[Geoserver-devel] CSW
Glanced at all the outstanding CSW extension pull requests.
It happens from time to time that a given extension has no official maintainer, but it keeps being an extension because people might be using it, right?
By the other hand, Niels is actively working on it but noone has the time to review/approve all those PR’s.
So, why not just either downgrade it to a community module (unlikely), or create a separate comnunity module (does the NG postfix sound familiar to anyone?) so that he can do his business and when done and complies with all the requirements to upgrade to extension it can be a drop-in replacement for the current CSW extension?
Happened before, probably just in geotools ( wfs-ng, jdbc-ng, shapefile-ng? ), but I don’t see why not, the project seems to be really flexible in allowing community modules.
it just occurred to me. 2c.
Gabriel Roldán
Hello Gabriel,
Indeed, I thought of this as well and did hint at this option somewhere but I guess it was lost in between embarrassing bickering that made up most of the thread.
I like the idea, but I would like to avoid duplicating all of the CSW module code.
My suggestion would be to separate all of the ISO metadata profile into a separate module “gs-csw-iso” and downgrade this module to community status (this shouldn’t be a problem, as mentioned before, the current implementation is actually too buggy to be considered a proper feature, and the current maintainers of the CSW module are not familiar with it themselves, as they admit).
The only thing I think that would still need to be duplicated is the GenericRecordBuilder which is now used for both DC and ISO, but I had to make considerable improvements to it to accommodate for the complexity of the ISO scheme (for DC, the old version is sufficient).
I might still need to add a little hook here or there in the core CSW extension, but hopefully that won’t be a problem then.
Does this sound like a reasonable compromise/solution?
Kind Regards
Niels
Gabriel Roldán
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
I thought I was co-maintaining the module because I had part in its initial development, but looking at its promotion proposal, there is no mention of maintainers:
https://github.com/geoserver/geoserver/wiki/GSIP-99
and some associated discussion threads:
http://osgeo-org.1560.x6.nabble.com/GSIP-98-Promote-CSW-Module-to-Extensions-td5068555.html
http://osgeo-org.1560.x6.nabble.com/CSW-Module-Structure-td5020998.html
http://osgeo-org.1560.x6.nabble.com/pushing-csw-changes-through-td5059151.html
Maybe I was just wrong about it, and the actual maintainers for the module were meant to be Justin and Niels?
Unsure, would be interested to see if anyone finds a better reference.
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi All,
we (as in GeoSolutions) use it together with MapStore so I would be
mildly against a downgrade while I would not to factor out the ISO
module (which looks promising btw).
Please, allow me some time to talk to Andrea and the other guys here
to find a solution that won't block Niels but which also won't block
us.
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Tue, Apr 30, 2019 at 12:09 PM Andrea Aime
<andrea.aime@anonymised.com> wrote:
On Tue, Apr 30, 2019 at 1:21 AM Gabriel Roldan <gabriel.roldan@anonymised.com> wrote:
By the other hand, Niels is actively working on it but noone has the time to review/approve all those PR's.
Happened before, probably just in geotools ( wfs-ng, jdbc-ng, shapefile-ng? ), but I don't see why not, the project seems to be really flexible in allowing community modules.
Gabriel Roldán
Thanks, Simone
On 01/05/2019 22:09, Simone Giannecchini wrote:
Hi All,
us.
Simone Giannecchini
@simogeo
Founder/Director
Gabriel Roldán
Dear All,
talked to Andrea, here is our suggestion:
- Niels to prepare a PR to factor our the ISO Record Support into a
community module so he is free to do whatever he needs. Then we can
merge it back as/if needed.
- Andrea will help out with the pending PR from Niels as well as with
eventual PR against the core CSW module
For the records, we use CSW with Dublin Core in MapStore so that is
strategic to us.
I am hoping this accounts for everybody's needs. Let me know otherwise.
Simone Giannecchini
@simogeo
Founder/Director
On Thu, May 2, 2019 at 1:22 PM Niels Charlier <niels@anonymised.com> wrote:
Thanks, Simone
> Hi All,
> us.
> Regards,
> Simone Giannecchini
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Italy
>> Hi,
>> Cheers
>> Andrea
>> On Tue, Apr 30, 2019 at 1:21 AM Gabriel Roldan <gabriel.roldan@anonymised.com..> wrote:
>>> Gabriel Roldán
>>> _______________________________________________
Okay, great news. Just to be clear: the majority of current PR's should be closed, and replaced by a PR that factors out the iso metadata profile. Changes to the csw core/api modules should be kept to an absolute minimum. Is that correct?
Regards
Niels
On 02/05/2019 18:30, Simone Giannecchini wrote:
Dear All,
strategic to us.
Simone Giannecchini
@simogeo
Founder/Director
Thanks, Simone
Hi All,
us.
Simone Giannecchini
@simogeo
Founder/Director
Gabriel Roldán
Hi Niels,
that would be ideal yes
That summarises well my proposal.
Of course, I am open to hear other options from you, if you have any
to put on the table.
Simone Giannecchini
@simogeo
Founder/Director
Regards
Niels
> Dear All,
> strategic to us.
> Regards,
> Simone Giannecchini
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Italy
>> Thanks, Simone
>>> Hi All,
>>> us.
>>> Regards,
>>> Simone Giannecchini
>>> @simogeo
>>> Founder/Director
>>> GeoSolutions S.A.S.
>>> Italy
>>>> Hi,
>>>> Cheers
>>>> Andrea
>>>> On Tue, Apr 30, 2019 at 1:21 AM Gabriel Roldan <gabriel.roldan@anonymised.com3...> wrote:
>>>>> Gabriel Roldán
Make a microservice :slight_smile:
Gabriel Roldán
Hello Simone, Andrea, Anyone who is interested,
I closed all the ISO related PR's and will be making a new one for the split.
I just left two PR's open related to the CSW work that are not directly iso-related
(1) https://github.com/geoserver/geoserver/pull/3346 a very trivial one that adds a few additional service url placeholders
(2) https://github.com/geoserver/geoserver/pull/3361 actually a core change to the catalogpropertyaccessor, quite small and contained as well.
If anyone could have a look at these would be fantastic.
Thanks in advance.
Kind Regards
Niels
Simone Giannecchini
@simogeo
Founder/Director
Regards
Niels
Dear All,
strategic to us.
Simone Giannecchini
@simogeo
Founder/Director
Thanks, Simone
Hi All,
us.
Simone Giannecchini
@simogeo
Founder/Director
Gabriel Roldán
