[Geoserver-devel] Error creating ArcSDE FeatureType
I am running the 10/15 nightly (latest) build on XP, Java jdk1.5.0_07 and
trying to access ArcSDE 9.2 which works with Oracle 10g. I can see the list
of the ArcSDE layers in the Feature Type Name list but when I click on one
of them and then click on the New button the GeoServer admin page is
replaced with:
HTTP ERROR: 500
NONE
RequestURI=/geoserver/config/data/typeNewSubmit.do
Caused by:
java.lang.NoSuchFieldError: NONE
  at
org.geotools.data.arcsde.ArcSDEAdapter.createAttributeTypes(ArcSDEAdapter.java:418)
  at
org.geotools.data.arcsde.ArcSDEAdapter.fetchSchema(ArcSDEAdapter.java:287)
  at
org.geotools.data.arcsde.ArcSDEDataStore.getSchema(ArcSDEDataStore.java:202)
  at
org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute(DataFeatureTypesNewAction.java:83)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
In the console, I see the following:
18579 [main] INFO org.mortbay.log - Started SelectChannelConnector @
0.0.0.0:8090
26501 [btpool0-6] INFO org.apache.struts.tiles.TilesRequestProcessor - Tiles
definition factory found for request processor ''.
38299 [btpool0-6] INFO org.acegisecurity.userdetails.memory.UserMap - Adding
user [org.acegisecurity.userdetails.User@anonymised.com: Username: admin; Password:
[PROTECTED]; Enabled: true; AccountNonExpired: true;credentialsNonExpired:
true; AccountNonLocked: true; Granted Authorities: ROLE_ADMINISTRATOR]
48096 [btpool0-5] WARN org.geotools.data.arcsde - No database name specified
48111 [btpool0-5] INFO org.geotools.data.arcsde - Created pool
org.apache.commons.pool.impl.GenericObjectPool@anonymised.com
51143 [btpool0-5] WARN org.geotools.data.arcsde - No database name specified
51143 [btpool0-5] INFO org.geotools.data.arcsde - Created pool
128583 [btpool0-5] WARN org.geotools.data.arcsde - No database name
specified
specified
128708 [btpool0-5] WARN org.geotools.data.arcsde - Figured Row-ID Column
named 'OBJECTID' for tableNDHUB.COUNTIES_POLY
128708 [btpool0-5] INFO org.geotools.data.arcsde - About to parse CRS for
layer COUNTIES_POLY:
GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]
128708 [btpool0-5] INFO org.geotools.data.arcsde - Se CRS envelope:
(-105.5,45.0,-95.5,55.0)
128723 [btpool0-5] ERROR org.mortbay.log - Error for
/geoserver/config/data/typeNewSubmit.dojava.lang.NoSuchFieldError: NONE
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459)
        at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1054)
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
        at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
        at
        at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
        at
        at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
        at
        at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
        at
        at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
        at
        at
org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
        at
        at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
        at
        at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
        at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
        at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1045)
        at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
        at
        at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:358)
        at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:231)
        at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:629)
        at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
        at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
        at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
        at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
        at org.mortbay.jetty.Server.handle(Server.java:303)
        at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:452)
        at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:735)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:636)
        at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:209)
        at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
        at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:320)
        at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
I was getting the same error with 1.6 Beta 3.
Thanks, Bob
View this message in context: http://www.nabble.com/Error-creating-ArcSDE-FeatureType-tf4634206.html#a13233582
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Aha! Bob, I got it.
The problem is that you've installed the geoserver 1.5.x ArcSDE extension
into a geoserver 1.6.x snapshot.
In order to use ArcSDE with geoserver 1.6.x, you'll need a geoserver 1.6.x
arcsde extension snapshot.
Here's a really short description of what the ArcSDE extension to geoserver
actually is:
* One file called "gt2-arcsde.jar". Sometimes it's got a 'SNAPSHOT' tucked
into the name, too
Here's where to get a nightly snapshot of gt2-arcsde(-XXX).jar file:
http://lists.refractions.net/m2/org/geotools/gt2-arcsde/2.4-SNAPSHOT/gt2-arcsde-2.4-SNAPSHOT.jar
So, if you have a 'fresh' nightly, just plop gt2-arcsde-2.4-SNAPSHOT.jar
into the WEB-INF/lib directory of the unrolled nightly, also plop the jsde
jarfiles alongside it in the same directory, and then start everything up.
Things should work a little better at that point (I hope!)
Let me know if that gets you back to working status with the nightly
snapshots.
--saul
Bob Nutsch wrote:
list of the ArcSDE layers in the Feature Type Name list but when I click
on one of them and then click on the New button the GeoServer admin page
is replaced with:
HTTP ERROR: 500
NONE
Caused by:
  at
  at
  at
  at
  at
  at
  at
0.0.0.0:8090
Tiles definition factory found for request processor ''.
Adding user [org.acegisecurity.userdetails.User@anonymised.com: Username: admin;
Password: [PROTECTED]; Enabled: true; AccountNonExpired:
true;credentialsNonExpired: true; AccountNonLocked: true; Granted
specified
specified
specified
specified
specified
specified
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
Thanks, Bob
View this message in context: http://www.nabble.com/Error-creating-ArcSDE-FeatureType-tf4634206.html#a13235169
Hi Saul,
Thanks for the help! The ArcSDE extension that I was using came from the
nightly extensions at http://geo.openplans.org/nightly/trunk/ext-latest/. I
went ahead and downloaded your referenced ..SNAPSHOT.jar and dropped it into
the WEB-INF/lib but was having the same problem as before. But then I went
and removed the existing 'gt-arcsde.jar' that was present in the
WEB-INF/lib. Now things seem to behaving like they should. I'm able to
create a featuretype and display it via OpenLayers!
Thanks again very much!
Bob
sfarber wrote:
Aha! Bob, I got it.
geoserver actually is:
tucked into the name, too
snapshots.
--saul
Bob Nutsch wrote:
is replaced with:
HTTP ERROR: 500
NONE
Caused by:
  at
  at
  at
  at
  at
  at
  at
0.0.0.0:8090
specified
specified
specified
specified
specified
specified
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
Thanks, Bob
View this message in context: http://www.nabble.com/Error-creating-ArcSDE-FeatureType-tf4634206.html#a13235713
