/109 kB | 0/1.0 MBProgress (3): 40/44 kB | 53/109 kB | 0/1.0 MBProgress (3): 40/44 kB | 57/109 kB | 0/1.0 MBProgress (3): 40/44 kB | 61/109 kB | 0/1.0 MBProgress (3): 40/44 kB | 65/109 kB | 0/1.0 MBProgress (4): 40/44 kB | 65/109 kB | 0/1.0 MB | 2.2/30 kBProgress (4): 40/44 kB | 65/109 kB | 0/1.0 MB | 5.0/30 kBProgress (4): 40/44 kB | 65/109 kB | 0/1.0 MB | 7.7/30 kBProgress (4): 40/44 kB | 69/109 kB | 0/1.0 MB | 7.7/30 kBProgress (4): 40/44 kB | 73/109 kB | 0/1.0 MB | 7.7/30 kBProgress (4): 40/44 kB | 77/109 kB | 0/1.0 MB | 7.7/30 kBProgress (4): 40/44 kB | 81/109 kB | 0/1.0 MB | 7.7/30 kBProgress (4): 40/44 kB | 85/109 kB | 0/1.0 MB | 7.7/30 kBProgress (4): 40/44 kB | 90/109 kB | 0/1.0 MB | 7.7/30 kBProgress (4): 40/44 kB | 94/109 kB | 0/1.0 MB | 7.7/30 kBProgress (4): 40/44 kB | 98/109 kB | 0/1.0 MB | 7.7/30 kBProgress (4): 40/44 kB | 102/109 kB | 0/1.0 MB | 7.7/30 kBProgress (4): 40/44 kB | 106/109 kB | 0/1.0 MB | 7.7/30 kBProgress (4): 40/44 kB | 109 kB | 0/1.0 MB | 7.7/30 kB Progress (4): 44 kB | 109 kB | 0/1.0 MB | 7.7/30 kB Progress (4): 44 kB | 109 kB | 0/1.0 MB | 10/30 kB Progress (4): 44 kB | 109 kB | 0/1.0 MB | 10/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 13/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 13/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 16/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 19/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 21/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 21/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 24/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 24/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 24/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 27/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 27/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 30/30 kBProgress (4): 44 kB | 109 kB | 0/1.0 MB | 30 kB Progress (5): 44 kB | 109 kB | 0/1.0 MB | 30 kB | 2.8/224 kBProgress (5): 44 kB | 109 kB | 0.1/1.0 MB | 30 kB | 2.8/224 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar (109 kB at 8.4 MB/s)
Progress (4): 44 kB | 0.1/1.0 MB | 30 kB | 2.8/224 kBProgress (4): 44 kB | 0.1/1.0 MB | 30 kB | 5.5/224 kBProgress (4): 44 kB | 0.1/1.0 MB | 30 kB | 5.5/224 kBProgress (4): 44 kB | 0.1/1.0 MB | 30 kB | 5.5/224 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar
Progress (4): 44 kB | 0.1/1.0 MB | 30 kB | 8.3/224 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar (44 kB at 3.6 MB/s)
Progress (3): 0.1/1.0 MB | 30 kB | 8.3/224 kBProgress (3): 0.1/1.0 MB | 30 kB | 11/224 kB Progress (3): 0.1/1.0 MB | 30 kB | 11/224 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar
Progress (3): 0.1/1.0 MB | 30 kB | 11/224 kBProgress (3): 0.1/1.0 MB | 30 kB | 11/224 kBProgress (3): 0.1/1.0 MB | 30 kB | 14/224 kBProgress (3): 0.1/1.0 MB | 30 kB | 16/224 kBProgress (3): 0.1/1.0 MB | 30 kB | 19/224 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar (30 kB at 2.5 MB/s)
Progress (2): 0.1/1.0 MB | 22/224 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar
Progress (2): 0.1/1.0 MB | 22/224 kBProgress (2): 0.1/1.0 MB | 22/224 kBProgress (2): 0.1/1.0 MB | 25/224 kBProgress (2): 0.1/1.0 MB | 25/224 kBProgress (2): 0.1/1.0 MB | 25/224 kBProgress (2): 0.1/1.0 MB | 27/224 kBProgress (2): 0.1/1.0 MB | 30/224 kBProgress (2): 0.1/1.0 MB | 33/224 kBProgress (2): 0.1/1.0 MB | 33/224 kBProgress (2): 0.1/1.0 MB | 33/224 kBProgress (2): 0.1/1.0 MB | 33/224 kBProgress (2): 0.1/1.0 MB | 33/224 kBProgress (2): 0.1/1.0 MB | 37/224 kBProgress (2): 0.1/1.0 MB | 41/224 kBProgress (2): 0.1/1.0 MB | 45/224 kBProgress (2): 0.1/1.0 MB | 49/224 kBProgress (2): 0.1/1.0 MB | 49/224 kBProgress (2): 0.1/1.0 MB | 49/224 kBProgress (2): 0.1/1.0 MB | 49/224 kBProgress (2): 0.1/1.0 MB | 49/224 kBProgress (2): 0.1/1.0 MB | 53/224 kBProgress (2): 0.1/1.0 MB | 57/224 kBProgress (3): 0.1/1.0 MB | 57/224 kB | 2.8/20 kBProgress (3): 0.1/1.0 MB | 57/224 kB | 2.8/20 kBProgress (3): 0.1/1.0 MB | 57/224 kB | 2.8/20 kBProgress (3): 0.1/1.0 MB | 57/224 kB | 2.8/20 kBProgress (3): 0.1/1.0 MB | 57/224 kB | 2.8/20 kBProgress (3): 0.2/1.0 MB | 57/224 kB | 2.8/20 kBProgress (3): 0.2/1.0 MB | 57/224 kB | 2.8/20 kBProgress (3): 0.2/1.0 MB | 61/224 kB | 2.8/20 kBProgress (3): 0.2/1.0 MB | 61/224 kB | 2.8/20 kBProgress (4): 0.2/1.0 MB | 61/224 kB | 2.8/20 kB | 4.1/49 kBProgress (5): 0.2/1.0 MB | 61/224 kB | 2.8/20 kB | 4.1/49 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 61/224 kB | 2.8/20 kB | 7.7/49 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 61/224 kB | 2.8/20 kB | 12/49 kB | 4.1/80 kB Progress (5): 0.2/1.0 MB | 61/224 kB | 2.8/20 kB | 16/49 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 61/224 kB | 2.8/20 kB | 20/49 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 61/224 kB | 5.5/20 kB | 20/49 kB | 4.1/80 kBProgress (5): 0.2/1.0 MB | 61/224 kB | 5.5/20 kB | 20/49 kB | 7.7/80 kBProgress (5): 0.2/1.0 MB | 61/224 kB | 5.5/20 kB | 20/49 kB | 7.7/80 kBProgress (5): 0.2/1.0 MB | 63/224 kB | 5.5/20 kB | 20/49 kB | 7.7/80 kBProgress (5): 0.2/1.0 MB | 63/224 kB | 5.5/20 kB | 20/49 kB | 12/80 kB Progress (5): 0.2/1.0 MB | 63/224 kB | 5.5/20 kB | 24/49 kB | 12/80 kBProgress (5): 0.2/1.0 MB | 63/224 kB | 8.3/20 kB | 24/49 kB | 12/80 kBProgress (5): 0.2/1.0 MB | 63/224 kB | 8.3/20 kB | 24/49 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 63/224 kB | 8.3/20 kB | 28/49 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 63/224 kB | 11/20 kB | 28/49 kB | 16/80 kB Progress (5): 0.2/1.0 MB | 63/224 kB | 11/20 kB | 32/49 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 67/224 kB | 11/20 kB | 32/49 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 67/224 kB | 11/20 kB | 32/49 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 71/224 kB | 11/20 kB | 32/49 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 71/224 kB | 11/20 kB | 32/49 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 71/224 kB | 11/20 kB | 32/49 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 71/224 kB | 14/20 kB | 32/49 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 71/224 kB | 14/20 kB | 32/49 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 75/224 kB | 14/20 kB | 32/49 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 75/224 kB | 14/20 kB | 32/49 kB | 20/80 kBProgress (5): 0.2/1.0 MB | 75/224 kB | 16/20 kB | 32/49 kB | 20/80 kBProgress (5): 0.2/1.0 MB | 79/224 kB | 16/20 kB | 32/49 kB | 20/80 kBProgress (5): 0.2/1.0 MB | 79/224 kB | 16/20 kB | 36/49 kB | 20/80 kBProgress (5): 0.2/1.0 MB | 79/224 kB | 16/20 kB | 36/49 kB | 24/80 kBProgress (5): 0.2/1.0 MB | 79/224 kB | 16/20 kB | 40/49 kB | 24/80 kBProgress (5): 0.2/1.0 MB | 79/224 kB | 16/20 kB | 40/49 kB | 28/80 kBProgress (5): 0.2/1.0 MB | 79/224 kB | 19/20 kB | 40/49 kB | 28/80 kBProgress (5): 0.2/1.0 MB | 79/224 kB | 19/20 kB | 40/49 kB | 28/80 kBProgress (5): 0.2/1.0 MB | 79/224 kB | 20 kB | 40/49 kB | 28/80 kB Progress (5): 0.2/1.0 MB | 79/224 kB | 20 kB | 40/49 kB | 32/80 kBProgress (5): 0.2/1.0 MB | 79/224 kB | 20 kB | 45/49 kB | 32/80 kBProgress (5): 0.2/1.0 MB | 84/224 kB | 20 kB | 45/49 kB | 32/80 kBProgress (5): 0.2/1.0 MB | 84/224 kB | 20 kB | 45/49 kB | 32/80 kBProgress (5): 0.2/1.0 MB | 84/224 kB | 20 kB | 49/49 kB | 32/80 kBProgress (5): 0.2/1.0 MB | 88/224 kB | 20 kB | 49/49 kB | 32/80 kBProgress (5): 0.2/1.0 MB | 88/224 kB | 20 kB | 49/49 kB | 32/80 kBProgress (5): 0.2/1.0 MB | 92/224 kB | 20 kB | 49/49 kB | 32/80 kBProgress (5): 0.2/1.0 MB | 92/224 kB | 20 kB | 49 kB | 32/80 kB Progress (5): 0.2/1.0 MB | 92/224 kB | 20 kB | 49 kB | 32/80 kBProgress (5): 0.2/1.0 MB | 96/224 kB | 20 kB | 49 kB | 32/80 kBProgress (5): 0.2/1.0 MB | 96/224 kB | 20 kB | 49 kB | 36/80 kBProgress (5): 0.2/1.0 MB | 96/224 kB | 20 kB | 49 kB | 40/80 kBProgress (5): 0.2/1.0 MB | 96/224 kB | 20 kB | 49 kB | 45/80 kBProgress (5): 0.2/1.0 MB | 96/224 kB | 20 kB | 49 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 100/224 kB | 20 kB | 49 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 104/224 kB | 20 kB | 49 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 104/224 kB | 20 kB | 49 kB | 49/80 kBProgress (5): 0.2/1.0 MB | 104/224 kB | 20 kB | 49 kB | 53/80 kBProgress (5): 0.2/1.0 MB | 108/224 kB | 20 kB | 49 kB | 53/80 kBProgress (5): 0.2/1.0 MB | 108/224 kB | 20 kB | 49 kB | 57/80 kBProgress (5): 0.2/1.0 MB | 108/224 kB | 20 kB | 49 kB | 57/80 kBProgress (5): 0.2/1.0 MB | 108/224 kB | 20 kB | 49 kB | 61/80 kBProgress (5): 0.2/1.0 MB | 112/224 kB | 20 kB | 49 kB | 61/80 kBProgress (5): 0.2/1.0 MB | 112/224 kB | 20 kB | 49 kB | 65/80 kBProgress (5): 0.2/1.0 MB | 112/224 kB | 20 kB | 49 kB | 65/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar (20 kB at 985 kB/s)
Progress (4): 0.2/1.0 MB | 112/224 kB | 49 kB | 65/80 kB Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar
Progress (4): 0.2/1.0 MB | 112/224 kB | 49 kB | 69/80 kBProgress (4): 0.2/1.0 MB | 116/224 kB | 49 kB | 69/80 kBProgress (4): 0.2/1.0 MB | 116/224 kB | 49 kB | 73/80 kBProgress (4): 0.2/1.0 MB | 120/224 kB | 49 kB | 73/80 kBProgress (4): 0.2/1.0 MB | 120/224 kB | 49 kB | 77/80 kBProgress (4): 0.2/1.0 MB | 125/224 kB | 49 kB | 77/80 kBProgress (4): 0.2/1.0 MB | 125/224 kB | 49 kB | 80 kB Progress (4): 0.2/1.0 MB | 129/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 129/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 129/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 129/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 129/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 133/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 137/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 141/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 145/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 145/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 145/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 145/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 145/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 149/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 153/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 157/224 kB | 49 kB | 80 kBProgress (4): 0.2/1.0 MB | 161/224 kB | 49 kB | 80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar (80 kB at 3.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar
Progress (3): 0.2/1.0 MB | 161/224 kB | 49 kBProgress (3): 0.3/1.0 MB | 161/224 kB | 49 kBProgress (3): 0.3/1.0 MB | 166/224 kB | 49 kBProgress (3): 0.3/1.0 MB | 166/224 kB | 49 kBProgress (3): 0.3/1.0 MB | 170/224 kB | 49 kBProgress (3): 0.3/1.0 MB | 170/224 kB | 49 kBProgress (3): 0.3/1.0 MB | 174/224 kB | 49 kBProgress (3): 0.3/1.0 MB | 178/224 kB | 49 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar (49 kB at 2.0 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar
Progress (2): 0.3/1.0 MB | 178/224 kBProgress (2): 0.3/1.0 MB | 178/224 kBProgress (2): 0.3/1.0 MB | 178/224 kBProgress (2): 0.3/1.0 MB | 182/224 kBProgress (2): 0.3/1.0 MB | 182/224 kBProgress (2): 0.3/1.0 MB | 186/224 kBProgress (2): 0.3/1.0 MB | 190/224 kBProgress (2): 0.3/1.0 MB | 194/224 kBProgress (3): 0.3/1.0 MB | 194/224 kB | 4.1/121 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 4.1/121 kB | 2.2/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 8.2/121 kB | 2.2/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 12/121 kB | 2.2/195 kB Progress (4): 0.3/1.0 MB | 194/224 kB | 16/121 kB | 2.2/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 16/121 kB | 5.0/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 16/121 kB | 5.0/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 16/121 kB | 5.0/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 16/121 kB | 5.0/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 16/121 kB | 7.7/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 16/121 kB | 7.7/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 16/121 kB | 10/195 kB Progress (4): 0.3/1.0 MB | 194/224 kB | 20/121 kB | 10/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 20/121 kB | 13/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 25/121 kB | 13/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 29/121 kB | 13/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 29/121 kB | 16/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 33/121 kB | 16/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 33/121 kB | 19/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 33/121 kB | 19/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 33/121 kB | 19/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 33/121 kB | 21/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 33/121 kB | 21/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 33/121 kB | 21/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 33/121 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 37/121 kB | 24/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 37/121 kB | 27/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 41/121 kB | 27/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 45/121 kB | 27/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 45/121 kB | 30/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 49/121 kB | 30/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 49/121 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 49/121 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 49/121 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 49/121 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 49/121 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 53/121 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 57/121 kB | 32/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 57/121 kB | 36/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 61/121 kB | 36/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 61/121 kB | 40/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 66/121 kB | 40/195 kBProgress (4): 0.3/1.0 MB | 194/224 kB | 66/121 kB | 45/195 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 66/121 kB | 45/195 kB | 4.1/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 66/121 kB | 49/195 kB | 4.1/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 66/121 kB | 49/195 kB | 7.7/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 66/121 kB | 49/195 kB | 7.7/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 66/121 kB | 49/195 kB | 12/80 kB Progress (5): 0.3/1.0 MB | 194/224 kB | 66/121 kB | 49/195 kB | 12/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 66/121 kB | 49/195 kB | 16/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 66/121 kB | 49/195 kB | 16/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 66/121 kB | 49/195 kB | 16/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 70/121 kB | 49/195 kB | 16/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 74/121 kB | 49/195 kB | 16/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 74/121 kB | 53/195 kB | 16/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 78/121 kB | 53/195 kB | 