[Geoserver-devel] Build speedup pull request ready
the work on speeding up the build resulted in the following pull request, also thanks to
Christian assistance to fix some security tests:
https://github.com/geoserver/geoserver/pull/1033
On my computer the buld times of a “mvn clean install -T4 -nsu -Prelease”
went down from around 18 minutes down to around 13 minutes, not a bad speedup imho,
close to 30%
On Travis, which has to download all the geotools jars at every build,
refresh the repository cache at the beginning of each build, and so on,
we go down from 37 minutes to 30 on the openjdk builds, which is not bad either
(the last build timed 39, not sure why, the enviroment over there is really flacky,
build times go up and down as they please…).
I’ve annotated the pull request with descriptions of the changes to facilitate
life to the reviewer, feedback welcomed.
Also, I’ve found looking on the internet a suggestion to allegedly speed up the build
on windows… turns out the clean phase is pretty expensive on NTFS (blasted
file system) and you can speed it up quite a bit by simply renaming
target instead of deleting it (on Linux, no speedup achieved instead, delete
or rename is similarly fast).
One can apply this trick, and have a separate build to do the cleanups instead:
http://bosy.dailydev.org/2009/02/speed-up-your-maven-build-four-times.html
Might be worth checking out, the current build time on the windows build box
is over an hour long…
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
so… should I conclude everybody is happy with our current build speed? :slight_smile:
On Sun, May 3, 2015 at 9:49 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
close to 30%
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
I will be happy to review this morning.
close to 30%
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Reviewed, you have really knocked this one out of the part - not sure I have ever seen a pull request so heavily commented.
On 3 May 2015 at 12:49, Andrea Aime <andrea.aime@anonymised.com> wrote:
close to 30%
Ing. Andrea Aime
@geowolf
Technical Lead
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-devel mailing list
Jody Garnett
On Sun, May 10, 2015 at 4:57 AM, Jody Garnett <jody.garnett@anonymised.com>
As suggested in the pull request comments, I've reworked the spring bean
lazy loading so that
it's not the test that has to declare to desire eager loading, but it's the
beans that
need to be eagerly loaded that need to add lazy-init="false", like this:
There is not that many needing this treatment, in general, they are beans
that
either alter their environment in the constructor (attaching listeners for
example) or
are application context aware, and doing the enviroment modification when
the
app context is set.
So, once the patch is applied, devs need to be on the lookout for this
situation, and
set the bean to not lazy init.
For the normal startup we are still going for full eager loading, it's best
to have
everything set before the OGC requests start hitting the server.
But for the tests, the speedup of lazy init, especially when running tests
from the
IDE, is too good to be left out (a single system test class run stand alone
does it job in
half of the time, 4-7 seconds instead of 10-14)
GeoSolutions for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
