[Geoserver-devel] Build in path with spaces?
What happened to having Hudson build in a path with spaces? I thought we did. I just ran into a build failure (see below) that would have been spotted earlier if Hudson built in a path with spaces.
To enhance platform support (such as GeoServer installed in Windows "Program Files"), I always build (and have my local buildbot build) in a path with spaces. This catches all sorts of bad file handling, and helps us improve the Mac/Windows user experience by using DataUtilities urlToFile/fileToURL wherever possible.
Kind regards,
Ben.
-------- Original Message --------
Subject: [Geoserver-devel] [jira] Created: (GEOS-3995) Build failure caused by unsafe URL-File conversion in KMLMapTransformer
Date: Fri, 4 Jun 2010 12:23:13 +0800
From: Ben Caradoc-Davies (JIRA) <jira@anonymised.com>
To: geoserver-devel@lists.sourceforge.net <geoserver-devel@lists.sourceforge.net>
                  Key: GEOS-3995
                  URL: http://jira.codehaus.org/browse/GEOS-3995
              Project: GeoServer
           Issue Type: Bug
           Components: WMS
     Affects Versions: 2.0.x, 2.1.x
             Reporter: Ben Caradoc-Davies
             Assignee: Andrea Aime
             Priority: Blocker
              Fix For: 2.0.3, 2.0.x, 2.1.x
The new behaviour and expanded unit test coverage introduced in r14469 by GEOS-3994 causes the build to fail in a path with spaces. (The broken code existed before; these changes in GEOS-3994 found it.)
While determining the location of a symboliser graphic, we have:
{code}
File file = new File(graphic.getLocation().getFile());
{code}
This is unsafe because it does not unescape URL encoded characters such as spaces. If the graphic is present in a path with spaces, the resulting file does not exist. The solution is to replace this with:
{code}
File file = DataUtilities.urlToFile(graphic.getLocation());
{code}
ThinkGeek and WIRED's GeekDad team up for the Ultimate
GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
lucky parental unit. See the prize list and enter to win:
http://p.sf.net/sfu/thinkgeek-promo
Geoserver-devel mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
We had for a short time a Windows Hudson that was running in a path
with spaces. Unfortunately it turned out to be very unstable and
we have to shut it down. That happened many months ago.
Is there anyone able to stand up a Hudson build server on Windows
again? And have it work in a path with spaces?
Andrea Aime
OpenGeo - http://opengeo.org
I thought someone had a Hudson building in a paths with spaces under Linux. Perhaps it was Christian Mueller's Hudson? I thought it was OpenGeo. Would it be hard to change OpenGeo's Hudson to build in a path with spaces?
Even a path with spaces under Linux catches 90% of my bungled File<->URL conversions. It won't catch problems with Windows shares or Mac Java 5, but it does help.
Kind regards,