16/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 78/121 kB | 57/195 kB | 16/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 82/121 kB | 57/195 kB | 16/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 82/121 kB | 61/195 kB | 16/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 82/121 kB | 65/195 kB | 16/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 82/121 kB | 65/195 kB | 20/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 82/121 kB | 65/195 kB | 24/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 82/121 kB | 65/195 kB | 28/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 82/121 kB | 65/195 kB | 28/80 kBProgress (5): 0.3/1.0 MB | 194/224 kB | 82/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 194/224 kB | 82/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 194/224 kB | 86/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 194/224 kB | 86/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 194/224 kB | 90/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 194/224 kB | 90/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 194/224 kB | 94/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 198/224 kB | 94/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 202/224 kB | 94/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 206/224 kB | 94/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 65/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 69/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 73/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 77/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 81/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 81/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 81/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 81/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 211/224 kB | 94/121 kB | 81/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 94/121 kB | 81/195 kB | 32/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 94/121 kB | 81/195 kB | 36/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 98/121 kB | 81/195 kB | 36/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 98/121 kB | 81/195 kB | 40/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 98/121 kB | 81/195 kB | 45/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 98/121 kB | 81/195 kB | 49/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 98/121 kB | 81/195 kB | 49/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 98/121 kB | 81/195 kB | 49/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 102/121 kB | 81/195 kB | 49/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 106/121 kB | 81/195 kB | 49/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 111/121 kB | 81/195 kB | 49/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 115/121 kB | 81/195 kB | 49/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 119/121 kB | 81/195 kB | 49/80 kBProgress (5): 0.4/1.0 MB | 215/224 kB | 121 kB | 81/195 kB | 49/80 kB Progress (5): 0.4/1.0 MB | 219/224 kB | 121 kB | 81/195 kB | 49/80 kBProgress (5): 0.4/1.0 MB | 219/224 kB | 121 kB | 85/195 kB | 49/80 kBProgress (5): 0.4/1.0 MB | 223/224 kB | 121 kB | 85/195 kB | 49/80 kBProgress (5): 0.4/1.0 MB | 224 kB | 121 kB | 85/195 kB | 49/80 kB Progress (5): 0.4/1.0 MB | 224 kB | 121 kB | 85/195 kB | 53/80 kBProgress (5): 0.4/1.0 MB | 224 kB | 121 kB | 85/195 kB | 57/80 kBProgress (5): 0.4/1.0 MB | 224 kB | 121 kB | 85/195 kB | 61/80 kBProgress (5): 0.4/1.0 MB | 224 kB | 121 kB | 85/195 kB | 65/80 kBProgress (5): 0.4/1.0 MB | 224 kB | 121 kB | 85/195 kB | 65/80 kBProgress (5): 0.4/1.0 MB | 224 kB | 121 kB | 85/195 kB | 65/80 kBProgress (5): 0.4/1.0 MB | 224 kB | 121 kB | 85/195 kB | 69/80 kBProgress (5): 0.4/1.0 MB | 224 kB | 121 kB | 90/195 kB | 69/80 kB Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar (121 kB at 3.6 MB/s)
Progress (4): 0.4/1.0 MB | 224 kB | 90/195 kB | 73/80 kBProgress (4): 0.4/1.0 MB | 224 kB | 94/195 kB | 73/80 kBProgress (4): 0.4/1.0 MB | 224 kB | 94/195 kB | 77/80 kBProgress (4): 0.4/1.0 MB | 224 kB | 98/195 kB | 77/80 kBProgress (4): 0.4/1.0 MB | 224 kB | 98/195 kB | 80 kB Progress (4): 0.4/1.0 MB | 224 kB | 102/195 kB | 80 kBProgress (4): 0.4/1.0 MB | 224 kB | 106/195 kB | 80 kBProgress (4): 0.4/1.0 MB | 224 kB | 110/195 kB | 80 kBProgress (4): 0.4/1.0 MB | 224 kB | 114/195 kB | 80 kB Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar (224 kB at 5.9 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar
Progress (3): 0.4/1.0 MB | 118/195 kB | 80 kBProgress (3): 0.4/1.0 MB | 118/195 kB | 80 kBProgress (3): 0.4/1.0 MB | 122/195 kB | 80 kBProgress (3): 0.4/1.0 MB | 122/195 kB | 80 kBProgress (3): 0.4/1.0 MB | 126/195 kB | 80 kBProgress (3): 0.4/1.0 MB | 126/195 kB | 80 kBProgress (3): 0.4/1.0 MB | 131/195 kB | 80 kBProgress (3): 0.4/1.0 MB | 131/195 kB | 80 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar (80 kB at 2.2 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar
Progress (2): 0.4/1.0 MB | 131/195 kBProgress (2): 0.4/1.0 MB | 135/195 kBProgress (2): 0.4/1.0 MB | 135/195 kBProgress (2): 0.4/1.0 MB | 139/195 kBProgress (2): 0.4/1.0 MB | 143/195 kBProgress (2): 0.4/1.0 MB | 147/195 kBProgress (2): 0.4/1.0 MB | 147/195 kBProgress (3): 0.4/1.0 MB | 147/195 kB | 2.2/12 kBProgress (3): 0.4/1.0 MB | 147/195 kB | 2.2/12 kBProgress (3): 0.4/1.0 MB | 147/195 kB | 5.0/12 kBProgress (3): 0.4/1.0 MB | 151/195 kB | 5.0/12 kBProgress (3): 0.4/1.0 MB | 151/195 kB | 7.7/12 kBProgress (3): 0.4/1.0 MB | 155/195 kB | 7.7/12 kBProgress (3): 0.4/1.0 MB | 155/195 kB | 7.7/12 kBProgress (3): 0.4/1.0 MB | 159/195 kB | 7.7/12 kBProgress (3): 0.4/1.0 MB | 159/195 kB | 10/12 kB Progress (3): 0.4/1.0 MB | 163/195 kB | 10/12 kBProgress (3): 0.4/1.0 MB | 163/195 kB | 12 kB Progress (3): 0.5/1.0 MB | 163/195 kB | 12 kBProgress (3): 0.5/1.0 MB | 163/195 kB | 12 kBProgress (3): 0.5/1.0 MB | 163/195 kB | 12 kBProgress (3): 0.5/1.0 MB | 167/195 kB | 12 kBProgress (3): 0.5/1.0 MB | 171/195 kB | 12 kBProgress (3): 0.5/1.0 MB | 176/195 kB | 12 kBProgress (3): 0.5/1.0 MB | 176/195 kB | 12 kBProgress (3): 0.5/1.0 MB | 180/195 kB | 12 kBProgress (3): 0.5/1.0 MB | 180/195 kB | 12 kBProgress (3): 0.5/1.0 MB | 180/195 kB | 12 kBProgress (3): 0.5/1.0 MB | 180/195 kB | 12 kBProgress (4): 0.5/1.0 MB | 180/195 kB | 12 kB | 4.1/251 kBProgress (4): 0.5/1.0 MB | 180/195 kB | 12 kB | 7.7/251 kBProgress (4): 0.5/1.0 MB | 184/195 kB | 12 kB | 7.7/251 kBProgress (4): 0.5/1.0 MB | 184/195 kB | 12 kB | 12/251 kB Progress (4): 0.5/1.0 MB | 188/195 kB | 12 kB | 12/251 kBProgress (4): 0.5/1.0 MB | 188/195 kB | 12 kB | 12/251 kBProgress (4): 0.5/1.0 MB | 188/195 kB | 12 kB | 16/251 kBProgress (4): 0.5/1.0 MB | 188/195 kB | 12 kB | 16/251 kBProgress (4): 0.5/1.0 MB | 192/195 kB | 12 kB | 16/251 kBProgress (4): 0.5/1.0 MB | 192/195 kB | 12 kB | 16/251 kBProgress (4): 0.5/1.0 MB | 195 kB | 12 kB | 16/251 kB Progress (4): 0.5/1.0 MB | 195 kB | 12 kB | 16/251 kBProgress (4): 0.5/1.0 MB | 195 kB | 12 kB | 20/251 kBProgress (4): 0.5/1.0 MB | 195 kB | 12 kB | 20/251 kBProgress (4): 0.5/1.0 MB | 195 kB | 12 kB | 24/251 kBProgress (4): 0.5/1.0 MB | 195 kB | 12 kB | 24/251 kBProgress (4): 0.5/1.0 MB | 195 kB | 12 kB | 28/251 kBProgress (4): 0.5/1.0 MB | 195 kB | 12 kB | 28/251 kBProgress (4): 0.5/1.0 MB | 195 kB | 12 kB | 28/251 kBProgress (4): 0.5/1.0 MB | 195 kB | 12 kB | 32/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar (12 kB at 289 kB/s)
Progress (3): 0.5/1.0 MB | 195 kB | 32/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 32/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 36/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 36/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 40/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 40/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 45/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 49/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 49/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 53/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 53/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 57/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 57/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 61/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 61/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 65/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 69/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 69/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 73/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 73/251 kBProgress (3): 0.5/1.0 MB | 195 kB | 77/251 kBProgress (3): 0.6/1.0 MB | 195 kB | 77/251 kBProgress (3): 0.6/1.0 MB | 195 kB | 81/251 kBProgress (3): 0.6/1.0 MB | 195 kB | 81/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar (195 kB at 4.3 MB/s)
Progress (2): 0.6/1.0 MB | 85/251 kBProgress (2): 0.6/1.0 MB | 85/251 kBProgress (2): 0.6/1.0 MB | 90/251 kBProgress (2): 0.6/1.0 MB | 90/251 kBProgress (2): 0.6/1.0 MB | 94/251 kBProgress (2): 0.6/1.0 MB | 94/251 kBProgress (2): 0.6/1.0 MB | 98/251 kBProgress (2): 0.6/1.0 MB | 98/251 kBProgress (2): 0.6/1.0 MB | 102/251 kBProgress (2): 0.6/1.0 MB | 102/251 kBProgress (2): 0.6/1.0 MB | 106/251 kBProgress (2): 0.6/1.0 MB | 106/251 kBProgress (2): 0.6/1.0 MB | 110/251 kBProgress (2): 0.6/1.0 MB | 110/251 kBProgress (2): 0.6/1.0 MB | 110/251 kBProgress (2): 0.6/1.0 MB | 114/251 kBProgress (2): 0.6/1.0 MB | 114/251 kBProgress (2): 0.6/1.0 MB | 114/251 kBProgress (2): 0.6/1.0 MB | 114/251 kBProgress (2): 0.6/1.0 MB | 114/251 kBProgress (2): 0.6/1.0 MB | 118/251 kBProgress (2): 0.6/1.0 MB | 122/251 kBProgress (2): 0.6/1.0 MB | 126/251 kBProgress (2): 0.6/1.0 MB | 131/251 kBProgress (2): 0.6/1.0 MB | 131/251 kBProgress (2): 0.6/1.0 MB | 131/251 kBProgress (2): 0.6/1.0 MB | 135/251 kBProgress (2): 0.6/1.0 MB | 135/251 kBProgress (2): 0.6/1.0 MB | 139/251 kBProgress (2): 0.6/1.0 MB | 139/251 kBProgress (2): 0.6/1.0 MB | 143/251 kBProgress (2): 0.6/1.0 MB | 147/251 kBProgress (2): 0.6/1.0 MB | 147/251 kBProgress (2): 0.6/1.0 MB | 151/251 kBProgress (2): 0.6/1.0 MB | 151/251 kBProgress (2): 0.6/1.0 MB | 155/251 kBProgress (2): 0.6/1.0 MB | 155/251 kBProgress (2): 0.6/1.0 MB | 159/251 kBProgress (2): 0.6/1.0 MB | 159/251 kBProgress (2): 0.6/1.0 MB | 163/251 kBProgress (2): 0.6/1.0 MB | 167/251 kBProgress (2): 0.6/1.0 MB | 167/251 kBProgress (2): 0.6/1.0 MB | 171/251 kBProgress (2): 0.6/1.0 MB | 171/251 kBProgress (2): 0.6/1.0 MB | 176/251 kBProgress (2): 0.7/1.0 MB | 176/251 kBProgress (2): 0.7/1.0 MB | 180/251 kBProgress (2): 0.7/1.0 MB | 180/251 kBProgress (2): 0.7/1.0 MB | 184/251 kBProgress (2): 0.7/1.0 MB | 188/251 kBProgress (2): 0.7/1.0 MB | 188/251 kBProgress (2): 0.7/1.0 MB | 192/251 kBProgress (2): 0.7/1.0 MB | 192/251 kBProgress (2): 0.7/1.0 MB | 196/251 kBProgress (2): 0.7/1.0 MB | 196/251 kBProgress (2): 0.7/1.0 MB | 196/251 kBProgress (2): 0.7/1.0 MB | 200/251 kBProgress (2): 0.7/1.0 MB | 200/251 kBProgress (2): 0.7/1.0 MB | 204/251 kBProgress (2): 0.7/1.0 MB | 204/251 kBProgress (2): 0.7/1.0 MB | 208/251 kBProgress (2): 0.7/1.0 MB | 208/251 kBProgress (2): 0.7/1.0 MB | 212/251 kBProgress (2): 0.7/1.0 MB | 212/251 kBProgress (2): 0.7/1.0 MB | 217/251 kBProgress (2): 0.7/1.0 MB | 217/251 kBProgress (2): 0.7/1.0 MB | 221/251 kBProgress (2): 0.7/1.0 MB | 221/251 kBProgress (2): 0.7/1.0 MB | 225/251 kBProgress (2): 0.7/1.0 MB | 225/251 kBProgress (2): 0.7/1.0 MB | 229/251 kBProgress (2): 0.7/1.0 MB | 229/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 233/251 kBProgress (2): 0.7/1.0 MB | 237/251 kBProgress (2): 0.7/1.0 MB | 237/251 kBProgress (2): 0.7/1.0 MB | 241/251 kBProgress (2): 0.7/1.0 MB | 241/251 kBProgress (2): 0.7/1.0 MB | 245/251 kBProgress (2): 0.7/1.0 MB | 245/251 kBProgress (2): 0.7/1.0 MB | 249/251 kBProgress (2): 0.7/1.0 MB | 251 kB Progress (2): 0.7/1.0 MB | 251 kBProgress (2): 0.7/1.0 MB | 251 kBProgress (2): 0.7/1.0 MB | 251 kBProgress (2): 0.7/1.0 MB | 251 kBProgress (3): 0.7/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.7/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0.1/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0.1/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0.1/1.3 MBProgress (3): 0.8/1.0 MB | 251 kB | 0.1/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar (251 kB at 4.5 MB/s)
Progress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.8/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.1/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 0.9/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.2/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0/1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MB Progress (2): 1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MBProgress (2): 1.0 MB | 0.3/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar (1.0 MB at 15 MB/s)
Progress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.3/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.4/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.5/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar (1.3 MB at 12 MB/s)
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en&gt;
     [echo] Build directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.16-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;:137:Inline literal start-string without end-string.
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 49.205 s
[e[1;34mINFOe[m] Finished at: 2019-06-01T13:08:36Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://build.geoserver.org/job/geoserver-master-live-docs/1829/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] GEOS-9184 style image upload: NPE if new style (#3443)
[...truncated 713 B...]
  at hudson.model.Executor.run(Executor.java:429)
ln builds/lastStableBuild /var/lib/jenkins/jobs/geoserver-master-live-docs/lastStable failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-master-live-docs/lastStable
  at sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:242)
  at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:108)
  at java.nio.file.Files.deleteIfExists(Files.java:1165)
  at hudson.Util.createSymlink(Util.java:1193)
  at hudson.model.Run.createSymlink(Run.java:1955)
  at hudson.model.Run.updateSymlinks(Run.java:1937)
  at hudson.model.Run.execute(Run.java:1814)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
  at hudson.model.ResourceController.execute(ResourceController.java:97)
Building remotely on i-0a9a845f685f55dd7 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-live-docs/ws/&gt;
No credentials specified
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 6c2a17f522d5ea064ab08aa5cfcd12b376e5407e (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 6c2a17f522d5ea064ab08aa5cfcd12b376e5407e
Commit message: "GEOS-9184 style image upload: NPE if new style (#3443)"
> git rev-list --no-walk 2c1d5c473c03781114b2ded9ea74c340c51a8f5e # timeout=10
[geoserver-master-live-docs] $ mvn -f doc/en/pom.xml clean compile
[e[1;34mINFOe[m] Scanning for projects...
