[Geoserver-devel] [continuum] BUILD FAILURE: GeoServer
http://traffic.openplans.org:8080/continuum/buildResult.action?buildId=134&projectId=7
Hmmm... not sure what to make up of this one, it's not a compile or test failure, something fishy going on in the maven build itself apparently:
[INFO] Surefire report directory: /spare/homes/jdeolive/continuum-1.1-beta-2/apps/continuum/webapp/WEB-INF/working-directory/7/platform/target/surefire-reports
java.lang.NoSuchMethodError: java.net.URL.openCmnnection()Ljava/net/URLConnection;
  at sun.net.www.protocol.jar.JarURLConnection.<init>(JarURLConnection.java:64)
  at sun.net.www.protocol.jar.Handler.openConnection(Handler.java:24)
  at java.net.URL.openConnection(URL.java:896)
  at java.net.URL.openStream(URL.java:913)
  at java.lang.ClassLoader.getResourceAsStream(ClassLoader.java:997)
  at java.util.ResourceBundle$1.run(ResourceBundle.java:1083)
  at java.security.AccessController.doPrivileged(Native Method)
  at java.util.ResourceBundle.loadBundle(ResourceBundle.java:1079)
  at java.util.ResourceBundle.findBundle(ResourceBundle.java:927)
  at java.util.ResourceBundle.getBundleImpl(ResourceBundle.java:745)
  at java.util.ResourceBundle.getBundle(ResourceBundle.java:551)
  at org.apache.maven.surefire.Surefire.<init>(Surefire.java:42)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
  at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
  at java.lang.reflect.Constructor.newInstance(Constructor.java:274)
  at java.lang.Class.newInstance0(Class.java:308)
  at java.lang.Class.newInstance(Class.java:261)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:283)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:818)
[ERROR] BUILD FAILURE
Well, indeed java.net.URL.openCmnnection() (notice the typo, Cmnnection instead of Connection) is not going to be there but... how can an error like this one be in the java runtime? Surefire starts a separate jvm
to run the tests afaik.
