See <https://build.geoserver.org/job/geoserver-master-nightly/2743/display/redirect?page=changes>
Changes:
[Daniele Romagnoli] ClientStreamAbortedException logged at SEVERE level, should be at lower
[...truncated 227.39 KB...]
[INFO] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/src/main/java/org/geoserver/web/wicket/browser/GeoServerFileChooser.java>: Recompile with -Xlint:deprecation for details.
[INFO] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/src/main/java/org/geoserver/web/wicket/GeoServerTablePanel.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/src/main/java/org/geoserver/web/wicket/GeoServerTablePanel.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-core ---
[INFO] Copying 12 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-core ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 80 source files to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/target/test-classes>
[INFO] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/src/test/java/org/geoserver/web/admin/ContactPageTest.java>: Some input files use or override a deprecated API.
[INFO] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/src/test/java/org/geoserver/web/admin/ContactPageTest.java>: Recompile with -Xlint:deprecation for details.
[INFO] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/src/test/java/org/geoserver/web/admin/AbstractAdminPrivilegeTest.java>: Some input files use unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/src/test/java/org/geoserver/web/admin/AbstractAdminPrivilegeTest.java>: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-core ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/target/gs-web-core-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/target/gs-web-core-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/target/gs-web-core-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/target/gs-web-core-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-web-core ---
[INFO] Copying gwc-core-1.15-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/target/dependency/gwc-core-1.15-SNAPSHOT.jar>
[INFO] Copying gt-main-21-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/target/dependency/gt-main-21-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-core ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/target/gs-web-core-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-core/2.15-SNAPSHOT/gs-web-core-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-core/2.15-SNAPSHOT/gs-web-core-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/target/gs-web-core-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-core/2.15-SNAPSHOT/gs-web-core-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/target/gs-web-core-2.15-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-core/2.15-SNAPSHOT/gs-web-core-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/core/target/gs-web-core-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-core/2.15-SNAPSHOT/gs-web-core-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building WMS UI Module 2.15-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-wms ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master-nightly/ws/src/web/wms/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-wms ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-wms ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master-nightly/ws/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-wms ---
[debug] Using AOSP style
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.068 s]
[INFO] Core Platform Module ............................... SUCCESS [ 4.612 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.447 s]
[INFO] Main Module ........................................ SUCCESS [ 21.505 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.066 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [ 1.960 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.128 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.248 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.726 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.791 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 2.565 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 2.435 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 4.435 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 7.773 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.414 s]
[INFO] gs-rest ............................................ SUCCESS [ 0.793 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 4.226 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 2.496 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 0.631 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 0.513 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 0.669 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.025 s]
[INFO] Core UI Module ..................................... SUCCESS [ 4.747 s]
[INFO] WMS UI Module ...................................... FAILURE [ 0.117 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer Security Community Modules ............... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Core .... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SKIPPED
[INFO] GeoServer Keycloak Security Plugin ................. SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] gs-notification-common ............................. SKIPPED
[INFO] GeoServer notification event system extension for GeoNode SKIPPED
[INFO] OWS Dispatcher Simulate Plugin ..................... SKIPPED
[INFO] JDBC Metrics Plugin ................................ SKIPPED
[INFO] OpenSearch EO parent ............................... SKIPPED
[INFO] OpenSearch for EO .................................. SKIPPED
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] OpenSearch for EO REST configuration API ........... SKIPPED
[INFO] GeoServer Mapbox Styling ........................... SKIPPED
[INFO] GeoServer Status Monitoring Module ................. SKIPPED
[INFO] NSG Profiles ....................................... SKIPPED
[INFO] NSG WMTS 1.0 Profile ............................... SKIPPED
[INFO] NSG WFS 2.0 Profile ................................ SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF GHRSST encoder .............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] WFS 3 prototype .................................... SKIPPED
[INFO] S3 Geotiff Support ................................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer Task Manager ............................. SKIPPED
[INFO] GeoServer Task Manager Core ........................ SKIPPED
[INFO] GeoServer Task Manager S3 .......................... SKIPPED
[INFO] GeoServer Quality of Service GetCapabilities module SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 01:22 min
[INFO] Finished at: 2019-01-19T08:01:29+00:00
[INFO] Final Memory: 274M/1704M
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:format (default) on project gs-web-wms: Execution default of goal com.coveo:fmt-maven-plugin:2.4.0:format failed. ArrayIndexOutOfBoundsException: 15 -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-wms