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m----------------------< e[0;36morg.geoserver.en:gs-docse[0;1m >----------------------e[m
[e[1;34mINFOe[m] e[1mBuilding GeoServer English Documentation 2.16-SNAPSHOTe[m
[e[1;34mINFOe[m] e[1m--------------------------------[ pom ]---------------------------------e[m
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-clean-plugin:2.5:cleane[m e[1m(default-clean)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] Deleting <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(coverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coverages.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(coverageStores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coveragestores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coveragestores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coveragestores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(datastores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/datastores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/datastores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/datastores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(featureTypes)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml&gt;
[e[1;33mWARNINGe[m] generated unique operationId `getFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `putFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `postFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `deleteFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `getFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `putFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `postFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `deleteFeatureType_0`
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/featuretypes/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/featuretypes/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(fonts)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 47.000 s
[e[1;34mINFOe[m] Finished at: 2019-06-01T13:30:55Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
See <http://build.geoserver.org/job/geoserver-master-live-docs/1830/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Makng GeoServer compile after removal of deprecated methods/objects in
[Andrea Aime] Removing/replacing all deprecated calls to IOUtils.closeQuietly
[Andrea Aime] Switching from old junit assert to the current one
[Andrea Aime] Removing easymock classpath extension, is deprecated and has been merged
[Andrea Aime] Removing RequestUtils deprecated method
[Andrea Aime] Removing HTTPServletAware and its usage points
[Andrea Aime] Replacing deprecated DefaultServiceExceptionHandler with its superclass
[Andrea Aime] Completing cleanup of the gs-ows module, removed the deprecated OWS
[Andrea Aime] Replacing commons deprecated MultiHashMap with MultiValueHashMap
[Andrea Aime] Replacing deprecated Wrapper and AbstractCatalogDecorator with the
[Andrea Aime] Bye bye DataAccessManager
[Andrea Aime] Sweeping under the rug a bit of deprecatd org.vfny stuff, unfortunately
[Andrea Aime] Replacing deprecated Spring Base64 class with java own
[Andrea Aime] Resource step one
[Andrea Aime] Replacing deprecated url method in GeoServerResourceLoader
[Andrea Aime] Cleaning up GeoServerDataDirectory deprecated methods
[Andrea Aime] Removing deprecated ResourceInfo.getPrefixedName
[Andrea Aime] Removing deprecated methods from Catalog
[Andrea Aime] Removing deprecated prefixedName from PublishedInfo
[Andrea Aime] Removing deprecated methods from ContactInfo and GeoServerInfo
[Andrea Aime] Removing deprecated methods from JAIInfo
[Andrea Aime] The concurrent operation registry is in jai-ext
[Andrea Aime] Fixing IOUtils.write calls and removing GeoServeFeatureLocking
[Andrea Aime] Replacing calls to Throwables deprecated methods
[Andrea Aime] Dude, this is the two arguments constructor....
[Andrea Aime] Fixing deprecated calls to Spring Assert methos, use junit assert in
[Andrea Aime] Removing CatalogFacade deprecated method
[Andrea Aime] Removing StyleInfo deprecated methods
[Andrea Aime] Removing deprecated methods from template loader
[Andrea Aime] Resolving assorted deprecations in gs-main tests, fixing pmd and
[Andrea Aime] Fixing deprecated calls to Capture
[Andrea Aime] Removing PropertyFileWatcher deprecated constructor
[Andrea Aime] Removing deprecated methods from FileWatcher and friends
[Andrea Aime] Fixing deprecated class usage in LDAP module... finger crossed, I don't
[Andrea Aime] Fixing deprecated calls to readFileToString
[Andrea Aime] Fixed usage of deprecated SimpleEnumerationType
[Andrea Aime] Removed dodgy deprecation, was deprecated but GMLInfo was not given a
[Andrea Aime] Goodbye TransactionPlugin
[Andrea Aime] Removing deprecated method from Response
[Andrea Aime] Removing usage of deprecated EMFUtils.clone method
[Andrea Aime] Fixing calls to URLDecoder.decode deprecated method version
[Andrea Aime] Fixing deprecated point constructor call
[Andrea Aime] Removing ShapeZipOutputFormat deprecated constructor
[Andrea Aime] Small deprecation and PMD fixes
[Andrea Aime] Removing deprecated call to ExpressionDOMParser static method
[Andrea Aime] GetLegendGraphicRequest deprecated methods removal
[Andrea Aime] Ignore deprecatins in MockHttpClientConnectionManager, nothing we can do
[Andrea Aime] Completing WMS small cleanups
[Andrea Aime] Fixing deprecated calls to FileUtils.write
[Andrea Aime] Fixing usage of deprecated constructor of
[Andrea Aime] Removing deprecated methods in GeoServerTileLayer
[Andrea Aime] Handling assorted deprecations in gwc src/main
[Andrea Aime] Assorted deprecation fixes. Some are just suppressions, the author of
[Andrea Aime] Assorted deprecated call fixes in restconfig
[Andrea Aime] Fixing assorted deprecations in web/core
[Andrea Aime] Removing deprecated method from GeoServerSecurityManager
[Andrea Aime] Ignoring deprecation on wicket method call that has no obvious
[Andrea Aime] web/app deprecation fixes. Start.java uses a bunch of deprecated
[Andrea Aime] Removing deprecated IOUtils class, switch usage points to its superclass
[Andrea Aime] Completing app-schema-test cleanup
[Andrea Aime] Cleaning up html image map
[Andrea Aime] Fixing ogr output format
[Andrea Aime] Cleaning up GSProcess usage
[Andrea Aime] Assorted minor fixes in wps
[Andrea Aime] Cleaning up geofence and monitoring
[Andrea Aime] Follow up on GeoTools changes
[Andrea Aime] Making community modules in communityRelease compile
[Andrea Aime] Fixing build after deprecated method removal in GeoWebCache
[Andrea Aime] Deprecated API checkpoint on main, more deprecated API yet to remove
[Andrea Aime] Closing up main
[Andrea Aime] Make community modules compile
[Andrea Aime] java 11 fixes
[Andrea Aime] More java 11 fixes. WCS 1.1 has the same 'fix' as CQL, cannot have
[Andrea Aime] Revert "Resource step one"
[Andrea Aime] Resources.find( resource, force ) javadoc Implement
Checking out Revision 290813cbc463e68459b7eb7d8e6b031b0e192657 (origin/master)
> git checkout -f 290813cbc463e68459b7eb7d8e6b031b0e192657
Commit message: "Merge pull request #3449 from aaime/deprecation"
> git rev-list --no-walk 6c2a17f522d5ea064ab08aa5cfcd12b376e5407e # timeout=10
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 46.444 s
[e[1;34mINFOe[m] Finished at: 2019-06-01T14:00:56Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
See <http://build.geoserver.org/job/geoserver-master-live-docs/1831/display/redirect?page=changes&gt;
Changes:
[Torben Barsballe] [GEOS-8752] Allow integrated GWC to seed secured layers - Add regression
[...truncated 1.00 KB...]
Building remotely on i-0aca19576bc2ce084 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-live-docs/ws/&gt;
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <http://build.geoserver.org/job/geoserver-master-live-docs/ws/&gt; # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
Checking out Revision 1b8a459b27881fece2783a8189ae5e6414bf3478 (origin/master)
> git checkout -f 1b8a459b27881fece2783a8189ae5e6414bf3478
Commit message: "Merge pull request #3525 from tbarsballe/GEOS-8752"
> git rev-list --no-walk 290813cbc463e68459b7eb7d8e6b031b0e192657 # timeout=10
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 59.710 s
[e[1;34mINFOe[m] Finished at: 2019-06-03T18:11:20Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
See <http://build.geoserver.org/job/geoserver-master-live-docs/1832/display/redirect?page=changes&gt;
Changes:
[Torben Barsballe] [GEOS-8254] Add demo page english translation for DXF
[Torben Barsballe] Add demo page english translations for OGR-WFS
[Torben Barsballe] [GEOS-8628] Add missing demo page english translation for VectorTiles
[Torben Barsballe] Add missing demo page english translation for GeoPackage
[Torben Barsballe] Add missing demo page english translation for DDS BIL
[Torben Barsballe] Add demo page english translation for MapML
[Torben Barsballe] Add missing demo page english translation for GeoRSS and KML
[...truncated 401.53 KB...]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom
Progress (1): 861 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom (861 B at 215 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom
Progress (1): 761 B Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.pom (761 B at 190 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom
Progress (1): 138 B Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.5/ant-1.5.pom (138 B at 20 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom
Progress (1): 643 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.pom (643 B at 214 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom
Progress (1): 2.2/12 kBProgress (1): 5.0/12 kBProgress (1): 7.8/12 kBProgress (1): 11/12 kB Progress (1): 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.4/maven-2.0.4.pom (12 kB at 2.4 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom
Progress (1): 1.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.pom (1.8 kB at 460 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom
Progress (1): 1.5/1.6 kBProgress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.pom (1.6 kB at 542 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom
Progress (1): 2.7 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.pom (2.7 kB at 903 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom
Progress (1): 767 B Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.pom (767 B at 192 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom
Progress (1): 1.2 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.pom (1.2 kB at 412 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom
Progress (1): 998 B Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.pom (998 B at 333 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom
Progress (1): 1.6 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.pom (1.6 kB at 404 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom
Progress (1): 1.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.pom (1.4 kB at 453 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom
Progress (1): 1.3/1.5 kBProgress (1): 1.5 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.pom (1.5 kB at 496 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom
Progress (1): 765 B Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.pom (765 B at 255 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom
Progress (1): 2.8/5.3 kBProgress (1): 5.3 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.pom (5.3 kB at 1.8 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom
Progress (1): 2.8/9.8 kBProgress (1): 5.5/9.8 kBProgress (1): 8.3/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus/1.0.12/plexus-1.0.12.pom (9.8 kB at 2.5 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom
Progress (1): 2.2/2.4 kBProgress (1): 2.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.pom (2.4 kB at 596 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom
Progress (1): 2.8/4.4 kBProgress (1): 4.4 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-parent/1.7.1/ant-parent-1.7.1.pom (4.4 kB at 1.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom
Progress (1): 2.8/9.8 kBProgress (1): 5.5/9.8 kBProgress (1): 8.3/9.8 kBProgress (1): 9.8 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.pom (9.8 kB at 2.4 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar
Downloading from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar
Progress (1): 2.8/109 kBProgress (1): 5.5/109 kBProgress (2): 5.5/109 kB | 2.2/8.3 kBProgress (2): 8.3/109 kB | 2.2/8.3 kBProgress (2): 8.3/109 kB | 5.0/8.3 kBProgress (2): 11/109 kB | 5.0/8.3 kB Progress (2): 11/109 kB | 7.7/8.3 kBProgress (2): 11/109 kB | 8.3 kB Progress (2): 14/109 kB | 8.3 kBProgress (3): 14/109 kB | 8.3 kB | 4.1/44 kBProgress (3): 14/109 kB | 8.3 kB | 7.7/44 kBProgress (3): 14/109 kB | 8.3 kB | 12/44 kB Progress (3): 14/109 kB | 8.3 kB | 16/44 kBProgress (3): 16/109 kB | 8.3 kB | 16/44 kBProgress (3): 19/109 kB | 8.3 kB | 16/44 kBProgress (3): 22/109 kB | 8.3 kB | 16/44 kBProgress (3): 22/109 kB | 8.3 kB | 20/44 kBProgress (3): 22/109 kB | 8.3 kB | 24/44 kBProgress (3): 22/109 kB | 8.3 kB | 28/44 kBProgress (3): 25/109 kB | 8.3 kB | 28/44 kBProgress (3): 25/109 kB | 8.3 kB | 32/44 kBProgress (3): 27/109 kB | 8.3 kB | 32/44 kBProgress (3): 30/109 kB | 8.3 kB | 32/44 kBProgress (4): 30/109 kB | 8.3 kB | 32/44 kB | 2.2/224 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.4/maven-plugin-api-2.0.4.jar (8.3 kB at 1.2 MB/s)
Progress (3): 33/109 kB | 32/44 kB | 2.2/224 kBProgress (3): 33/109 kB | 36/44 kB | 2.2/224 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar
