I'm working in the Issues community module and I would like to use hibernate's annotations.
The problem I have is linking in a dependancy into the pom.xml file. I can't find hibernate's ejb3-persistence-1.0.jar in any of the repositorys like ibiblio and so on.
I searched around and other people have had the same problem and their solutions were to download the jar from jboss into their own maven repository.
Does geoserver have it's own maven repository that where can upload this jar into?
Pablo you can use http://lists.refractions.net/m2 - a webdav folder. If you had a uDig svn password it would work for you.
Paul can we set Pablo up here with svn access? He will be working with Jesse for the next while and has made
it through the uDig training course.
Jody
thanks
- Pablo.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
If you ask nicely the people from refractions might let you use the
repository they have set up.
-Justin
Pablo Casado wrote:
repository.
jar into?
thanks
- Pablo.
!DSPAM:1004,45017857305911804284693!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
