[Geoserver-devel] DynamicColorMap
Wondering if anyone has any hints as to what might be causing this issue:
https://osgeo-org.atlassian.net/browse/GEOS-8070
Even if it’s just where in the code I might look for the issue. I looked at the actual ColorMap generation, and that seems fairly straight forward so I’m not sure if the problem is there. Otherwise I’m not so sure. My first thought is that something’s not being buffered correctly or something along those lines, but I wouldn’t know where to start.
Hi Devon,
going by memory the dynamic color map module depends on coverage statistics metadata
derived in GDAL called “PAM_DATASET”. Did you check the requirements and followed the
necessary steps?
http://docs.geoserver.org/stable/en/user/community/colormap/index.html#dynamiccolormap-requirements
On Mon, Apr 3, 2017 at 11:26 PM, Devon Tucker <dtucker@anonymised.com> wrote:
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
The statistics all seem to be there and fine. As far as I can tell, the ColorMap itself seems to generate fine. The example, at least when viewed at full extents looks fine and exactly like it does in the test case data. The problem only occurs at certain scales and extents.
Right now I’m looking at the various bits of the rendering pipeline (RenderedImageMapOutputFormat.directRasterRender) that get invoked when you have a a RenderingTransformation vs. without one. There are definitely some differences there, in terms of the code paths taken. The one thing I do notice is that the the GridGeometries of the coverage after the rendering transformation is applied vs. the grid geometry when the coverage is read without a rendering transform are slightly different, which I think is maybe causing the issue?
For example after the rendering transformation the coverage grid geometry looks like this:
GridGeometry2D[GridEnvelope2D[1..7, 2..12], PARAM_MT[“Affine”,
PARAMETER[“num_row”, 3],
PARAMETER[“num_col”, 3],
PARAMETER[“elt_0_0”, 0.5742214584350587],
PARAMETER[“elt_0_2”, 6.840767460515945],
PARAMETER[“elt_1_1”, -0.159840087890625],
PARAMETER[“elt_1_2”, 43.519122374398364]]]
And without doing the rendering transformation, the coverage looks like this:
GridGeometry2D[GridEnvelope2D[0..7, 0..11], PARAM_MT[“Affine”,
PARAMETER[“elt_0_2”, 7.414988918951003],
PARAMETER[“elt_1_2”, 43.19944219861711]]]
I think this would explain the pixels cut off on the right and bottom? But I’m not sure. The big difference I’ve noticed in the two code paths is that when doing the coverage read while performing the rendering transformation the read is done against the coverage reader directly, but otherwise a GridCoverageReaderHelper is used. I still need to look into what the differences might be there, but there’s a lot of moving parts. I may just try to plug the GridCoverageReaderHelper into the former code path and see what pops out, just as an experiment.
On Tue, Apr 4, 2017 at 2:33 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Devon,
necessary steps?
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Devon,
short answer is… I have no clue. Yes, indeed the path between RT and non RT cannot be the same, one works off a reader,
the other off a coverage and the RT can influence what is being read (area and resolution).
I would not blame the geometry per se though, some time ago Niels was reporting an “off by one” error somewhere in
the coverage reading chain… but I don’t remember if the thread was here or elsewhere, or if a ticket was opened.
It could be the cause of the issue though.
Niels, do you remember the thread in question?
Hi Devon,
necessary steps?
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
You mean this
https://osgeo-org.atlassian.net/browse/GEOS-7793
On 05-04-17 12:57, Andrea Aime wrote:
Hi Devon,
short answer is... I have no clue. Yes, indeed the path between RT and non RT cannot be the same, one works off a reader,
I would not blame the geometry per se though, some time ago Niels was reporting an "off by one" error somewhere in
the coverage reading chain... but I don't remember if the thread was here or elsewhere, or if a ticket was opened.
On Wed, Apr 5, 2017 at 2:15 AM, Devon Tucker <dtucker@anonymised.com <mailto:dtucker@anonymised.com>> wrote:
    scales and extents.
    Right now I'm looking at the various bits of the rendering
    GridGeometry2D[GridEnvelope2D[1..7, 2..12], PARAM_MT["Affine",
      PARAMETER["num_row", 3],
      PARAMETER["num_col", 3],
      PARAMETER["elt_0_0", 0.5742214584350587],
      PARAMETER["elt_0_2", 6.840767460515945],
      PARAMETER["elt_1_1", -0.159840087890625],
      PARAMETER["elt_1_2", 43.519122374398364]]]
    like this:
      GridGeometry2D[GridEnvelope2D[0..7, 0..11], PARAM_MT["Affine",
      PARAMETER["elt_0_2", 7.414988918951003],
      PARAMETER["elt_1_2", 43.19944219861711]]]
    bottom? But I'm not sure. The big difference I've noticed in the
    the differences might be there, but there's a lot of moving parts.