Progress (3): 33/109 kB | 40/44 kB | 2.2/224 kBProgress (3): 33/109 kB | 40/44 kB | 5.0/224 kBProgress (3): 33/109 kB | 44 kB | 5.0/224 kB Progress (3): 33/109 kB | 44 kB | 7.7/224 kBProgress (3): 37/109 kB | 44 kB | 7.7/224 kBProgress (3): 41/109 kB | 44 kB | 7.7/224 kBProgress (3): 45/109 kB | 44 kB | 7.7/224 kBProgress (3): 45/109 kB | 44 kB | 10/224 kB Progress (3): 49/109 kB | 44 kB | 10/224 kBProgress (3): 49/109 kB | 44 kB | 13/224 kBProgress (3): 49/109 kB | 44 kB | 16/224 kBProgress (3): 53/109 kB | 44 kB | 16/224 kBProgress (3): 53/109 kB | 44 kB | 19/224 kBProgress (3): 57/109 kB | 44 kB | 19/224 kBProgress (3): 61/109 kB | 44 kB | 19/224 kBProgress (3): 66/109 kB | 44 kB | 19/224 kBProgress (3): 66/109 kB | 44 kB | 21/224 kBProgress (3): 66/109 kB | 44 kB | 24/224 kBProgress (3): 66/109 kB | 44 kB | 27/224 kBProgress (3): 70/109 kB | 44 kB | 27/224 kBProgress (3): 70/109 kB | 44 kB | 30/224 kBProgress (3): 74/109 kB | 44 kB | 30/224 kBProgress (3): 78/109 kB | 44 kB | 30/224 kBProgress (3): 78/109 kB | 44 kB | 32/224 kBProgress (3): 82/109 kB | 44 kB | 32/224 kBProgress (4): 82/109 kB | 44 kB | 32/224 kB | 4.1/30 kBProgress (4): 82/109 kB | 44 kB | 32/224 kB | 7.7/30 kBProgress (4): 82/109 kB | 44 kB | 32/224 kB | 12/30 kB Progress (4): 82/109 kB | 44 kB | 32/224 kB | 16/30 kBProgress (4): 86/109 kB | 44 kB | 32/224 kB | 16/30 kBProgress (4): 90/109 kB | 44 kB | 32/224 kB | 16/30 kBProgress (4): 94/109 kB | 44 kB | 32/224 kB | 16/30 kBProgress (4): 94/109 kB | 44 kB | 36/224 kB | 16/30 kBProgress (4): 98/109 kB | 44 kB | 36/224 kB | 16/30 kBProgress (4): 98/109 kB | 44 kB | 40/224 kB | 16/30 kBProgress (4): 98/109 kB | 44 kB | 45/224 kB | 16/30 kBProgress (4): 98/109 kB | 44 kB | 45/224 kB | 20/30 kBProgress (4): 98/109 kB | 44 kB | 49/224 kB | 20/30 kBProgress (4): 98/109 kB | 44 kB | 49/224 kB | 24/30 kBProgress (4): 102/109 kB | 44 kB | 49/224 kB | 24/30 kBProgress (4): 102/109 kB | 44 kB | 49/224 kB | 28/30 kBProgress (4): 106/109 kB | 44 kB | 49/224 kB | 28/30 kBProgress (4): 106/109 kB | 44 kB | 49/224 kB | 30 kB Progress (4): 109 kB | 44 kB | 49/224 kB | 30 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-settings/2.0.4/maven-settings-2.0.4.jar (44 kB at 4.4 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar
Progress (3): 109 kB | 53/224 kB | 30 kBProgress (3): 109 kB | 57/224 kB | 30 kBProgress (3): 109 kB | 61/224 kB | 30 kBProgress (3): 109 kB | 65/224 kB | 30 kBProgress (4): 109 kB | 65/224 kB | 30 kB | 0/1.0 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0.4/maven-profile-2.0.4.jar (30 kB at 2.5 MB/s)
Progress (3): 109 kB | 69/224 kB | 0/1.0 MBProgress (3): 109 kB | 69/224 kB | 0/1.0 MBProgress (3): 109 kB | 73/224 kB | 0/1.0 MB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar
Progress (3): 109 kB | 77/224 kB | 0/1.0 MBProgress (3): 109 kB | 81/224 kB | 0/1.0 MBProgress (3): 109 kB | 81/224 kB | 0/1.0 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0.4/maven-project-2.0.4.jar (109 kB at 9.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar
Progress (2): 81/224 kB | 0/1.0 MBProgress (2): 81/224 kB | 0/1.0 MBProgress (2): 85/224 kB | 0/1.0 MBProgress (2): 85/224 kB | 0/1.0 MBProgress (2): 90/224 kB | 0/1.0 MBProgress (2): 94/224 kB | 0/1.0 MBProgress (2): 98/224 kB | 0/1.0 MBProgress (2): 98/224 kB | 0/1.0 MBProgress (2): 98/224 kB | 0/1.0 MBProgress (2): 98/224 kB | 0/1.0 MBProgress (2): 98/224 kB | 0/1.0 MBProgress (2): 102/224 kB | 0/1.0 MBProgress (3): 102/224 kB | 0/1.0 MB | 2.2/80 kBProgress (3): 106/224 kB | 0/1.0 MB | 2.2/80 kBProgress (3): 110/224 kB | 0/1.0 MB | 2.2/80 kBProgress (3): 114/224 kB | 0/1.0 MB | 2.2/80 kBProgress (3): 114/224 kB | 0/1.0 MB | 2.2/80 kBProgress (3): 114/224 kB | 0/1.0 MB | 2.2/80 kBProgress (4): 114/224 kB | 0/1.0 MB | 2.2/80 kB | 4.1/20 kBProgress (4): 114/224 kB | 0/1.0 MB | 2.2/80 kB | 7.7/20 kBProgress (4): 118/224 kB | 0/1.0 MB | 2.2/80 kB | 7.7/20 kBProgress (4): 118/224 kB | 0/1.0 MB | 2.2/80 kB | 12/20 kB Progress (4): 122/224 kB | 0/1.0 MB | 2.2/80 kB | 12/20 kBProgress (4): 126/224 kB | 0/1.0 MB | 2.2/80 kB | 12/20 kBProgress (4): 126/224 kB | 0/1.0 MB | 2.2/80 kB | 16/20 kBProgress (4): 131/224 kB | 0/1.0 MB | 2.2/80 kB | 16/20 kBProgress (5): 131/224 kB | 0/1.0 MB | 2.2/80 kB | 16/20 kB | 4.1/49 kBProgress (5): 131/224 kB | 0/1.0 MB | 2.2/80 kB | 20 kB | 4.1/49 kB Progress (5): 131/224 kB | 0/1.0 MB | 2.2/80 kB | 20 kB | 7.7/49 kBProgress (5): 131/224 kB | 0/1.0 MB | 2.2/80 kB | 20 kB | 12/49 kB Progress (5): 131/224 kB | 0/1.0 MB | 2.2/80 kB | 20 kB | 12/49 kBProgress (5): 131/224 kB | 0/1.0 MB | 5.0/80 kB | 20 kB | 12/49 kBProgress (5): 131/224 kB | 0/1.0 MB | 5.0/80 kB | 20 kB | 16/49 kBProgress (5): 135/224 kB | 0/1.0 MB | 5.0/80 kB | 20 kB | 16/49 kBProgress (5): 135/224 kB | 0/1.0 MB | 7.7/80 kB | 20 kB | 16/49 kBProgress (5): 135/224 kB | 0/1.0 MB | 7.7/80 kB | 20 kB | 16/49 kBProgress (5): 139/224 kB | 0/1.0 MB | 7.7/80 kB | 20 kB | 16/49 kBProgress (5): 139/224 kB | 0/1.0 MB | 7.7/80 kB | 20 kB | 16/49 kBProgress (5): 139/224 kB | 0/1.0 MB | 10/80 kB | 20 kB | 16/49 kB Progress (5): 139/224 kB | 0/1.0 MB | 10/80 kB | 20 kB | 16/49 kBProgress (5): 143/224 kB | 0/1.0 MB | 10/80 kB | 20 kB | 16/49 kBProgress (5): 147/224 kB | 0/1.0 MB | 10/80 kB | 20 kB | 16/49 kBProgress (5): 147/224 kB | 0/1.0 MB | 10/80 kB | 20 kB | 20/49 kBProgress (5): 147/224 kB | 0/1.0 MB | 10/80 kB | 20 kB | 24/49 kBProgress (5): 147/224 kB | 0/1.0 MB | 10/80 kB | 20 kB | 28/49 kBProgress (5): 147/224 kB | 0/1.0 MB | 10/80 kB | 20 kB | 32/49 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 10/80 kB | 20 kB | 32/49 kBProgress (5): 147/224 kB | 0.1/1.0 MB | 10/80 kB | 20 kB | 32/49 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-repository-metadata/2.0.4/maven-repository-metadata-2.0.4.jar (20 kB at 1.2 MB/s)
Progress (4): 147/224 kB | 0.1/1.0 MB | 10/80 kB | 32/49 kBProgress (4): 147/224 kB | 0.1/1.0 MB | 10/80 kB | 32/49 kBProgress (4): 147/224 kB | 0.1/1.0 MB | 13/80 kB | 32/49 kBProgress (4): 147/224 kB | 0.1/1.0 MB | 16/80 kB | 32/49 kBProgress (4): 147/224 kB | 0.1/1.0 MB | 19/80 kB | 32/49 kBProgress (4): 147/224 kB | 0.1/1.0 MB | 21/80 kB | 32/49 kBProgress (4): 147/224 kB | 0.1/1.0 MB | 21/80 kB | 32/49 kBProgress (4): 147/224 kB | 0.1/1.0 MB | 24/80 kB | 32/49 kBProgress (4): 147/224 kB | 0.1/1.0 MB | 24/80 kB | 32/49 kBProgress (4): 147/224 kB | 0.1/1.0 MB | 24/80 kB | 32/49 kBProgress (4): 147/224 kB | 0.1/1.0 MB | 27/80 kB | 32/49 kBProgress (4): 151/224 kB | 0.1/1.0 MB | 27/80 kB | 32/49 kBProgress (4): 155/224 kB | 0.1/1.0 MB | 27/80 kB | 32/49 kBProgress (4): 155/224 kB | 0.1/1.0 MB | 30/80 kB | 32/49 kBProgress (4): 159/224 kB | 0.1/1.0 MB | 30/80 kB | 32/49 kBProgress (4): 163/224 kB | 0.1/1.0 MB | 30/80 kB | 32/49 kBProgress (4): 163/224 kB | 0.1/1.0 MB | 32/80 kB | 32/49 kBProgress (4): 163/224 kB | 0.1/1.0 MB | 36/80 kB | 32/49 kBProgress (4): 163/224 kB | 0.1/1.0 MB | 36/80 kB | 32/49 kBProgress (4): 167/224 kB | 0.1/1.0 MB | 36/80 kB | 32/49 kBProgress (4): 167/224 kB | 0.1/1.0 MB | 36/80 kB | 36/49 kBProgress (4): 171/224 kB | 0.1/1.0 MB | 36/80 kB | 36/49 kBProgress (4): 176/224 kB | 0.1/1.0 MB | 36/80 kB | 36/49 kB Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar
Progress (4): 176/224 kB | 0.1/1.0 MB | 36/80 kB | 40/49 kBProgress (4): 176/224 kB | 0.1/1.0 MB | 40/80 kB | 40/49 kBProgress (4): 176/224 kB | 0.1/1.0 MB | 40/80 kB | 45/49 kBProgress (4): 180/224 kB | 0.1/1.0 MB | 40/80 kB | 45/49 kBProgress (4): 180/224 kB | 0.1/1.0 MB | 45/80 kB | 45/49 kBProgress (4): 180/224 kB | 0.1/1.0 MB | 45/80 kB | 49/49 kBProgress (4): 180/224 kB | 0.1/1.0 MB | 49/80 kB | 49/49 kBProgress (4): 180/224 kB | 0.1/1.0 MB | 49/80 kB | 49 kB Progress (4): 180/224 kB | 0.1/1.0 MB | 49/80 kB | 49 kBProgress (4): 180/224 kB | 0.1/1.0 MB | 49/80 kB | 49 kBProgress (4): 180/224 kB | 0.1/1.0 MB | 49/80 kB | 49 kBProgress (4): 180/224 kB | 0.1/1.0 MB | 49/80 kB | 49 kBProgress (4): 180/224 kB | 0.1/1.0 MB | 53/80 kB | 49 kBProgress (4): 184/224 kB | 0.1/1.0 MB | 53/80 kB | 49 kBProgress (4): 184/224 kB | 0.1/1.0 MB | 57/80 kB | 49 kBProgress (4): 188/224 kB | 0.1/1.0 MB | 57/80 kB | 49 kBProgress (4): 188/224 kB | 0.1/1.0 MB | 61/80 kB | 49 kBProgress (4): 192/224 kB | 0.1/1.0 MB | 61/80 kB | 49 kBProgress (4): 192/224 kB | 0.1/1.0 MB | 65/80 kB | 49 kBProgress (4): 196/224 kB | 0.1/1.0 MB | 65/80 kB | 49 kBProgress (4): 196/224 kB | 0.1/1.0 MB | 65/80 kB | 49 kBProgress (4): 196/224 kB | 0.1/1.0 MB | 65/80 kB | 49 kBProgress (4): 196/224 kB | 0.1/1.0 MB | 65/80 kB | 49 kBProgress (4): 196/224 kB | 0.1/1.0 MB | 65/80 kB | 49 kBProgress (4): 196/224 kB | 0.1/1.0 MB | 69/80 kB | 49 kBProgress (4): 196/224 kB | 0.1/1.0 MB | 73/80 kB | 49 kBProgress (4): 200/224 kB | 0.1/1.0 MB | 73/80 kB | 49 kBProgress (4): 200/224 kB | 0.1/1.0 MB | 77/80 kB | 49 kBProgress (4): 204/224 kB | 0.1/1.0 MB | 77/80 kB | 49 kBProgress (4): 204/224 kB | 0.1/1.0 MB | 80 kB | 49 kB Progress (4): 208/224 kB | 0.1/1.0 MB | 80 kB | 49 kBProgress (4): 212/224 kB | 0.1/1.0 MB | 80 kB | 49 kBProgress (4): 212/224 kB | 0.1/1.0 MB | 80 kB | 49 kBProgress (4): 212/224 kB | 0.1/1.0 MB | 80 kB | 49 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.4/maven-artifact-manager-2.0.4.jar (49 kB at 2.3 MB/s)
Progress (3): 212/224 kB | 0.1/1.0 MB | 80 kB Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar
Progress (3): 212/224 kB | 0.1/1.0 MB | 80 kBProgress (3): 217/224 kB | 0.1/1.0 MB | 80 kBProgress (3): 221/224 kB | 0.1/1.0 MB | 80 kBProgress (3): 224 kB | 0.1/1.0 MB | 80 kB Progress (3): 224 kB | 0.1/1.0 MB | 80 kBProgress (3): 224 kB | 0.1/1.0 MB | 80 kBProgress (3): 224 kB | 0.1/1.0 MB | 80 kBProgress (3): 224 kB | 0.1/1.0 MB | 80 kBProgress (4): 224 kB | 0.1/1.0 MB | 80 kB | 4.1/195 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 4.1/195 kBProgress (4): 224 kB | 0.2/1.0 MB | 80 kB | 7.7/195 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-model/2.0.4/maven-model-2.0.4.jar (80 kB at 3.5 MB/s)
Progress (3): 224 kB | 0.2/1.0 MB | 12/195 kBProgress (3): 224 kB | 0.2/1.0 MB | 12/195 kBProgress (3): 224 kB | 0.2/1.0 MB | 16/195 kBProgress (3): 224 kB | 0.2/1.0 MB | 16/195 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar
Progress (3): 224 kB | 0.2/1.0 MB | 16/195 kBProgress (4): 224 kB | 0.2/1.0 MB | 16/195 kB | 4.1/121 kBProgress (4): 224 kB | 0.2/1.0 MB | 20/195 kB | 4.1/121 kBProgress (4): 224 kB | 0.2/1.0 MB | 20/195 kB | 8.2/121 kBProgress (4): 224 kB | 0.2/1.0 MB | 24/195 kB | 8.2/121 kB Downloaded from central: https://repo.maven.apache.org/maven2/ant-contrib/ant-contrib/1.0b3/ant-contrib-1.0b3.jar (224 kB at 8.6 MB/s)
Progress (3): 0.2/1.0 MB | 28/195 kB | 8.2/121 kBProgress (3): 0.2/1.0 MB | 28/195 kB | 12/121 kB Progress (3): 0.2/1.0 MB | 32/195 kB | 12/121 kB Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar
Progress (3): 0.2/1.0 MB | 32/195 kB | 16/121 kBProgress (3): 0.2/1.0 MB | 32/195 kB | 20/121 kBProgress (3): 0.2/1.0 MB | 32/195 kB | 25/121 kBProgress (3): 0.2/1.0 MB | 32/195 kB | 29/121 kBProgress (3): 0.2/1.0 MB | 36/195 kB | 29/121 kBProgress (3): 0.2/1.0 MB | 36/195 kB | 33/121 kBProgress (3): 0.2/1.0 MB | 40/195 kB | 33/121 kBProgress (3): 0.2/1.0 MB | 45/195 kB | 33/121 kBProgress (3): 0.2/1.0 MB | 49/195 kB | 33/121 kBProgress (4): 0.2/1.0 MB | 49/195 kB | 33/121 kB | 4.1/80 kBProgress (4): 0.2/1.0 MB | 49/195 kB | 33/121 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 49/195 kB | 37/121 kB | 7.7/80 kBProgress (4): 0.2/1.0 MB | 49/195 kB | 37/121 kB | 12/80 kB Progress (4): 0.2/1.0 MB | 49/195 kB | 41/121 kB | 12/80 kBProgress (4): 0.2/1.0 MB | 49/195 kB | 41/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 49/195 kB | 45/121 kB | 16/80 kBProgress (4): 0.2/1.0 MB | 49/195 kB | 49/121 kB | 16/80 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 49/121 kB | 16/80 kB | 2.2/251 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 49/121 kB | 16/80 kB | 2.2/251 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 49/121 kB | 20/80 kB | 2.2/251 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 53/121 kB | 20/80 kB | 2.2/251 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 53/121 kB | 24/80 kB | 2.2/251 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 53/121 kB | 24/80 kB | 2.2/251 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 53/121 kB | 28/80 kB | 2.2/251 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 57/121 kB | 28/80 kB | 2.2/251 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 57/121 kB | 28/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 61/121 kB | 28/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 61/121 kB | 32/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 61/121 kB | 32/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 49/195 kB | 61/121 kB | 32/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 53/195 kB | 61/121 kB | 32/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 57/195 kB | 61/121 kB | 32/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 61/195 kB | 61/121 kB | 32/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 65/195 kB | 61/121 kB | 32/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 65/195 kB | 61/121 kB | 32/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 65/195 kB | 61/121 kB | 36/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 65/195 kB | 61/121 kB | 40/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 65/195 kB | 61/121 kB | 45/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 65/195 kB | 61/121 kB | 49/80 kB | 5.0/251 kBProgress (5): 0.2/1.0 MB | 65/195 kB | 61/121 kB | 49/80 kB | 7.7/251 kBProgress (5): 0.2/1.0 MB | 65/195 kB | 66/121 kB | 49/80 kB | 7.7/251 kBProgress (5): 0.2/1.0 MB | 65/195 kB | 66/121 kB | 49/80 kB | 10/251 kB Progress (5): 0.2/1.0 MB | 65/195 kB | 66/121 kB | 49/80 kB | 13/251 kBProgress (5): 0.2/1.0 MB | 65/195 kB | 66/121 kB | 49/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 65/195 kB | 66/121 kB | 53/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 69/195 