[Geoserver-devel] commits to catalog and restconfig
Hi Daniele,
I see you are making commits on 1.7.x to restconfig and main. I would appreciate posting patches for pre review first before committing. Especially in this case where we have not yet wrapped up discussion about how to handle the PUT issue from previous email.
I am not trying to hamper work here but I have been deemed the maintainer of that extension, and while there are no hard rules in place about who is allowed to commit, i would appreciate being to review commits before they go through.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Reviewing the commits more closely I definitely have a few concerns which affirms my preference to have these changes reviewed before hand.
* The method added to catalog builder seems unnecessary to me. I think just the plain buildLayer can be called, and then properties overrideen after the fact, instead put putting them into a map and passing it into the method. It also does not sync up with any of the other methods in that class. I would like to keep that class as consistent as possible.
* You have made changes to api without any discussion. Supporting wmspath and and style as query parameters is not documented as api options:
http://gridlock.openplans.org/geoserver/1.7.x/doc/user/extensions/rest/rest-config-api.html#coverage-stores
Not saying we should not have them, but this is an extension now, not a community module anymore, such things require discussion before hand.
* Many of the changes seem a bit arbitrary, changing variable declarations to final for instance. Again, for consistency sake I prefer that you delegate to how the rest of the class / method does things when making chagnes.
* Setting the layer name as the entity is again an api change, and one I don't agree with. It is more RESTful to set the location of the resource using the appropriate HTTP header, 'Location' like we do for the POST case. Also, the indication of where the resource should be down with a full uri, just returning the name assumes that URI's are non-opaque, ie the client has pre-knowledge of how URI's are built, which is another REST nono.
-Justin
Justin Deoliveira wrote:
Hi Daniele,
-Justin
Justin Deoliveira
Hi Justin,
I’m really sorry about this.
Next time I’ll follows the steps you are talking about.
I was working on the coverages ingestion and I needed to re-enable some capabilities available in 1.7.2 for an urgent application.
I was too hasty. Sorry again.
On Fri, May 8, 2009 at 4:22 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
  • The method added to catalog builder seems unnecessary to me. I think
  • You have made changes to api without any discussion. Supporting
The previous RESTConfig allowed to handle them. I had tought during migration to extensions they have been forgotten.
You are Right.
  • Many of the changes seem a bit arbitrary, changing variable
    making chagnes.
  • Setting the layer name as the entity is again an api change, and one I
    don’t agree with. It is more RESTful to set the location of the resource
    using the appropriate HTTP header, ‘Location’ like we do for the POST
    full uri, just returning the name assumes that URI’s are non-opaque, ie
    the client has pre-knowledge of how URI’s are built, which is another
    REST nono.
Do you think it would be better if I revert my changes?
Daniele
-Justin
Hi Daniele,
-Justin
Justin Deoliveira
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there’s a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you’ll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-devel mailing list
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
No need to apologize. I am sympathetic to your deadline and I do not mean to come across as over protective of that code but when I turned restconfig from a community module to an extension, it required a lot of cleanup. I would like to ensure we maintain its current quality. A code review process is the best way to do that imo.
So about the current changes, I plan to rework your commits a bit, maintaining the functionality you added. I can post patches for you to review before I commit.
-Justin
Daniele Romagnoli wrote:
Hi Justin,
I'm really sorry about this. Next time I'll follows the steps you are talking about.
On Fri, May 8, 2009 at 4:22 PM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    options:
    <http://gridlock.openplans.org/geoserver/1.7.x/doc/user/extensions/rest/rest-config-api.html#coverage-stores&gt;
You are Right.
    making chagnes.
    REST nono.
Daniele
    -Justin
     > Hi Daniele,
     > I see you are making commits on 1.7.x to restconfig and main. I would
     > appreciate posting patches for pre review first before committing.
     > Especially in this case where we have not yet wrapped up discussion
     > about how to handle the PUT issue from previous email.
     > I am not trying to hamper work here but I have been deemed the
     > maintainer of that extension, and while there are no hard rules
    in place
     > about who is allowed to commit, i would appreciate being to review
     > commits before they go through.
