[Geoserver-devel] Cite test engine maven dependency
I've managed to, quite unintentionally, discover a version dependency in the new cite tests. I cannot install the engine using Maven 2.0.9 due to a bug in the passing of the line.separator variable to the ant environment. It builds fine for me with version 2.2.0, and Andrea has confirmed it builds with 2.1.something.
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
Hmmm... well we could probably hack around using line.separator. I will play around see if i can come up with something that works without using it.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