kB | 66/121 kB | 53/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 69/195 kB | 66/121 kB | 53/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 69/195 kB | 66/121 kB | 57/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 73/195 kB | 66/121 kB | 57/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 73/195 kB | 70/121 kB | 57/80 kB | 16/251 kBProgress (5): 0.2/1.0 MB | 73/195 kB | 70/121 kB | 57/80 kB | 19/251 kBProgress (5): 0.2/1.0 MB | 73/195 kB | 74/121 kB | 57/80 kB | 19/251 kBProgress (5): 0.2/1.0 MB | 77/195 kB | 74/121 kB | 57/80 kB | 19/251 kBProgress (5): 0.2/1.0 MB | 77/195 kB | 74/121 kB | 61/80 kB | 19/251 kBProgress (5): 0.2/1.0 MB | 77/195 kB | 74/121 kB | 61/80 kB | 19/251 kBProgress (5): 0.2/1.0 MB | 77/195 kB | 74/121 kB | 65/80 kB | 19/251 kBProgress (5): 0.2/1.0 MB | 77/195 kB | 74/121 kB | 65/80 kB | 19/251 kBProgress (5): 0.2/1.0 MB | 81/195 kB | 74/121 kB | 65/80 kB | 19/251 kBProgress (5): 0.2/1.0 MB | 81/195 kB | 74/121 kB | 65/80 kB | 21/251 kBProgress (5): 0.2/1.0 MB | 81/195 kB | 74/121 kB | 65/80 kB | 24/251 kBProgress (5): 0.2/1.0 MB | 81/195 kB | 74/121 kB | 65/80 kB | 27/251 kBProgress (5): 0.2/1.0 MB | 81/195 kB | 74/121 kB | 65/80 kB | 30/251 kBProgress (5): 0.2/1.0 MB | 81/195 kB | 74/121 kB | 65/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 85/195 kB | 74/121 kB | 65/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 90/195 kB | 74/121 kB | 65/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 94/195 kB | 74/121 kB | 65/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 94/195 kB | 74/121 kB | 65/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 98/195 kB | 74/121 kB | 65/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 98/195 kB | 74/121 kB | 65/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 98/195 kB | 74/121 kB | 65/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 98/195 kB | 74/121 kB | 65/80 kB | 32/251 kBProgress (5): 0.2/1.0 MB | 98/195 kB | 74/121 kB | 65/80 kB | 36/251 kBProgress (5): 0.2/1.0 MB | 98/195 kB | 74/121 kB | 65/80 kB | 40/251 kBProgress (5): 0.2/1.0 MB | 98/195 kB | 74/121 kB | 65/80 kB | 45/251 kBProgress (5): 0.2/1.0 MB | 98/195 kB | 74/121 kB | 65/80 kB | 49/251 kBProgress (5): 0.2/1.0 MB | 102/195 kB | 74/121 kB | 65/80 kB | 49/251 kBProgress (5): 0.2/1.0 MB | 106/195 kB | 74/121 kB | 65/80 kB | 49/251 kBProgress (5): 0.2/1.0 MB | 110/195 kB | 74/121 kB | 65/80 kB | 49/251 kBProgress (5): 0.2/1.0 MB | 110/195 kB | 74/121 kB | 65/80 kB | 49/251 kBProgress (5): 0.2/1.0 MB | 114/195 kB | 74/121 kB | 65/80 kB | 49/251 kBProgress (5): 0.2/1.0 MB | 114/195 kB | 74/121 kB | 65/80 kB | 49/251 kBProgress (5): 0.2/1.0 MB | 114/195 kB | 74/121 kB | 65/80 kB | 49/251 kBProgress (5): 0.2/1.0 MB | 114/195 kB | 74/121 kB | 65/80 kB | 49/251 kBProgress (5): 0.2/1.0 MB | 114/195 kB | 74/121 kB | 65/80 kB | 53/251 kBProgress (5): 0.2/1.0 MB | 114/195 kB | 74/121 kB | 65/80 kB | 57/251 kBProgress (5): 0.2/1.0 MB | 114/195 kB | 74/121 kB | 65/80 kB | 61/251 kBProgress (5): 0.2/1.0 MB | 114/195 kB | 74/121 kB | 65/80 kB | 65/251 kBProgress (5): 0.2/1.0 MB | 118/195 kB | 74/121 kB | 65/80 kB | 65/251 kBProgress (5): 0.2/1.0 MB | 122/195 kB | 74/121 kB | 65/80 kB | 65/251 kBProgress (5): 0.2/1.0 MB | 126/195 kB | 74/121 kB | 65/80 kB | 65/251 kBProgress (5): 0.2/1.0 MB | 131/195 kB | 74/121 kB | 65/80 kB | 65/251 kBProgress (5): 0.2/1.0 MB | 131/195 kB | 74/121 kB | 65/80 kB | 69/251 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 74/121 kB | 65/80 kB | 69/251 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 78/121 kB | 65/80 kB | 69/251 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 82/121 kB | 65/80 kB | 69/251 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 82/121 kB | 65/80 kB | 73/251 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 82/121 kB | 65/80 kB | 77/251 kBProgress (5): 0.2/1.0 MB | 135/195 kB | 82/121 kB | 65/80 kB | 81/251 kBProgress (5): 0.2/1.0 MB | 139/195 kB | 82/121 kB | 65/80 kB | 81/251 kBProgress (5): 0.2/1.0 MB | 143/195 kB | 82/121 kB | 65/80 kB | 81/251 kBProgress (5): 0.2/1.0 MB | 143/195 kB | 82/121 kB | 65/80 kB | 81/251 kBProgress (5): 0.2/1.0 MB | 143/195 kB | 82/121 kB | 69/80 kB | 81/251 kBProgress (5): 0.2/1.0 MB | 143/195 kB | 82/121 kB | 69/80 kB | 81/251 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 82/121 kB | 69/80 kB | 81/251 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 82/121 kB | 69/80 kB | 81/251 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 86/121 kB | 69/80 kB | 81/251 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 86/121 kB | 69/80 kB | 81/251 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 90/121 kB | 69/80 kB | 81/251 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 90/121 kB | 69/80 kB | 85/251 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 90/121 kB | 73/80 kB | 85/251 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 90/121 kB | 73/80 kB | 90/251 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 90/121 kB | 77/80 kB | 90/251 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 90/121 kB | 77/80 kB | 94/251 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 94/121 kB | 77/80 kB | 94/251 kBProgress (5): 0.2/1.0 MB | 147/195 kB | 94/121 kB | 77/80 kB | 98/251 kBProgress (5): 0.2/1.0 MB | 151/195 kB | 94/121 kB | 77/80 kB | 98/251 kBProgress (5): 0.2/1.0 MB | 151/195 kB | 94/121 kB | 80 kB | 98/251 kB Progress (5): 0.2/1.0 MB | 155/195 kB | 94/121 kB | 80 kB | 98/251 kBProgress (5): 0.2/1.0 MB | 155/195 kB | 94/121 kB | 80 kB | 98/251 kBProgress (5): 0.3/1.0 MB | 155/195 kB | 94/121 kB | 80 kB | 98/251 kBProgress (5): 0.3/1.0 MB | 155/195 kB | 94/121 kB | 80 kB | 98/251 kBProgress (5): 0.3/1.0 MB | 155/195 kB | 94/121 kB | 80 kB | 98/251 kBProgress (5): 0.3/1.0 MB | 155/195 kB | 94/121 kB | 80 kB | 102/251 kBProgress (5): 0.3/1.0 MB | 155/195 kB | 94/121 kB | 80 kB | 106/251 kBProgress (5): 0.3/1.0 MB | 155/195 kB | 94/121 kB | 80 kB | 110/251 kBProgress (5): 0.3/1.0 MB | 155/195 kB | 98/121 kB | 80 kB | 110/251 kBProgress (5): 0.3/1.0 MB | 155/195 kB | 98/121 kB | 80 kB | 114/251 kBProgress (5): 0.3/1.0 MB | 159/195 kB | 98/121 kB | 80 kB | 114/251 kBProgress (5): 0.3/1.0 MB | 159/195 kB | 98/121 kB | 80 kB | 114/251 kBProgress (5): 0.3/1.0 MB | 163/195 kB | 98/121 kB | 80 kB | 114/251 kBProgress (5): 0.3/1.0 MB | 163/195 kB | 98/121 kB | 80 kB | 114/251 kBProgress (5): 0.3/1.0 MB | 163/195 kB | 98/121 kB | 80 kB | 114/251 kBProgress (5): 0.3/1.0 MB | 163/195 kB | 98/121 kB | 80 kB | 114/251 kBProgress (5): 0.3/1.0 MB | 163/195 kB | 98/121 kB | 80 kB | 118/251 kBProgress (5): 0.3/1.0 MB | 163/195 kB | 102/121 kB | 80 kB | 118/251 kBProgress (5): 0.3/1.0 MB | 163/195 kB | 102/121 kB | 80 kB | 122/251 kBProgress (5): 0.3/1.0 MB | 163/195 kB | 106/121 kB | 80 kB | 122/251 kBProgress (5): 0.3/1.0 MB | 163/195 kB | 106/121 kB | 80 kB | 126/251 kBProgress (5): 0.3/1.0 MB | 163/195 kB | 111/121 kB | 80 kB | 126/251 kBProgress (5): 0.3/1.0 MB | 163/195 kB | 111/121 kB | 80 kB | 131/251 kBProgress (5): 0.3/1.0 MB | 163/195 kB | 115/121 kB | 80 kB | 131/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact/2.0.4/maven-artifact-2.0.4.jar (80 kB at 2.1 MB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar
Progress (4): 0.3/1.0 MB | 163/195 kB | 115/121 kB | 131/251 kBProgress (4): 0.3/1.0 MB | 167/195 kB | 115/121 kB | 131/251 kBProgress (4): 0.3/1.0 MB | 167/195 kB | 119/121 kB | 131/251 kBProgress (4): 0.3/1.0 MB | 167/195 kB | 119/121 kB | 131/251 kBProgress (4): 0.3/1.0 MB | 171/195 kB | 119/121 kB | 131/251 kBProgress (4): 0.3/1.0 MB | 171/195 kB | 119/121 kB | 131/251 kBProgress (4): 0.3/1.0 MB | 176/195 kB | 119/121 kB | 131/251 kBProgress (4): 0.3/1.0 MB | 176/195 kB | 121 kB | 131/251 kB Progress (4): 0.3/1.0 MB | 176/195 kB | 121 kB | 131/251 kBProgress (4): 0.3/1.0 MB | 176/195 kB | 121 kB | 135/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 121 kB | 135/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 121 kB | 139/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 121 kB | 143/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 121 kB | 147/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 121 kB | 147/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 121 kB | 147/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 121 kB | 147/251 kBProgress (4): 0.3/1.0 MB | 180/195 kB | 121 kB | 147/251 kBProgress (4): 0.3/1.0 MB | 184/195 kB | 121 kB | 147/251 kBProgress (4): 0.3/1.0 MB | 188/195 kB | 121 kB | 147/251 kBProgress (4): 0.3/1.0 MB | 188/195 kB | 121 kB | 151/251 kBProgress (4): 0.3/1.0 MB | 192/195 kB | 121 kB | 151/251 kBProgress (4): 0.3/1.0 MB | 192/195 kB | 121 kB | 155/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 121 kB | 155/251 kB Progress (4): 0.3/1.0 MB | 195 kB | 121 kB | 159/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 121 kB | 163/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 121 kB | 163/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 121 kB | 163/251 kB Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/3.8.1/junit-3.8.1.jar (121 kB at 3.0 MB/s)
Progress (3): 0.3/1.0 MB | 195 kB | 163/251 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar
Progress (3): 0.3/1.0 MB | 195 kB | 163/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 167/251 kBProgress (3): 0.3/1.0 MB | 195 kB | 171/251 kBProgress (4): 0.3/1.0 MB | 195 kB | 171/251 kB | 4.1/12 kBProgress (4): 0.3/1.0 MB | 195 kB | 176/251 kB | 4.1/12 kBProgress (4): 0.3/1.0 MB | 195 kB | 176/251 kB | 7.7/12 kBProgress (4): 0.3/1.0 MB | 195 kB | 180/251 kB | 7.7/12 kBProgress (4): 0.3/1.0 MB | 195 kB | 180/251 kB | 12/12 kB Progress (4): 0.3/1.0 MB | 195 kB | 180/251 kB | 12 kB Progress (4): 0.3/1.0 MB | 195 kB | 180/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 195 kB | 180/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 195 kB | 180/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 195 kB | 180/251 kB | 12 kBProgress (4): 0.3/1.0 MB | 195 kB | 184/251 kB | 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-container-default/1.0-alpha-9/plexus-container-default-1.0-alpha-9.jar (195 kB at 4.1 MB/s)
Progress (3): 0.3/1.0 MB | 188/251 kB | 12 kBProgress (3): 0.3/1.0 MB | 192/251 kB | 12 kBProgress (3): 0.3/1.0 MB | 196/251 kB | 12 kBProgress (3): 0.3/1.0 MB | 196/251 kB | 12 kBProgress (3): 0.4/1.0 MB | 196/251 kB | 12 kBProgress (3): 0.4/1.0 MB | 196/251 kB | 12 kBProgress (3): 0.4/1.0 MB | 196/251 kB | 12 kBProgress (3): 0.4/1.0 MB | 200/251 kB | 12 kBProgress (3): 0.4/1.0 MB | 204/251 kB | 12 kBProgress (3): 0.4/1.0 MB | 204/251 kB | 12 kBProgress (3): 0.4/1.0 MB | 208/251 kB | 12 kBProgress (3): 0.4/1.0 MB | 208/251 kB | 12 kBProgress (3): 0.4/1.0 MB | 208/251 kB | 12 kBProgress (3): 0.4/1.0 MB | 212/251 kB | 12 kBProgress (3): 0.4/1.0 MB | 212/251 kB | 12 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant-launcher/1.7.1/ant-launcher-1.7.1.jar (12 kB at 248 kB/s)
Progress (2): 0.4/1.0 MB | 212/251 kBProgress (2): 0.4/1.0 MB | 217/251 kBProgress (2): 0.4/1.0 MB | 217/251 kBProgress (2): 0.4/1.0 MB | 221/251 kBProgress (2): 0.4/1.0 MB | 221/251 kBProgress (2): 0.4/1.0 MB | 225/251 kBProgress (2): 0.4/1.0 MB | 225/251 kBProgress (2): 0.4/1.0 MB | 229/251 kBProgress (2): 0.4/1.0 MB | 229/251 kBProgress (2): 0.4/1.0 MB | 233/251 kBProgress (2): 0.4/1.0 MB | 233/251 kBProgress (2): 0.4/1.0 MB | 237/251 kBProgress (2): 0.4/1.0 MB | 237/251 kBProgress (2): 0.4/1.0 MB | 241/251 kBProgress (2): 0.4/1.0 MB | 241/251 kBProgress (2): 0.4/1.0 MB | 245/251 kBProgress (2): 0.4/1.0 MB | 249/251 kBProgress (2): 0.4/1.0 MB | 251 kB Progress (2): 0.4/1.0 MB | 251 kBProgress (2): 0.4/1.0 MB | 251 kBProgress (2): 0.4/1.0 MB | 251 kBProgress (2): 0.4/1.0 MB | 251 kBProgress (2): 0.4/1.0 MB | 251 kBProgress (2): 0.4/1.0 MB | 251 kBProgress (2): 0.4/1.0 MB | 251 kBProgress (2): 0.4/1.0 MB | 251 kBProgress (2): 0.4/1.0 MB | 251 kBProgress (2): 0.5/1.0 MB | 251 kBProgress (2): 0.5/1.0 MB | 251 kBProgress (2): 0.5/1.0 MB | 251 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.6/plexus-utils-1.5.6.jar (251 kB at 4.6 MB/s)
Progress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (1): 0.5/1.0 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.5/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.6/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.1/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.7/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.2/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.8/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.3/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 0.9/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.4/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0/1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MB Progress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.5/1.3 MBProgress (2): 1.0 MB | 0.6/1.3 MBProgress (2): 1.0 MB | 0.6/1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.jar (1.0 MB at 11 MB/s)
Progress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.6/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.7/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.8/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 0.9/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.0/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.1/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.2/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3/1.3 MBProgress (1): 1.3 MB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/ant/ant/1.7.1/ant-1.7.1.jar (1.3 MB at 11 MB/s)
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en&gt;
     [echo] Build directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.16-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;:137:Inline literal start-string without end-string.