     > -Justin
    Justin Deoliveira
    thanks to
    Kodak, there's a perfect scanner to get the job done! With the NEW
    KODAK i700
    Series Scanner you'll get full speed at 300 dpi even with all image
    <mailto:Geoserver-devel@lists.sourceforge.net>
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
For the first patch:
+ final LayerInfo layerInfo;
+ final Map<String,String> layerProperties = new HashMap<String,String>(2);
+ if (form.getFirst("style") != null)
+ layerProperties.put("style", form.getFirstValue("style"));
+ if (form.getFirst("wmspath") != null)
+ layerProperties.put("path", form.getFirstValue("wmspath"));
+ if (layerProperties.isEmpty())
+ layerInfo = builder.buildLayer(cinfo);
+ else
+ layerInfo = builder.buildLayer(cinfo,layerProperties);
+ catalog.add(layerInfo);
I think this should be handled with a second call, rather than stack up available options. It makes the api cleaner imo. And is less arbitrary. For instance why do we support style and wms path but not the other properties?
So I would prefer the interaction to be:
1) PUT to upload the coverage
2) PUT to modify the coverage
Objections?
Hi Justin,
    options:
You are Right.
    making chagnes.
    REST nono.
Daniele
    -Justin
     > Hi Daniele,
    in place
     > -Justin
    Justin Deoliveira
    thanks to
    KODAK i700
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Justin Deoliveira
On Fri, May 8, 2009 at 5:10 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Ok, thank you very much then. I’ll review your patches asap, in order to restore the situation.
Daniele
-Justin
Hi Justin,
I’m really sorry about this. Next time I’ll follows the steps you are talking about.
On Fri, May 8, 2009 at 4:22 PM, Justin Deoliveira <jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)> wrote:
    options:
<http://gridlock.openplans.org/geoserver/1.7.x/doc/user/extensions/rest/rest-config-api.html#coverage-stores>
You are Right.
    making chagnes.
    REST nono.
Daniele
-Justin
Hi Daniele,
in place
-Justin
Justin Deoliveira
thanks to
KODAK i700
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Actually,
yeah, I have one objection.
Beside the fact that I am not so convinced that separating the two
calls will make the api cleaner, I am quite worried that this would
make the whole process much weaker. In the real world, when you want
to add data in a dynamic way with a heavily loaded server with the
current geoserver internal catalog it is not uncommon that everything
breaks due to the fact that it takes quite some time to persiste the
changes. You understand that starting to explode the number of calls
to configure a single layer will not work in real use cases.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Fri, May 8, 2009 at 5:25 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
+ else
properties?
Objections?
Hi Justin,
which affirms my preference to have these changes reviewed before hand\.
\* The method added to catalog builder seems unnecessary to me\. I think
the method\. It also does not sync up with any of the other methods in
that class\. I would like to keep that class as consistent as possible\.
\* You have made changes to api without any discussion\. Supporting
options:
&lt;http://gridlock.openplans.org/geoserver/1.7.x/doc/user/extensions/rest/rest-config-api.html#coverage-stores&gt;
community module anymore, such things require discussion before hand\.
You are Right.
\* Many of the changes seem a bit arbitrary, changing variable
declarations to final for instance\. Again, for consistency sake I prefer
making chagnes\.
\* Setting the layer name as the entity is again an api change, and one I
don&#39;t agree with\. It is more RESTful to set the location of the resource
using the appropriate HTTP header, &#39;Location&#39; like we do for the POST
case\. Also, the indication of where the resource should be down with a
full uri, just returning the name assumes that URI&#39;s are non\-opaque, ie
the client has pre\-knowledge of how URI&#39;s are built, which is another
REST nono\.
Daniele
\-Justin
 &gt; Hi Daniele,
 &gt;
 &gt; I see you are making commits on 1\.7\.x to restconfig and main\. I would
 &gt; appreciate posting patches for pre review first before committing\.
 &gt; Especially in this case where we have not yet wrapped up discussion
 &gt; about how to handle the PUT issue from previous email\.
