[Geoserver-devel] Enabling windows build server "hate mails"
we just had 48 working builds on the windows build server,
I’d say it’s stable enough to send mails to GeoServer devel.
Enabled now, Linux and OSX devs, please pay extra attention
to file/stream management, if anything is left open this build
server is likely going to complain.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
+1
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Mon, May 4, 2015 at 12:26 PM, Andrea Aime
<andrea.aime@anonymised.com> wrote:
I'd say it's stable enough to send mails to GeoServer devel.
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-devel mailing list
Thanks so much Andrea.
On Mon, May 4, 2015 at 8:08 AM Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
+1
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Ing. Andrea Aime
@geowolf
Technical Lead
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
