[Geoserver-devel] [continuum] BUILD FAILURE: GeoServer
http://geo.openplans.org:9090/continuum/servlet/continuum/target/ProjectBuild.vm/view/ProjectBuild/id/156/buildId/499
It seems I've broke the build. Apologies, I'm looking at it right now.
Gabriel
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-devel mailing list
the continuum build at geo fails with the following error:
"Error occurred during initialization of VM
Could not reserve enough space for object heap"
the build is ok on my box, wondering what could be going on at the build
server. Could it have to be with the setting of MAVEN_OPTS environment
variable with "-Xmx256m" or something?
Gabriel
Gabriel
>ui ld.vm/view/ProjectBuild/id/156/buildId/499
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
the build is ok on my box, wondering what could be going on at the build server. Could it have to be with the setting of MAVEN_OPTS environment variable with "-Xmx256m" or something?
Hum, it's failing trying to allocate the initial amount of memory.
I looked at that pc, and saw other java apps eating tons of memory.
I'll have to double check with Chris and Justin