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 58.003 s
[e[1;34mINFOe[m] Finished at: 2019-06-03T22:31:27Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://build.geoserver.org/job/geoserver-master-live-docs/1833/display/redirect?page=changes&gt;
Changes:
[Jody Garnett] Fix GWC RESTIntegration test to work after recent Spring MVC fix
[...truncated 713 B...]
  at hudson.model.Executor.run(Executor.java:429)
ln builds/lastStableBuild /var/lib/jenkins/jobs/geoserver-master-live-docs/lastStable failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-master-live-docs/lastStable
  at sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:242)
  at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:108)
  at java.nio.file.Files.deleteIfExists(Files.java:1165)
  at hudson.Util.createSymlink(Util.java:1193)
  at hudson.model.Run.createSymlink(Run.java:1955)
  at hudson.model.Run.updateSymlinks(Run.java:1937)
  at hudson.model.Run.execute(Run.java:1814)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
  at hudson.model.ResourceController.execute(ResourceController.java:97)
Building remotely on i-0408a7466a12bf142 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-live-docs/ws/&gt;
No credentials specified
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 422c153c5bbce2231e7bfd7427a8396067f614e1 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 422c153c5bbce2231e7bfd7427a8396067f614e1
Commit message: "Fix GWC RESTIntegration test to work after recent Spring MVC fix"
> git rev-list --no-walk 9b710fac8b676b893506a89cc90d49beb2bdfa8a # timeout=10
[geoserver-master-live-docs] $ mvn -f doc/en/pom.xml clean compile
[e[1;34mINFOe[m] Scanning for projects...
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m----------------------< e[0;36morg.geoserver.en:gs-docse[0;1m >----------------------e[m
[e[1;34mINFOe[m] e[1mBuilding GeoServer English Documentation 2.16-SNAPSHOTe[m
[e[1;34mINFOe[m] e[1m--------------------------------[ pom ]---------------------------------e[m
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-clean-plugin:2.5:cleane[m e[1m(default-clean)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] Deleting <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(coverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coverages.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(coverageStores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coveragestores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coveragestores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coveragestores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(datastores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/datastores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/datastores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/datastores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(featureTypes)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml&gt;
[e[1;33mWARNINGe[m] generated unique operationId `getFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `putFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `postFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `deleteFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `getFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `putFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `postFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `deleteFeatureType_0`
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/featuretypes/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/featuretypes/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(fonts)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 49.046 s
[e[1;34mINFOe[m] Finished at: 2019-06-04T00:45:58Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
See <http://build.geoserver.org/job/geoserver-master-live-docs/1834/display/redirect?page=changes&gt;
Changes:
[niels] GEOS-9125 improve indexed property support in catalogpropertyaccessor
[...truncated 256.16 KB...]
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0/maven-profile-2.0.jar
Progress (3): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kBProgress (3): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kBProgress (3): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kBProgress (3): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kBProgress (3): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kBProgress (3): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kBProgress (3): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kBProgress (3): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kBProgress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 4.1/105 kBProgress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 7.7/105 kBProgress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 12/105 kB Progress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 16/105 kBProgress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 16/105 kBProgress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 16/105 kBProgress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 16/105 kBProgress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 16/105 kBProgress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 20/105 kBProgress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 24/105 kBProgress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 28/105 kBProgress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.3/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4/2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kBProgress (4): 2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kB Progress (5): 2.4 MB | 0.6/1.2 MB | 20/23 kB | 32/105 kB | 4.1/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 20/23 kB | 36/105 kB | 4.1/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 36/105 kB | 4.1/30 kB Progress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 40/105 kB | 4.1/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 40/105 kB | 7.7/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 40/105 kB | 7.7/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 45/105 kB | 7.7/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 49/105 kB | 7.7/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 53/105 kB | 7.7/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 57/105 kB | 7.7/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 61/105 kB | 7.7/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 65/105 kB | 7.7/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 69/105 kB | 7.7/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 73/105 kB | 7.7/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 77/105 kB | 7.7/30 kBProgress (5): 2.4 MB | 0.6/1.2 MB | 23 kB | 81/105 kB | 7.7/30 kB Downloaded from central: https://repo.maven.apache.org/maven2/io/swagger/swagger-codegen/2.2.2/swagger-codegen-2.2.2.jar (2.4 MB at 4.5 MB/s)
Progress (4): 0.6/1.2 MB | 23 kB | 81/105 kB | 7.7/30 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-descriptor/2.0/maven-plugin-descriptor-2.0.jar
Progress (4): 0.6/1.2 MB | 23 kB | 81/105 kB | 7.7/30 kBProgress (4): 0.6/1.2 MB | 23 kB | 81/105 kB | 7.7/30 kBProgress (4): 0.6/1.2 MB | 23 kB | 85/105 kB | 7.7/30 kBProgress (4): 0.6/1.2 MB | 23 kB | 90/105 kB | 7.7/30 kBProgress (4): 0.6/1.2 MB | 23 kB | 94/105 kB | 7.7/30 kBProgress (4): 0.6/1.2 MB | 23 kB | 98/105 kB | 7.7/30 kBProgress (4): 0.6/1.2 MB | 23 kB | 102/105 kB | 7.7/30 kBProgress (4): 0.6/1.2 MB | 23 kB | 105 kB | 7.7/30 kB Progress (4): 0.6/1.2 MB | 23 kB | 105 kB | 12/30 kB Progress (4): 0.6/1.2 MB | 23 kB | 105 kB | 16/30 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-project/2.0/maven-project-2.0.jar (105 kB at 192 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/felix/maven-bundle-plugin/2.3.4/maven-bundle-plugin-2.3.4.jar
Progress (3): 0.6/1.2 MB | 23 kB | 20/30 kBProgress (3): 0.6/1.2 MB | 23 kB | 24/30 kBProgress (4): 0.6/1.2 MB | 23 kB | 24/30 kB | 4.1/33 kBProgress (4): 0.6/1.2 MB | 23 kB | 28/30 kB | 4.1/33 kBProgress (4): 0.6/1.2 MB | 23 kB | 28/30 kB | 7.7/33 kBProgress (4): 0.6/1.2 MB | 23 kB | 28/30 kB | 12/33 kB Progress (4): 0.6/1.2 MB | 23 kB | 28/30 kB | 16/33 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-tools-api/2.0/maven-plugin-tools-api-2.0.jar (23 kB at 41 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/biz/aQute/bndlib/1.15.0/bndlib-1.15.0.jar
Progress (3): 0.6/1.2 MB | 28/30 kB | 20/33 kBProgress (3): 0.6/1.2 MB | 28/30 kB | 24/33 kBProgress (3): 0.6/1.2 MB | 28/30 kB | 28/33 kBProgress (3): 0.6/1.2 MB | 28/30 kB | 32/33 kBProgress (3): 0.6/1.2 MB | 28/30 kB | 33 kB Progress (4): 0.6/1.2 MB | 28/30 kB | 33 kB | 4.1/117 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 33 kB | 7.7/117 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 33 kB | 12/117 kB Progress (4): 0.6/1.2 MB | 28/30 kB | 33 kB | 16/117 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 33 kB | 20/117 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 33 kB | 24/117 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 33 kB | 28/117 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 33 kB | 32/117 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 33 kB | 36/117 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 33 kB | 40/117 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 33 kB | 45/117 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 33 kB | 49/117 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-descriptor/2.0/maven-plugin-descriptor-2.0.jar (33 kB at 60 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/net/sf/kxml/kxml2/2.2.2/kxml2-2.2.2.jar
Progress (4): 0.6/1.2 MB | 28/30 kB | 49/117 kB | 4.1/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 49/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 53/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 57/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 61/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 65/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 69/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 73/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 77/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 81/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 85/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 90/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 90/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 94/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 98/117 kB | 7.7/548 kBProgress (4): 0.6/1.2 MB | 28/30 kB | 98/117 kB | 12/548 kB Progress (5): 0.6/1.2 MB | 28/30 kB | 98/117 kB | 12/548 kB | 4.1/43 kBProgress (5): 0.6/1.2 MB | 28/30 kB | 98/117 kB | 12/548 kB | 7.7/43 kBProgress (5): 0.6/1.2 MB | 30 kB | 98/117 kB | 12/548 kB | 7.7/43 kB Progress (5): 0.6/1.2 MB | 30 kB | 98/117 kB | 12/548 kB | 12/43 kB Progress (5): 0.6/1.2 MB | 30 kB | 98/117 kB | 12/548 kB | 16/43 kBProgress (5): 0.6/1.2 MB | 30 kB | 102/117 kB | 12/548 kB | 16/43 kBProgress (5): 0.6/1.2 MB | 30 kB | 106/117 kB | 12/548 kB | 16/43 kBProgress (5): 0.6/1.2 MB | 30 kB | 110/117 kB | 12/548 kB | 16/43 kBProgress (5): 0.6/1.2 MB | 30 kB | 110/117 kB | 12/548 kB | 20/43 kBProgress (5): 0.6/1.2 MB | 30 kB | 110/117 kB | 16/548 kB | 20/43 kBProgress (5): 0.6/1.2 MB | 30 kB | 110/117 kB | 20/548 kB | 20/43 kBProgress (5): 0.6/1.2 MB | 30 kB | 110/117 kB | 20/548 kB | 20/43 kBProgress (5): 0.6/1.2 MB | 30 kB | 110/117 kB | 20/548 kB | 24/43 kBProgress (5): 0.6/1.2 MB | 30 kB | 114/117 kB | 20/548 kB | 24/43 kBProgress (5): 0.6/1.2 MB | 30 kB | 114/117 kB | 20/548 kB | 28/43 kBProgress (5): 0.6/1.2 MB | 30 kB | 114/117 kB | 20/548 kB | 32/43 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-profile/2.0/maven-profile-2.0.jar (30 kB at 55 kB/s)
Progress (4): 0.6/1.2 MB | 117 kB | 20/548 kB | 32/43 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/felix/org.apache.felix.bundlerepository/1.6.2/org.apache.felix.bundlerepository-1.6.2.jar
Progress (4): 0.6/1.2 MB | 117 kB | 20/548 kB | 32/43 kBProgress (4): 0.6/1.2 MB | 117 kB | 20/548 kB | 36/43 kBProgress (4): 0.6/1.2 MB | 117 kB | 24/548 kB | 36/43 kBProgress (4): 0.6/1.2 MB | 117 kB | 28/548 kB | 36/43 kBProgress (4): 0.6/1.2 MB | 117 kB | 28/548 kB | 36/43 kBProgress (4): 0.6/1.2 MB | 117 kB | 32/548 kB | 36/43 kBProgress (4): 0.6/1.2 MB | 117 kB | 32/548 kB | 36/43 kBProgress (4): 0.6/1.2 MB | 117 kB | 32/548 kB | 36/43 kBProgress (4): 0.6/1.2 MB | 117 kB | 32/548 kB | 40/43 kBProgress (4): 0.6/1.2 MB | 117 kB | 32/548 kB | 43 kB Progress (4): 0.6/1.2 MB | 117 kB | 36/548 kB | 43 kBProgress (4): 0.6/1.2 MB | 117 kB | 40/548 kB | 43 kBProgress (4): 0.6/1.2 MB | 117 kB | 40/548 kB | 43 kBProgress (4): 0.6/1.2 MB | 117 kB | 40/548 kB | 43 kBProgress (4): 0.6/1.2 MB | 117 kB | 45/548 kB | 43 kBProgress (4): 0.6/1.2 MB | 117 kB | 49/548 kB | 43 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/felix/maven-bundle-plugin/2.3.4/maven-bundle-plugin-2.3.4.jar (117 kB at 209 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/osgi/org.osgi.core/4.1.0/org.osgi.core-4.1.0.jar
Progress (3): 0.6/1.2 MB | 53/548 kB | 43 kBProgress (3): 0.6/1.2 MB | 57/548 kB | 43 kBProgress (3): 0.6/1.2 MB | 61/548 kB | 43 kBProgress (3): 0.6/1.2 MB | 61/548 kB | 43 kBProgress (3): 0.6/1.2 MB | 65/548 kB | 43 kBProgress (3): 0.6/1.2 MB | 65/548 kB | 43 kBProgress (3): 0.6/1.2 MB | 65/548 kB | 43 kBProgress (3): 0.6/1.2 MB | 65/548 kB | 43 kBProgress (3): 0.6/1.2 MB | 69/548 kB | 43 kB Downloaded from central: https://repo.maven.apache.org/maven2/net/sf/kxml/kxml2/2.2.2/kxml2-2.2.2.jar (43 kB at 77 kB/s)
Progress (2): 0.6/1.2 MB | 69/548 kB Downloading from central: https://repo.maven.apache.org/maven2/org/easymock/easymock/2.4/easymock-2.4.jar
Progress (2): 0.6/1.2 MB | 69/548 kBProgress (2): 0.6/1.2 MB | 73/548 kBProgress (2): 0.6/1.2 MB | 77/548 kBProgress (2): 0.6/1.2 MB | 81/548 kBProgress (2): 0.6/1.2 MB | 81/548 kBProgress (2): 0.6/1.2 MB | 81/548 kBProgress (2): 0.7/1.2 MB | 81/548 kBProgress (2): 0.7/1.2 MB | 81/548 kBProgress (2): 0.7/1.2 MB | 85/548 kBProgress (2): 0.7/1.2 MB | 90/548 kBProgress (2): 0.7/1.2 MB | 94/548 kBProgress (2): 0.7/1.2 MB | 98/548 kBProgress (3): 0.7/1.2 MB | 98/548 kB | 2.2/81 kBProgress (3): 0.7/1.2 MB | 98/548 kB | 2.2/81 kBProgress (3): 0.7/1.2 MB | 98/548 kB | 5.0/81 kBProgress (3): 0.7/1.2 MB | 98/548 kB | 5.0/81 kBProgress (3): 0.7/1.2 MB | 98/548 kB | 5.0/81 kBProgress (3): 0.7/1.2 MB | 98/548 kB | 5.0/81 kBProgress (3): 0.7/1.2 MB | 98/548 kB | 7.7/81 kBProgress (3): 0.7/1.2 MB | 102/548 kB | 7.7/81 kBProgress (3): 0.7/1.2 MB | 102/548 kB | 10/81 kB Progress (4): 0.7/1.2 MB | 102/548 kB | 10/81 kB | 4.1/151 kBProgress (4): 0.7/1.2 MB | 102/548 kB | 10/81 kB | 4.1/151 kBProgress (4): 0.7/1.2 MB | 102/548 kB | 13/81 kB | 4.1/151 kBProgress (4): 0.7/1.2 MB | 102/548 kB | 13/81 kB | 7.7/151 kBProgress (4): 0.7/1.2 MB | 102/548 kB | 13/81 kB | 12/151 kB Progress (4): 0.7/1.2 MB | 102/548 kB | 16/81 kB | 12/151 kBProgress (4): 0.7/1.2 MB | 102/548 kB | 16/81 kB | 16/151 kBProgress (4): 0.7/1.2 MB | 102/548 kB | 19/81 kB | 16/151 kBProgress (4): 0.7/1.2 MB | 102/548 kB | 21/81 kB | 16/151 kBProgress (4): 0.7/1.2 MB | 102/548 kB | 21/81 kB | 20/151 kBProgress (4): 0.7/1.2 MB | 106/548 kB | 21/81 kB | 20/151 kBProgress (4): 0.7/1.2 MB | 106/548 kB | 21/81 kB | 24/151 kBProgress (4): 0.7/1.2 MB | 106/548 kB | 24/81 kB | 24/151 kBProgress (5): 0.7/1.2 MB | 106/548 kB | 24/81 kB | 24/151 kB | 4.1/163 kBProgress (5): 0.7/1.2 MB | 106/548 kB | 24/81 kB | 24/151 kB | 4.1/163 kBProgress (5): 0.7/1.2 MB | 106/548 kB | 24/81 kB | 24/151 kB | 7.7/163 kBProgress (5): 0.7/1.2 MB | 106/548 kB | 24/81 kB | 24/151 kB | 7.7/163 kBProgress (5): 0.7/1.2 MB | 106/548 kB | 24/81 kB | 28/151 kB | 7.7/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 24/81 kB | 28/151 kB | 7.7/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 24/81 kB | 32/151 kB | 7.7/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 24/81 kB | 32/151 kB | 7.7/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 24/81 kB | 32/151 kB | 12/163 kB Progress (5): 0.7/1.2 MB | 110/548 kB | 27/81 kB | 32/151 kB | 12/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 27/81 kB | 32/151 kB | 