[Geoserver-devel] Early backport of [GEOS-10434] Externalized GeoServer environment properties
+0
-Jukka Rahkonen-
Lähettäjä: Marco Volpini <marco.volpini@…6887…>
Lähetetty: torstai 31. maaliskuuta 2022 18.57
Vastaanottaja: GeoServer geoserver-devel@lists.sourceforge.net
Aihe: [Geoserver-devel] Early backport of [GEOS-10434] Externalized GeoServer environment properties
Dear all,
I’m writing to ask early backport permission of GEOS-10434. The improvement adds the possibility to provide geoserver-environment.properties also from outside the geoserver data dir.
No backward compatibility issue is foreseen, the change is purely additive.
Details on the Jira ticket along with the main pr link.
Marco Volpini
Visit http://bit.ly/gs-services-us for more information.
Marco Volpini
Software Engineer
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
