[Geoserver-devel] Error in "mvn clean install"
Good afternoon, I'm starting to try to work with the code, everything works fine for me 2.2.x branch, but when I work with branch 2.4.x, when running the command "mvn clean install" gives me the following error. (attached file)
What am I doing wrong?
thanks
(attachments)
Error1.txt (13.5 KB)
On Fri, May 9, 2014 at 1:29 AM, Oscar Cano R <ocr.caro69@anonymised.com> wrote:
(attached file)
It seems the compiler is not found:
[WARNING] Unable to autodetect 'javac' path, using 'javac' from the
environment.
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] Failure executing javac, but could not parse the error:
"javac" no se reconoce como un comando interno o externo,
programa o archivo por lotes ejecutable.
Did you setup your JAVA_HOME correctly?
Anyways, in branch 2.4.x I believe all developers already switched to maven
3,
that might be a factor too (and oh, the branch is supposed to be built with
java 6)
Meet us at GEO Business 2014! in London! Visit Visit GeoSolutions at GEO Business 2014 in London! - GeoSolutions
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
environment.
maven 3,
with java 6)
Oscar, please also check that you have a JDK installed, not just a JRE (which lacks the compiler). I do not know why 2.2.x works; did you use the same maven and java?
Try:
mvn -version
to discover the maven and java version used in your current environment.
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
This is the result
mvn -version
Apache Maven 3.2.1 (ea8b2b07643dbb1b84b6d16e1f08391b666bc1e9; 2014-02-14T11:37:52-06:00)
Maven home: C:\Program Files (x86)\ApacheSF\apache-maven-3.2.1
Java version: 1.7.0_51, vendor: Oracle Corporation
Java home: C:\Program Files\Java\jre7
Default locale: es_MX, platform encoding: Cp1252
OS name: "windows 8", version: "6.2", arch: "amd64", family: "windows"
environment.
maven 3,
with java 6)
Try:
mvn -version
Kind regards,
It looks like the java version running is the JRE and not the JDK, hence no compiler. ": C:\Program Files\Java\jre7 "
If you have a JDK installed, change the JAVA_HOME environment variable to point at the JDK instead. If not installed, you can install the JDK and update the JAVA_HOME then.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Direct (719) 452-7257
-----Original Message-----
Sent: Friday, May 09, 2014 9:32 AM
To: Ben Caradoc-Davies; Andrea Aime
Cc: Geoserver-devel
Subject: Re: [Geoserver-devel] Error in "mvn clean install"
This is the result
mvn -version
Maven home: C:\Program Files (x86)\ApacheSF\apache-maven-3.2.1 Java version: 1.7.0_51, vendor: Oracle Corporation Java home: C:\Program Files\Java\jre7 Default locale: es_MX, platform encoding: Cp1252 OS name: "windows 8", version: "6.2", arch: "amd64", family: "windows"
On Fri, May 9, 2014 at 1:29 AM, Oscar Cano R <ocr.caro69@...403...
environment.
"javac" no se reconoce como un comando interno o externo, programa o
maven 3, that might be a factor too (and oh, the branch is supposed
to be built with java 6)
Try:
mvn -version
Kind regards,
Is your legacy SCM system holding you back? Join Perforce May 7 to find out:
&#149; 3 signs your SCM is hindering your productivity &#149; Requirements for releasing software faster &#149; Expert tips and advice for migrating your SCM now http://p.sf.net/sfu/perforce _______________________________________________
Geoserver-devel mailing list
Sorry, to go trying to change the JAVA_HOME path, but the path of the sdk, I do not work.
For the 2.2.x branch, if I work, but for the 2.4.x branch, I do not work, any ideas?
I send the results of the error of "mvn clean install" and the result of "mvn -version"
Thank you.
Chris Snider
From: Oscar Cano R [mailto:ocr.caro69@anonymised.com]
Cc: Geoserver-devel
This is the result
mvn -version
environment.
Try:
mvn -version
Kind regards,
(attachments)
Error24x.txt (79.6 KB)
MVN-Version.txt (381 Bytes)
Run the following statement I found in:
http://docs.geoserver.org/stable/en/developer/maven-guide/index.html#maven-guide
mvn -DskipTests clean install
Do not know if that will affect me in something, but the eclipse if the application works and looks good.
thanks