    <mailto:andrea.aime@anonymised.com>> wrote:
        Hi Devon,
        derived in GDAL called "PAM_DATASET". Did you check the
        necessary steps?
        <http://docs.geoserver.org/stable/en/user/community/colormap/index.html#dynamiccolormap-requirements&gt;
        wrote:
            causing this issue:
            <https://osgeo-org.atlassian.net/browse/GEOS-8070&gt;
            Even if it's just where in the code I might look for the
            that seems fairly straight forward so I'm not sure if the
            problem is there. Otherwise I'm not so sure. My first
            thought is that something's not being buffered correctly
            or something along those lines, but I wouldn't know where
            to start.
            Check out the vibrant tech community on one of the world's
            most
            <mailto:Geoserver-devel@lists.sourceforge.net>
            <https://lists.sourceforge.net/lists/listinfo/geoserver-devel&gt;
        Ing. Andrea Aime
        @geowolf
        Technical Lead
        phone: +39 0584 962313 <tel:+39%200584%20962313>
        fax: +39 0584 1660272 <tel:+39%200584%20166%200272>
        mob: +39 339 8844549 <tel:+39%20339%20884%204549>
        <http://twitter.com/geosolutions_it&gt;
        Le informazioni contenute in questo messaggio di posta
        elettronica e/o nel/i file/s allegato/i sono da considerarsi
        strettamente riservate. Il loro utilizzo è consentito
        esclusivamente al destinatario del messaggio, per le finalità
        indicate nel messaggio stesso. Qualora riceviate questo
        messaggio senza esserne il destinatario, Vi preghiamo
        cortesemente di darcene notizia via e-mail e di procedere alla
        distruzione del messaggio stesso, cancellandolo dal Vostro
        sistema. Conservare il messaggio stesso, divulgarlo anche in
        parte, distribuirlo ad altri soggetti, copiarlo, od
        utilizzarlo per finalità diverse, costituisce comportamento
        contrario ai principi dettati dal D.Lgs. 196/2003.
        The information in this message and/or attachments, is
        intended solely for the attention and use of the named
        addressee(s) and may be confidential or proprietary in nature
        or covered by the provisions of privacy act (Legislative
        Decree June, 30 2003, no.196 - Italy's New Data Protection
        Code).Any use not in accord with its purpose, any disclosure,
        reproduction, copying, distribution, or either dissemination,
        either whole or partial, is strictly forbidden except previous
        formal approval of the named addressee(s). If you are not the
        intended recipient, please contact immediately the sender by
        telephone, fax or e-mail and delete the information in this
        message that has been received in error. The sender does not
        give any warranty or accept liability as the content, accuracy
        or completeness of sent messages and accepts no
        responsibility for changes made after they were sent or for
        other risks which arise as a result of e-mail transmission,
        viruses, etc.
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Nope, not that one. You did find some issues with code removing 1 from the pixel grid extents, if memory
serves me right.
Btw that issue you are pointing to might have been solved recently by avoiding the large raster space coordinates
in image mosaic: https://osgeo-org.atlassian.net/browse/GEOT-5615
On Wed, Apr 5, 2017 at 1:59 PM, Niels Charlier <niels@anonymised.com> wrote:
You mean this
Hi Devon,
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Devon,
necessary steps?
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Either I have forgotten or it was somebody else... can't find it back.
Interesting about that other issue btw, that should resolve it indeed
serves me right.
On Wed, Apr 5, 2017 at 1:59 PM, Niels Charlier <niels@anonymised.com <mailto:niels@anonymised.com>> wrote:
    You mean this
    <https://osgeo-org.atlassian.net/browse/GEOS-7793&gt;
    Hi Devon,
        looks like this:
        and bottom? But I'm not sure. The big difference I've noticed
        what the differences might be there, but there's a lot of
            Hi Devon,
            necessary steps?
                causing this issue:
                I'm not sure if the problem is there. Otherwise I'm
                not so sure. My first thought is that something's not
                lines, but I wouldn't know where to start.
