[Geoserver-devel] Deadlock condition in GWC GeoServer integration
we just found out a nasty deadlock condition that might happen when a reload is
triggered against a GeoServer that is also under tile load stress:
https://osgeo-org.atlassian.net/browse/GEOS-7376
When this happens all tile access is toast, one has to restart the instance to get it
to serve tiles again.
In the ticket I’ve tried to explain what I believe is the source of the dealock, and
proposed a solution.
Has anyone time to verify that I’m on the right path? Otherwise I’ll just go ahead,
getting this to happen is not too hard, one just need to apply the right amount of pressure
with the tile load while doing GS config reloads in parallel.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
here is a pull request:
https://github.com/geoserver/geoserver/pull/1402
What do you think, shall we try to include this in 2.8.2 (to be released Monday)?
On Thu, Jan 14, 2016 at 7:33 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ehm,
I'd say _absolutely yes_
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, Jan 15, 2016 at 11:54 AM, Andrea Aime
Monday)?
wrote:
reload is
instance to get it
In the ticket I've tried to explain what I believe is the source of the
dealock, and
Has anyone time to verify that I'm on the right path? Otherwise I'll just
go ahead,
amount of pressure
Ing. Andrea Aime
@geowolf
Technical Lead
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-devel mailing list
yep! and provide it as a reason to upgrade
On 15 January 2016 at 02:54, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Cool,
do I go ahead without a review?
On Fri, Jan 15, 2016 at 6:49 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
I should be able to review a bit later today.
Kevin Michael Smith
smithkm@anonymised.com
On Fri, Jan 15, 2016, at 09:53 AM, Andrea Aime wrote:
Cool,
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
addressed Jody’s feedback, merged, ported back to 2.8.x and 2.7.x
On Fri, Jan 15, 2016 at 6:53 PM, Andrea Aime <andrea.aime@anonymised.com…> wrote:
Cool,
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
