[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #346
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/346/changes&gt;
Changes:
[jody.garnett] Flush ContentState during FeatureType DELETE (GEOS-6616)
Started by timer
Building in workspace <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/&gt;
Checkout:geoserver-master / <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/&gt; - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision cf7cdfc44def2f04db4ba48793df0c714fbe1b01 (origin/master)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
Commencing build of Revision c58e515cd10f58a6dcdab3efaf431d43180681f6 (origin/master)
Checking out Revision c58e515cd10f58a6dcdab3efaf431d43180681f6 (origin/master)
[geoserver-master] $ /bin/sh -xe /tmp/hudson472812490636530726.sh
+ ver=master
+ dist=/var/www/geoserver/master
+ date +%Y-%m-%d
+ datestamp=2014-08-16
+ mvn=/opt/apache-maven-2.2.1/bin/mvn
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=346 -P release,communityRelease clean install
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Coverage Service 2.0 Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] KML support for GeoServer
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Security UI Modules
[INFO] Security UI Core Module
[INFO] Security UI JDBC Module
[INFO] Security UI LDAP Module
[INFO] REST UI Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] Authentication by unique url key
[INFO] WorldWind Format Module
[INFO] NetCDF Coverage format
[INFO] WCS NetCDF output Module
[INFO] GeoServer Embedded FTP server
[INFO] GeoServer Extensions
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] GeoServer Scripting Extensions
[INFO] Core Scripting Extension
[INFO] H2 DataStore Extension
[INFO] Python Scripting Extension
[INFO] JavaScript Scripting Extension
[INFO] Groovy Scripting Extension
[INFO] GeoServer JDBC KV Catalog
[INFO] Simple Feature Service
[INFO] Aggregating Data Store
[INFO] WMS-EO
[INFO] ColorMap
[INFO] GeoServer mbtiles Extension
[INFO] GeoServer GeoPackage Extension
[INFO] GRIB Coverage Format
[INFO] Dynamic WMS dimension value defaults
[INFO] REST plugin community module
[INFO] GeoServer Community Release Module
[INFO] SpatiaLite Extension
[INFO] Web UI Scripting Extension
[INFO] BeanShell Scripting Extension
[INFO] Ruby Scripting Extension
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF WFS output format and WPS PPIO
[INFO] DXF WPS PPIO
[INFO] Printing Module
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] GeoServer Data Importer
[INFO] Importer Core Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] GeoServer Release Module
[INFO] Building GeoServer
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/target&gt;
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #679 from jodygarnett/GEOS-6616
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 16.08.2014 @ 02:08:42 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-Aug-2014 08:01
[INFO] [GitCommitIdMojo] build.build.time = 16.08.2014 @ 08:01:44 UTC
[INFO] [GitCommitIdMojo] build.branch = c58e515cd10f58a6dcdab3efaf431d43180681f6
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = c58e515
[INFO] [GitCommitIdMojo] build.commit.id = c58e515cd10f58a6dcdab3efaf431d43180681f6
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #679 from jodygarnett/GEOS-6616
Patch limited flushing content state (or falling back to datastore dispose) during DELETE operation
Resetting datastore cached attributes during PUSH creation of a FeatureType can be a new feature for 2.7.x.
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geotools:gt-api:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:library:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:geotools:12-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.boundlessgeo.com/main/org/geotools/geotools/12-SNAPSHOT/geotools-12-20140816.050750-2.pom
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geotools:modules:pom:null
Reason: Cannot find parent: org.geotools:geotools for project: org.geotools:modules:pom:null for project org.geotools:modules:pom:null
[INFO] Total time: 34 seconds
[INFO] Finished at: Sat Aug 16 08:01:51 UTC 2014
[INFO] Final Memory: 53M/232M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-08-16-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/347/changes&gt;
Changes:
[jared.erickson] Improve style editor browser detection and handle browsers that don't support codemirror
[andrea.aime] Some windows running/installer fixes
[andrea.aime] [GEOS-6619] Rendering based feature info will return just one geometry of the group that falls into the same pixel
[jdeolive] Fixing links to old website
[...truncated 924 lines...]