                world's most
            Ing. Andrea Aime
            @geowolf
            Technical Lead
            considerarsi strettamente riservate. Il loro utilizzo è
            consentito esclusivamente al destinatario del messaggio,
            per le finalità indicate nel messaggio stesso. Qualora
            riceviate questo messaggio senza esserne il destinatario,
            Vi preghiamo cortesemente di darcene notizia via e-mail e
            di procedere alla distruzione del messaggio stesso,
            cancellandolo dal Vostro sistema. Conservare il messaggio
            stesso, divulgarlo anche in parte, distribuirlo ad altri
            soggetti, copiarlo, od utilizzarlo per finalità diverse,
            costituisce comportamento contrario ai principi dettati
    Ing. Andrea Aime
    @geowolf
    Technical Lead
    indicate nel messaggio stesso. Qualora riceviate questo messaggio
    senza esserne il destinatario, Vi preghiamo cortesemente di
    darcene notizia via e-mail e di procedere alla distruzione del
    messaggio stesso, cancellandolo dal Vostro sistema. Conservare il
    messaggio stesso, divulgarlo anche in parte, distribuirlo ad
    altri soggetti, copiarlo, od utilizzarlo per finalità diverse,
    costituisce comportamento contrario ai principi dettati dal
    D.Lgs. 196/2003.
Ing. Andrea Aime
@geowolf
Technical Lead
I've also seen issues with GeoServer potentially losing the right-most and
bottom-most pixels when using rendering transformations to style raster
data. I've reproduced this in 2.9.x and 2.10.x with GeoTIFF coverages and
with raster-to-raster and raster-to-vector transformations. This can create
noticeable artifacts when using tiling.
The data appears to be getting lost from a Crop operation and I think that
it is when CoverageCrop is called in
org.geotools.renderer.lite.RenderingTransformationHelper but I haven't had a
chance to do more testing yet.
Steve Ikeoka
View this message in context: http://osgeo-org.1560.x6.nabble.com/DynamicColorMap-tp5315555p5315917.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
You could start by providing a reproducable test case in Jira :slight_smile:
On Wed, Apr 5, 2017 at 4:40 PM, sikeoka <steve.ikeoka@anonymised.com> wrote:
I’ve also seen issues with GeoServer potentially losing the right-most and
data. I’ve reproduced this in 2.9.x and 2.10.x with GeoTIFF coverages and
org.geotools.renderer.lite.RenderingTransformationHelper but I haven’t had a
Steve Ikeoka
Ing. Andrea Aime
@geowolf
Technical Lead
I don't use the dynamic colormap module but the JIRA ticket in the first post
has a test case using it:
Adding 1 to the envelope width and height here seems to fix the problem:
Old: Rectangle rect = new Rectangle(minx, miny, (maxx - minx), (maxy -
miny));
New: Rectangle rect = new Rectangle(minx, miny, (maxx - minx + 1), (maxy -
miny + 1));
A quick search of the GeoServer code found another case where this is also
done:
Steve Ikeoka
View this message in context: http://osgeo-org.1560.x6.nabble.com/DynamicColorMap-tp5315555p5315956.html
Hmm, I think the issue is in that area though:
I changed this:
MathTransform g2w = reader.getOriginalGridToWorld(PixelInCell.CELL_CENTER);
to this:
MathTransform g2w = reader.getOriginalGridToWorld(PixelInCell.CELL_CORNER);
(full diff here: https://github.com/dvntucker/geotools/pull/6/files)
And it seems to fix the issue, which sort of make sense intuitively, given that it seemed that a fraction of the pixels on the right and bottom were cut off. It also matches what the GridCoverageRenderer currently does:
https://github.com/geotools/geotools/blob/master/modules/library/render/src/main/java/org/geotools/renderer/lite/gridcoverage2d/GridCoverageRenderer.java#L304
Does anyone see any potential issues with this change? All of the tests in GeoServer and GeoTools pass for me with this change. If no one sees anything obvious then I’ll try to write a unit test for the issue and do a proper PR.
On Wed, Apr 5, 2017 at 11:13 AM, sikeoka <steve.ikeoka@anonymised.com> wrote:
I don’t use the dynamic colormap module but the JIRA ticket in the first post
https://github.com/geotools/geotools/blob/master/modules/library/render/src/main/java/org/geotools/renderer/lite/RenderingTransformationHelper.java#L127
miny));
miny + 1));
done:
https://github.com/geoserver/geoserver/blob/master/src/wcs2_0/src/main/java/org/geoserver/wcs2_0/ScalingPolicy.java#L288
Steve Ikeoka
On Thu, Apr 6, 2017 at 1:37 AM, Devon Tucker <dtucker@anonymised.com>
I changed this:
to this:
(full diff here: Update rendering transform to use pixel cell corner instead of center by dvntucker · Pull Request #6 · dvntucker/geotools · GitHub)
anything obvious then I'll try to write a unit test for the issue and do a
proper PR.
I'd go ahead with a PR
GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
I tested changing CELL_CENTER to CELL_CORNER and it only seemed to fix the
extra cropping about half of the time for me. The gap can be up to one
pixel width with the current code on master and changing CELL_CENTER to
CELL_CORNER reduces the gap to up to a half pixel width but does not
eliminate it completely.
