[Geoserver-devel] Can we keep the gt 15.x/gs 2.9.x builds alive a bit longer?
given that we cut short the lifetime of 2.9.x, would it be possible to keep the builds
alive for a little bit longer?
No more release intended, but on a maintenance series
releases are not really better than a nightly, they just happen to have convenient
installers.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
We can do so, I also got some feedback that “many people are using 2.9”. Would you like to re-enable the jobs and sort them back into the view?
How we can do this:
  • Doc generation/publication is no longer needed - and will conflict with 2.10.x
  • Can we cut the cite tests?
On 10 March 2017 at 01:38, Andrea Aime <andrea.aime@anonymised.com> wrote:
installers.
Ing. Andrea Aime
@geowolf
Technical Lead
Announcing the Oxford Dictionaries API! The API offers world-renowned
dictionary content that is easy and intuitive to access. Sign up for an
account today to start using our lexical data to power your apps and
projects. Get started today and enter our developer competition.
http://sdm.link/oxford
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Jody Garnett
On Fri, Mar 10, 2017 at 5:17 PM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
We can do so, I also got some feedback that "many people are using 2.9".
Yep, users already have troubles keeping up with our 6-months release cycle
(and we'd have trouble stabilizing and releasing it with a longer cycle),
cutting the 2.9.x and 2.10.x lifetimes shorter is making things harder for
them.
How we can do this:
- Doc generation/publication is no longer needed - and will conflict with
2.10.x
Ok, can look into that
- Can we cut the cite tests?
I'd rather not do that, cite tests run fast compared to the other builds
and people getting a nightly of
2.9.x at this point are definitely using it for production purposes
Ing. Andrea Aime
@geowolf
Technical Lead
Ok, hopefully done correctly. As far as I can tell, doc wise:
  • Geotools has a post-build step for docs, that I removed
  • GeoWebCache has nothing
  • GeoServer has a dedicated build, that is still disabled
On Sat, Mar 11, 2017 at 10:59 AM, Andrea Aime <andrea.aime@anonymised.com…> wrote:
On Fri, Mar 10, 2017 at 5:17 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Yep, users already have troubles keeping up with our 6-months release cycle (and we’d have trouble stabilizing and releasing it with a longer cycle),
cutting the 2.9.x and 2.10.x lifetimes shorter is making things harder for them.
How we can do this:
I’d rather not do that, cite tests run fast compared to the other builds and people getting a nightly of
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