16/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 30/81 kB | 32/151 kB | 16/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 30/81 kB | 36/151 kB | 16/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 32/81 kB | 36/151 kB | 16/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 32/81 kB | 36/151 kB | 20/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 32/81 kB | 36/151 kB | 24/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 32/81 kB | 36/151 kB | 28/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 32/81 kB | 36/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 36/81 kB | 36/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 110/548 kB | 40/81 kB | 36/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 114/548 kB | 40/81 kB | 36/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 114/548 kB | 45/81 kB | 36/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 114/548 kB | 45/81 kB | 36/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 114/548 kB | 45/81 kB | 40/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 114/548 kB | 45/81 kB | 40/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 114/548 kB | 45/81 kB | 45/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 114/548 kB | 45/81 kB | 45/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 114/548 kB | 45/81 kB | 49/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 118/548 kB | 45/81 kB | 49/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 118/548 kB | 49/81 kB | 49/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 49/81 kB | 49/151 kB | 32/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 49/81 kB | 49/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 49/81 kB | 53/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 49/81 kB | 53/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 49/81 kB | 57/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 49/81 kB | 61/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 49/81 kB | 65/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 53/81 kB | 65/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 57/81 kB | 65/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 61/81 kB | 65/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 65/81 kB | 65/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 65/81 kB | 65/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 65/81 kB | 65/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 65/81 kB | 69/151 kB | 36/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 65/81 kB | 69/151 kB | 40/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 65/81 kB | 73/151 kB | 40/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 65/81 kB | 73/151 kB | 45/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 65/81 kB | 73/151 kB | 49/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 69/81 kB | 73/151 kB | 49/163 kBProgress (5): 0.7/1.2 MB | 122/548 kB | 73/81 kB | 73/151 kB | 49/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 73/81 kB | 73/151 kB | 49/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 73/151 kB | 49/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 77/151 kB | 49/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 81/151 kB | 49/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 81/151 kB | 53/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 81/151 kB | 57/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 81/151 kB | 61/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 81/151 kB | 65/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 85/151 kB | 65/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 90/151 kB | 65/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 94/151 kB | 65/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 98/151 kB | 65/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 98/151 kB | 69/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 98/151 kB | 73/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 98/151 kB | 77/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 98/151 kB | 81/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 102/151 kB | 81/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 106/151 kB | 81/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 110/151 kB | 81/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 114/151 kB | 81/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 114/151 kB | 85/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 114/151 kB | 90/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 114/151 kB | 94/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 114/151 kB | 98/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 118/151 kB | 98/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 122/151 kB | 98/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 126/151 kB | 98/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 131/151 kB | 98/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 131/151 kB | 102/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 131/151 kB | 106/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 131/151 kB | 110/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 131/151 kB | 114/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 131/151 kB | 114/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 114/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 114/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 118/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.7/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 77/81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 126/548 kB | 81 kB | 135/151 kB | 122/163 kB Progress (5): 0.8/1.2 MB | 126/548 kB | 81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 131/548 kB | 81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 131/548 kB | 81 kB | 135/151 kB | 122/163 kBProgress (5): 0.8/1.2 MB | 131/548 kB | 81 kB | 135/151 kB | 126/163 kBProgress (5): 0.8/1.2 MB | 131/548 kB | 81 kB | 139/151 kB | 126/163 kBProgress (5): 0.8/1.2 MB | 131/548 kB | 81 kB | 139/151 kB | 131/163 kBProgress (5): 0.8/1.2 MB | 131/548 kB | 81 kB | 143/151 kB | 131/163 kBProgress (5): 0.8/1.2 MB | 131/548 kB | 81 kB | 147/151 kB | 131/163 kBProgress (5): 0.8/1.2 MB | 131/548 kB | 81 kB | 151 kB | 131/163 kB Progress (5): 0.8/1.2 MB | 135/548 kB | 81 kB | 151 kB | 131/163 kBProgress (5): 0.8/1.2 MB | 139/548 kB | 81 kB | 151 kB | 131/163 kBProgress (5): 0.8/1.2 MB | 143/548 kB | 81 kB | 151 kB | 131/163 kBProgress (5): 0.8/1.2 MB | 147/548 kB | 81 kB | 151 kB | 131/163 kBProgress (5): 0.8/1.2 MB | 147/548 kB | 81 kB | 151 kB | 131/163 kBProgress (5): 0.8/1.2 MB | 147/548 kB | 81 kB | 151 kB | 135/163 kBProgress (5): 0.8/1.2 MB | 147/548 kB | 81 kB | 151 kB | 139/163 kBProgress (5): 0.8/1.2 MB | 147/548 kB | 81 kB | 151 kB | 143/163 kBProgress (5): 0.8/1.2 MB | 147/548 kB | 81 kB | 151 kB | 147/163 kBProgress (5): 0.8/1.2 MB | 147/548 kB | 81 kB | 151 kB | 147/163 kBProgress (5): 0.8/1.2 MB | 147/548 kB | 81 kB | 151 kB | 147/163 kBProgress (5): 0.8/1.2 MB | 151/548 kB | 81 kB | 151 kB | 147/163 kBProgress (5): 0.8/1.2 MB | 151/548 kB | 81 kB | 151 kB | 147/163 kBProgress (5): 0.8/1.2 MB | 155/548 kB | 81 kB | 151 kB | 147/163 kBProgress (5): 0.8/1.2 MB | 155/548 kB | 81 kB | 151 kB | 147/163 kBProgress (5): 0.8/1.2 MB | 159/548 kB | 81 kB | 151 kB | 147/163 kBProgress (5): 0.8/1.2 MB | 163/548 kB | 81 kB | 151 kB | 147/163 kBProgress (5): 0.8/1.2 MB | 163/548 kB | 81 kB | 151 kB | 151/163 kBProgress (5): 0.8/1.2 MB | 163/548 kB | 81 kB | 151 kB | 155/163 kBProgress (5): 0.8/1.2 MB | 163/548 kB | 81 kB | 151 kB | 159/163 kBProgress (5): 0.8/1.2 MB | 163/548 kB | 81 kB | 151 kB | 159/163 kBProgress (5): 0.8/1.2 MB | 163/548 kB | 81 kB | 151 kB | 159/163 kBProgress (5): 0.8/1.2 MB | 163/548 kB | 81 kB | 151 kB | 163/163 kBProgress (5): 0.8/1.2 MB | 163/548 kB | 81 kB | 151 kB | 163/163 kBProgress (5): 0.8/1.2 MB | 163/548 kB | 81 kB | 151 kB | 163 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/felix/org.apache.felix.bundlerepository/1.6.2/org.apache.felix.bundlerepository-1.6.2.jar (151 kB at 259 kB/s)
Downloaded from central: https://repo.maven.apache.org/maven2/org/easymock/easymock/2.4/easymock-2.4.jar (81 kB at 140 kB/s)
Progress (3): 0.8/1.2 MB | 167/548 kB | 163 kBProgress (3): 0.8/1.2 MB | 171/548 kB | 163 kBProgress (3): 0.8/1.2 MB | 176/548 kB | 163 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/felix/org.osgi.core/1.0.0/org.osgi.core-1.0.0.jar
Progress (3): 0.8/1.2 MB | 180/548 kB | 163 kBProgress (3): 0.9/1.2 MB | 180/548 kB | 163 kBProgress (3): 0.9/1.2 MB | 184/548 kB | 163 kBProgress (3): 0.9/1.2 MB | 188/548 kB | 163 kBProgress (3): 0.9/1.2 MB | 192/548 kB | 163 kBProgress (3): 0.9/1.2 MB | 192/548 kB | 163 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/felix/org.osgi.service.obr/1.0.1/org.osgi.service.obr-1.0.1.jar
Progress (3): 0.9/1.2 MB | 192/548 kB | 163 kBProgress (3): 0.9/1.2 MB | 192/548 kB | 163 kBProgress (3): 0.9/1.2 MB | 192/548 kB | 163 kBProgress (3): 0.9/1.2 MB | 196/548 kB | 163 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/osgi/org.osgi.core/4.1.0/org.osgi.core-4.1.0.jar (163 kB at 280 kB/s)
Progress (2): 0.9/1.2 MB | 196/548 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-archiver/2.2/maven-archiver-2.2.jar
Progress (2): 0.9/1.2 MB | 196/548 kBProgress (2): 0.9/1.2 MB | 196/548 kBProgress (2): 0.9/1.2 MB | 196/548 kBProgress (3): 0.9/1.2 MB | 196/548 kB | 4.1/61 kBProgress (3): 0.9/1.2 MB | 196/548 kB | 7.7/61 kBProgress (3): 0.9/1.2 MB | 200/548 kB | 7.7/61 kBProgress (3): 0.9/1.2 MB | 200/548 kB | 12/61 kB Progress (3): 0.9/1.2 MB | 204/548 kB | 12/61 kBProgress (3): 0.9/1.2 MB | 204/548 kB | 16/61 kBProgress (3): 0.9/1.2 MB | 208/548 kB | 16/61 kBProgress (3): 0.9/1.2 MB | 212/548 kB | 16/61 kBProgress (3): 0.9/1.2 MB | 212/548 kB | 16/61 kBProgress (3): 0.9/1.2 MB | 212/548 kB | 16/61 kBProgress (3): 0.9/1.2 MB | 212/548 kB | 16/61 kBProgress (3): 0.9/1.2 MB | 212/548 kB | 16/61 kBProgress (3): 0.9/1.2 MB | 212/548 kB | 20/61 kBProgress (3): 0.9/1.2 MB | 217/548 kB | 20/61 kBProgress (3): 0.9/1.2 MB | 217/548 kB | 24/61 kBProgress (3): 0.9/1.2 MB | 221/548 kB | 24/61 kBProgress (3): 0.9/1.2 MB | 221/548 kB | 28/61 kBProgress (3): 0.9/1.2 MB | 225/548 kB | 28/61 kBProgress (3): 0.9/1.2 MB | 225/548 kB | 32/61 kBProgress (3): 0.9/1.2 MB | 229/548 kB | 32/61 kBProgress (3): 0.9/1.2 MB | 229/548 kB | 32/61 kBProgress (4): 0.9/1.2 MB | 229/548 kB | 32/61 kB | 4.1/10 kBProgress (4): 0.9/1.2 MB | 229/548 kB | 32/61 kB | 4.1/10 kBProgress (4): 0.9/1.2 MB | 229/548 kB | 32/61 kB | 7.7/10 kBProgress (4): 0.9/1.2 MB | 229/548 kB | 32/61 kB | 7.7/10 kBProgress (4): 0.9/1.2 MB | 229/548 kB | 32/61 kB | 10 kB Progress (4): 0.9/1.2 MB | 229/548 kB | 32/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 233/548 kB | 32/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 237/548 kB | 32/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 241/548 kB | 32/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 245/548 kB | 32/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 245/548 kB | 36/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 245/548 kB | 40/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 245/548 kB | 45/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 245/548 kB | 45/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 245/548 kB | 49/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 245/548 kB | 49/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 245/548 kB | 49/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 245/548 kB | 49/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 249/548 kB | 49/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 253/548 kB | 49/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 258/548 kB | 49/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 262/548 kB | 49/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 262/548 kB | 53/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 262/548 kB | 57/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 262/548 kB | 61/61 kB | 10 kBProgress (4): 0.9/1.2 MB | 262/548 kB | 61 kB | 10 kB Progress (4): 0.9/1.2 MB | 262/548 kB | 61 kB | 10 kBProgress (4): 0.9/1.2 MB | 262/548 kB | 61 kB | 10 kBProgress (4): 0.9/1.2 MB | 262/548 kB | 61 kB | 10 kBProgress (4): 0.9/1.2 MB | 262/548 kB | 61 kB | 10 kBProgress (4): 0.9/1.2 MB | 266/548 kB | 61 kB | 10 kBProgress (4): 0.9/1.2 MB | 270/548 kB | 61 kB | 10 kBProgress (4): 0.9/1.2 MB | 274/548 kB | 61 kB | 10 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-archiver/2.2/maven-archiver-2.2.jar (10 kB at 17 kB/s)
Progress (3): 0.9/1.2 MB | 278/548 kB | 61 kB Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.7/maven-artifact-manager-2.0.7.jar
Progress (3): 1.0/1.2 MB | 278/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 278/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 278/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 278/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 282/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 286/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 290/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 294/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 294/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 294/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 294/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 294/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 298/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 303/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 307/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 311/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 311/548 kB | 61 kBProgress (3): 1.0/1.2 MB | 311/548 kB | 61 kBProgress (4): 1.0/1.2 MB | 311/548 kB | 61 kB | 4.1/57 kBProgress (4): 1.0/1.2 MB | 311/548 kB | 61 kB | 4.1/57 kBProgress (4): 1.0/1.2 MB | 311/548 kB | 61 kB | 7.7/57 kBProgress (4): 1.0/1.2 MB | 311/548 kB | 61 kB | 7.7/57 kBProgress (4): 1.0/1.2 MB | 311/548 kB | 61 kB | 12/57 kB Progress (4): 1.0/1.2 MB | 315/548 kB | 61 kB | 12/57 kBProgress (4): 1.0/1.2 MB | 315/548 kB | 61 kB | 16/57 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/felix/org.osgi.core/1.0.0/org.osgi.core-1.0.0.jar (61 kB at 103 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/shared/maven-dependency-tree/1.2/maven-dependency-tree-1.2.jar
Progress (3): 1.0/1.2 MB | 315/548 kB | 16/57 kBProgress (3): 1.0/1.2 MB | 315/548 kB | 16/57 kBProgress (3): 1.0/1.2 MB | 315/548 kB | 16/57 kBProgress (3): 1.0/1.2 MB | 315/548 kB | 16/57 kBProgress (4): 1.0/1.2 MB | 315/548 kB | 16/57 kB | 4.1/11 kBProgress (4): 1.0/1.2 MB | 315/548 kB | 16/57 kB | 7.7/11 kBProgress (4): 1.0/1.2 MB | 315/548 kB | 16/57 kB | 11 kB Progress (4): 1.0/1.2 MB | 315/548 kB | 16/57 kB | 11 kBProgress (4): 1.0/1.2 MB | 319/548 kB | 16/57 kB | 11 kBProgress (4): 1.0/1.2 MB | 323/548 kB | 16/57 kB | 11 kBProgress (4): 1.0/1.2 MB | 327/548 kB | 16/57 kB | 11 kBProgress (4): 1.0/1.2 MB | 327/548 kB | 16/57 kB | 11 kBProgress (4): 1.0/1.2 MB | 327/548 kB | 20/57 kB | 11 kBProgress (4): 1.0/1.2 MB | 327/548 kB | 20/57 kB | 11 kBProgress (4): 1.0/1.2 MB | 327/548 kB | 20/57 kB | 11 kBProgress (4): 1.0/1.2 MB | 327/548 kB | 24/57 kB | 11 kBProgress (4): 1.0/1.2 MB | 331/548 kB | 24/57 kB | 11 kBProgress (4): 1.0/1.2 MB | 335/548 kB | 24/57 kB | 11 kBProgress (5): 1.0/1.2 MB | 335/548 kB | 24/57 kB | 11 kB | 4.1/35 kBProgress (5): 1.0/1.2 MB | 335/548 kB | 28/57 kB | 11 kB | 4.1/35 kBProgress (5): 1.0/1.2 MB | 335/548 kB | 28/57 kB | 11 kB | 7.7/35 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/felix/org.osgi.service.obr/1.0.1/org.osgi.service.obr-1.0.1.jar (11 kB at 18 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-archiver/1.0-alpha-7/plexus-archiver-1.0-alpha-7.jar
