[Geoserver-devel] build server proposal
I had a chance to chat with Torben yesterday,
Here is a work-in-progress proposal for setting up build.geoserver.org to a new location.
  1. GeoCat can provide Jenkins and a Nexus (for snapshots) on our build server
  • access provided to PSC members for maintenance/setup
  1. Torben is happy to do the initial setup, transferring the configuration over
  2. Coordinate with OSGeo to take over ownership of geoserver.org domain name and redirect build.geoserver.org location
Feedback, discussion, refine as needed.
Jody Garnett
Hi Jody,
as long as everyone in the PSC has access to the build server and the names are controlled by OSGEO (with PSC getting access to it) I am fine.
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Nexus for snapshots? Where do tagged releases go?
Yep, this is fundamental.
Excellent
  1. Coordinate with OSGeo to take over ownership of geoserver.org domain name and redirect build.geoserver.org location
Are there SAC tickets for those?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
On Mon, 2 Mar 2020 at 03:36, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Feb 28, 2020 at 1:20 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
OSGeo repo, see progress on artifact manager to replace download.osgeo.org/webdav/geotools
Yes here: transfer of domains from planet.federal.com
There are several more tickets as we have lots to do:
home for blog.geoserver.org
Jenkins build server to replace build.geoserver.org (added comment we were exploring geocat hosting this)
