[Geoserver-devel] build server update - turning off geofence nightly builds
It has been some months since the geofence builds have run successfully. I am disabling these builds rather than continue to receive email.
The error message indicates:
[WARNING] org.eclipse.emf:org.eclipse.emf.common/maven-metadata.xml failed to transfer from https://repo.boundlessgeo.com/main/ during a previous attempt. This failure was cached in the local repository and resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.emf:org.eclipse.emf.common/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): repo.boundlessgeo.com: Temporary failure in name resolution
I expect the geofence pom.xml needs to be updated, when GeoFence is restored the above builds can be restored.
ยทยทยท
Jody Garnett