Progress (4): 1.0/1.2 MB | 335/548 kB | 32/57 kB | 7.7/35 kBProgress (4): 1.0/1.2 MB | 339/548 kB | 32/57 kB | 7.7/35 kBProgress (4): 1.0/1.2 MB | 344/548 kB | 32/57 kB | 7.7/35 kBProgress (4): 1.0/1.2 MB | 344/548 kB | 32/57 kB | 7.7/35 kBProgress (4): 1.0/1.2 MB | 344/548 kB | 32/57 kB | 7.7/35 kBProgress (4): 1.0/1.2 MB | 344/548 kB | 32/57 kB | 7.7/35 kBProgress (4): 1.0/1.2 MB | 344/548 kB | 32/57 kB | 7.7/35 kBProgress (4): 1.0/1.2 MB | 344/548 kB | 36/57 kB | 7.7/35 kBProgress (4): 1.0/1.2 MB | 344/548 kB | 40/57 kB | 7.7/35 kBProgress (4): 1.0/1.2 MB | 344/548 kB | 40/57 kB | 12/35 kB Progress (4): 1.0/1.2 MB | 344/548 kB | 45/57 kB | 12/35 kBProgress (4): 1.0/1.2 MB | 344/548 kB | 45/57 kB | 16/35 kBProgress (4): 1.0/1.2 MB | 344/548 kB | 49/57 kB | 16/35 kBProgress (4): 1.1/1.2 MB | 344/548 kB | 49/57 kB | 16/35 kBProgress (4): 1.1/1.2 MB | 344/548 kB | 49/57 kB | 16/35 kBProgress (4): 1.1/1.2 MB | 344/548 kB | 49/57 kB | 16/35 kBProgress (4): 1.1/1.2 MB | 344/548 kB | 53/57 kB | 16/35 kBProgress (4): 1.1/1.2 MB | 344/548 kB | 57 kB | 16/35 kB Progress (4): 1.1/1.2 MB | 348/548 kB | 57 kB | 16/35 kBProgress (4): 1.1/1.2 MB | 348/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 348/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 352/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 356/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 360/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 360/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 360/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 360/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 360/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 364/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 368/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 372/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 376/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 376/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 376/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 376/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 376/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 380/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 384/548 kB | 57 kB | 20/35 kBProgress (4): 1.1/1.2 MB | 384/548 kB | 57 kB | 24/35 kBProgress (4): 1.1/1.2 MB | 384/548 kB | 57 kB | 24/35 kBProgress (4): 1.1/1.2 MB | 384/548 kB | 57 kB | 28/35 kBProgress (4): 1.1/1.2 MB | 384/548 kB | 57 kB | 28/35 kBProgress (4): 1.1/1.2 MB | 384/548 kB | 57 kB | 28/35 kBProgress (4): 1.1/1.2 MB | 384/548 kB | 57 kB | 28/35 kBProgress (4): 1.1/1.2 MB | 389/548 kB | 57 kB | 28/35 kBProgress (4): 1.1/1.2 MB | 389/548 kB | 57 kB | 32/35 kBProgress (4): 1.1/1.2 MB | 393/548 kB | 57 kB | 32/35 kBProgress (5): 1.1/1.2 MB | 393/548 kB | 57 kB | 32/35 kB | 4.1/142 kBProgress (5): 1.1/1.2 MB | 393/548 kB | 57 kB | 35 kB | 4.1/142 kB Progress (5): 1.1/1.2 MB | 393/548 kB | 57 kB | 35 kB | 7.7/142 kBProgress (5): 1.1/1.2 MB | 393/548 kB | 57 kB | 35 kB | 12/142 kB Progress (5): 1.1/1.2 MB | 393/548 kB | 57 kB | 35 kB | 12/142 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.7/maven-artifact-manager-2.0.7.jar (57 kB at 94 kB/s)
Downloading from central: https://repo.maven.apache.org/maven2/org/slf4j/slf4j-ext/1.7.12/slf4j-ext-1.7.12.jar
Progress (4): 1.1/1.2 MB | 397/548 kB | 35 kB | 12/142 kBProgress (4): 1.1/1.2 MB | 401/548 kB | 35 kB | 12/142 kBProgress (4): 1.1/1.2 MB | 405/548 kB | 35 kB | 12/142 kBProgress (4): 1.1/1.2 MB | 409/548 kB | 35 kB | 12/142 kBProgress (4): 1.1/1.2 MB | 413/548 kB | 35 kB | 12/142 kBProgress (4): 1.1/1.2 MB | 417/548 kB | 35 kB | 12/142 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/shared/maven-dependency-tree/1.2/maven-dependency-tree-1.2.jar (35 kB at 58 kB/s)
Progress (3): 1.1/1.2 MB | 421/548 kB | 12/142 kBProgress (3): 1.1/1.2 MB | 425/548 kB | 12/142 kBProgress (4): 1.1/1.2 MB | 425/548 kB | 12/142 kB | 4.1/43 kBProgress (4): 1.1/1.2 MB | 425/548 kB | 12/142 kB | 7.7/43 kBProgress (4): 1.1/1.2 MB | 425/548 kB | 12/142 kB | 12/43 kB Progress (4): 1.1/1.2 MB | 425/548 kB | 12/142 kB | 16/43 kBProgress (4): 1.1/1.2 MB | 425/548 kB | 16/142 kB | 16/43 kBProgress (4): 1.1/1.2 MB | 430/548 kB | 16/142 kB | 16/43 kBProgress (4): 1.1/1.2 MB | 430/548 kB | 16/142 kB | 20/43 kB Downloading from central: https://repo.maven.apache.org/maven2/ch/qos/cal10n/cal10n-api/0.8.1/cal10n-api-0.8.1.jar
Progress (4): 1.1/1.2 MB | 430/548 kB | 16/142 kB | 20/43 kBProgress (4): 1.1/1.2 MB | 430/548 kB | 16/142 kB | 20/43 kBProgress (4): 1.1/1.2 MB | 430/548 kB | 20/142 kB | 20/43 kBProgress (4): 1.1/1.2 MB | 430/548 kB | 20/142 kB | 24/43 kBProgress (4): 1.1/1.2 MB | 430/548 kB | 20/142 kB | 28/43 kBProgress (4): 1.1/1.2 MB | 434/548 kB | 20/142 kB | 28/43 kBProgress (4): 1.1/1.2 MB | 434/548 kB | 20/142 kB | 32/43 kBProgress (4): 1.1/1.2 MB | 434/548 kB | 24/142 kB | 32/43 kBProgress (4): 1.1/1.2 MB | 438/548 kB | 24/142 kB | 32/43 kBProgress (4): 1.1/1.2 MB | 442/548 kB | 24/142 kB | 32/43 kBProgress (4): 1.1/1.2 MB | 442/548 kB | 24/142 kB | 36/43 kBProgress (4): 1.1/1.2 MB | 442/548 kB | 24/142 kB | 40/43 kBProgress (4): 1.1/1.2 MB | 442/548 kB | 24/142 kB | 43 kB Progress (4): 1.1/1.2 MB | 442/548 kB | 24/142 kB | 43 kBProgress (4): 1.1/1.2 MB | 442/548 kB | 28/142 kB | 43 kBProgress (4): 1.1/1.2 MB | 442/548 kB | 32/142 kB | 43 kBProgress (5): 1.1/1.2 MB | 442/548 kB | 32/142 kB | 43 kB | 2.2/38 kBProgress (5): 1.1/1.2 MB | 446/548 kB | 32/142 kB | 43 kB | 2.2/38 kBProgress (5): 1.1/1.2 MB | 450/548 kB | 32/142 kB | 43 kB | 2.2/38 kBProgress (5): 1.1/1.2 MB | 454/548 kB | 32/142 kB | 43 kB | 2.2/38 kBProgress (5): 1.1/1.2 MB | 454/548 kB | 32/142 kB | 43 kB | 5.0/38 kBProgress (5): 1.1/1.2 MB | 458/548 kB | 32/142 kB | 43 kB | 5.0/38 kBProgress (5): 1.1/1.2 MB | 458/548 kB | 32/142 kB | 43 kB | 5.0/38 kBProgress (5): 1.1/1.2 MB | 458/548 kB | 32/142 kB | 43 kB | 5.0/38 kBProgress (5): 1.1/1.2 MB | 458/548 kB | 32/142 kB | 43 kB | 7.7/38 kBProgress (5): 1.1/1.2 MB | 458/548 kB | 32/142 kB | 43 kB | 7.7/38 kBProgress (5): 1.1/1.2 MB | 458/548 kB | 32/142 kB | 43 kB | 7.7/38 kBProgress (5): 1.1/1.2 MB | 458/548 kB | 36/142 kB | 43 kB | 7.7/38 kBProgress (5): 1.1/1.2 MB | 458/548 kB | 36/142 kB | 43 kB | 10/38 kB Progress (5): 1.1/1.2 MB | 458/548 kB | 40/142 kB | 43 kB | 10/38 kBProgress (5): 1.1/1.2 MB | 458/548 kB | 45/142 kB | 43 kB | 10/38 kBProgress (5): 1.1/1.2 MB | 462/548 kB | 45/142 kB | 43 kB | 10/38 kBProgress (5): 1.1/1.2 MB | 462/548 kB | 49/142 kB | 43 kB | 10/38 kBProgress (5): 1.2/1.2 MB | 462/548 kB | 49/142 kB | 43 kB | 10/38 kBProgress (5): 1.2/1.2 MB | 462/548 kB | 49/142 kB | 43 kB | 10/38 kBProgress (5): 1.2/1.2 MB | 462/548 kB | 49/142 kB | 43 kB | 10/38 kBProgress (5): 1.2/1.2 MB | 462/548 kB | 49/142 kB | 43 kB | 10/38 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/slf4j/slf4j-ext/1.7.12/slf4j-ext-1.7.12.jar (43 kB at 70 kB/s)
Progress (4): 1.2/1.2 MB | 462/548 kB | 53/142 kB | 10/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 57/142 kB | 10/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 61/142 kB | 10/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 65/142 kB | 10/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 69/142 kB | 10/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 73/142 kB | 10/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 77/142 kB | 10/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 81/142 kB | 10/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 85/142 kB | 10/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 90/142 kB | 10/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 94/142 kB | 10/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 98/142 kB | 10/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 98/142 kB | 13/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 102/142 kB | 13/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 106/142 kB | 13/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 110/142 kB | 13/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 114/142 kB | 13/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 118/142 kB | 13/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 122/142 kB | 13/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 126/142 kB | 13/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 131/142 kB | 13/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 135/142 kB | 13/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 139/142 kB | 13/38 kBProgress (4): 1.2/1.2 MB | 462/548 kB | 142 kB | 13/38 kB Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-archiver/1.0-alpha-7/plexus-archiver-1.0-alpha-7.jar (142 kB at 232 kB/s)
Progress (3): 1.2/1.2 MB | 462/548 kB | 13/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 13/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 13/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 13/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 16/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 16/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 19/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 21/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 24/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 27/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 27/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 27/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 30/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 32/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 35/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 38/38 kBProgress (3): 1.2/1.2 MB | 466/548 kB | 38 kB Progress (3): 1.2/1.2 MB | 471/548 kB | 38 kBProgress (3): 1.2/1.2 MB | 475/548 kB | 38 kBProgress (3): 1.2/1.2 MB | 475/548 kB | 38 kBProgress (3): 1.2/1.2 MB | 475/548 kB | 38 kBProgress (3): 1.2/1.2 MB | 479/548 kB | 38 kBProgress (3): 1.2/1.2 MB | 483/548 kB | 38 kBProgress (3): 1.2/1.2 MB | 487/548 kB | 38 kBProgress (3): 1.2/1.2 MB | 491/548 kB | 38 kBProgress (3): 1.2/1.2 MB | 491/548 kB | 38 kBProgress (3): 1.2/1.2 MB | 491/548 kB | 38 kBProgress (3): 1.2/1.2 MB | 491/548 kB | 38 kBProgress (3): 1.2/1.2 MB | 491/548 kB | 38 kB Downloaded from central: https://repo.maven.apache.org/maven2/ch/qos/cal10n/cal10n-api/0.8.1/cal10n-api-0.8.1.jar (38 kB at 62 kB/s)
Progress (2): 1.2/1.2 MB | 495/548 kBProgress (2): 1.2/1.2 MB | 499/548 kBProgress (2): 1.2/1.2 MB | 503/548 kBProgress (2): 1.2/1.2 MB | 507/548 kBProgress (2): 1.2/1.2 MB | 507/548 kBProgress (2): 1.2/1.2 MB | 507/548 kBProgress (2): 1.2/1.2 MB | 507/548 kBProgress (2): 1.2/1.2 MB | 507/548 kBProgress (2): 1.2/1.2 MB | 511/548 kBProgress (2): 1.2/1.2 MB | 516/548 kBProgress (2): 1.2/1.2 MB | 520/548 kBProgress (2): 1.2/1.2 MB | 524/548 kBProgress (2): 1.2/1.2 MB | 524/548 kBProgress (2): 1.2 MB | 524/548 kB Progress (2): 1.2 MB | 528/548 kBProgress (2): 1.2 MB | 532/548 kBProgress (2): 1.2 MB | 536/548 kBProgress (2): 1.2 MB | 540/548 kBProgress (2): 1.2 MB | 544/548 kBProgress (2): 1.2 MB | 548 kB Downloaded from central: https://repo.maven.apache.org/maven2/com/fasterxml/jackson/core/jackson-databind/2.8.4/jackson-databind-2.8.4.jar (1.2 MB at 2.0 MB/s)
Downloaded from central: https://repo.maven.apache.org/maven2/biz/aQute/bndlib/1.15.0/bndlib-1.15.0.jar (548 kB at 880 kB/s)
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
Downloading from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom
Downloaded from central: https://repo.maven.apache.org/maven2/ant/ant/1.6.5/ant-1.6.5.pom (0 B at 0 B/s)
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en&gt;
     [echo] Build directory is <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.16-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;:137:Inline literal start-string without end-string.
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 52.597 s
[e[1;34mINFOe[m] Finished at: 2019-06-04T11:31:14Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://build.geoserver.org/job/geoserver-master-live-docs/1835/display/redirect?page=changes&gt;
Changes:
[daniele.romagnoli] Updating imageio-ext and jai-ext versions
[...truncated 713 B...]
  at hudson.model.Executor.run(Executor.java:429)
ln builds/lastStableBuild /var/lib/jenkins/jobs/geoserver-master-live-docs/lastStable failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-master-live-docs/lastStable
  at sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:242)
  at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:108)
  at java.nio.file.Files.deleteIfExists(Files.java:1165)
  at hudson.Util.createSymlink(Util.java:1193)
  at hudson.model.Run.createSymlink(Run.java:1955)
  at hudson.model.Run.updateSymlinks(Run.java:1937)
  at hudson.model.Run.execute(Run.java:1814)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
  at hudson.model.ResourceController.execute(ResourceController.java:97)
Building remotely on i-0cd931f994d495f2a (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-live-docs/ws/&gt;
No credentials specified
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision bb9c71cd559ad61b3cc30d612e05f2c50faabafe (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f bb9c71cd559ad61b3cc30d612e05f2c50faabafe
Commit message: "Merge pull request #3553 from dromagnoli/ext-update"
> git rev-list --no-walk 0f3806873db16cede30bdc82e23a5b7f05c049c8 # timeout=10
[geoserver-master-live-docs] $ mvn -f doc/en/pom.xml clean compile
[e[1;34mINFOe[m] Scanning for projects...
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m----------------------< e[0;36morg.geoserver.en:gs-docse[0;1m >----------------------e[m
[e[1;34mINFOe[m] e[1mBuilding GeoServer English Documentation 2.16-SNAPSHOTe[m
[e[1;34mINFOe[m] e[1m--------------------------------[ pom ]---------------------------------e[m
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-clean-plugin:2.5:cleane[m e[1m(default-clean)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] Deleting <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(coverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coverages.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(coverageStores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coveragestores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coveragestores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coveragestores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(datastores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/datastores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/datastores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/datastores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(featureTypes)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml&gt;
[e[1;33mWARNINGe[m] generated unique operationId `getFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `putFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `postFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `deleteFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `getFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `putFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `postFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `deleteFeatureType_0`
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/featuretypes/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/featuretypes/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(fonts)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 53.172 s
[e[1;34mINFOe[m] Finished at: 2019-06-04T13:06:15Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
See <http://build.geoserver.org/job/geoserver-master-live-docs/1836/display/redirect?page=changes&gt;
Changes:
[Jody Garnett] Use Charset.defaultCharset() to test resource operations
[Jody Garnett] comment used to force rebuild
Checking out Revision c1c317a8c614a78b40b81f362702faebd8d25831 (origin/master)
> git checkout -f c1c317a8c614a78b40b81f362702faebd8d25831
Commit message: "comment used to force rebuild"
> git rev-list --no-walk bb9c71cd559ad61b3cc30d612e05f2c50faabafe # timeout=10
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 54.018 s
[e[1;34mINFOe[m] Finished at: 2019-06-04T14:36:07Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
See <http://build.geoserver.org/job/geoserver-master-live-docs/1837/display/redirect&gt;
[...truncated 996 B...]
> git rev-list --no-walk c1c317a8c614a78b40b81f362702faebd8d25831 # timeout=10
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 47.627 s
[e[1;34mINFOe[m] Finished at: 2019-06-04T23:25:18Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
See <http://build.geoserver.org/job/geoserver-master-live-docs/1838/display/redirect?page=changes&gt;