 &gt;
 &gt; I am not trying to hamper work here but I have been deemed the
 &gt; maintainer of that extension, and while there are no hard rules
in place
 &gt; about who is allowed to commit, i would appreciate being to review
 &gt; commits before they go through\.
 &gt;
 &gt; \-Justin
 &gt;
Justin Deoliveira
OpenGeo \- http://opengeo.org
Enterprise support for open source geospatial\.
The NEW KODAK i700 Series Scanners deliver under ANY circumstances\! Your
production scanning environment may not be a perfect world \- but
thanks to
Kodak, there&#39;s a perfect scanner to get the job done\! With the NEW
KODAK i700
Series Scanner you&#39;ll get full speed at 300 dpi even with all image
processing features enabled\. http://p.sf.net/sfu/kodak-com
\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_
Geoserver\-devel mailing list
Geoserver\-devel@lists\.sourceforge\.net
&lt;mailto:Geoserver-devel@lists.sourceforge.net&gt;
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
  • final LayerInfo layerInfo;
  • final Map<String,String> layerProperties = new HashMap<String,String>(2);
  • if (form.getFirst(“style”) != null)
  • layerProperties.put(“style”, form.getFirstValue(“style”));
  • if (form.getFirst(“wmspath”) != null)
  • layerProperties.put(“path”, form.getFirstValue(“wmspath”));
  • if (layerProperties.isEmpty())
  • layerInfo = builder.buildLayer(cinfo);
  • else
  • layerInfo = builder.buildLayer(cinfo,layerProperties);
  • catalog.add(layerInfo);
  1. PUT to upload the coverage
  2. PUT to modify the coverage
Objections?
In my opinion, I think it would be better to do these quick additional settings in a single pass.
About your question involving properties, indeed, we can check for additional properties.
Daniele
Hi Justin,
    options:
You are Right.
    making chagnes.
    REST nono.
Daniele
-Justin
Hi Daniele,
in place
-Justin
Justin Deoliveira
thanks to
KODAK i700
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Series Scanner you’ll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Simone Giannecchini wrote:
Actually,
I would argue it does from a REST perspective. Any parameters that modify the resource being PUT should be in the request entity, not in the URI that defines the resource.
I understand the issue, but I hope you can understand why I am hesitant to make API compromises to get around limitations which are currently just an implementation detail. Like if we had a catalog that performed well under update this would be an non issue.
Even in 2.0 this should be much less of an issue since now the only thing that gets saved is what you modify. Should be much more performant under heavy update load. That said I do realize that you are working with 1.7.x and need to work stable.
Putting the issue of the current catalog aside for the moment, I would speculate that the cost of a second call should be negligible compared to the first. The reason being that since the first request involves a data upload it could potentially take a while assuming a decently sized dataset. But the second call should always be constant time. So you have 1 potentially long request + 1 constant time (instantaneous when we have a decent catalog).
That said, I would like to come up with a compromise here, and I would like to do so in a way that does not prevent you from meeting any deadlines. Since the rest system is pluggable can we move the code that contains these workarounds for our current catalog limitations into a community module. Doing so allows us to have a way to achieve the desired functionality for now, but at the same time does not tie us to it for future versions. And with a little spring magic we should be able to do in a way that the community module version overrides the extension version so there are no URI conflicts.
Thoughts?
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
+ else
properties?
Objections?
Hi Justin,
    options:
You are Right.
    making chagnes.
    REST nono.
Daniele
    -Justin
     > Hi Daniele,
    in place
     > -Justin
    Justin Deoliveira
    thanks to
    KODAK i700
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Justin Deoliveira
Ciao Justin,
please, see below...
On Fri, May 8, 2009 at 6:10 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Actually,
I agree, but we don't have such a catalog yet :-).
decent catalog).
I am talking about a different thing.
If you have 2000 coveragerages configured it takes a non negligible
time to persist the config.
Do it twice is simply not acceptable.
conflicts.
I'll live that to daniele, since we already modifying code that worked
before 1.7.3, therefore there is not much time available for more
work.
Simone.
Thoughts?
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
+ else
+ layerInfo =
properties?
Objections?
Hi Justin,
hand.
think
overrideen
into
possible.
options:
a
You are Right.
prefer
when
making chagnes.
one I
resource
a
ie
REST nono.