1121/1638K
1121/1638K
1122/1638K
1126/1638K
1127/1638K
1128/1638K
1132/1638K
1132/1638K
1134/1638K
1138/1638K
1138/1638K
1141/1638K
1144/1638K
1146/1638K
1149/1638K
1152/1638K
1155/1638K
1158/1638K
1161/1638K
1163/1638K
1166/1638K
1169/1638K
1172/1638K
1175/1638K
1177/1638K
1180/1638K
1183/1638K
1186/1638K
1189/1638K
1192/1638K
1194/1638K
1197/1638K
1200/1638K
1203/1638K
1206/1638K
1209/1638K
1211/1638K
1214/1638K
1217/1638K
1220/1638K
1223/1638K
1226/1638K
1228/1638K
1232/1638K
1233/1638K
1235/1638K
1238/1638K
1241/1638K
1244/1638K
1247/1638K
1250/1638K
1252/1638K
1255/1638K
1258/1638K
1261/1638K
1264/1638K
1267/1638K
1269/1638K
1272/1638K
1275/1638K
1278/1638K
1281/1638K
1284/1638K
1286/1638K
1289/1638K
1292/1638K
1295/1638K
1298/1638K
1300/1638K
1303/1638K
1307/1638K
1308/1638K
1309/1638K
1313/1638K
1313/1638K
1315/1638K
1319/1638K
1319/1638K
1320/1638K
1324/1638K
1325/1638K
1327/1638K
1330/1638K
1333/1638K
1336/1638K
1339/1638K
1342/1638K
1344/1638K
1347/1638K
1350/1638K
1353/1638K
1356/1638K
1358/1638K
1361/1638K
1364/1638K
1367/1638K
1370/1638K
1373/1638K
1375/1638K
1378/1638K
1380/1638K
1381/1638K
1384/1638K
1387/1638K
1390/1638K
1392/1638K
1395/1638K
1398/1638K
1401/1638K
1404/1638K
1407/1638K
1409/1638K
1412/1638K
1416/1638K
1416/1638K
1419/1638K
1422/1638K
1425/1638K
1428/1638K
1431/1638K
1433/1638K
1436/1638K
1439/1638K
1442/1638K
1445/1638K
1448/1638K
1450/1638K
1453/1638K
1456/1638K
1459/1638K
1462/1638K
1465/1638K
1467/1638K
1470/1638K
1473/1638K
1476/1638K
1479/1638K
1481/1638K
1484/1638K
1488/1638K
1489/1638K
1490/1638K
1494/1638K
1494/1638K
1496/1638K
1500/1638K
1500/1638K
1501/1638K
1505/1638K
1506/1638K
1507/1638K
1511/1638K
1511/1638K
1514/1638K
1517/1638K
1520/1638K
1523/1638K
1525/1638K
1528/1638K
1531/1638K
1534/1638K
1537/1638K
1539/1638K
1542/1638K
1545/1638K
1548/1638K
1549/1638K
1552/1638K
1555/1638K
1558/1638K
1561/1638K
1564/1638K
1566/1638K
1569/1638K
1573/1638K
1573/1638K
1575/1638K
1579/1638K
1579/1638K
1580/1638K
1584/1638K
1585/1638K
1586/1638K
1590/1638K
1590/1638K
1592/1638K
1596/1638K
1596/1638K
1599/1638K
1602/1638K
1605/1638K
1607/1638K
1610/1638K
1613/1638K
1616/1638K
1619/1638K
1621/1638K
1624/1638K
1627/1638K
1630/1638K
1633/1638K
1636/1638K
1638/1638K
1638K downloaded (gt-main-12-20140816.193624-1.jar)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geowebcache:gwc-core:jar:1.6-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geowebcache -DartifactId=gwc-core -Dversion=1.6-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geowebcache -DartifactId=gwc-core -Dversion=1.6-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver:geoserver:pom:2.6-SNAPSHOT
    2) org.geowebcache:gwc-core:jar:1.6-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  boundless (http://repo.boundlessgeo.com/main),
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org)
[INFO] Total time: 31 seconds
[INFO] Finished at: Sun Aug 17 08:11:18 UTC 2014
[INFO] Final Memory: 55M/224M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-08-17-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/348/changes&gt;
