[Geoserver-devel] building error of 2.0.x branch
Hi
I'm trying to build the 2.0.x branch but I get some errors:
[INFO] Installing /home/stefan/Develop/src/gs/2.0.x/maven/pom.xml to /home/stefan/.m2/repository/org/geoserver/maven/2.0.3-SNAPSHOT/maven-2.0.3-SNAPSHOT.pom
[INFO] Installing /home/stefan/Develop/src/gs/2.0.x/maven/target/maven-2.0.3-SNAPSHOT-tests.jar to /home/stefan/.m2/repository/org/geoserver/maven/2.0.3-SNAPSHOT/maven-2.0.3-SNAPSHOT-tests.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] task-segment: [install]
[INFO] [plugin:descriptor {execution: default-descriptor}]
[WARNING] Using platform encoding (UTF-8 actually) to read mojo metadata, i.e. build is platform dependent!
[ERROR] BUILD ERROR
[INFO] The API of the mojo scanner is not compatible with this plugin version. Please check the plugin dependencies configured in the POM and ensure the versions match.
Embedded error: org.apache.maven.tools.plugin.scanner.MojoScanner.populatePluginDescriptor(Lorg/apache/maven/tools/plugin/PluginToolsRequest;)V
[INFO] Trace
org.apache.maven.lifecycle.LifecycleExecutionException: The API of the mojo scanner is not compatible with this plugin version. Please check the plugin dependencies configured in the POM and ensure the versions match.
        at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:719)
        at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifecycleExecutor.java:556)
        at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:535)
        at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:387)
        at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:348)
        at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:180)
        at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:328)
        at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:138)
        at org.apache.maven.cli.MavenCli.main(MavenCli.java:362)
        at org.apache.maven.cli.compat.CompatibleMain.main(CompatibleMain.java:60)
        at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
        at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
        at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
        at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.MojoExecutionException: The API of the mojo scanner is not compatible with this plugin version. Please check the plugin dependencies configured in the POM and ensure the versions match.
        at org.apache.maven.plugin.plugin.AbstractGeneratorMojo.execute(AbstractGeneratorMojo.java:193)
        at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:490)
        at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:694)
        ... 17 more
Caused by: java.lang.NoSuchMethodError: org.apache.maven.tools.plugin.scanner.MojoScanner.populatePluginDescriptor(Lorg/apache/maven/tools/plugin/PluginToolsRequest;)V
        at org.apache.maven.plugin.plugin.AbstractGeneratorMojo.execute(AbstractGeneratorMojo.java:171)
        ... 19 more
[INFO] Total time: 4 seconds
[INFO] Finished at: Sat Jul 17 14:44:37 CEST 2010
[INFO] Final Memory: 28M/187M
Any ideas? Thanks.
regards
Stefan
mit freundlichem Gruss
Stefan Ziegler
Ziegler Stefan ha scritto:
Hi
[ERROR] BUILD ERROR
[INFO] Trace
        ... 17 more
        ... 19 more
Any ideas? Thanks.
Odd. I can build without issues using Maven 2.2.1
mvn --version
Apache Maven 2.2.1 (r801777; 2009-08-06 21:16:01+0200)
Java version: 1.5.0_22
Java home: /usr/lib/jvm/jdk1.5.0_22/jre
Default locale: it_IT, platform encoding: UTF-8
OS name: "linux" version: "2.6.31-22-generic" arch: "amd64" Family: "unix"
Which version are you using?
Andrea Aime
OpenGeo - http://opengeo.org
Again… wrong list…
Stefan: This message looks like it’s caused by a module that’s not compatible to maven 3. Try using maven 2.x.x
Am 17.07.2010 um 19:40 schrieb Andrea Aime:
Lennart Jütte ha scritto:
I get this problem when building with maven 3.0-dontknow 8the one bundled m2eclipse.
Ah. Yeah, that is new ground, none of the GeoServer developers
uses m2eclipse as far as I know.
That said, the module in question is old and maybe it’s just not specifying the version numbers of its dependencies properly
(thinking about maven-plugin-plugin).
No time to look at it right now, but if you want to report
back to the list with your findings
Andrea Aime
Am 17.07.2010 um 14:49 schrieb Ziegler Stefan:
Hi
I’m trying to build the 2.0.x branch but I get some errors:
[ERROR] BUILD ERROR
[INFO] Trace
… 17 more
… 19 more
Any ideas? Thanks.
regards
Stefan
Stefan Ziegler
This SF.net email is sponsored by Sprint
What will you do first with EVO, the first 4G phone?
Visit sprint.com/first – http://p.sf.net/sfu/sprint-com-first
Geoserver-devel mailing list
Geoserver-devel@anonymised.comge.net