Daniele
-Justin
> Hi Daniele,
would
discussion
in place
> -Justin
Justin Deoliveira
Your
thanks to
KODAK i700
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
to
i700
Justin Deoliveira
to
i700
Justin Deoliveira
while waiting for an improved catalog, as a quick workaround we could set up a community module which is a “copy” of the actual restconfig extension containing the workarounds.
(let’s say, something similar to a branch, but restricted to a single module).
Does this sounds ok?
Daniele
On Fri, May 8, 2009 at 6:16 PM, Simone Giannecchini <simone.giannecchini@anonymised.com1268…> wrote:
Ciao Justin,
please, see below…
Actually,
I agree, but we don’t have such a catalog yet :-).
decent catalog).
conflicts.
I’ll live that to daniele, since we already modifying code that worked
work.
Simone.
Thoughts?
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
  • else
  • layerInfo =
properties?
Objections?
Hi Justin,
hand.
    think
    overrideen
    into
    possible.
    options:
a
You are Right.
    prefer
    when
    making chagnes.
    one I
    resource
    a
    ie
    REST nono.
Daniele
-Justin
Hi Daniele,
would
discussion
in place
-Justin
Justin Deoliveira
Your
thanks to
KODAK i700
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comsourceforge.net)
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
to
i700
Justin Deoliveira
to
i700
Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Well actually thinking about it, the old RESTConfig community module is still there, and all the classes are there pre-change. So you may just be able to use it.
My only hesitation is that we will end up in this same situation, a bunch of work will be done there and it will not be ported properly back to the extension. But since you guys are on a tight deadline we don't have much choice.
So proceed as you see fit, either create a new community module or use the existing RESTConfig one.
-Justin
while waiting for an improved catalog, as a quick workaround we could set up a community module which is a "copy" of the actual restconfig extension containing the workarounds.
(let's say, something similar to a branch, but restricted to a single module).
Daniele
On Fri, May 8, 2009 at 6:16 PM, Simone Giannecchini <simone.giannecchini@anonymised.com <mailto:simone.giannecchini@anonymised.com>> wrote:
    Ciao Justin,
     > Simone Giannecchini wrote:
     >> Actually,
     >> yeah, I have one objection.
     >> Beside the fact that I am not so convinced that separating the two
     >> calls will make the api cleaner,
     > I would argue it does from a REST perspective. Any parameters
    that modify
     > the resource being PUT should be in the request entity, not in
    the URI that
     > defines the resource.
     > I am quite worried that this would
     >> make the whole process much weaker. In the real world, when you want
     >> to add data in a dynamic way with a heavily loaded server with the
     >> current geoserver internal catalog it is not uncommon that
    everything
     >> breaks due to the fact that it takes quite some time to persiste the
     >> changes. You understand that starting to explode the number of calls
     >> to configure a single layer will not work in real use cases.
     > I understand the issue, but I hope you can understand why I am
    hesitant to
     > make API compromises to get around limitations which are
    currently just an
     > implementation detail. Like if we had a catalog that performed
    well under
     > update this would be an non issue.
     > Even in 2.0 this should be much less of an issue since now the
    only thing
     > that gets saved is what you modify. Should be much more
    performant under
     > heavy update load. That said I do realize that you are working
    with 1.7.x
     > and need to work stable.
     > Putting the issue of the current catalog aside for the moment, I
    would
     > speculate that the cost of a second call should be negligible
    compared to
     > the first. The reason being that since the first request involves
    a data
     > upload it could potentially take a while assuming a decently
    sized dataset.
     > But the second call should always be constant time. So you have 1
     > potentially long request + 1 constant time (instantaneous when we
    have a
     > decent catalog).
     > That said, I would like to come up with a compromise here, and I
    would like
     > to do so in a way that does not prevent you from meeting any
    deadlines.
     > Since the rest system is pluggable can we move the code that
    contains these
     > workarounds for our current catalog limitations into a community
    module.
