[Geoserver-devel] Couple questions about schema.xml
I was playing with schema.xml overrides and found out a couple things:
- when trying to override the geometry type of a feature type that has
   a generic GeometryPropertyType I got back a Q1:PointPropertyType.
   Investigation showed that it was happening because I did not
   add the xmlns:gml="http://www.opengis.net/gml" in my complexType
   element.
   Very reasonable, yet an error, or an implicit import of the gml
   namespace if missing, could be helpful
- I then tried to override the geometry type of a geometry whose
   type is already know, but it's supposedly wrong. That did not
   work, the original geometry type resisted my override efforts.
   Not sure if this to be expected thought, as simple types
   can be overridden at will (can take a string and force it into
   a xs:integer... thought in output I get xs:long)
We should probably also open a jira about documenting these
schema override features.
Andrea Aime
OpenGeo - http://opengeo.org
Andrea Aime wrote:
   element.
Hmm... I tried the same test and it worked for me in PostGIS. Can you include the schema.xsd you are using.
Indeed. It seems that this feature has been brought to the forefront much more than initially expected.
Justin Deoliveira
Andrea Aime wrote:
   element.
Yeah, this can probably be fixed. The implicit namespace does happen, it is just there is no mapping. I think just a simple check to ensure that a namespace mapping exists should fix that issue. Filed a jira for this:
http://jira.codehaus.org/browse/GEOS-2937
Justin Deoliveira
