[Geoserver-devel] data in community-schema community module
Hi Gabriel,
I just did an update and noticed your community module. I also noticed
that the checkout included the entire release configuration :(. I was
wondering if you could create yourself a configuration under
http://svn.codehaus.org/geoserver/trunk/configuration instead of storing
it in the source tree as we have done with the other configurations.
-Justin
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
I also noticed that the web module has a 'minimal' configuration, and wasn't sure if that was by design? I could see it being that web wants to always be able to build a geoserver that can at least run...
Justin Deoliveira wrote:
Hi Gabriel,
-Justin
Chris Holmes
Yup it was put there to ensure that people can build geoserver if they
just check out the source.. If you do an update you will notice a little
"X" when you try to update it. Which means its actually the one stored
under the configuration directory, just liked using the svn:externals
property.
-Justin
Hi Gabriel,
-Justin
opinions on IT & business topics through brief surveys-and earn cash
!DSPAM:1004,45e6fd89108902095110867!
Geoserver-devel mailing list
Justin Deoliveira
Geoserver does run with minimal (unless there are still bugs around)... it's just that you don't have any data in it.
oops sorry,
but once I svn move the config directory to /configuration how do I link it to
be the default for my web module?
thanks,
Gabriel
On Thursday 01 March 2007 17:12, Justin Deoliveira wrote:
Hi Gabriel,
-Justin
There are a number of ways listed here
http://docs.codehaus.org/display/GEOSDOC/2+Maven+Quickstart
in the "Building the Web Module". Personally i like using settings.xml.
-Justin
Gabriel Roldán wrote:
oops sorry,
thanks,
Gabriel
Hi Gabriel,
-Justin
!DSPAM:1004,45e70892119774820651628!
Justin Deoliveira
done, thanks for the instructions
Gabriel
-Justin
> oops sorry,
> it to be the default for my web module?
> thanks,
> Gabriel
>> Hi Gabriel,
>> Thanks,
>> -Justin
> your opinions on IT & business topics through brief surveys-and earn cash
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