     > Doing so allows us to have a way to achieve the desired
    functionality for
     > now, but at the same time does not tie us to it for future
    versions. And
     > with a little spring magic we should be able to do in a way that the
     > community module version overrides the extension version so there
    are no URI
     > conflicts.
    work.
    Simone.
     > Thoughts?
     >> Simone.
     >> Ing. Simone Giannecchini
     >> GeoSolutions S.A.S.
     >> Owner - Software Engineer
     >> Via Carignoni 51
     >> 55041 Camaiore (LU)
     >> Italy
     >> phone: +39 0584983027
     >> fax: +39 0584983027
     >> mob: +39 333 8128928
     >> http://www.geo-solutions.it
     >> http://simboss.blogspot.com/
     >> http://www.linkedin.com/in/simonegiannecchini
     >> On Fri, May 8, 2009 at 5:25 PM, Justin Deoliveira
     >> wrote:
     >>> For the first patch:
     >>> + final LayerInfo layerInfo;
     >>> + final Map<String,String> layerProperties = new
     >>> HashMap<String,String>(2);
     >>> + if (form.getFirst("style") != null)
     >>> + layerProperties.put("style",
     >>> form.getFirstValue("style"));
     >>> + if (form.getFirst("wmspath") != null)
     >>> + layerProperties.put("path",
     >>> form.getFirstValue("wmspath"));
     >>> + if (layerProperties.isEmpty())
     >>> + layerInfo = builder.buildLayer(cinfo);
     >>> + else
     >>> + layerInfo =
     >>> builder.buildLayer(cinfo,layerProperties);
     >>> + catalog.add(layerInfo);
     >>> I think this should be handled with a second call, rather than
    stack up
     >>> available options. It makes the api cleaner imo. And is less
    arbitrary.
     >>> For instance why do we support style and wms path but not the other
     >>> properties?
     >>> So I would prefer the interaction to be:
     >>> 1) PUT to upload the coverage
     >>> 2) PUT to modify the coverage
     >>> Objections?
     >>> Daniele Romagnoli wrote:
     >>>> Hi Justin,
     >>>> I'm really sorry about this.
     >>>> Next time I'll follows the steps you are talking about.
     >>>> I was working on the coverages ingestion and I needed to
    re-enable some
     >>>> capabilities available in 1.7.2 for an urgent application.
     >>>> I was too hasty. Sorry again.
     >>>> On Fri, May 8, 2009 at 4:22 PM, Justin Deoliveira
     >>>> <mailto:jdeolive@anonymised.com>>
    wrote:
     >>>> Reviewing the commits more closely I definitely have a few
    concerns
     >>>> which affirms my preference to have these changes reviewed
    before
     >>>> hand.
     >>>> * The method added to catalog builder seems unnecessary to
    me. I
     >>>> think
     >>>> just the plain buildLayer can be called, and then properties
     >>>> overrideen
     >>>> after the fact, instead put putting them into a map and
    passing it
     >>>> into
     >>>> the method. It also does not sync up with any of the other
    methods in
     >>>> that class. I would like to keep that class as consistent as
     >>>> possible.
     >>>> * You have made changes to api without any discussion.
    Supporting
     >>>> wmspath and and style as query parameters is not documented
    as api
     >>>> options:
     >>>> The previous RESTConfig allowed to handle them. I had tought
    during
     >>>> migration to extensions they have been forgotten.
     >>>> Not saying we should not have them, but this is an
    extension now, not
     >>>> a
     >>>> community module anymore, such things require discussion
    before hand.
     >>>> You are Right.
     >>>> * Many of the changes seem a bit arbitrary, changing variable
     >>>> declarations to final for instance. Again, for consistency
    sake I
     >>>> prefer
     >>>> that you delegate to how the rest of the class / method
    does things
     >>>> when
     >>>> making chagnes.
     >>>> * Setting the layer name as the entity is again an api
    change, and
     >>>> one I
     >>>> don't agree with. It is more RESTful to set the location of the
     >>>> resource
     >>>> using the appropriate HTTP header, 'Location' like we do
    for the POST
     >>>> case. Also, the indication of where the resource should be
    down with
     >>>> a
     >>>> full uri, just returning the name assumes that URI's are
    non-opaque,
     >>>> ie
     >>>> the client has pre-knowledge of how URI's are built, which
    is another
     >>>> REST nono.
