[Geoserver-devel] combining rasters to make one
I was wondering if there exists any tool in the geotools/geoserver framework to do the following:
Given two rasters A[x,y] and B[x,y] you want to output a single layer with colors C[x,y] = some_calculation(A[x,y], B[x,y]) which can be expressed in a simple CQL expression.
I thought of doing this with SLD. I considered the rasters could be put in different bands of the same raster file, because combining data from different layers does not seem possible in SLD, but it even that does not seem to make it possible. Unlike for vector tiles it does not seem possible to do calculations on the basis of bands like you can do with feature properties. You only have color maps.
I also found this http://docs.geoserver.org/stable/en/user/styling/sld-extensions/rendering-transform.html
But that does not include raster(s)-to-raster conversion.
Wondering if there is something that I am missing.
Regards
Niels
On Mon, Jun 29, 2015 at 10:32 AM, Niels Charlier <niels@anonymised.com> wrote:
I also found this
This one: - Raster Algebra Processes based on Jiffle scripting language by afabiani · Pull Request #534 · geotools/geotools · GitHub
Not sure what its current state is though, cc'ing Alessio
GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Look at JAI tools and JAI tools jiffle (http://jaitools.org/docs/jiffle/latest/userguide/html/)
I also found this
This one: https://github.com/geotools/geotools/pull/534
Not sure what its current state is though, cc’ing Alessio
Ing. Andrea Aime
@geowolf
Technical Lead