Steve Ikeoka
View this message in context: http://osgeo-org.1560.x6.nabble.com/DynamicColorMap-tp5315555p5316152.html
Thanks Steve, I’ll play around with it a bit more. I didn’t have time to fully explore the results yesterday.
Steve Ikeoka
Steve do you have an example layer and request for which the CELL_CORNER fix doesn’t work? Playing around with the water temperature layer in my ticket it I don’t see the issue anywhere.
Steve Ikeoka
I downloaded the 10.47 MB GeoTIFF from here and loaded it into GeoServer:
http://www.naturalearthdata.com/downloads/50m-raster-data/50m-gray-earth/
I created a new style called contour_test (full SLD at the end). I then
used the following URLs against a GeoServer that is patched with the
CELL_CORNER fix. All three URLs work fine when adding 1 to the width and
height and all three have significant gaps without either fix. I tested
against GeoServer 2.10.1 using native JAI.
works fine:
http://localhost:8080/geoserver/wms?service=WMS&version=1.3.0&request=GetMap&format=image/png&crs=CRS:84&layers=gis:GRAY_50M_SR_W&styles=contour_test&bgcolor=0xFF0000&width=800&height=800&bbox=71.0,35.0,71.08,35.08
has missing contours on the right side of the image:
http://localhost:8080/geoserver/wms?service=WMS&version=1.3.0&request=GetMap&format=image/png&crs=CRS:84&layers=gis:GRAY_50M_SR_W&styles=contour_test&bgcolor=0xFF0000&width=800&height=800&bbox=71.0,35.0,71.09,35.09
works fine:
http://localhost:8080/geoserver/wms?service=WMS&version=1.3.0&request=GetMap&format=image/png&crs=CRS:84&layers=gis:GRAY_50M_SR_W&styles=contour_test&bgcolor=0xFF0000&width=800&height=800&bbox=71.0,35.0,71.1,35.1
<?xml version="1.0" encoding="ISO-8859-1"?>
<StyledLayerDescriptor version="1.0.0" xmlns="http://www.opengis.net/sld&quot;
xmlns:ogc="http://www.opengis.net/ogc&quot;
  xmlns:xlink="http://www.w3.org/1999/xlink&quot;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
  xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd&quot;&gt;
    <NamedLayer>
        <Name>contour_test</Name>
        <LayerFeatureConstraints>
            <FeatureTypeConstraint/>
        </LayerFeatureConstraints>
        <UserStyle>
            <FeatureTypeStyle>
                <Transformation>
                    <ogc:Function name="ras:Contour">
                        <ogc:Function name="parameter">
                            <ogc:Literal>data</ogc:Literal>
                        </ogc:Function>
                            <ogc:Literal>interval</ogc:Literal>
                            <ogc:Literal>5</ogc:Literal>
                        </ogc:Function>
                    </ogc:Function>
                </Transformation>
                <Rule>
                    <LineSymbolizer>
                        <Stroke>
                            <CssParameter
name="stroke">#000000</CssParameter>
                        </Stroke>
                    </LineSymbolizer>
                </Rule>
            </FeatureTypeStyle>
        </UserStyle>
    </NamedLayer>
</StyledLayerDescriptor>
Steve Ikeoka
View this message in context: http://osgeo-org.1560.x6.nabble.com/DynamicColorMap-tp5315555p5316209.html
Thanks Steve, you’re right, just changing the cell anchor does not fix it.
I’m actually a decent bit confused by this bug at this point. I think it may be related to cropping the coverage after the read? The rendering transform pipeline increases the size of the bounding box to ensure that at least one pixel is returned, then in the very next step the coverage is cropped to the exact same envelope in case the coverage store returns more than the requested bounds. This is where things go wrong, because the bbox of the coverage that returns ends up being smaller than the one requested for the crop. I put the coverage + the bboxes into QGIS to see what’s going on:
http://imgur.com/a/xxR81
Apologies for the awful image, I’ll try to explain it:
So, I think something is going wrong in that crop operating (https://github.com/geotools/geotools/blob/master/modules/library/render/src/main/java/org/geotools/renderer/lite/RenderingTransformationHelper.java#L152). The BBOX handed in to the crop is the biggest expanded one, but for whatever reason the resulting coverage has the smaller bbox. Not quite sure what’s going on there. I’m continuing to look at it today.
works fine:
works fine:
contour_test
<ogc:Function name=“ras:Contour”>
<ogc:Function name=“parameter”>
ogc:Literaldata</ogc:Literal>
</ogc:Function>
ogc:Literalinterval</ogc:Literal>
ogc:Literal5</ogc:Literal>
</ogc:Function>
</ogc:Function>
#000000
Steve Ikeoka