     >>>> Do you think it would be better if I revert my changes?
     >>>> Daniele
     >>>> -Justin
     >>>> Justin Deoliveira wrote:
     >>>> > Hi Daniele,
     >>>> > I see you are making commits on 1.7.x to restconfig and
    main. I
     >>>> would
     >>>> > appreciate posting patches for pre review first before
    committing.
     >>>> > Especially in this case where we have not yet wrapped up
     >>>> discussion
     >>>> > about how to handle the PUT issue from previous email.
     >>>> > I am not trying to hamper work here but I have been
    deemed the
     >>>> > maintainer of that extension, and while there are no
    hard rules
     >>>> in place
     >>>> > about who is allowed to commit, i would appreciate being
    to review
     >>>> > commits before they go through.
     >>>> > -Justin
     >>>> OpenGeo - http://opengeo.org
     >>>> Enterprise support for open source geospatial.
     >>>> The NEW KODAK i700 Series Scanners deliver under ANY
    circumstances!
     >>>> Your
     >>>> production scanning environment may not be a perfect world
    - but
     >>>> thanks to
     >>>> Kodak, there's a perfect scanner to get the job done! With
    the NEW
     >>>> KODAK i700
     >>>> Series Scanner you'll get full speed at 300 dpi even with
    all image
     >>>> processing features enabled. http://p.sf.net/sfu/kodak-com
     >>>> _______________________________________________
     >>>> Geoserver-devel mailing list
     >>>> Geoserver-devel@lists.sourceforge.net
     >>>> <mailto:Geoserver-devel@lists.sourceforge.net
    <mailto:Geoserver-devel@lists.sourceforge.net>>
     >>>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
     >>>> Eng. Daniele Romagnoli
     >>>> Software Engineer
     >>>> GeoSolutions S.A.S.
     >>>> Via Carignoni 51
     >>>> 55041 Camaiore (LU)
     >>>> Italy
     >>>> phone: +39 0584983027
     >>>> fax: +39 0584983027
     >>>> mob: +39 328 0559267
     >>>> http://www.geo-solutions.it
    circumstances! Your
     >>>> production scanning environment may not be a perfect world -
    but thanks
     >>>> to
     >>>> Kodak, there's a perfect scanner to get the job done! With the
    NEW KODAK
     >>>> i700
     >>>> Series Scanner you'll get full speed at 300 dpi even with all
    circumstances! Your
    but thanks
     >>> to
    NEW KODAK
     >>> i700
     >>> Series Scanner you'll get full speed at 300 dpi even with all image
     > Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Ciao Justin,
just out of curiosity, what's the situation with rest and restconfig on trunk?
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Fri, May 8, 2009 at 6:40 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
able to use it.
choice.
-Justin
module).
Daniele
Ciao Justin,
>> Actually,
that modify
the URI that
want
everything
the
calls
hesitant to
currently just an
well under
&gt; Even in 2\.0 this should be much less of an issue since now the
only thing
performant under
with 1.7.x
would
compared to
a data
sized dataset.
have a
> decent catalog).
&gt; That said, I would like to come up with a compromise here, and I
would like
deadlines.
contains these
module.
functionality for
versions. And
are no URI
> conflicts.
work.
Simone.
> Thoughts?
>> Simone.
>> GeoSolutions S.A.S.
>> Via Carignoni 51
>> 55041 Camaiore (LU)
>> Italy
>> fax: +39 0584983027
>>> + else
>>> + layerInfo =
stack up
arbitrary.
other
>>> properties?
>>> Objections?
>>>> Hi Justin,
re-enable some
concerns
before
>>>> hand.
me. I
>>>> think
>>>> overrideen
passing it
>>>> into
methods in
>>>> possible.
Supporting
as api
>>>> options:
during
extension now, not
>>>> a
before hand.
>>>> You are Right.
sake I
>>>> prefer
does things
>>>> when
>>>> making chagnes.
change, and
>>>> one I
the
>>>> resource
for the POST
down with
>>>> a
non-opaque,
>>>> ie
is another
>>>> REST nono.
