[Geoserver-devel] Change the default Suggested Tile Size?
I’m using the neat Importer extension to batch import my raster data to Geoserver.
My only problem with it is with the default “Suggested Tile Size” (512,512).
Is there a way to change it to 256,256, without changing it for each individual layer?
The reason behind it is that when accessing a layer from Cesium with the default Tile Size causes the following bug:
https://github.com/CesiumGS/cesium/issues/7994
I’m not sure if it’s a bug in Geoserver or in Cesium, but when the Suggested Tile Size is different then the TIFF block size then this bug appears only in Cesium as far as I can tell.
Kind regards,
Idan
