[Geoserver-devel] Editing/fixing the EPSG database
I am trying to edit and fix my EPSG database. I am trying to follow
the directions titled "Manually editing the EPSG database" here:
http://docs.geoserver.org/latest/en/user/configuration/crshandling/manualepsg.html
In step 3 it states to open the EPSG.sql file, but I do not see this
file. Where is the file that I am supposed to edit?
/org/geotools/referencing/factory/epsg$ ls
DatabaseCreationScript.class FactoryUsingHSQL.class
HsqlEpsgDatabase.class ThreadedHsqlEpsgFactory.class
EPSG_Indexes.sql HsqlDialectEpsgFactory.class
PrepareForHSQL.xml UpdateEPSGDatabase.txt
EPSG.zip HsqlDialectEpsgMediator.class
SqlScriptReader.class
I believe that I need to edit this file because SRS 900913 is not
showing up on my GeoServer when I search for it.
Also, when I go to my Geoserver Gridsets menu and click on
EPSG:900913, it gives me an error. Here are the first 2 lines of the
error:
org.apache.wicket.WicketRuntimeException: Can't instantiate page using
constructor 'public
org.geoserver.gwc.web.gridset.GridSetEditPage(org.apache.wicket.request.mapper.parameter.PageParameters)'
and argument 'gridSet=[EPSG:900913]'. An exception has been thrown
during construction! at
org.apache.wicket.session.DefaultPageFactory.newPage(DefaultPageFactory.java:194)
Also, my GeoWebCache is on, but I do not see any cached copy of the
EPSG database on my system.
Assistance would be appreciated.
Tom G.