>>>> Daniele
>>>> -Justin
>>>> > Hi Daniele,
main. I
>>>> would
committing.
>>>> discussion
deemed the
hard rules
>>>> in place
to review
>>>> > -Justin
>>>> Justin Deoliveira
circumstances!
>>>> Your
- but
>>>> thanks to
the NEW
>>>> KODAK i700
all image
>>>> Software Engineer
>>>> GeoSolutions S.A.S.
>>>> Via Carignoni 51
>>>> 55041 Camaiore (LU)
>>>> Italy
>>>> fax: +39 0584983027
circumstances! Your
but thanks
>>>> to
NEW KODAK
>>>> i700
>>> Justin Deoliveira
circumstances! Your
but thanks
>>> to
NEW KODAK
>>> i700
> Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Being the RESTConfig community module no more used, we can remove it and copy the modified restconfig in community. (do you think about a special name to avoid confusion? some prefix/suffix?)
I think the new restconfig has several improvements with respect to the older one, therefore we prefer to use the last one.
If we go in that direction, you can clean up the extension as you like.
Let me know and I will open a new thread to request setting up a community module.
Daniele
My only hesitation is that we will end up in this same situation, a bunch of work will be done there and it will not be ported properly back to the extension. But since you guys are on a tight deadline we don’t have much choice.
-Justin
Daniele
On Fri, May 8, 2009 at 6:16 PM, Simone Giannecchini <simone.giannecchini@anonymised.com8… mailto:[simone.giannecchini@anonymised.com](mailto:simone.giannecchini@anonymised.com)> wrote:
Ciao Justin,
please, see below…
Actually,
that modify
the URI that
everything
hesitant to
currently just an
well under
only thing
performant under
with 1.7.x
would
compared to
a data
sized dataset.
have a
decent catalog).
would like
deadlines.
contains these
module.
functionality for
versions. And
are no URI
conflicts.
work.
Simone.
Thoughts?
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
  • else
  • layerInfo =
stack up
arbitrary.
properties?
Objections?
Hi Justin,
re-enable some
<mailto:jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)>>
concerns
before
hand.
    me. I
    think
    overrideen
    passing it
    into
    methods in
    possible.
    Supporting
    as api
    options:
during
extension now, not
a
before hand.
You are Right.
    sake I
    prefer
    does things
    when
    making chagnes.
    change, and
    one I
    resource
    for the POST
    down with
    a
    non-opaque,
    ie
    is another
    REST nono.
Daniele
-Justin
Hi Daniele,
main. I
would
committing.
discussion
deemed the
hard rules
in place
to review
-Justin
Justin Deoliveira
circumstances!
Your
  • but
thanks to
the NEW
KODAK i700
all image
<mailto:Geoserver-devel@anonymised.comge.net
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)>
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
circumstances! Your
but thanks
to
NEW KODAK
i700
Justin Deoliveira
circumstances! Your
but thanks
to
NEW KODAK
i700
Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Has not been forward ported from 1.7.x yet. The reason being that when i moved RESTConfig from community to extension i rewrote it against the new catalog api. Since that api has been under flux lately I have been putting off porting the restconfig extension to trunk. But plan to do so soon.
-Justin
Ciao Justin,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
able to use it.
choice.
-Justin
module).
Daniele
   Ciao Justin,
    >> Actually,
   that modify
   the URI that
want
   everything
the
calls
   hesitant to
   currently just an
   well under
   only thing
   performant under
   with 1.7.x
   would
   compared to
   a data
   sized dataset.
   have a
    > decent catalog).
   would like
   deadlines.
   contains these
   module.
   functionality for
   versions. And
   are no URI
    > conflicts.
   work.
   Simone.
    > Thoughts?
    >> Simone.
    >> Via Carignoni 51
    >> Italy
    >>> + else
    >>> + layerInfo =
   stack up
   arbitrary.
other
    >>> properties?
    >>> Objections?
    >>>> Hi Justin,
   re-enable some
   concerns
   before
    >>>> hand.
   me. I
    >>>> think
    >>>> overrideen
   passing it
    >>>> into
   methods in
    >>>> possible.
