Dear all,
I’m writing to ask permission for early backport of GEOS-10030 SLDService add a checks on max unique values for uniqueInterval classification vector data.
The pr uniform the sld Service behaviour with respect to the UniqueIntervalClassification, supporting a system variable for vector data (previously supported for rasters only) that allows to define a threshold of number of unique values, over which the classification should not be executed. Also some missing documentation has been added.
No backward compatibility issue is foreseen. Details are available on the jira ticket linked above.
Best regards,
Marco Volpini
+0
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1
Nuno Oliveira
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
