[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #1128
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/1128/&gt;
[...truncated 2641 lines...]
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-script-bsh ---
[INFO] Compiling 1 source file to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-script-bsh ---
[INFO] Copying 6 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-script-bsh ---
[INFO] Compiling 5 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-script-bsh ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-script-bsh ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-script-bsh ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-script-bsh ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-script-bsh ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-script-bsh ---
[INFO] Copying gt-api-16-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/target/dependency/gt-api-16-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.10-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/target/dependency/gwc-core-1.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-script-bsh ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-bsh/2.10-SNAPSHOT/gs-script-bsh-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-bsh/2.10-SNAPSHOT/gs-script-bsh-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-bsh/2.10-SNAPSHOT/gs-script-bsh-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-bsh/2.10-SNAPSHOT/gs-script-bsh-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/script/bsh/target/gs-script-bsh-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/gs-script-bsh/2.10-SNAPSHOT/gs-script-bsh-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Groovy Scripting Extension 2.10-SNAPSHOT
[INFO] Downloading: https://repo.boundlessgeo.com/main/no/ecc/vectortile/java-vector-tile/1.0.9/java-vector-tile-1.0.9.pom
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-mysql/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/jdbc/gt-jdbc-mysql/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/jdbc/gt-jdbc-mysql/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools.jdbc:gt-jdbc-mysql:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[WARNING] Failure to transfer org.geotools.jdbc:gt-jdbc-mysql:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.jdbc:gt-jdbc-mysql:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-charts/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-charts/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-charts/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-charts:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[WARNING] Failure to transfer org.geotools:gt-charts:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-charts:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-imagepyramid/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-imagepyramid/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-imagepyramid/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-imagepyramid:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[WARNING] Failure to transfer org.geotools:gt-imagepyramid:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-imagepyramid:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-imageio-ext-gdal/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-imageio-ext-gdal/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-imageio-ext-gdal/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-imageio-ext-gdal:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[WARNING] Failure to transfer org.geotools:gt-imageio-ext-gdal:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-imageio-ext-gdal:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-netcdf/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-netcdf/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-netcdf/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-netcdf:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[WARNING] Failure to transfer org.geotools:gt-netcdf:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-netcdf:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-coverage-multidim/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-coverage-multidim/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-coverage-multidim/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-coverage-multidim:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-coverage-api/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-coverage-api/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-coverage-api/16-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://artifacts.unidata.ucar.edu/content/repositories/unidata/org/geotools/gt-coverage-api/16-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-coverage-api:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[WARNING] Failure to transfer org.geotools:gt-coverage-api:16-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-coverage-api:16-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [10:38 min]
[INFO] Core Platform Module ............................... SUCCESS [ 5.566 s]
[INFO] Open Web Service Module ............................ SUCCESS [01:12 min]
[INFO] Main Module ........................................ SUCCESS [ 31.114 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.104 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 5.042 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 4.782 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.532 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 6.952 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 6.944 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 8.182 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 13.242 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 46.545 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 7.307 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 29.381 s]
[INFO] REST Support Module ................................ SUCCESS [ 4.583 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 9.710 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.066 s]
[INFO] Core UI Module ..................................... SUCCESS [ 12.101 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 6.695 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 7.855 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 4.450 s]
[INFO] Demos Module ....................................... SUCCESS [ 5.809 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 4.867 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.070 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 8.896 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 6.022 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 4.758 s]
[INFO] REST UI Module ..................................... SUCCESS [ 3.831 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 15.844 s]
[INFO] Community Space .................................... SUCCESS [ 0.062 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 13.245 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 18.182 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [01:06 min]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 6.730 s]
[INFO] Aggregating Data Store ............................. SUCCESS [01:05 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.041 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.047 s]
[INFO] Web Processing Service Module ...................... SUCCESS [03:19 min]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.103 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 5.523 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 4.581 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.682 s]
[INFO] Groovy Scripting Extension ......................... FAILURE [08:24 min]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] Python Scripting Extension ......................... SKIPPED
[INFO] JavaScript Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension ........................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] REST plugin community module ....................... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 31:06 min
[INFO] Finished at: 2016-08-21T08:52:21+00:00
[INFO] Final Memory: 136M/367M
[ERROR] Failed to execute goal on project gs-script-groovy: Could not resolve dependencies for project org.geoserver.script:gs-script-groovy:jar:2.10-SNAPSHOT: Failed to collect dependencies at org.geoscript:geoscript-groovy:jar:1.7-SNAPSHOT -> no.ecc.vectortile:java-vector-tile:jar:1.0.9: Failed to read artifact descriptor for no.ecc.vectortile:java-vector-tile:jar:1.0.9: Could not transfer artifact no.ecc.vectortile:java-vector-tile:pom:1.0.9 from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-script-groovy
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/1129/&gt;