   Supporting
   as api
    >>>> options:
   during
   extension now, not
    >>>> a
   before hand.
    >>>> You are Right.
   sake I
    >>>> prefer
   does things
    >>>> when
   change, and
    >>>> one I
the
    >>>> resource
   for the POST
   down with
    >>>> a
   non-opaque,
    >>>> ie
   is another
    >>>> REST nono.
    >>>> Daniele
    >>>> -Justin
    >>>> > Hi Daniele,
   main. I
    >>>> would
   committing.
    >>>> discussion
   deemed the
   hard rules
    >>>> in place
   to review
    >>>> > -Justin
   circumstances!
    >>>> Your
   - but
    >>>> thanks to
   the NEW
    >>>> KODAK i700
   all image
    >>>> Italy
   circumstances! Your
   but thanks
    >>>> to
   NEW KODAK
    >>>> i700
   circumstances! Your
   but thanks
    >>> to
   NEW KODAK
    >>> i700
    > Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Justin Deoliveira
Sure, go ahead and start a separate thread. Can I ask that for issues you find while hacking the community copy can you open jiras for me, as I do plan to incorporate all the changes you are making, just that I want them to go through the review process first.
-Justin
Daniele
On Fri, May 8, 2009 at 6:40 PM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    -Justin
        single module).
        Daniele
        <mailto:simone.giannecchini@anonymised.com>>> wrote:
           Ciao Justin,
            >> Actually,
         separating the two
           that modify
           the URI that
        when you want
        with the
           everything
        persiste the
        number of calls
           hesitant to
           currently just an
           well under
           only thing
           performant under
           with 1.7.x
        moment, I
           would
           compared to
        involves
           a data
           sized dataset.
        have 1
        when we
           have a
            > decent catalog).
        negligible
        and I
           would like
           deadlines.
           contains these
        community
           module.
           functionality for
           versions. And
        way that the
        so there
           are no URI
            > conflicts.
        that worked
           work.
           Simone.
            > Thoughts?
            >> Simone.
            >> Via Carignoni 51
            >> Italy
            >>> + else
            >>> + layerInfo =
        rather than
           stack up
           arbitrary.
        not the other
            >>> properties?
            >>> Objections?
            >>>> Hi Justin,
           re-enable some
        <mailto:jdeolive@anonymised.com> <mailto:jdeolive@anonymised.com
        <mailto:jdeolive@anonymised.com>>>>
        a few
           concerns
        reviewed
           before
            >>>> hand.
        unnecessary to
           me. I
            >>>> think
        properties
            >>>> overrideen
           passing it
            >>>> into
        other
           methods in
        consistent as
            >>>> possible.
           Supporting
        documented
           as api
            >>>> options:
        tought
           during
           extension now, not
            >>>> a
           before hand.
            >>>> You are Right.
        variable
        consistency
           sake I
            >>>> prefer
           does things
            >>>> when
           change, and
            >>>> one I
        location of the
            >>>> resource
           for the POST
        should be
           down with
            >>>> a
           non-opaque,
            >>>> ie
        which
           is another
            >>>> REST nono.
            >>>> Daniele
            >>>> -Justin
            >>>> > Hi Daniele,
        restconfig and
           main. I
            >>>> would
        before
           committing.
        wrapped up
            >>>> discussion
        email.
           deemed the
           hard rules
            >>>> in place
        appreciate being
           to review
            >>>> > -Justin
           circumstances!
            >>>> Your
        world
           - but
            >>>> thanks to
        done! With
           the NEW
            >>>> KODAK i700
        with
           all image
        <mailto:Geoserver-devel@lists.sourceforge.net>>>
            >>>> Italy
           circumstances! Your
        world -
           but thanks
            >>>> to
        With the
           NEW KODAK
            >>>> i700
        with all
           circumstances! Your
           but thanks
            >>> to
        With the
           NEW KODAK
            >>> i700
        with all image
            > Justin Deoliveira
        Software Engineer
        Via Carignoni 51
        55041 Camaiore (LU)
        fax: +39 0584983027
    -- Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
