Just a quick note as I know the next release is imminent...
I'm just playing with the 17-dec nightly build and firstly my JNDI Oracle datastores failed to load from my existing configuration (I had to remove them and add them again) and secondly I can't seem to edit any datastores at all - nothing happens when the save button is pushed except if you are adding a new datastore.
No biggie but wouldn't look so hot in a release. Should I file an issue on this?
Miles
___________________________________________________________________________
Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
Visit our web site at http://www.antarctica.gov.au/
issue on this?
Also getting an exception when clicking on "Layers", from the OCI datastore (even though I don't have one set up):
java.lang.NoSuchFieldError: PK_METADATA_TABLE
org.geotools.data.oracle.OracleNGOCIDataStoreFactory.setupParameters(OracleNGOCIDataStoreFactory.java:85)
org.geotools.jdbc.JDBCDataStoreFactory.getParametersInfo(JDBCDataStoreFactory.java:210)
org.geotools.data.AbstractDataStoreFactory.canProcess(AbstractDataStoreFactory.java:115)
org.geotools.jdbc.JDBCDataStoreFactory.canProcess(JDBCDataStoreFactory.java:105)
org.vfny.geoserver.util.DataStoreUtils.aquireFactory(DataStoreUtils.java:139)
org.vfny.geoserver.util.DataStoreUtils.getDataAccess(DataStoreUtils.java:91)
org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:298)
org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:535)
org.geoserver.catalog.impl.FeatureTypeInfoImpl.getFeatureType(FeatureTypeInfoImpl.java:86)
sun.reflect.GeneratedMethodAccessor176.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
java.lang.reflect.Method.invoke(Method.java:597)
org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:114)
$Proxy13.getFeatureType(Unknown Source)
org.geoserver.web.CatalogIconFactory.getSpecificLayerIcon(CatalogIconFactory.java:112)
org.geoserver.web.data.layer.LayerPage$1.getComponentForProperty(LayerPage.java:52)
org.geoserver.web.wicket.GeoServerTablePanel$1$1.populateItem(GeoServerTablePanel.java:134)
org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:573)
org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:127)
org.apache.wicket.Component.internalBeforeRender(Component.java:1009)
DELETE the message.
I think I just reported the same bug. Actually found by Florence Tan attempting to deploy a patched GeoServer trunk for NVCL; I think we found the cause:
http://jira.codehaus.org/browse/GEOT-2897
Yes, this is a release blocker.
Thanks for reporting this one Miles. It is good to get confirmation that we are not the only ones affected.
Kind regards,
Ben.
Miles
DELETE the message.
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon's best-in-class app development support
A streamlined, 14 day to market process makes app distribution fast and easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
Geoserver-devel mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
